基于A4982设计的DMOS微型步进马达驱动技术
发布者:HeavenlySunset最新更新时间:2011-09-29 关键字:于A4982  DMOS  步进马达驱动 手机看文章 扫描二维码
随时随地手机看文章
Allegro公司的A4982是集成了电平转换和过流保护的微型步进马达驱动器,适用于双极步进马达驱动,工作在全步进,半步进,1/4步进和1/6步进模式,输出驱动能力高达35V和±2 A. A4982包括固定的离线电流调节器,兼容3.3V和5V逻辑,睡眠模式电流小于10 μA.本文介绍了A4982主要特性和优势, 功能方框图, 典型应用框图以及LP和ET封装的应用电路和PCB布局框图.
DMOS Microstepping Driver with Translator and Overcurrent Protection
The A4982 is a complete microstepping motor driver with built-in translator for easy operation. It is designed to operate bipolar stepper motors in full-, half-, quarter-, and sixteenth-step modes, with an output drive capacity of up to 35 V and ±2 A.
The A4982 includes a fixed off-time current regulator which has the ability to operate in Slow or Mixed decay modes. The ET package meets customer requirements for no smoke no fire (NSNF) designs by adding no-connect pins between critical output, sense, and supply pins. So, in the case of a pin-to-adjacent-pin short, the device does not cause smoke or fire. Additionally, the device does not cause smoke or fire when any pin is shorted to ground or left open.
The translator is the key to the easy implementation of the A4982. Simply inputting one pulse on the STEP input drives the motor one microstep. There are no phase sequence tables, high frequency control lines, or complex interfaces to program.
The A4982 interface is an ideal fit for applications where a complex microprocessor is unavailable or is overburdened. During stepping operation, the chopping control in the A4982 automatically selects the current decay mode, Slow or Mixed. In Mixed decay mode, the device is set initially to a fast decay for a proportion of the fixed off-time, then to a slow decay for the remainder of the off-time. Mixed decay current control results in reduced audible motor noise, increased step accuracy, and reduced power dissipation.
Internal synchronous rectification control circuitry is provided to improve power dissipation during PWM operation. Internal circuit protection includes: thermal shutdown with hysteresis, undervoltage lockout (UVLO), and crossover-current protection.
Special power-on sequencing is not required. The A4982 is supplied in two surface mount package, the ET, a 5 mm × 5 mm, 0.90 mm nominal overall package height QFN package, and the LP package, a 24-pin TSSOP. Both packages have exposed pads for enhanced thermal dissipation, and are lead (Pb) free (suffix –T), with 100% matte tin plated leadframes.
A4982主要特性和优势:
▪ Low RDS(ON) outputs
▪ Automatic current decay mode detection/selection
▪ Mixed and Slow current decay modes
▪ Synchronous rectification for low power dissipation
▪ Internal UVLO
▪ Crossover-current protection
▪ 3.3 and 5 V compatible logic supply
▪ Thin profile QFN and TSSOP packages
▪ Thermal shutdown circuitry
▪ Short-to-ground protection
▪ Shorted load protection
▪ Low current Sleep mode, < 10 μA
▪ No smoke no fire (NSNF) compliance (ET package)
图1.A4982功能方框图
图2.A4982典型应用框图
图3.A4982 LP封装应用电路和PCB布局框图
图4.A4982 ET封装应用电路和PCB布局框图
关键字:于A4982  DMOS  步进马达驱动 引用地址:基于A4982设计的DMOS微型步进马达驱动技术
上一篇:由单片IC构成的廉价100KHZ V-F转换器
下一篇:基于HT46R73D-3设计的8位OTP MCU应用方案
推荐阅读最新更新时间:2024-03-16 12:42
Allegro MicroSystems, LLC推出全新四路DMOS全桥式PWM电机驱动器IC
美国马萨诸塞州伍斯特市 Allegro MicroSystems, LLC发布全新四路DMOS全桥式驱动器IC A5988,它能够驱动多达两个步进电机或四个直流电机,每一全桥式输出额定值可达1.6A和40V。A5988集成有固定停机时间脉宽调制(PWM)电流稳压器,以及2位非线性DAC(数模转换器),可允许步进电机以整步、半步、以及四分之一步进模式控制,直流电机则能够以正转、反转及自由停机模式(coast modes)控制。PWM电流稳压器采用了Allegro 已获专利的混合衰减模式,以减轻可闻电机噪声、提高步进精度、并降低功耗。新器件面向消费产品和办公室自动化市场,终端应用包括闭路电视(摇摄和斜摄)应用、扫描仪、POS机,以及激
[电源管理]
Allegro MicroSystems, LLC推出全新四路<font color='red'>DMOS</font>全桥式PWM电机<font color='red'>驱动</font>器IC
8位可定址DMOS功率驱动
Allegro公司的A6259KA和A6259KLW集3到8线CMOS译码器和数据锁存、控制电路及DMOS输出于一身,具有存储单线数据于可定址锁存器的多功能功率驱动器,可用做译码器或分工器。其功能框图示于图1。 表1 功能表   输入   定址输出 其他输出 功能 CLEAR ENABLE DATA       H H L L H L L H R R 可定址锁存 H H X R R 存储器 L
[应用]
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
  • ARM裸机篇--按键中断
    先看看GPOI的输入实验:按键电路图:GPF1管教的功能:EINT1要使用GPF1作为EINT1的功能时,只要将GPFCON的3:2位配置成10就可以了!GPF1先配 ...
  • 网上下的--ARM入门笔记
    简单的介绍打今天起菜鸟的ARM笔记算是开张了,也算给我的这些笔记找个存的地方。为什么要发布出来?也许是大家感兴趣的,其实这些笔记之所 ...
  • 学习ARM开发(23)
    三个任务准备与运行结果下来看看创建任务和任运的栈空间怎么样的,以及运行输出。Made in china by UCSDN(caijunsheng)Lichee 1 0 0 ...
  • 学习ARM开发(22)
    关闭中断与打开中断中断是一种高效的对话机制,但有时并不想程序运行的过程中中断运行,比如正在打印东西,但程序突然中断了,又让另外一个 ...
  • 学习ARM开发(21)
    先要声明任务指针,因为后面需要使用。 任务指针 volatile TASK_TCB* volatile g_pCurrentTask = NULL;volatile TASK_TCB* vol ...
  • 学习ARM开发(20)
  • 学习ARM开发(19)
  • 学习ARM开发(14)
  • 学习ARM开发(15)
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
