HoltekHT7A4016非隔离式DC电源解决方案
最新更新时间:2011-12-24来源: chinaaet关键字:电源管理  DC/DC转换器 手机看文章 扫描二维码
随时随地手机看文章
LED TV的LED背光照明.本文介绍了HT7A4016主要特性,方框图以及针对各种不同应用电路的参考设计电路.
The HT7A4016 is a controller IC that includes the necessary features to implement off-line or DC-DC current mode control schemes with a minimal external parts count. Internal circuits include a specially designed Mixed-Mode/Analog Interface for multi-function and multi-topology control schemes (DC-DC Buck/Boost, Off-line AC-DC), a trimmed oscillator for precise duty-cycle control under voltage lockout with a start-up current of less than 0.5mA, a wide temperature range, precise voltage reference, internal Slope Compensation and Leading-Edge Blanking. The HT7A4016 features basic system protection functions such as Cycle-by-Cycle Current Limiting and Under Voltage Lock-Out (UVLO). A Multi-Function Pin can be used as a dimming function for LED driving, and as a primary feedback control f o r Primary - Side Feed back AC - DC applications.
HT7A4016主要特性:
• High Performance, Low Cost Current Mode PWM Controller especially designed for Energy Star 2.0
• Very Low Startup Current (<20μA) and Operating Current
• High-Voltage CMOS Process with Excellent ESD protection (>3KV)
• ±5% Trimmed Oscillator for Precise Frequency Control
• LEB (Leading-Edge Blanking) on CS Pin
• Internal Slope Compensation
• Programmable Switching Frequency
• Internally Trimmed Reference with UVLO (Under Voltage Lockout)
• Cycle-by-Cycle Current Limiting
HT7A4016应用:
• Switching AC-DC Adaptors
• DC-DC Switching Buck/Boost Converters
• LED Backlights for LCD/LED TVs
图1. HT7A4016方框图
图2. HT7A4016典型应用电路图
图3. HT7A4016恒压升压应用电路图(DC/DC升压)
图4. HT7A4016用于背光LED驱动的DC/DC恒流升压应用电路图
图5. HT7A4016 LED照明驱动的恒流降压应用电路图
图6. HT7A4016恒流降压稳压器应用电路图(高边降压)
图7. HT7A4016初级反馈的隔离反激AC/DC转换器电路图
详情请见:
http://www.holtek.com.tw/PDF/Power_Management/ht7a4016v100.pdf
关键字:电源管理  DC/DC转换器 编辑:探路者 引用地址:HoltekHT7A4016非隔离式DC电源解决方案
上一篇:三相PFC整流器在输入电压不对称时的改进
下一篇:二级保护器件协助功率系统防止热失控引起的损坏
推荐阅读最新更新时间:2023-10-18 16:16
FairchildFL7730220VAC8.4WLED灯解决方案
Fairchild 公司的FL7730是可调光的单级PFC离线LED驱动器,和传统的TRIAC控制兼容,和无调光灯设计兼容,不需要输入大电容和反馈电路,具有开路,短路保护,逐个周期的限流,起动电流20uA,工作电流5mA,应用电压倒80VAC ~ 308VAC,主要用于照明.本文介绍了FL7730主要特性,方框图以及8.4W LED照明灯主要性能指标,灯外形,PCB电路图,材料清单和PCB元件布局图. This highly integrated PWM controller, FL7730MY, provides several features to enhance the performance of single-stage
[电源管理]
Windows CE 电源管理
