The Texas InstrumentsMSP430 family of ultralow-power microcontrollers consists of several devices featuring different sets of peripherals targeted for various applications. The architecture, combined with five low-power modes, is optimized to achieve extended battery life in portable measurement applications. The devices feature a powerful 16-bit RISC CPU, 16-bit registers, and constant generators that contribute to maximum code efficiency.The digitally controlled oscillator (DCO) allows wake-up from low-power modes to active mode in less than 6us.
The MSP430F471xx series are microcontroller configurations targeted to single-phase and poly-phase electricity meters with three, six, or seven 16-bit sigma-delta A/D converters. Each channel has a differential input pair and programmable input gain. Also integrated are two 16-bit timers, four universal serial communication interfaces (USCI), DMA, 68 I/O pins, and a liquid crystal driver (LCD) with integrated contrast control.
MSP430F471xx主要特性:
D Low Supply-Voltage Range: 1.8 V to 3.6 V
D Ultralow Power Consumption
-- Active Mode: 350uA at 1 MHz, 2.2 V
-- Standby Mode: 1.1 uA
-- Off Mode (RAM Retention): 0.2 uA
D Five Power-Saving Modes
D Wake-Up From Standby Mode in Less Than 6us
D 16-Bit RISC Architecture, 62.5-ns Instruction Cycle Time
D Three-Channel Internal DMA
D Three, Six or Seven 16-Bit Sigma-Delta Analog-to-Digital (A/D) Converters With Differential PGA Inputs
D 16-Bit Timer_B With Three Capture/Compare-With-Shadow Registers
D 16-Bit Timer_A With Three Capture/Compare Registers
D On-Chip Comparator
D Four Universal Serial Communication Interface (USCI) Modules
-- USCI_A0 and USCI_A1
-- Enhanced UART Supporting Auto-Baudrate Detection
-- IrDA Encoder and Decoder
-- Synchronous SPI
-- USCI_B0 and USCI_B1
-- I2C
-- Synchronous SPI
D Integrated LCD Driver With Contrast Control for Up to 160 Segments
D Basic Timer With Real-Time Clock Feature
D 32-Bit Hardware Multiplier
D Brownout Detector
D Supply Voltage Supervisor/Monitor With Programmable Level Detection
D Serial Onboard Programming, No External Programming Voltage Needed Programmable Code Protection by Security Fuse
D Bootstrap Loader
D On-Chip Emulation Module
D Family Members Include
MSP430F47163: 92KB Flash, 4KB RAM
3 Sigma-Delta ADCs
MSP430F47173: 92KB Flash, 8KB RAM
3 Sigma-Delta ADCs
MSP430F47183: 116KB Flash, 8KB RAM
3 Sigma-Delta ADCs
MSP430F47193: 120KB Flash, 4KB RAM
3 Sigma-Delta ADCs
MSP430F47126: 56KB Flash, 4KB RAM
6 Sigma-Delta ADCs
MSP430F47166: 92KB Flash, 4KB RAM
6 Sigma-Delta ADCs
MSP430F47176: 92KB Flash, 8KB RAM
6 Sigma-Delta ADCs
MSP430F47186: 116KB Flash, 8KB RAM
6 Sigma-Delta ADCs
MSP430F47196: 120KB Flash, 4KB RAM
6 Sigma-Delta ADCs
MSP430F47127: 56KB Flash, 4KB RAM
7 Sigma-Delta ADCs
MSP430F47167: 92KB Flash, 4KB RAM
7 Sigma-Delta ADCs
MSP430F47177: 92KB Flash, 8KB RAM
7 Sigma-Delta ADCs
MSP430F47187: 116KB Flash, 8KB RAM
7 Sigma-Delta ADCs
MSP430F47197: 120KB Flash, 4KB RAM
7 Sigma-Delta ADCs
D Available in a 100-Pin Plastic Quad
Flatpack (QFP) Package
图1. MSP430F471x7方框图
图2. MSP430F471x6方框图
图3. MSP430F471x3方框图
采用MSP430F471xx的三相电度(瓦特-小时)表
This application report describes the implementation of a three phase electronic electricity
meter using the Texas Instruments MSP430F471xx system-on-chip (SOC) processor.
This application report includes the necessary information with regard to metrology software, hardware and calibration procedures for this single chip implementation. Results are included at the end, which show performance of this device for three phase using current transformers as sensors.
图4.采用MSP430F47197的三相四线星形连接的电度表框图
图5. MSP430电表的容性电源电路图
图6. MSP430电表的基于变压器电源电路图
图7.三相电表EVM外形图
图8.三相电表EVM电路图
详情请见:
http://www.ti.com/lit/ds/symlink/msp430f47197.pdf
和
http://www.ti.com/lit/an/slaa409a/slaa409a.pdf
上一篇:激光红外在风光供电监控摄像机中的应用
下一篇:无功补偿容量的经典优化法分析
推荐阅读最新更新时间:2023-10-18 16:38
Vishay线上图书馆
- 选型-汽车级表面贴装和通孔超快整流器
- 你知道吗?DC-LINK电容在高湿条件下具有高度稳定性
- microBUCK和microBRICK直流/直流稳压器解决方案
- SOP-4小型封装光伏MOSFET驱动器VOMDA1271
- 使用薄膜、大功率、背接触式电阻的优势
- SQJQ140E车规级N沟道40V MOSFET
- 非常见问题解答第223期:如何在没有软启动方程的情况下测量和确定软启动时序?
- Vicor高性能电源模块助力低空航空电子设备和 EVTOL的发展
- Bourns 推出两款厚膜电阻系列,具备高功率耗散能力, 采用紧凑型 TO-220 和 DPAK 封装设计
- Bourns 全新高脉冲制动电阻系列问世,展现卓越能量消散能力
- Nexperia推出新款120 V/4 A半桥栅极驱动器,进一步提高工业和汽车应用的鲁棒性和效率
- 英飞凌推出高效率、高功率密度的新一代氮化镓功率分立器件
- Vishay 新款150 V MOSFET具备业界领先的功率损耗性能
- 强茂SGT MOSFET第一代系列:创新槽沟技术 车规级60 V N通道 突破车用电子的高效表现
- 面向车载应用的 DC/DC 电源
- 端到端大模型席卷广州车展,智驾行业的一次技术大跃迁
- 主机厂ADAS研究:架构调整、团队整合、拼D2D,一切为了智驾领先
- 新格局 新未来!2024中国汽车充换电生态大会在太原召开
- 本田固态电池5年内上车:续航提升2倍 一次可行驶1000公里
- 逐鹿智驾的“法门”,藏在最新技术趋势里
- 强茂SGT MOSFET第一代系列:创新槽沟技术车规级60 V N通道 突破车用电子的高效表现
- 睿瀚医疗万斌:“脑机接口+AI+机器人”是康复赛道的未来
- 希润医疗孟铭强:手功能软体机器人,让脑卒中患者重获新生
- 柔灵科技陈涵:将小型、柔性的脑机接口睡眠设备,做到千家万户
- 微灵医疗李骁健:脑机接口技术正在开启意识与AI融合的新纪元
