TIbq25504高效率超低功耗能量采集解决方案
最新更新时间:2011-12-24来源: chinaaet关键字:电源管理  能量采集  太阳能 手机看文章 扫描二维码
随时随地手机看文章
TI 公司的bq25504是高效率超低功耗能量采集升压充电IC,可以管理各种直流源如太阳能或热电发生器(TEG)所产生的微瓦或毫瓦功率,超低静态电流小于330nA,可连续从VIN大于80mV的输入源采集能量,冷起动电压VIN大于330mV,具有可编程的动态MPPT,所采集的能量可储存在锂电池,薄膜电池,超级电容或传统电容.主要用于能量采集,太阳能充电器, TEG收集,无线传感器网络(WSN),工业监视,能量存储,环境监测,桥梁/结构健康监测(SHM),智能建筑物控制,手持保健设备以及娱乐系统遥控等.本文介绍了bq25504主要优势和特性,方框图, 太阳能,TEG和MPPT应用电路图,bq25504 EVM评估板性能指标,电路图和材料清单,PCB布局图以及太阳能能量采集总体解决方案包括传统逆变器解决方案框图, 微逆变器解决方案框图和太阳能街灯照明方框图.
Texas Instruments introduces highly efficient boost charger IC for nano power energy harvesting
The bq25504 is the first of a new family of intelligent integrated energy harvesting Nano-Power management solutions that are well suited for meeting the special needs of ultra low power applications. The product is specifically designed to efficiently acquire and manage the microwatts (μW) to miliwatts (mW) of power generated from a variety of DC sources like photovoltaic (solar) or thermal electric generators. The bq25504 is the first device of its kind to implement a highly efficient boost converter/charger targeted toward products and systems, such as wireless sensor networks (WSN) which have stringent power and operational demands. The design of the bq25504 starts with a DCDC boost converter/charger that requires only microwatts of power to begin operating.
bq25504主要优势和特性:
• Ultra Low Power With High Efficiency DC/DC Boost Converter/Charger
–Continuous Energy Harvesting From Low Input Sources: VIN ≥ 80 mV(Typical)
–Ultra Low Quiescent Current: IQ < 330 nA (Typical)
–Cold-Start Voltage: VIN ≥ 330 mV (Typical)
• Programmable Dynamic Maximum Power Point Tracking (MPPT)
– Integrated Dynamic Maximum Power Point Tracking for Optimal Energy Extraction From a Variety of Energy Generation Sources
–Input Voltage Regulation Prevents Collapsing Input Source
• Energy Storage
–Energy can be Stored to Re-Chargeable Li-ion Batteries, Thin-film Batteries, Super-Capacitors, or Conventional Capacitors
• Battery Charging and Protection User Programmable Undervoltage /Overvoltage Levels
– On-Chip Temperature Sensor with Programmable Overtemperature Shutoff
• Battery Status Output
–Battery Good Output Pin
–Programmable Threshold and Hysteresis
–Warn Attached Microcontrollers of Pending Loss of Power
–Can be Used to Enable/Disable System Loads
bq25504应用:
• Energy Harvesting
• Solar Charger
• Thermal Electric Generator (TEG) Harvesting
• Wireless Sensor Networks (WSN)
• Industrial Monitoring
• Energy Storage
• Environmental Monitoring
• Bridge / Structural Health Monitoring (SHM)
• Smart Building Controls
• Portable and Wearable Health Devices
• Entertainment System Remote Controls
图1.bq25504功能方框图
图2.bq25504太阳能应用电路图
VIN_DC = 1.2 V, CSTOR= 4.7 μF, LBST= 22 μH, CHVR= 4.7 μF, CREF= 10 nF, TSD_PROTL (65°C), MPPT (VOC) = 80% VBAT_OV = 3.1 V, VBAT_UV = 2.2 V, VBAT_OK = 2.4 V, VBAT_OK_HYST = 2.8 V, ROK1 = 4.42 MΩ, ROK2 = 4.22 MΩ, ROK3 = 1.43 MΩ, ROV1 = 5.9 MΩ, ROV2 = 4.02 MΩ, RUV1= 5.6 MΩ, RUV2 = 4.42 MΩ, ROC1= 15.62 MΩ, ROC2 = 4.42 MΩ
图3.bq25504 TEG应用电路图
