FairchildFLS324710W离线LED驱动解决方案
最新更新时间:2012-08-02来源: chinaaet关键字:LED驱动器  AC/DC转换器  离线电源 手机看文章 扫描二维码
随时随地手机看文章
Fairchild公司的FLS3247是集成了功率MOSFET的单级PFC初级调整的离线LED驱动器,包括PWM控制器和功率MOSFET,能增强低功率反激转换器的性能,应用电压范围80VAC ~ 308VAC,提供LED开路,短路和超温保护功能.主要用于LED照明系统.本文介绍了FLS3247主要特性,方框图,通用输入10W LED驱动器电路图以及10W LED驱动器评估板主要指标,电路图,材料清单和PCB布局图.
This highly integrated PWM controller with power MOSFET, FLS3217 / FLS3247, provides several features to enhance the performance of low-power flyback converters. The proprietary topology enables simplified circuit design for LED lighting applications.
By using the single-stage topology with primary-side regulation, an LED lighting board can be implemented with the few external components and minimized cost; requiring no input bulk capacitor or feedback circuitry.
To implement good power factor and low THD, constant on-time control is utilized with an external capacitor connected to COMI. Precise constant-current control regulates accurate output current versus changes in input voltage and output voltage. The operating frequency is proportionally changed by the output voltage to guarantee DCM operation with higher efficiency and simple design.
FLS3217 and FLS3247 provide protection features such as open-LED, short-LED, and over-temperature protection. The current-limit level is automatically reduced to minimize the output current and protect external components in short-LED condition.
FLS3247主要特性:
 Cost-Effective Solution without Input Bulk Capacitor and Feedback Circuitry
 Power-Factor Correction (PFC)
 Integrated Power MOSFET
 Accurate Constant-Current (CC) Control Independent Online Voltage, Output Voltage, and Magnetizing Inductance Variation
 Linear Frequency Control for Increased Efficiency
 Open / Short-LED Protection
 Cycle-by-Cycle Current Limiting
 Over-Temperature Protection with Auto Restart
 Low Startup Current: 20μA
 Low Operating Current: 5mA
 VDD Over-Voltage Protection (OVP)
 VDD Under-Voltage Lockout (UVLO)
 Application Voltage Range: 80VAC ~ 308VAC
FLS3247应用:
 LED Lighting System
图1.FLS3247方框图
图2.FLS3247通用输入10W LED驱动器电路图
10W LED驱动器评估板
This document describes the proposed solution for a universal line voltage LED ballast using the FLS3247N Primary-Side Regulator (PSR) single-stage controller. The input voltage range is 90VRMS – 265VRMS and there is one DC output with a constant current of 400mA at 25VMAX. This document contains a general description of the FLS3247N, the power supply specification, schematic, bill of materials, and typical operating Characteristics.
