OnSemi公司的NCP1271是一款最新的固定频率电流模式PWM开关控制器,具有为低级声频噪声提供可调节的Soft-Skip待机操作模式,为节省待机功耗内部集成高压启动,过载故障检测定时器,内部锁保护功能特性。本文首先介绍NCP1271、基本特性、内部框图及应用领域,并给出相应设计方案的设计原理图、元器件列表及PCB元件布局图。
The NCP1271 represents a new, pin to pin compatible, generation of the successful 7−pin current mode NCP12XX product series. The controller allows for excellent stand by power consumption by use of its adjustable Soft−Skip mode and integrated high voltage startup
FET. This proprietary Soft−Skip also dramatically reduces the risk of acoustic noise. This allows the use of inexpensive transformers and capacitors in the clamping network. Internal frequency jittering,ramp compensation, timer−based fault detection and a latch input make this controller an excellent candidate for converters where ruggedness and component cost are the key constraints.
NCP1271主要特性:
• Fixed−Frequency Current−Mode Operation with Ramp Compensation and Skip Cycle in Standby Condition
• Timer−Based Fault Protection for Improved Overload Detection
• “Soft−Skip Mode” Technique for Optimal Noise Control in Standby
• Internal High−Voltage Startup Current Source for Lossless Startup
• _5% Current Limit Accuracy over the Full Temperature Range
• Adjustable Skip Level
• Internal Latch for Easy Implementation of Overvoltage and Overtemperature Protection
• Frequency Jittering for Softened EMI Signature
• +500 mA/−800 mA Peak Current Drive Capability
• Sub−100 mW Standby Power can be Achieved
• Pin−to−Pin Compatible with the Existing NCP120X Series
• This is a Pb−Free Device
NCP1271应用领域:
• AC−DC Adapters for Notebooks, LCD Monitors
• Offline Battery Chargers
• Consumer Electronic Appliances STB, DVD, DVDR
图1. NCP1271内部方框图
NCP1271ADAPGEVB方案介绍:
This evaluation board user’s manual presents an example circuit using the NCP1271 (65 kHz version) in a flyback topology. The design steps and subsequent measurements are also included. An Excel based design worksheet is available at www.onsemi.com.
The measurements show that the 19 V, 3.0 A circuit delivers above 85% across a universal input (85 to 265 Vac).The no load standby consumption is 83 mW at 230 Vac and the light load operation is greater than 75% efficient.
NCP1271ADAPGEVB方案原理图:
图2. NCP1271ADAPGEVB方案原理图
NCP1271ADAPGEVB方案材料清单:
PCB元件布局图:
Top View
关键字:NCP1271 保护功能 操作模式 待机功耗
编辑:探路者 引用地址:OnSemiNCP127119V,3.0A通用AC-DC适配器设计方案
推荐阅读最新更新时间:2023-10-17 15:13
Galaxy Z折叠手机具有保护电池功能 限制电池充电提来高寿命
锂离子电池都有一个特定的充电周期,之后就无法提供相同的电池寿命。为了解决这个问题,三星在Galaxy Z Fold 3和Galaxy Z Flip 3中引入了一个新的 “保护电池”功能,以延长新手机电池寿命。 Galaxy Z Fold 3和Galaxy Z Flip 3配备三星最新研发的用户界面One UI 3.1.1,可能不会在美学方面带来大量的变化,但它已经引入了一些功能,旨在让你的设备有更长寿命。其中之一是“保护电池”,根据Sammobile上传的图片,最大电量被限制在85%,用户也可以通过导航进入“更多电池设置”找到这项功能。 这项功能可能没有出现在三星的智能手机中,但它已经在其平板电脑系列中出现了相当长
[手机便携]
意法半导体大幅降低家电、照明及工业设备中的待机功耗
新款离线功率转换器芯片拥有同级领先的零待机功耗,其独特的智能电源管理技术可实现更方便的系统唤醒功能
横跨多重电子应用领域、全球领先的半导体供应商意法半导体(STMicroelectronics,简称ST;纽约证券交易所代码:STM)推出符合国际零待机功耗标准的新电源管理芯片,率先为白色家电(white good)、照明及工业设备提供唤醒功能智能管理方式。这也代表着电能吸血鬼(装置在被关掉或处于闲置状态时仍在消耗电能)将不复存在。
最大限度降低用电设备的待机耗电量(也称:电能吸血鬼)是设计人员长期努力的目标,这也推动了全世界启用IEA等国际组织提出的节能建议,即在2010年和2013年前将电器
[电源管理]
具有完善保护功能的DSP三相SPWM逆变电源设计
1系统介绍 根据结构不同,变频电源可分为直接变频电源与间接变频电源两大类。本文所研究的变频 电源 采用间接 逆变 结构即交-直-交变换过程。首先通过单相全桥整流电路完成交-直变换,然后在DSP控制下把直流电源转换成三相 SPWM 波形供给后级滤波电路,形成标准的正弦波。变频系统控制器采用TI公司推出的业界首款浮点数字信号控制器TMS320F28335,它具有150MHz高速处理能力,具备32位浮点处理单元,单指令周期32位累加运算,可满足应用对于更快代码开发与集成高级控制器的浮点处理器性能的要求。与上一代领先的数字信号处理器相比,最新的F2833x浮点控制器不仅可将性能平均提升50%,还具有精度更高、简化软件开发、兼容定点C28
[电源管理]
LabVIEW之生产者/消费者模式--队列操作
本文章主要是对学习LabVIEW之生产者/消费者模式的学习笔记,其中涉及到同步控制技术-队列、事件、状态机、生产者-消费者模式,这几种技术在在本章中都会有侧重点的进行介绍和总结!
