IntersilISL8013A3A低静态电流1MHz高效同步降压稳压器参考方案
最新更新时间:2013-01-20来源: 21IC关键字:ISL8013A  降压稳压器 手机看文章 扫描二维码
随时随地手机看文章
Intersil公司的ISL8013A是一款高效率,单片同步降压型DC-DC转换器,可提供高达3A的连续输出电流从2.8V至5.5V的输入电源。它采用了电流控制架构,以提供非常低的占空比工作在高频率快速瞬态响应和卓越的环路稳定性。ISL8013A集成了一对低导通电阻的P沟道和N-通道内部MOSFET,以最大限度地提高效率和减少外部元件数量。100%占空比工作,允许小于300mV压差电压,输出电流为3A。ISL8013AEVAL2Z是基于ISL8013A芯片开发设计的参考方案。ISL8013AEVAL2Z开发套件应用于单负载点的设备,设备电压应用范围为2.7V-5.5V。ISL8013AEVAL2Z评估开发板主要用于展示ISL8013A低静态电流模式下的转换性能。本文主要介绍ISL8013A芯片简介、主要特性、应用及其内部框图。对于ISL8013AEVAL2Z参考方案,主要介绍参考方案的主要特性、原理图、元器件清单及其PCB Layout图。
The ISL8013A is a high efficiency, monolithic,synchronous step-down DC/DC converter that can deliver up to 3A continuous output current from a 2.8V to 5.5V input supply. It uses a current control architecture to deliver very low duty cycle operation at high frequency with fast transient response and excellent loop stability.
The ISL8013A integrates a pair of low ON-resistance P-Channel and N-Channel internal MOSFETs to maximize efficiency and minimize external component count. The 100% duty-cycle operation allows less than 300mV dropout voltage at 3A output current. High 1MHz pulse-width modulation (PWM) switching frequency allows the use of small external components and SYNC input enables multiple ICs to synchronize out of phase to reduce ripple and eliminate beat frequencies.
The ISL8013A can be configured for discontinuous or forced continuous operation at light load. Forced continuous operation reduces noise and RF interference while discontinuous mode provides high efficiency by reducing switching losses at light loads.
Fault protection is provided by internal hiccup mode current limiting during short circuit and overcurrent conditions, an output over voltage comparator and over-temperature monitor circuit. A power good output voltage monitor indicates when the output is in regulation.
The ISL8013A is offered in a space saving 4x4 QFN lead free package with exposed pad lead frames for low thermal resistance.
The ISL8013A includes a pair of low ON-resistance P-Channel and N-Channel internal MOSFETs to maximize efficiency and minimize external component count. The 100% duty-cycle operation allows less than 300mV dropout voltage at 3A.
The ISL8013A offers a 1ms Power Good (PG) timer at power-up. When shutdown, ISL8013A discharges the output capacitor. Other features include internal soft-start, internal compensation, overcurrent protection, and thermal shutdown.
The ISL8013A is offered in a 4mmx4mm 16 Ld QFN package with 1mm maximum height. The complete converter occupies less than 0.4in2 area.