10W LED驱动器评估板主要指标:
图3.10W LED驱动器评估板外形图(59mm (L) ×25.5mm (W) × 20.0mm (H))
10W LED驱动器评估板主要特性:
 Cost effective solution without input bulk capacitor and feedback circuitry
 Power Factor Correction
 Accurate constant-current (CC) Control
 Linear frequency control for better efficiency and easy design
 Constant current regulation vs. output voltage change (11~28V) : <± 2.85%
 Constant current regulation vs. line voltage change (90~265VAC) : <± 2.85%
 Output open & short circuit protection with auto restart
 System efficiency up to 86.8%
 PF and THD: PF (> 0.9), THD(< 20%)
图4.10W LED驱动器评估板电路图
10W LED驱动器评估板材料清单:
图5.10W LED驱动器评估板布局图(顶层)
图6.10W LED驱动器评估板布局图(底层)
详情请见:
http://www.fairchildsemi.com/ds/FL/FLS3247.pdf
http://www.fairchildsemi.com/an/AN/AN-FEBL042.pdf
关键字:LED驱动器  AC/DC转换器  离线电源 编辑:探路者 引用地址:FairchildFLS324710W离线LED驱动解决方案
上一篇:基于电流环电路的远距离数据传输
下一篇:基于VHDL的直流电机控制功能模块设计
推荐阅读最新更新时间:2023-10-17 15:00
开关模式LED驱动器的调光技术
led发出的可见光的亮度概念相当容易理解。 LED调光方法 对开关模式驱动 电路 的LED进行 调光有两种常用方法:脉宽调制调光和模拟调光。两种方法都对经过LED 或LED串的时间平均 电流 进行控制,但在衡量两种调光电路的优缺点时,两者之间的差异也很明显。   图1显示采用 降压 拓扑的一个 LED驱动器。Vin必须始终高于LED 和RSNS上的 电压 之和。电感电流为LED电流。该电流通过监控CS引脚的电压进行调节。当CS开始低于设置的电压时,流经 L1、LED和RSNS的电流脉冲的占空比增加,从而增加LED的平均电流。 模拟调光 LED的模拟调光是对LED电流的每个周期进行调整。更简单地说,它是不断调整 LED的
[电源管理]
开关模式<font color='red'>LED驱动器</font>的调光技术
ROHM开发出4通道线性LED驱动器“BD183x7EFV-M”
全球知名 半导体 制造商 ROHM (总部位于日本京都)面向两轮 / 四轮机动车中应用日益普及的 LED 尾灯 (刹车灯、后尾灯)、雾灯、转向灯等,开发出内置 MOSFET 的 4 通道线性 LED 驱动器 IC“BD183x7EFV-M”(BD18337EFV-M / BD18347EFV-M)。 新产品采用了两项新技术,即 ROHM 独有的热分散电路和 LED 单独控制功能,有助于显著削减 LED 灯的电路板面积和应用的设计周期,能够为以印度为主的海外两轮机动车市场提供解决方案。 在削减电路板面积方面,利用独有的热分散电路,将以往各输出通道所需的热分散电路用引脚集约为 1 个引脚,从而通过小型 16pin 封装实
[汽车电子]
ROHM开发出4通道线性<font color='red'>LED驱动器</font>“BD183x7EFV-M”
固态照明标准的离线LED驱动器GreenPoint®参考设计
  随着高亮度发光二极管(HB-LED)在光输出、能效及成本方面的全面改善,同时结合小巧、低压工作及环保等众多优势,LED照明(也称固态照明(SSL))正在掀起一场照明革命。而在节能环保的趋势下,LED照明自然也成为众多规范机构所瞄准的目标。如美国能源部“能源之星”项目的1.1版固态照明标准自2009年2月开始生效,中国的中国标准化研究院也在牵头携手相关机构,准备在2010年发布中国版本的LED照明能效标准。   就“能源之星”的新版固态照明标准而言,这标准的一项重要特点是要求多种住宅照明产品的功率因数最低要达到0.7,其中的一些典型产品有便携式台灯、橱柜灯及户外走廊灯等。这类LED照明应用的功率一般在1到12 W间,属于低