VIN_DC = 0.5 V, CSTOR = 4.7 μF, LBST = 22 μH, CHVR = 4.7 μF, CREF = 10 nF, TSD_PROTH (120°C), MPPT (VOC) = 50% VBAT_OV = 4.2 V, VBAT_UV = 3.2 V, VBAT_OK = 3.5 V, VBAT_OK_HYST = 3.7 V, ROK1 = 3.32 MΩ, ROK2 = 6.12 MΩ, ROK3 = 0.542 MΩ, ROV1 = 4.42 MΩ, ROV2 = 5.62 MΩ, RUV1 = 3.83 MΩ, RUV2 = 6.12 MΩ, ROC1 = 10 MΩ, ROC2 = 10 MΩ
图4.bq25504 MPPT应用电路图
VIN_DC = 1.2 V, CSTOR = 4.7 μF, LBST = 22 μH, CHVR = 4.7 μF, TSD_PROTL (65℃),
MPPT (VOC) = Disabled VBAT_OV = 3.3 V, VBAT_UV = 2.2 V, VBAT_OK = 2.8 V, VBAT_OK_HYST = 3.1 V,ROK1 = 3.97 MΩ, ROK2 = 5.05 MΩ, ROK3 = 0.976 MΩ, ROV1 = 5.56 MΩ, ROV2 = 4.48 MΩ, RUV1 = 5.56 MΩ, RUV2 = 4.42 MΩ
bq25504 EVM评估板
bq25504 EVM – Ultra Low Power Boost Converter with Battery Management for Energy Harvester Applications
bq25504EVM-674 – Ultra Low Power Boost Converter with Battery Management for Energy Harvester Applications. This EVM is programmed from the factory for settings compatible with most MCU’s and 3V coin cell batteries. The EVM is programmed to deliver a 3.1VDC maximum voltage (OV) for charging the storage element and the under voltage is programmed to 2.2VDC. The VBAT_OK indication toggles high when VSTOR ramps up at 2.8VDC and when VSTOR ramps down to 2.4VDC. The user’s guide describes the bq25504 evaluation module (EVM), how to perform a stand-alone evaluation and allows the EVM to interface with the system and host.
bq25504 EVM评估板主要特性:
Evaluation Module for bq25504
Ultra Low Power Boost Converter/Charger with Battery Management for Energy Harvester Applications
Resistor-programmable settings for under voltage, over voltage for flexible battery management Including POTs for fine tuning the settings (not populated)
Programmable push-pull output Indication for battery status (VBAT_OK)
Test Points for Key Signals Available for Testing Purpose – Easy Probe Hook-up Jumpers Available – Easy to Change Settings
图5. bq25504 EVM评估板外形图
bq25504 EVM评估板性能指标:
图6. bq25504 EVM评估板电路图
bq25504 EVM评估板材料清单(BOM):
图7. bq25504 EVM评估板PCB布局图
TI 太阳能能量采集总体解决方案
传统逆变器解决方案
Central, or “traditional”, inverters are centralized power control units that convert DC power from a string of 72-cell solar panels to AC power for use on the electrical utility grid. These are usually large scale commercial or residential systems producing in excess of 1 kW of power. Maximum power point tracking for the entire string is done only at the inverter box, which may also include relays to “island” the solar system from the grid.
图8.. 传统逆变器解决方案框图
微逆变器解决方案
Micro-inverters operate similarly to central inverter systems, but are installed on each individual panel and handle much less
power, typically 300 W. Micro-inverters provide the benefit of scalability for those who want to start small, yet have full
DC/AC conversion with MPPT, and expand later.
图9.微逆变器解决方案框图(1)
Micro-converters maximize the DC power point of a single solar panel and convert (down or up) the DC voltage to be transported downstream to a centralized AC (grid-tied) inverter. Being located on each panel, these systems are lower power (typ. 300 W) than centralized converters. These are sometimes called “optimizers” because they optimize the power of each panel, increasing the overall efficiency of the system.
