单片机16进制转10进制程序
发布者:开元轩最新更新时间:2014-02-08 来源: dqjsw关键字:单片机  16进制  10进制 手机看文章 扫描二维码
随时随地手机看文章
单片机16进制转10进制程序
unsigned char d[10];    //用于显示的10位显示缓存
     //16进制to10进制输出子程序:显示数据,起始位,结束位,有无小数点
 void output(unsigned long dd,unsigned char s,unsigned char
 e,unsigned char dip) {
     unsigned long div;
     unsigned char tm[8],i,j;
     div=10000000;
     for (i=0;i<8;i++) {
         tm[i]=dd/div;
         dd%=div;
         div/=10;
     for (i=0;i<6;i++) {
         if (tm[i]!=0) break;
         tm[i]=nul;
     tm[5]|=dip;            //小数点控制,请看“串行LED数码管显示驱动程序”
     j=7;
     for (i=s;i         d[i]=tm[j];
         j--;
 //把显示位5-9位的10进制数转换成为16进制数
 unsigned int input(void) {
     unsigned int dd,dat;
     dd=10000;dat=0;
     for (i=5;i<10;i++) {
         dat+=dd*temp;
         dd/=10;
     return(dat);
 /*    89C51系列CPU编程器接收CPU程序*/
 #i nclude
 #i nclude
 #i nclude
 #define e 8
 #define p 9
 #define l 10
 sbit led=P3^2;
 sbit p27=P2^7;
 sbit p26=P2^6;
 sbit p36=P3^6;
 sbit p37=P3^7;
 sbit rst=P3^3;
 sbit ale=P3^5;
 sbit vpp=P3^4;
 bit b_break;
 unsigned int adds;
 //    13.8mS
 void int_t0(void) interrupt 1 {
     TH0=-100;
     b_break=1;
 void wait(unsigned char w) {
     unsigned int t=w*184;
     b_break=0;
     TL0=-t%256-1;TH0=-t/256;
     while (b_break==0) {}
 void nop(void) {
     _nop_();_nop_();_nop_();_nop_();
 unsigned char command(void) {
     TH0=-100;b_break=0;
     while (RI==0) {if (b_break==1) return(0);}
     RI=0;
     return(SBUF);
 void earsure(unsigned char cpu) {
     switch (cpu) {
     case 1:        //89C51
     case 2:rst=p26=1;p27=p36=p37=0;nop();vpp=1;nop();
         ale=0;wait(110);ale=1;nop();
         break;
     case 3:
     case 4:break;
     case 5:
     case 6:break;
 void program(unsigned char cpu) {
     unsigned int bdata adds=0;
     unsigned char d;
     switch (cpu) {
     case 1:    //89C51
     case 2:
         p36=p37=1;rst=1;
         while (1) {
             TH0=-100;b_break=0;
             while (RI==0) {if (b_break==1) return;}
             RI=0;
             d=SBUF;
             //address
             P0=adds%256;
             P2=adds/256;
             p27=1;
             //data
             P1=d;
             nop();    //48clcl
             //vpp
             vpp=1;
             nop();    //48clcl
             //ale
             ale=0;
             wait(1);//100uS
             ale=1;
             nop();    //10uS
             vpp=0;
             nop();    //48clcl
             p27=0;
             nop();    //48clcl
             P1=0xff;
             TH0=-100;b_break=0;
             while (d!=P1) {if (b_break==1) return;}    //data
polling
             SBUF=d;
             adds++;
         break;
     case 3:
     case 4:
     case 5:
     case 6:break;
 void lock(unsigned char cpu) {
     unsigned char i;
     switch (cpu) {
     case 1:    //89c51
     case 2:
