TIbq2416x双输入2.5A锂电池充电解方案
最新更新时间:2012-03-03来源: 中电网关键字:电源管理  电池充电器  DC/DC转换器 手机看文章 扫描二维码
随时随地手机看文章
    TI公司的bq24160/ bq24161/ bq24163/ bq24168是高度集成的单个锂电池充电器和系统功率通路管理器件,充电电流高达2.5A,输入电压额度20V,USB输入6.5V,主要用在手持设备,手持媒体播放器,手提设备,上网本和手提上网设备(PID).本文介绍了bq2416x主要特性,方框图, 应用电路图以及bq24160/161/163/168评估模块主要特性,应用电路,材料清单和PCB布局图.
    2.5A, Dual-Input, Single Cell Switchmode Li-Ion Battery Charger with Power Path Management and I2C Interface
    The bq24160/ bq24161/ bq24163/ bq24168 are highly integrated single cell Li-Ion battery charger and system power path management devices targeted for space-limited, portable applications with high capacity batteries. The single cell charger has dual inputs which allow operation from either a USB port or higher-power input supply (i.e., AC adapter or wireless charging input) for a versatile solution. The two inputs are fully isolated from each other and are easily selectable using the I2C interface.
    The power path management feature allows the bq2416x to power the system from a high-efficiency DC-to-DC converter while simultaneously and independently charging the battery. The charger monitors the battery current at all times and reduces the charge current when the system load requires current above the input current limit.
    This allows for proper charge termination and timer operation. Under normal battery charging conditions, the system voltage is approximately equal to the battery voltage, however if the battery is deeply discharged, the system voltage does not drop below 3.5V. This minimum system voltage support enables the system to run with a defective or absent battery pack and enables instant system turn-on even with a totally discharged battery or no battery. The power-path management architecture also permits the battery to supplement the system current requirements when the adapter cannot deliver the peak system currents. This enables the use of a smaller adapter. The 2.5A input current capability allows for GSM phone calls as soon as the adapter is plugged in regardless of the battery voltage. The charge parameters are programmable using the I2C interface.
    The battery is charged in three phases: precharge, fast-charge constant current and constant voltage. In all charge phases, an internal control loop monitors the IC junction temperature and reduces the charge current if the internal temperature threshold is exceeded. Additionally, a voltage-based battery pack thermistor monitoring input (TS) is included that monitors battery temperature for safe charging. The TS function for bq24160, bq24163 and bq24168 is JEITA compatible.
    bq2416x主要特性:
2• High-Efficiency Switch Mode Charger with Separate Power Path Control
– Make a GSM Call with a Deeply Discharged Battery or No Battery