图10.微逆变器解决方案框图(2)
3.电池充电解决方案
Off-grid solar power systems often need to charge a battery, or array of battery cells, that provide continuous power to the load when solar energy is no longer present. Often cost sensitive, in order to optimize the size, cost and usable power of the storage elements, off-grid systems also require that the power point be maximized. However, this can be done by employing, lower power and less complex MCUs than grid-tied systems or by employing a simple fixed power point – often set at 76% of VOC. Loads such as LED lighting and motors may require additional power boosting and/or control.
图11.太阳能街灯照明方框图.
详情请见:
http://www.ti.com/lit/ds/symlink/bq25504.pdf
http://www.ti.com/lit/ug/sluu654a/sluu654a.pdf
以及
http://www.ti.com/lit/sl/slyy027/slyy027.pdf
关键字:电源管理  能量采集  太阳能 编辑:探路者 引用地址:TIbq25504高效率超低功耗能量采集解决方案
上一篇:NXPUBA2016A35WTL5高效荧光灯电源解决方案
下一篇:实现功率因数校正的电源和适配器方案
推荐阅读最新更新时间:2023-10-18 16:16
Power Integrations推出输出规格可动态设定的离线式开关电源IC
InnoSwitch™3-Pro集成开关IC可提供电源输出电压及电流的数字化微调,实现对电池充电的精确控制并省去DC-DC后级稳压电路。下面就随电源管理小编一起来了解一下相关内容吧. InnoSwitch3-Pro电源转换IC集成了微处理器VCC电源,无需新增外围LDO为外部微处理器供电;此外,还集成了n沟道MOSFET驱动电路,可用于使能或禁止电源的主功率输出。由于新器件集成了总线电压、电流和故障报告的遥测技术,以及可动态设定的各项保护功能,例如可外部设定电源的过温保护(OTP)、输入过压/欠压(OV/UV)保护、输出过压/欠压(OV/UV)保护和短路保护的反应机制,从而使得复杂的离线式电源的BOM元件数大幅减少,电源设计的复杂
[电源管理]
英国有机太阳能电池研究获重大突破
英国国家物理实验室(NPL)研究人员在太阳能发电技术中的有机光电计量上取得了重大突破,通过新型原子力显微镜可以“看到”到工作中的有机太阳电池,并将其三维纳米结构与其性能联系起来。 这项研究表明有可能获得正在运行中的有机太阳电池表面和表面以下至少20nm深度的结构和电子信息。新的测量方法是利用光导原子力显微镜(pc-AFM),通过纳米探针在同一时间测量表面状态和产生的光电流。这种技术可以解释工作中的有机太阳电池,其纳米尺度形态和其性能特点之间的直接联系。这一突破将提高对技术的认识,使制造商能够通过优化有机光伏材料的纳米尺度结构,提高其产品的效率。
[新能源]
中国第一支CIGS太阳能集电管亮相
  上月5日在上海开幕的2011第6届亚洲太阳能光伏工业展览会上,依托北京大学技术研发团队的支持,由河南燕垣光伏科技有限公司研发的中国第一支CIGS太阳能集电管今天在上海正式亮相。 在世界太阳能产业如火如荼发展的今天,人们对太阳能集热管不陌生,对太阳能电池片也熟悉,但可能不甚了解把二者结合起来的产物——太阳能集电管。这正是铜铟镓硒(CIGS)薄膜太阳电池应用的一种崭新形式,它为CIGS规模化生产探索出一条新的路径。 中科院院士、北京大学物理学院教授甘子钊表示,铜铟镓硒(CIGS)薄膜太阳电池应用是中国太阳能产业发展方向,它减少了传统意义上利用硅为基础材料的污染和高能耗,成本低廉、耗能低、效率高。北京大学技术研发团队研究的这项技术,
