研究32位Cortex-M3 MCU开发技术
发布者:zuiquan最新更新时间:2011-07-31 手机看文章 扫描二维码
随时随地手机看文章
本文介绍了LM3S9B96 MCU Cortex-M3处理器方框图以及Stellaris? LM3S9B96开发板主要特性,方框图,电路图和扩展板电路图。
  德州仪器(TI)公司Stellaris?所提供一系列的微控制器是首款基于ARM? CortexTM-M3的控制器,它们为对成本尤其敏感的嵌入式微控制器应用方案带来了高性能的32位运算能力。这些具备领先技术的芯片使用户能够以传统的8位和16位器件的价位来享受32位的性能,而且所有型号都是以小占位面积的封装形式提供。
  LM3S9B96微控制器的优势还在于能够方便的运用多种ARM的开发工具和片上系统(SoC)的底层IP应用方案,以及广大的用户群体。另外,该微控制器使用了兼容ARM Thumb?的Thumb2指令集来减少存储容量的需求,并以此达到降低成本的目的。最后,LM3S9B96微控制器与Stellaris?系列的所有成员是代码兼容的,这为用户提供了灵活性,能够适应各种精确的需求。
  为了能够帮助用户产品快速的上市,德州仪器(TI)公司提供了一整套的解决方案,包括评估和开发板、白皮书和应用笔记、方便使用的外设驱动程序库、以及强大的支持、销售和分销商网络。
  LM3S9B96目标应用:
  The Stellaris family is positioned for cost-conscious applications requiring significant control processing and connectivity capabilities such as:
  Remote monitoring
  Electronic point-of-sale (POS) machines
  Test and measurement equipment
  Network appliances and switches
  Factory automation
  HVAC and building control
  Gaming equipment
  Motion control
  Medical instrumentation
  Fire and security
  Power and energy
  Transportation
图1.Stellaris LM3S9B96方框图
  图2.Stellaris LM3S9B96 Cortex-M3处理器方框图
  The Stellaris? LM3S9B96 Development Board provides a platform for developing systems around the advanced capabilities of the LM3S9B96 ARM? Cortex?-M3-based microcontroller.
  The LM3S9B96 is a member of the Stellaris Tempest-class microcontroller family. Tempest-class devices include capabilities such as 80 MHz clock speeds, an External Peripheral Interface (EPI) and Audio I2S interfaces. In addition to new hardware to support these features, the DK-LM3S9B96 board includes a rich set of peripherals found on other Stellaris boards.
  The development board includes an on-board in-circuit debug interface (ICDI) that supports both JTAG and SWD debugging. A standard ARM 20-pin debug header supports an array of debugging solutions.
  The Stellaris? LM3S9B96 Development Kit accelerates development of Tempest-class microcontrollers. The kit also includes extensive example applications and complete source code.
LM3S9B96开发板主要特性:
  The Stellaris? LM3S9B96 Development Board includes the following features.
  Simple set-up—USB cable provides debugging, communication, and power
  Flexible development platform with a wide range of peripherals
  Color LCD graphics display
  – TFT LCD module with 320 x 240 resolution
  – Resistive touch interface
  80 MHz LM3S9B96 microcontroller with 256 K Flash, 96 K SRAM, and integrated Ethernet MAC+PHY, USB OTG, and CAN communications
  – – 8 MB SDRAM (plug-in EPI option board)
  – – EPI break-out board (plug-in option board)
  1 MB serial Flash memory
  Precision 3.00 V voltage reference
  SAFERTOS? operating system in microcontroller ROM
  I2S stereo audio codec
  – Line In/Out
  – Headphone Out
  – Microphone In
  Controller Area Network (CAN) Interface
  10/100 BaseT Ethernet
  USB On-The-Go (OTG) Connector
  – Device, Host, and OTG modes
  User LED and push button
  Thumbwheel potentiometer (can be used for menu navigation)
  MicroSD card slot
  Supports a range of debugging options
  – Integrated In-circuit Debug Interface (ICDI)
  – JTAG, SWD, and SWO all supported
  – Standard ARM? 20-pin JTAG debug connector
  USB Virtual COM Port
  Jumper shunts to conveniently reallocate I/O resources
  Develop using tools supporting Keil? RealView? Microcontroller Development Kit (MDK-ARM), IAR Embedded Workbench, Code Sourcery GCC development tools, Code Red Technologies development tools, or Texas Instruments’ Code Composer Studio? IDE
  Supported by StellarisWare? software including the graphics library, the USB library, and the peripheral driver library
  An optional Flash and SRAM memory expansion board (DK-LM3S9B96-EXP-FS8) is also available for use with the DK-LM3S9B96 development board
  – Works with the External Peripheral Interface (EPI) of the Stellaris microcontroller
  – Provides Flash memory, SRAM, and an improved performance LCD interface
  LM3S9B96开发板包括:
  The Stellaris? LM3S9B96 Development Kit contains everything needed to develop and run a range of applications using Stellaris microcontrollers:
  8 MB SDRAM expansion board
  EPI signal breakout board
  Retractable Ethernet cable
  USB Mini-B cable for debugger use
  USB Micro-B cable for OTG-to-PC connection
  USB Micro-A to USB A adapter for USB Host
  USB Flash memory stick
  microSD Card
  20-position ribbon cable
  CD containing:
  – A supported version of one of the following (including a toolchain-specific Quickstart
  guide):
  – Complete documentation
  – Quickstart application source code
  – Stellaris? Firmware Development Package with example source code
图3.LM3S9B96开发板外形图
图4.DK-LM3S9B96开发板方框图
图5.DK-LM3S9B96开发板电路图(1)
图6.DK-LM3S9B96开发板电路图(2)
图7.DK-LM3S9B96开发板电路图(3)
图8.DK-LM3S9B96开发板电路图(4)
图9.DK-LM3S9B96开发板电路图(5)
图10.DK-LM3S9B96开发板电路图(6)
图11.用于DK-LM3S9B96的FLASH/SRAM/LCD IF扩展板电路图(1)
  图12.用于DK-LM3S9B96的FLASH/SRAM/LCD IF扩展板电路图(2)
引用地址:研究32位Cortex-M3 MCU开发技术
上一篇:研究32位Cortex-M3 MCU开发技术
下一篇:研究32位Cortex-M3 MCU开发技术
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
最新工业控制文章