队列同步技术-操作函数
同步控制技术可以实现在多个VI之间或者同一VI 不同县城之间同步任务和交换数据;在LabVIEW中提供了 同步 函数选板,包括通知器、队列、信号量、集合点、事件、首次调用函数,本文主要关注同步控制技术之队列技术:
队列操作函数:
1 获取队列引用 函数
2 元素入队列 和 元素出队列 函数
函数作用:将元素入队列和出队列用(没什么好说的!)
[测试测量]
BAE系统公司研发360多功能车辆保护传感器 360度检测威胁并发送预警
(图片来源:BAE系统公司官网) 据外媒报道, BAE系统公司(BAE Systems)最新推出了360多功能车辆保护(MVP)传感器。作为该公司集成车辆保护系统(VPS)套件的一部分,该传感器提供了更好的能见度、态势感知、威胁警告及对策,以保护装甲车辆和装甲车乘员的安全。 该360 MVP传感器结合了4个高清、视野宽广的多功能摄像头当作VPS的眼睛,为装甲车乘员提供有关周围战场环境的高清图像,从而快速检测和跟踪威胁(从地面部队和小型武器到空中系统)、简易的爆炸装置和导弹。此类传感器在白天、夜间、恶劣天气下,以及具挑战性的自然和人为战场条件下(可能会有雾、尘和烟雾等),都可提供360度的能见度和威胁预警。 BAE系统
[汽车电子]
TI推出集成ESD保护功能的高速CAN收发器
日前,德州仪器 (TI) 宣布推出符合 ISO 11898-2 及 ISO 11898-5 汽车网络标准的两款最新 5V 控制器局域网 (CAN) 收发器。该 HVDA551-Q1 与 HVDA553-Q1 集成支持达 8kV 接触放电及 15kV 空气放电的供电静电放电 (ESD) 保护,不但可降低整体系统成本,缩小尺寸,同时还可提供两种器件配置的高设计灵活性。这两款器件符合美国 OEM 厂商测试的严格要求,无需外部保护二极管及共模线圈。上述产品适用的应用包括汽车车身控制模块、信息娱乐及高级驾驶员辅助系统 (ADAS)、汽车网关节点以及后视摄像头模块等。
HVDA551-Q1 与 HVDA553-Q1 的主要特性与
[汽车电子]
如何测试家电待机功耗?
我们家里的空调、冰箱等家电都贴有一张“中国能效标识”,标明了该家电的能耗等级。你知道这个能耗等级是怎么测试出来的吗?特别是一些小功率设备的待机功耗,其测试方法不同会严重影响结果。 首先让我们来看一个实际测试案例。某工程师用致远电子的功率计PA310测试开关电源的待机功耗。第一次测试时,发现待机功耗达到30mW,比理论值大出很多。测试参数如下图所示: 该工程师非常疑惑,于是与我司技术人员沟通测试方案,在详细了解其测试过程以及仪器参数设置之后,我司技术人员给出了测试建议,修改了部分设置参数以及测试接线方式,得到了真实的待机功耗数据,测试参数如下图所示: 对比上面两张图,可以发现,修改参数和接线后,测试的待机功耗
[测试测量]
德州仪器将模拟保护与数字监控功能进行完美整合
日前,德州仪器 (TI) 宣布推出一款集成热插拔控制与高精度数字电流监控功能的最新高集成保护器件。该 TPS2480 控制器可提供最高精确度的电源使用测量与不同温度下不到 1% 的误差精度,从而可帮助系统设计人员生成详细的系统性能历史记录,预测故障情况,实施高级系统电源健康监控。如欲申请样片,订购评估板,敬请访问: www.ti.com.cn/tps2480-pr 。
具有数字监控功能的电源保护
TPS2480 设计旨在最大限度地降低浪涌电流,保护负载与 FET 免受过流或短路的影响。它不但可控制外部 N 通道 MOSFET 开关,而且还可通过 I2C 接口提供准确的电压、电流以及电源监视功能
[电源管理]