[新能源]
如何使太阳能光伏产品更智能、更高效
太阳照射地球每6个小时产生的能量就足以满足全球整整一年的能源需求。凭借这笔免费的巨额绿色财富,光伏(PV)技术毅然成为了环保运动的象征。然而,光伏/太阳能这种未来能源虽已问世三十余载,其产量却不到世界能源产量的0.5%。 将太阳能从新兴能源转变为主流能源面临着多方面的机遇和挑战。尽管来自太阳光照的能量巨大无比,但限于设备转换费用昂贵以及转换效率仍有待提高等原因,使太阳能光伏成为免费商品的路还很漫长,而利用半导体来管理转换系统则能够很容易地解决这个问题。目前,光伏能的发展在很大程度上取决于激励机制、政策主张和“小额贷款”的资本投资模式。然而,太阳能光伏总有一天会与化石燃料在价格上持平,这一点毫无疑问。从系统角度来看,
[半导体设计/制造]
如何使<font color='red'>太阳能</font>光伏产品更智能、更高效
意法半导体通过智能热点防护技术再生被损耗的太阳能
意法半导体(纽约证券交易所代码:STM),发布创新的太阳能面板解决方案SPV1001。这款解决方案以一个高能效的智能芯片为基础,封装尺寸与旁通二极管相同,可直接替代简单的旁通二极管,让更多太阳能电池产生的能量进入电网。SPV1001可提高太阳能面板应用产生的能量,提升投资收益。 意法半导体全新的SPV1001整合了低损耗功率开关和精密控制器,可直接取代用于预防热点效应的旁通二极管,进而保护在二极管内损耗掉的能量。与传统的二极管解决方案不同的是,当太阳能光伏(PV)面板发电时,SPV1001集成的功率开关的泄漏电流几乎为零。意法半导体的BCD6芯片制程是这款高效能功率器件与逻辑控制电路二合一芯片的关键技术
[半导体设计/制造]
意法半导体通过智能热点防护技术再生被损耗的<font color='red'>太阳能</font>
工业和无线助力,电源管理半导体市场强劲复苏
根据IHS公司,2013年第二季度电源管理半导体市场将取得两年来的最快增长,营业收入预计达75.6亿美元,比第一季度的70.9亿美元增长6.6%。第二季度增长率将至少是2011年初以来的最高水平,此前九个季度增长率从未超过3.8%,从而给预期中的下半年快速增长拉开序幕。有迹象显示该产业正在摆脱疲软局面。这是继6个月萎缩以来的首次增长,将是电源管理产业一段好时光的开始。预计第三季度增长率会更高,而通常是负增长的第四季度,今年也将实现正增长。   相对于2012年的黯淡市况,这是令人高兴的转变。去年,主导PC市场的数据处理产业表现低迷,而无线产品也让PC难以招架,拖累了电源管理芯片产业。由于PC销量减少,PC生产商削减电
[电源管理]
工业和无线助力,<font color='red'>电源管理</font>半导体市场强劲复苏
特斯拉CTO被证实将离职,对电动汽车影响不大
作为SolarCity的联合创始人兼首席技术官,该公司被 特斯拉 收购后,彼得·赖夫转而在特斯拉负责 太阳能 屋顶业务,曾经备受期待。不过,在他的哥哥林登离开公司后不久,他也离开了。   特斯拉公司的一位发言人证实了赖夫的离职。这位发言人表示,“我们可以证实,彼得·赖夫将离开公司,寻找新的机会。”     声明称:“作为SolarCity的联合创始人和首席技术官,彼得在向全国成千上万的人推广太阳能的过程中发挥了重要作用,有助于加速世界向可持续能源的转型。彼得的职责,包括太阳能屋顶的工作,将被分配到特斯拉现有的工程团队中。我们要感谢彼得为SolarCity和特斯拉所做的一切。”   作为首席技术官,他在开发特斯拉太阳能屋顶、从原
[嵌入式]
顺应电源管理集成趋势,芯片厂商妙招不断
在提高功率密度的需求下,用于工业的电源模块不仅向着低电压大电流的方向不懈努力,而且体积也从1/4砖、1/8砖、到1/16砖不断缩小着;与此同时,便携设备配套的电源部分在PCB板上占据的“地盘”也被挤得越来越小。 为了满足设备对电源提出的持续缩小尺寸、降低成本等苛刻要求,电源芯片厂商正尝试把线性稳压器、DC/DC转换器、PWM控制器、LDO和充电IC等不同元件集成到单个器件上,以提供完整的电源解决方案。很明显可以发现:功率集成技术越来越简化了电源的结构。 功率器件被广泛的集成 在AC/DC转换器中集成PFC或PWM,能有效减少电网污染并提高转换效率,这已经得到广泛普及。此外,很多功率器件,如MOSFET、二极管等也
[焦点新闻]
小广播
最新电源管理文章
换一换 更多 相关热搜器件