         //lock 1
         rst=p26=p36=p27=p37=1;nop();
         vpp=1;
         nop();
         ale=0;
     //    for (i=0;i<6;i++) wait(100);
         wait(1);
         ale=1;
         nop();
         vpp=0;
         nop();
         //lock 2
         rst=p26=p27=1;p36=p37=0;nop();
         vpp=1;
         nop();
         ale=0;
         wait(1);
         ale=1;
         nop();
         vpp=0;
         nop();
         //lock 3
         rst=p26=p36=1;p27=p37=0;nop();
         vpp=1;
         nop();
         ale=0;
         wait(1);
         ale=1;
         nop();
         vpp=0;
         nop();
         break;
     case 3:
     case 4:
     case 5:
     case 6:break;
 void main(void) {
     unsigned char disp,flash,temp,cpu;
     EA=1;
     SCON=0xd8;PCON=0x80;
     TMOD=0x21;
     TL1=TH1=0xff;TR1=1;
     TH0=-100;ET0=TR0=1;
     flash=0x80;
     while (1) {
         temp=command();
         switch (temp) {
         case 0:
         case 1:        //89c51
         case 2:        //89C52
         case 3:        //80f51
         case 4:        //80F52
         case 5:        //87F51
         case 6:cpu=temp;SBUF=temp;break;//87f52
         case e:SBUF=temp;earsure(cpu);break;    //erasure
         case p:SBUF=temp;program(cpu);break;    //program
         case l:lock(cpu);SBUF=temp;break;    //lock
         default:SBUF=temp;break;
         b_break=0;
         if ((++disp)>flash) {disp=0;led=!led;}
 //HT1380实时时钟驱动程序
 sbit clock_dat=P0^1;
 sbit clock_clk=P0^2;
 sbit clock_rst=P0^3;
 sbit a0=ACC^0;
 sbit a1=ACC^1;
 sbit a2=ACC^2;
 sbit a3=ACC^3;
 sbit a4=ACC^4;
 sbit a5=ACC^5;
 sbit a6=ACC^6;
 sbit a7=ACC^7;
 void clock_out(unsigned char dd) {
     ACC=dd;
     clock_dat=a0;clock_clk=1;clock_clk=0;
     clock_dat=a1;clock_clk=1;clock_clk=0;
     clock_dat=a2;clock_clk=1;clock_clk=0;
     clock_dat=a3;clock_clk=1;clock_clk=0;
     clock_dat=a4;clock_clk=1;clock_clk=0;
     clock_dat=a5;clock_clk=1;clock_clk=0;
     clock_dat=a6;clock_clk=1;clock_clk=0;
     clock_dat=a7;clock_clk=1;clock_clk=0;
 unsigned char clock_in(void) {
     clock_dat=1;
     a0=clock_dat;
     clock_clk=1;clock_clk=0;a1=clock_dat;
     clock_clk=1;clock_clk=0;a2=clock_dat;
     clock_clk=1;clock_clk=0;a3=clock_dat;
     clock_clk=1;clock_clk=0;a4=clock_dat;
     clock_clk=1;clock_clk=0;a5=clock_dat;
     clock_clk=1;clock_clk=0;a6=clock_dat;
     clock_clk=1;clock_clk=0;a7=clock_dat;
     return(ACC);
 unsigned char read_clock(unsigned char ord) {
     unsigned char dd=0;
     clock_clk=0;
     clock_rst=0;
     clock_rst=1;
     clock_out(ord);
     dd=clock_in();
     clock_rst=0;
     clock_clk=1;
     return(dd);
 void write_clock(unsigned char ord,unsigned char dd) {
     clock_clk=0;
     clock_rst=0;
     clock_rst=1;
关键字:单片机  16进制  10进制 引用地址:单片机16进制转10进制程序
上一篇:单片机在太阳能路灯控制器中的设计方案
下一篇:multisim单片机协同仿真
推荐阅读最新更新时间:2024-03-16 13:34