电源管理 Windows CE是典型的使用电池供电的系统。这使得正确操作系统十分关键,应用程序大多数时间都不需要关注Windows CE 设备的电源损耗,但是在某些时候,你可能要注意这些损耗。 当用户关闭了一个使用电池的Windows CE 设备,电源系统不会关闭PC电源,事实上,只是系统被挂起(译者注:这里就像有些PocketPC把关闭电源放在拔SIM卡的位置,拔出SIM卡才真正关闭电源。但是,目前包括Smartphone在内,因为硬件设备,比如CPU无法进入低功耗,所以为了省电,需要做到关闭应用处理器及大部分设备供电,然后需要唤醒时,再通过定时器或无线模块唤醒。所以不关闭电源的情况不是绝对的。)当用户打开设备电源,设备
[嵌入式]
富士通半导体推出面向便携设备的电源管理芯片MB39C326
上海,2012年7月23日 – 富士通半导体(上海)有限公司今日宣布推出面向便携设备的DC-DC转换器MB39C326,可通过自动切换降压/升压工作模式来扩大工作电压范围。MB39C326通过内置开关FET和采用2.15mm×1.94mm的小型封装构成贴装面积小、物料清单成本低的电源系统,且可通过DAC信号动态控制输出电压,支持APT、ET功能。目前,MB39C326已进入量产阶段。 随着便携式设备产品市场的急速扩张,不断对产品在性能、功能等方面提出新的要求。如何以卓越的性能实现丰富的功能以吸引更多的消费者,同时降低设备功耗、尺寸和成本,延长电池使用寿命等诸多难题,成为许多便携式设备供应商积极思考的问题。 根据市场需求
[电源管理]
电源管理芯片发展现状解析
摘要 电源管理芯片应用领域广泛电源管理芯片在电子信息产品中发挥了关键作用、具有广泛的产品应用。电源管理芯片广泛应用于手机与通讯、消费类电子、工业控制、医疗仪器、汽车电子等应用领域,同时随着物联网、新能源、人工智能、机器人等新兴应用领域的发展,电源管理芯片下游市场有望持续发展。 电源管理芯片应用领域广泛 电源管理芯片在电子信息产品中发挥了关键作用、具有广泛的产品应用。电源管理芯片广泛应用于手机与通讯、消费类电子、工业控制、医疗仪器、汽车电子等应用领域,同时随着物联网、新能源、人工智能、机器人等新兴应用领域的发展,电源管理芯片下游市场有望持续发展。 市场规模稳步增长
[电源管理]
<font color='red'>电源管理</font>芯片发展现状解析
IIC东莞站上比亚迪电源管理类芯片全解
  比亚迪微电子在本届IIC东莞站展示了其全套电源管理类芯片,包括功率器件以及电源管理IC两大类,其中有在大量出货的,用于诺基亚手机适配器的AC-DC以及被诺基亚认证的锂电池保护IC,也有刚开发出来的高压MOFET管。   在AC-DC方面,目前比亚迪既有用于手机适配器的产品,也有用于上网本的产品。前者目前已在大量生产,每月给诺基亚的出货都在10kk以上;后者为75W功率,主要应用于上网本的适配器。“采用我们的方案,适配器不需要光耦,具有低成本的特点。”比亚迪股分有限公司第六事业业产品一部市场开发经理陈刚表示。   在MOSFET方面,目前用于手机的低压MOFET是比亚迪出货量最大的市场,中压MOSFET用于电动自行车
[手机便携]
电源管理的应用:技术的趋势以及IC的分类
电源管理半导体从所包含的器件来说,明确强调电源管理集成电路(电源管理IC,简称电源管理芯片)的位置和作用。电源管理半导体包括两部分,即电源管理集成电路和电源管理分立式半导体器件。 电源管理集成电路包括很多种类别,大致又分成电压调整和接口电路两方面。电压凋整器包含线性低压降稳压器(即 LOD),以及正、负输出系列电路,此外不有脉宽调制(PWM)型的开关型电路等。因技术进步,集成电路芯片内数字电路的物理尺寸越来越小,因而工作电源向低电压发展,一系列新型电压调整器应运而生。电源管理用接口电路主要有接口驱动器、马达驱动器、功率场效应晶体管(MOSFET)驱动器以及高电压/大电流的显示驱动器等等。 电源管理分立式半导体器件则包括一些传统的功
[电源管理]
电源管理:ATCA 和 MicroTCA 标准引发集成
引言 为了顺应计算、通信以及工业市场在技术方面的快速进展,PCI 工业计算机制造集团 (PICMG®) 开发出了高级电信计算架构 (ATCA) 和 MicroTCA (μTCA、uTCA、MTCA 或 mTCA) 开放式标准,该标准现在已被广泛采用。2005 年 PICMG® 就采用了该标准,其中规定了关于机械、机架管理 (shelf management)、配电、散热以及 连接器 的要求。 减少旧系统的开发工作并降低成本是催生这些标准的主要原因,因为这些旧系统的实施与要求会随不同的应用以及不同的厂商而有所不同。由于更广泛地采用了新的开放式标准,从而为系统开发商和电信设备制造商 (TEM) 创造了许多商机。一般的标
[电源管理]
<font color='red'>电源管理</font>:ATCA 和 MicroTCA 标准引发集成
ADI最新推出集成式电源管理开关稳压器
    AnalogDevices,Inc.,全球领先的高性能信号处理解决方案供应商,最新推出集成式电源管理开关稳压器系列的最新成员ADP2118DC/DC开关稳压器。这款新型集成式3A、降压型DC/DC同步稳压器包含低导通电阻开关FET(场效应晶体管),可最大限度地提高效率,并集成了内部回路补偿、电源良好指示器、精密使能、跟踪和同步功能,以简化负载点电源系统的设计。ADP2118设计用于支持从医疗设备到通信基础设施设备等多种应用中的高性能信号链负载,这些应用信号链可能包括ADC(模数转换器)、DAC(数模转换器)、精密放大器以及诸如DSP(数字信号处理器)和FPGA(现场可编程门阵列)等其它高性能亚微米IC。     “对于
[电源管理]
小广播
最新电源管理文章