– Instantly Start Up System from a Deeply Discharged Battery or No Battery
• Dual Input Charger
• Highly Integrated Battery N-Channel MOSFET Controller for Power Path Management
– 20 V input rating, with Overvoltage Protection (OVP)
– 6.5 V for USB Input
– 10.5 V for IN input (bq24160/1/3)
– 6.5 V for IN input (bq24168)
– Integrated FETs for Up to 2.5A Charge Rate
– Up to 2.5 A from IN Input (input current limit)
– Up to 1.5 A from USB Input (input current limit)
• Safe and Accurate Battery Management Functions
– 0.5% Battery Regulation Accuracy
– 10% Charge Current Accuracy
• Charge Parameters Programmed Using I2C™ Interface
– Charge Voltage, Current, Termination Threshold, Input Current Limit, VINDPM Threshold
• Voltage Based, NTC Monitoring Input
– JEITA Compatible (bq24160/3/8)
• Thermal Regulation Protection for Output Current Control
• Low Battery Leakage Current, BAT Short-Circuit Protection
• Soft-Start Feature to Reduce Inrush Current
• Thermal Shutdown and Protection
• Available in small 2.8mm × 2.8mm 49-ball WCSP or 4mm × 4mm QFN-24 Packages
bq2416x应用:
• Handheld Products
• Portable Media Players
• Portable Equipment
• Netbook and Portable Internet Devices
图1.bq2416x方框图
图2.bq24160应用电路图
图3.bq24161应用电路图
The bq24160/161/163/168 evaluation module is a complete charger module for evaluating compact, flexible, high-efficiency, USB-friendly, switch-mode charge management solution for single-cell, Li-ion and Li-polymer batteries used in a wide range of portable applications. The bq24160/161/163/168 integrates a synchronous PWM controller, power MOSFETs, input-current sensing, high-accuracy current and voltage regulation, charge termination and power path management into a small WCSP package
bq24160/161/163/168评估模块主要特性:
153-mm × 153-mm × 1.2-mm footprint for entire solution
Input power connectors for both USB input and ac adapter
Programmable battery voltage, charge current, input current, and status via I2C™ interface
IN operating range of 4.2 V – 10 V (bq24160/161/163) or 4.2 V – 6 V (bq24168)
USB operating range of 4.2 V – 6 V
LED indication for status signals
Test points for key signals available for testing purposes. Easy probe hook-up
图4.bq24160/161/163/168评估模块(HPA721)电路图
HPA721材料清单:
图5.评估模块HPA721元件布局图
详情请见:
http://www.ti.com/lit/ds/slusao0/slusao0.pdf
http://www.ti.com/lit/ug/sluu496/sluu496.pdf
关键字:电源管理  电池充电器  DC/DC转换器 编辑:探路者 引用地址:TIbq2416x双输入2.5A锂电池充电解方案
上一篇:张力控制变频收卷的控制原理及在纺织行业中的应用
下一篇:基于PWM降压转换器AP3003的车载充电器的系统设计
推荐阅读最新更新时间:2023-10-18 16:27
便携式应用处理器的电源管理解决方案
便携式应用处理器的电源管理解决方案 当今便携式应用处理器的电源管理解决方案的集成度越来越高。总功耗、待机和深度睡眠的电流消耗会影响电池的大小、物料单(BOM)的成本和产品的认知度。 当设计便携式设备—如智能电话或PDA—的时候,系统设计工程师必须考虑许多电源的变量。随着它们消耗的功率越来越大,智能电话要求高度集成的电源管理解决方案,以便在尽可能最小的PCB面积中实现电池寿命最长的设计目标。 当今的应用处理器需要为内核、I/O、存储器和外部设备等等提供不同的电源域。例如,LP3971就是一种设计用来满足所有这些要求的电源管理单元(PMU),它利用了3个高效率的降压转换器和6个低压差(LDO)调整器。 应用处理