ISL8013A主要特性:
• High Efficiency Synchronous Buck Regulator with up to 97% Efficiency
• Power-Good (PG) Output with a 1ms Delay
• 2.8V to 5.5V Supply Voltage
• 3% Output Accuracy Over-Temperature/Load/Line
• 3A Output Current
• Start-Up with Pre-Biased Output
• Internal Soft-Start - 1ms
• Soft-Stop Output Discharge During Disabled
• 35μA Quiescent Supply Current in PFM Mode
• Selectable Forced PWM Mode and PFM Mode
• External Synchronization up to 4MHz
• Less than 1μA Logic Controlled Shutdown Current
• 100% Maximum Duty Cycle
• Internal Current Mode Compensation
• Peak Current Limiting and Hiccup Mode Short Circuit Protection
• Over-Temperature Protection
• Small 16 Ld 4mmx4mm QFN
• Pb-Free (RoHS Compliant)
 ISL8013A应用:
• DC/DC POL Modules
• μC/μP, FPGA and DSP Power
• Plug-in DC/DC Modules for Routers and Switchers
• Portable Instruments
• Test and Measurement Systems
• Li-ion Battery Powered Devices
• Small Form Factor (SFP) Modules
• Bar Code Readers
图1. ISL8013A内部方框图
ISL8013AEVAL2Z主要特性:
• High Efficiency Synchronous Buck Regulator with up to 95% Efficiency
• Power-Good (PG) Output with 1ms Delay
• 2.7V to 5.5V Supply Voltage
• 3A Guaranteed Output Current
• Start-up with Pre-biased Output
• Internal Digital Soft-Start - 1ms
• 100% Maximum Duty Cycle for Lowest Dropout
ISL8013AEVAL2Z原理图:
图2. ISL8013AEVAL2Z原理图
ISL8013AEVAL2Z元器件清单:
PCB Layout图:
关键字:ISL8013A  降压稳压器 编辑:探路者 引用地址:IntersilISL8013A3A低静态电流1MHz高效同步降压稳压器参考方案
上一篇:60V 输入降压型 DC/DC 控制器 在电池供电系统中仅吸取 40µA 电流
下一篇:OnSemiNCP127119V,3.0A通用AC-DC适配器设计方案
推荐阅读最新更新时间:2023-10-17 15:13
Vicor 进一步壮大 48V Cool-Power ZVS 降压稳压器产品阵营
Vicor 推出 PI3523-00-LGIZ (PI3523),进一步壮大 Cool-Power 48V ZVS 20A 降压稳压器产品阵营。PI352x 系列提供 20A 输出能力,是以前所推出的 10A 48VINPI354x 系列的增强补充,完善了从 48V 直接为负载点 (PoL) 供电的应用可调电压的选项。PI3523 是一款额定输入为 48V输出电压为 3.3V 的降压稳压器,能够提供高达 22A 的电流。该稳压器系列支持从 48VIN 直至 20A 负载点电压的应用,该系列产品覆盖 2.2VOUT 至 14VOUT的应用范围. 小巧的外形带来两倍的功率 PI352x 产品系列提供与 Vicor 现有 48
[电源管理]
Vicor 进一步壮大 48V Cool-Power ZVS <font color='red'>降压稳压器</font>产品阵营
国半1.5A单芯片同步降压稳压器输入电压可达36V
美国国家半导体公司(National Semiconductor)日前宣布推出全新的同步SIMPLE SWITCHER稳压器系列的首款产品,这款型号为LM3100的全新芯片据称是业界首款适用于4.5V至36V输入电压范围的1.5A单芯片同步降压稳压器,其特点是采用独特的结构,有助于简化电路设计。这系列稳压器的其他型号预计会在今年内陆续推出。 美国国家半导体电源管理产品部策略市场总监Paul Greenland表示:“由于美国国家半导体SIMPLE SWITCHER稳压器系列的多款不同产品一直大受欢迎,因此我们乘势推出LM3100芯片。这款同步降压稳压器采用创新的固定开启时间结构,可在广阔的输入电压范围内操作,而且非常容易使用