MCS51系列单片机软件抗干扰技术中的误区介绍
单片机中存在这样一种广泛流传的误解:在MCS-51系列单片机中,只要用指令使程序从起始地址开始执行,就可以复位单片机,摆脱干扰。通过一个简单的实验,揭示了软件复位的可靠方法。   有的单片机(如8098)有专门的复位指令,某些增强型MCS-51系统单片机虽然没有复位指令,但片内集成了WATCHDOG电路,故抗干扰也不成问题。而普及型MCS-51系列单片机(如8031和8032)既然无复位指令,又不带硬件WATCHDOS,如果没有外接硬件WATCHDOG电路,就必须采用软件抗干扰技术。常用的软件抗干扰技术有:软件陷阱、指令冗余、软件WATCHDOG等,它们的作用是在系统受干扰时能及时发现,再用软件的方法使系统复位。所谓软件复位
[工业控制]
单片机入门的几点误区
单片机入门的几点误区: 因为传统的教学方法都是一板一眼的,这和中国的教学体制有关。但这不是有效的教学。就我自己的经验和多年来回答初学者的问题中总结了一些更有效的学习方法。这里仅说几个误区吧,其他的学习方法可以在我即将出版的新书《爱上单片机》里找到答案。 误区1,一定要学习汇编才可以入门。学习汇编语言已经是很古老的事情了,实际上不需要会汇编也可以玩好单片机。而且汇编的用处不大,只有精准延时和其他一些很少用的程序才会用汇编语言。入门来讲用C语言是最好的。 误区2,一定要了解单片机的指令集、寄存器才可以入门。依我的观点,那些是没有必要学的,如果学了反而会对单片机失去兴趣。有一些初学者来信和我讲,他在学习单片机的中断原理,认为学好这
[单片机]
单片机串口通信原理和控制程序
我们前边学串口通信的时候,比较注重的是串口底层时序上的操作过程,所以例程都是简单的收发字符或者字符串。在实际应用中,往往串口还要和电脑上的上位机软件进行交互,实现电脑软件发送不同的指令,单片机对应执行不同操作的功能,这就要求我们组织一个比较合理的通信机制和逻辑关系,用来实现我们想要的结果。 本节所提供程序的功能是,通过电脑串口调试助手下发三个不同的命令,第一条指令:buzz on 可以让蜂鸣器响;第二条指令:buzz off 可以让蜂鸣器不响;第三条指令:showstr ,这个命令空格后边,可以添加任何字符串,让后边的字符串在 1602 液晶上显示出来,同时不管发送什么命令,单片机收到后把命令原封不动的再通过串口发送给电脑,以表示
[单片机]
单片机印制电路板的布线与工艺
  印制电路板的设计对 单片机 系统能否抗干扰非常重要。要本着尽量控制噪声源、尽量减小噪声的传播与耦合,尽量减小噪声的吸收这三大原则设计印制电路板和布线。当你设计单片机用印制电路板时,不仿对照下面的条条检查一下。   ·印制电路板要合理区分,单片机系统通常可分三区,即模拟电路区(怕干扰),数字电路区(即怕干扰、又产生干扰),功率驱动区(干扰源)。   ·印刷板按单点接电源、单点接地原则送电。三个区域的电源线、地线由该点分三路引出。噪声元件与非噪声元件要离得远一些。   ·时钟振荡电路、特殊高速逻辑电路部分用地线圈起来。让周围电场趋近于零。   ·I/O驱动器件、功率放大器件尽量靠近印刷板的边,靠近引出接插件。   ·能用
[单片机]
基于MSP430单片机的Profibus-DP通信接口
O 引言   Profibus是开放的、与制造商无关、无知识产权保护的标准。因此世界上任何人都可以获得该标准并设计各自的软硬件解决方案。Pro-fibus-DP通信接口的开发有两种方案选择:单片机+软件;单片机+Profibus通信芯片ASIC。   方案2中Profibus-DP协议完全由Profibus通信ASIC来实现,单片机主要处理用户程序。因此方案2开发周期相对少很多,本文将采用单片机+Profibus通信ASIC来实现Profibus通信接口的设计。   1 Profibus-DP基本特性   Profibus包括三个兼容系列:Profibus-FMS,Profibus-DP,Profibus-PA。F
[单片机]
基于单片机STC89C52RC的汽车中网扫描灯设计
    摘 要: 生活水平的不断提高使汽车逐步走进了千家万户。追求时尚个性的心理使车主们费尽心思装扮自己的爱车。汽车LED中网扫描灯既彰显个性,又可以起到警示作用,甚至还有一个好听的名字叫游侠灯。本文介绍一款汽车中网扫描灯的设计制作方法。它主要采用了常见的STC89C52RC单片机作为主控制器,采用光电耦合器进行信号转换,用市场上采购的食人鱼LED灯条改装成八组LED扫描灯。能够产生拖尾和呼吸等效果,还可以进行底盘灯和无线遥控等功能的扩展。    0 引言   LED产业的迅猛发展给照明和装饰都带来了不小的冲击,特别是LED与汽车的结合更是当前的热门话题。汽车中的阅读灯、示宽灯、刹车灯,甚至照明大灯都渐渐出现了LED的身影。当
[汽车电子]
基于<font color='red'>单片机</font>STC89C52RC的汽车中网扫描灯设计
全球车市的颓靡,法兰克福车展遭多家车企爽约
法兰克福车展德语名称 为 Internationale Automobil-Ausstellung ,意思为 国际汽车展览 ,多简称为IAA。2013年法兰克福车展主题是 电动化 。法兰克福汽车展,创 办于1897年,素有世界汽车工业 奥运会 之称,是世界最重要和最全面的汽车工业成就展,由德国汽车工业协会(VDA)主办。该展会每逢奇数年在法兰克 福展示乘用车(IAA Cars),偶数年在汉诺威展示商用车(IAA Commercial Vehicles),目前已成功举行了64届,本年度为第65届,参展的商家主要来自欧洲、美国和日本,尤其以欧洲汽车商居多。 全球车市的颓靡,正逐步蔓延至汽车电子领域。 9月10日的法兰克福,即将
[嵌入式]
基于C8051F000的多通道数据采集范围控制系统
1 引 言      在实际应用中,对被控对象的物理参数(温度、湿度、位移、电流、电压等)在一定的范围内进行控制,是单片机的典型应用之一。很多宏观要求精确控制的场合,其微观控制过程,仍可归结为是对某些参数变化范围的控制。如,传统的三相异步电机从启动到正常运行,其电流、电压和温度的变化;抽水塔水位的变化;机床刀具的行程变化及数字电表的自动量程变换等。这些控制过程最显著的特点是:被控物理量都是一个变化范围,而非某一个精确的“点”。有效控制物理量变化范围的方法很多,本文重点介绍利用C8051F000单片机片内8路高性能的12位ADC数据采集系统和可编程窗口检测器,实现对多路参数变化范围控制的硬件组成和软件设计方法。 2 C805
[应用]
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