[电源管理]
便携式应用处理器的<font color='red'>电源管理</font>解决方案
Dialog与台积公司开发行动产品电源管理芯片应用的BCD技术
台湾新竹——2012年3月29日——专精于高度整合电源管理解决方案的德商Dialog半导体公司与台积公司今日共同宣布:携手开发下一世代的BCD(Bipolar–CMOS -DMOS,双极–互补金属氧化半导体–双重扩散金属氧化半导体)技术,提供行动产品更高效能的电源管理芯片。 此项BCD技术能够有效整合先进逻辑、模拟、高电压以及场效型晶体管(FET type transistor),而Dialog公司将应用此技术生产电源管理整合度更高、尺寸更小的单一芯片,以符合智能型手机、平板计算机、超薄笔记本电脑等行动产品的需求;同时,0.13微米BCD技术可透过降低导通电阻Rds(on)大幅提升电源管理芯片的效能,提供客户更具节能优势的
[电源管理]
Windows Mobile电源管理分析与实现
如今在以数码消费产品为代表的嵌入式系统领域,大多数系统采用电池供电,由于电池容量有限,这使得实现产品的 低功耗 ,延长待机时间成为一个重要的课题。在已确定硬件 电路 功耗的情况下,提高电池 电源 的使用效率是实现低功耗的一个重要任务,其基本思想是在系统中没有任务等待运行时,把系统置于尽可能低的能量状态,等到有任务需要执行时,再将其快速唤醒,尽可能有效地利用功耗。 1 Windows Mobile中的 电源管理 WinCE系列操作系统中的电源管理模块正是出于后者的考虑而出现的,图1为电源管理(Power Manager)的运行机制。该模块根据系统实际运行情况,以CPU为中心,管理器件和外设的功耗状态,实现系统在不同电源状态间的转
[电源管理]
Windows Mobile<font color='red'>电源管理</font>分析与实现
Dialog半导体为Xilinx Kria K26自适应系统模块提供电源管理方案
Dialog PMIC和GreenPAK™组合方案集成到Kria SOM视觉AI平台中 中国北京,2021年8月30日 – 领先的电池管理、AC/DC电源转换、Wi-Fi、低功耗蓝牙(BLE)、工业IC解决方案供应商Dialog半导体公司今天宣布,扩大与自适应计算领域领先厂商赛灵思公司(Xilinx, Inc)的合作。Dialog已获青睐为赛灵思的新型Kria自适应系统模块(SOM)提供电源管理方案,该模块面向智慧城市和智慧工厂中的视觉人工智能(AI)应用。 赛灵思的Kria自适应SOM产品组合是可随时投产的小型嵌入式板卡,可在基于边缘的应用中实现快速部署。结合完整的软件堆栈和预构建的生产级加速应用,Kria自适应SOM是
[电源管理]
安森美半导体荣获2012中国年度电子成就奖之“电源管理最佳产品奖”
2012年2月27日–应用于高能效电子产品的首要高性能硅方案供应商安森美半导体(ONSemiconductor,美国纳斯达克上市代号:ONNN)的NCV8871汽车级非同步升压控制器荣获《电子工程专辑》2012中国年度电子成就奖之“电源管理最佳产品奖”。   此中国年度电子成就奖表彰在中国大陆推动创新电子设计且在当今电子产业有顶尖表现的公司及产品。   安森美半导体电源及便携产品全球销售及营销高级总监郑兆雄先生说:“我们的产品获得业界权威奖项的表彰,我们备感荣幸;这奖项也有力地认可了我们的产品开发,证明了我们在汽车应用电源管理领域持续处于领先地位。我们将继续致力于开发创新及高性能的技术和产品,提供高能效的汽车方案
[电源管理]
汽车导航系统的DC/DC转换器选择指南
汽车环境的宽工作电压要求、大瞬变电压以及大温度漂移等因素共同作用下,电子系统面临着严酷的条件,本文介绍如何在性能要求变得愈加苛刻的条件下,设计多个电源电压以满足汽车电子系统不同部分的要求。 目前生产的大多数中高档汽车都配置了基于DVD的GPS导航系统作为标准设备(图1)。然而可以证实,如果想设计一个用于控制此类系统内不同电压轨的电源,其复杂程度丝毫不亚于设计笔记本电脑用的电源系统。一个标准的汽车导航系统有可能具有6个或更多的电源,包括8V、5V、3.3V、2.5V、1.5V和1.2V。8V电源用于给使光盘旋转的DVD电机供电;这常常需要高达2A的峰值电流。5V和3.3V电源轨通常为系统总线,一般要求各提供2A~3A的电
[汽车电子]
基于DC/DC转换器提高RF功率放大器效率
从功率预算的角度而言,直接由电池供电的射频功率放大器(RF PA)是需要重点考虑的元件。传统上,CDMA/WCDMA蜂窝标准中使用的射频功率放大器都直接由电池供电,这种供电方式使系统很容易设计,但是,这种标准中使用的线性功率放大器在整个发射功率范围内的实际效率很低。本文讲述一种通过DC/DC转换器提供高效RF PA系统电源管理的方案。   随着蜂窝标准的不断发展,传输速率已从CDMA-1标准中的14.4kbps发展到CDMA2000/WCDMA标准中的2Mbps。此外,为了增加从每个用户获得的平均收入,蜂窝通信运营商已开始增加与3G电话相关的服务。同时,通话时间和电池寿命也期望采用具有同样或稍高一些容量的电池来获得提高。这使
[模拟电子]
基于<font color='red'>DC</font>/<font color='red'>DC转换器</font>提高RF功率放大器效率
昂宝推出高集成度电源管理芯片
昂宝电子日前推出高集成度、高功能的脉宽调制(PWM)控制芯片—OB2268/2269。此芯片应用于交流/直流交换式电源供应器,采用DIP8,SOP8的封装形式,内含昂宝的各项专利技术,使得系统设计更容易符合2007年国际能源机构(IEA),能源之星(Energy start)和蓝色天使(Blue Angel)建议的各项具体要求。 OB2268/2269系列产品采用BiCMOS制成,具有低启动电流(5uA)、工作电流(<3mA)和各项绿色环保要求,并可提供通过认证的昂宝电子SGS报告。 其主要特点集中表现在: 高集成特性可使外部零件减至最少,并降低电源设计的复杂度,进而缩短产品开发时间
[新品]
小广播
最新电源管理文章
换一换 更多 相关热搜器件