[电源管理]
固态照明标准的<font color='red'>离线</font>型<font color='red'>LED驱动器</font>GreenPoint®参考设计
LD7209:PWM调光LED驱动器
LD7209是一款LED驱动器, 该系列组件能驱动3~8颗WLED背光, 提供38V开路电压保护,可应用于锂电供电之小尺寸屏幕背光LED等便携式产品, 如手机、PDA、、GPS、笔记本电脑及数码相框。 LD7209采用1MHZ高频PWM开关频率设计, 可有效减外部电感及电容器的体积,并利用PWM输入(200HZ~200KHZ)调节LED亮度, 使LED电流正比于PWM责任比。 除了可灵活控制亮度外, LD7209同时整合了可靠的保护特性; 内建软激活可消除激活期间的浪涌电流,并具备LED开路保护、电流过载限制和过热保护。并且在切断模式下, 仅消耗0.1mA, 减少电池功耗。 LD7209效率最高可达90%以上,
[电源管理]
LD7209:PWM调光<font color='red'>LED驱动器</font>
用于车载液晶背光源的矩阵式(8路×24ch)LED驱动器“BD94130xxx-M”
~仅由1枚IC即可独立控制192个分区的Mini LED!局部调光功能有助于提高显示器的清晰度并降低功耗~ 全球知名半导体制造商ROHM(总部位于日本京都市)开发出适用于在新一代汽车信息娱乐系统和仪表盘等中应用日益广泛的大型显示器的 车载液晶背光用LED驱动器IC (以下简称“LED驱动器”)“BD94130xxx-M”(BD94130MUF-M、BD94130EFV-M)。  近年来,随着ADAS(高级驾驶辅助系统)的发展和车载信息娱乐功能的增加,车载显示器需要具备更高的清晰度以便提高视认性。针对这种需求,具有局部调光功能的LED驱动器可以只关闭液晶显示器暗部的背光,有助于提高液晶显示的清晰度并降低功耗,因此开发新
[电源管理]
用于车载液晶背光源的矩阵式(8路×24ch)<font color='red'>LED驱动器</font>“BD94130xxx-M”
带总线接口的LED驱动器SAA1064及其应用LEDDriverSAA1064withBusInterfaceandItsAplication
      摘要: SAA1064 是 Philips 公司生产的带 总线接口的 4 位 LED 驱动器。可用于驱动 4 位带小数点的七段显示器,并可通过多路开关对两个 2 位显示器进行切换显示,文中介绍了 SAA1064 的功能、工作原理及 通讯规约,并给出了该芯片与 80C552 的接口电路和程序框图。     关键词: 接口; SAA1064 ; LED ; 80C552 ;动态显示      1. 概述     SAA1064 是 Philips 公司生产的 4 位 LED 驱动器,为双极型电路,具有 接口。该电路是特别为驱动 4 位带有小
[应用]
罗姆首创搭载PFC功能的AC/DC转换器IC
日本知名半导体制造商ROHM(总部位于日本京都)面向TV和工业设备用电源等100W级别的中功率电子设备,开发出将PFC(功率因数改善)控制器与QR(准谐振)控制器一体化封装的高效AC/DC转换器IC“BM1C001F”。 本产品在PFC控制器上同时搭载ON/OFF设定功能与PFC输出新控制方式,为业界首创。而且,还实现了轻负载时的效率提升,大幅降低了设备的待机功耗。使用此款IC的电源电路,还可满足国际标准能源之星6.0所规定的水平。不仅如此,通过将两种控制器一体化封装,可减少零部件数量,因此,还有助于进一步实现电源的小型化。 本IC已于2013年9月份开始出售样品(样品价格100日元),于2013年10月份开始投入量产
[电源管理]
罗姆首创搭载PFC功能的<font color='red'>AC</font>/<font color='red'>DC转换器</font>IC
凌特推出集成肖特基二极管的高效白光LED驱动器
凌特公司日前推出采用SC70封装的高效率、恒定电流白光LED驱动器LT3491。LT3491片上集成了肖特基二极管,由于无需外部二极管,因而节省了成本和空间。独特的高压侧LED电流检测拓扑使LED阴极能够直接连接到地,从而产生了一个单线电流源。 LT3491以超过75%的效率、从单节锂离子电池驱动多达6个白光LED。它以2.3MHz的频率切换,允许使用纤巧电感器和电容器,同时保持开关噪声在关键的RF频带之外。LT3491兼有高效率、低噪声和极小的“总解决方案”占板面积,使其非常适用于需要高达6个白光LED的手持应用。 LT3491用作恒定电流源,不论LED正向电压随着温度、制造容限和老化程度怎样变化,它都为每个白光LE
[新品]
小广播
最新电源管理文章
换一换 更多 相关热搜器件