[新品]
大电流同步降压稳压器 效率达97%【美国国家半导体】
二零一一年二月二十三日 -- 中国讯 -- 美国国家半导体公司(National Semiconductor Corp.)今天宣布推出两款业界效率最高的大电流同步降压稳压器,其效率可高达97%。这两款型号为 LM21212-1 和 LM21215 的芯片可为高性能现场可编程门阵列(FPGA)、特殊应用集成电路(ASIC)和微处理器提供稳压供电,适用于内置此类电路的低压系统,包括无线通信、网络和光纤通信等基础设施等。采用美国国家半导体的 WEBENCHÒ Power Designer 电源设计工具或 WEBENCHÒ FPGA Power Architect 现场可编程门阵列电源系统架构设计工具,能让工程师在几分钟内完成整个系统
[电源管理]
Exar推出加强版2A PowerBlox降压稳压器XRP7674
高性能模拟混合信号器件和数据管理解决方案领导厂商Exar公司(纳斯达克:EXAR),近日发布新款同步脉冲频率调制和脉冲宽度调制(PFM/PWM)降压稳压器- XRP7674,该产品提供最高2A的负载电流和高达18V的操作输入电压。作为Exar高电压,高电流降压稳压器PowerBloxTM 家族的新成员,它为客户提供紧凑型和集成型解决方案,其改进型的轻载效率,帮助低至50mA输出电流获取90%以上的效率转换。   XRP7674针对5V 和12V的输入实现优化,致力于满足高效设备和最新能源之星认证设备之需。其中包括轻载效率对其至关重要的音频-视频设备,例如机顶盒和游戏系统,电信,计算机外设,分布式负载点转换和便携式应用等。
[模拟电子]
Exar推出加强版2A PowerBlox<font color='red'>降压稳压器</font>XRP7674
固定频率工作的降压稳压器设计
    大多数开关稳压器都依赖于专用时钟荡器来确定开关频率。电源控制器内的一个专用振荡器电路通常产生这一时钟信号。有一类磁滞开关稳压器,即使在输入线路和输出负载变化的情况下,无需时钟,实际上也可以以相对固定的频率工作。图1示出了一种以连续导通模式工作的简化的降压型稳压器。(电感器电流总是保持为正。)输出电压VOUT等于DVIN,其中D为降压开关Q1的占空比,VIN为输入电压。在固定频率工作时的占空系数D为TON/TS,其中TON为Q1的导通时间,TS为开关频率周期1/FS。对电路进行重新安排和元件替换,便可得出如下公式:D=VOUT/VIN=TON/(1/FS)=TONFS。 图1 在典型的降压型稳压器中,输出电压等于开关占空
[电源管理]
固定频率工作的<font color='red'>降压稳压器</font>设计
Vicor发布最新 Cool-Power ZVS 降压稳压器
摘要: PI3526-00-LGIZ 是 48V输入(30-60Vin) Cool-Power ZVS 降压稳压器产品组合的最新成员。PI352x 扩展现有 PI354x 48V 直接至负载点 (PoL) 应用产品组合中较高电流范围的解决方案。PI3526-00-LGIZ 是一款输出12V的降压稳压器,提供高达 18A 的输出电流,采用 10x14 mm LGA SiP 封装。 PI352x 同样提供 Vicor 现有 48V Cool-Power ZVS 降压稳压器的所有业界领先特性。同时,以仅增加约 40% 的封装体积提供比 PI354x 稳压器高 1 倍的功率性能。PI3525-00-LGIZ 只需要一个输出电感器与极
[电源管理]
Vicor发布最新 Cool-Power ZVS <font color='red'>降压稳压器</font>
贸泽电子4月新品推荐
率先引入新品的全球分销商 2018年5月14日 – 致力于快速引入新产品与新技术的业界领先分销商贸泽电子 ( Mouser Electronics ) ,首要任务是提供来自700多家顶尖厂商的最新产品与技术,帮助客户设计出先进产品,并加快产品的上市速度。 贸泽上月发布了超过222款 新品 ,这些产品均可以当天发货。 贸泽上月引入的部分产品包括: Analog Devices LTM8065 Silent Switcher® µModule®稳压器 LTM8065 µModule降压稳压器采用Silent Switcher架构,最大限度降低了电磁兼容 (EMC) 和电磁干扰 (EMI) 辐射,帮助将符
[半导体设计/制造]
贸泽电子4月新品推荐
Intersil扩充12V同步降压稳压器产品阵容
美国加州、MILPITAS --- 2017年4月5日 — 全球领先的半导体解决方案供应商瑞萨电子株式会社(TSE: 6723)子公司Intersil今天宣布,推出五款同步降压稳压器--- ISL85014、ISL85012、ISL85009、ISL85005A和ISL85005,可将12V电源轨电压降低至0.6V的负载点输入电压,适用于MCU、FPGA、内存和外设I/O。ISL850xx系列的这五款最新降压稳压器分别提供14A、12A、9A和5A连续输出电流,以支持工业计算机和可编程逻辑控制器以及电信、测试测量、服务器和存储网络设备。 ISL850xx同步降压稳压器支持3.8V - 18V输入电压和宽输出电流范围,为设计师提
[电源管理]
小广播
最新电源管理文章
换一换 更多 相关热搜器件
