12864液晶的超声波测距与语音播报电路及程序
发布者:luanzgc最新更新时间:2015-01-14 来源: 51hei关键字:12864液晶  超声波测距  语音播报 手机看文章 扫描二维码
随时随地手机看文章
器件清单:
单片机 瓷片电容0.1uf 电解电容10uf 电解电容220uf 电解电容4.7uf 0.001uf(瓷片电容) 22PF(瓷片电容) LED小灯(5mm) 语音芯片 12864液晶 喇叭 咪头(话筒)六脚插件(插针)四脚插件(插针)三脚插件(插针) 电阻  1k 电位器1k 独立按键(两脚) 晶振。
代码如下:代码还需要调试[page]
 #include
 #include
//超声波引脚定义
    sbit     RX    P1 ^ 1; //接超声波模块的Echo引脚
    sbit     TX    P1 ^ 2; //接超声波模块的Trig引脚。
//LCD12864引脚定义
    sbit     CS    P2 ^ 5; //片选 高电平有效 单片LCD使用时可固定高电平   接RS 引脚
    sbit     SID   P2 ^ 6; //数据 接RW引脚
    sbit     SCLK  P2 ^ 7; //时钟 接E引脚
//ISD1820引脚定义
    sbit     REC   P2 ^ 4; //
sbit     PLAYE =  P2 ^ 3; //
sbit     PLAYL =  P2 ^ 2;   //
//Function Definition 函数声明
void Delay(int num);
void Init_DS18B20(void);
unsigned char ReadOneChar(void);
void WriteOneChar(unsigned char dat);
unsigned int ReadTemperature(void);
void clock_out(unsigned char dd);
unsigned char clock_in(void);
unsigned char read_clock(unsigned char ord);
void write_clock(unsigned char ord, unsigned char dd);
void Disp(void);
void id_case1_key(void);
void id_case2_key(void);
void Set_time(unsigned char sel,bit sel_1);
void Timer0_Init(void);
void Init_1302(void);
void Set_Bell(unsigned char sel, bit sel_1);
void Bell(void);
//12864
void Write_char(bit start, unsigned char ddata);
void Send_byte(unsigned char bbyte);
void Delaynms(unsigned int di);
void Lcd_init(void);
void Disp_img(unsigned char *img);
void LCD_Write_string(unsigned char X,unsigned char Y,unsigned char *s);
void LCD_set_xy( unsigned char x, unsigned char y );
unsigned char code num[]={"0123456789 :.-"};
unsigned char code waves[]={"超声波测距系统"};
unsigned char code znwk[] ={"距离:"};
unsigned char code CM[] =  {"M"};
unsigned int  time=0;
         long S=0;
         bit  flag =0;
unsigned char disbuff[4]   ={ 0,0,0,0,};
unsigned char code logo[]={
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0xE0,0x00,0x00,0x0C,0x00,0x00,0x40,0x70,0x00,0x00,0x00,0x80,0x00,
0x00,0x00,0x00,0xE0,0x00,0x00,0x1E,0x00,0x00,0x60,0x70,0x00,0x00,0x0F,0xE0,0x00,
0x00,0x00,0x01,0xC0,0x00,0x60,0x3C,0x00,0x00,0xE0,0x60,0x00,0x1F,0xFF,0xE0,0x00,
0x00,0x00,0x03,0x80,0x00,0x70,0x70,0x40,0x00,0xE0,0x7E,0x00,0x1F,0xE0,0xC0,0x00,
0x00,0x00,0x03,0x00,0x00,0x73,0xC3,0xF0,0x01,0xC3,0xFC,0x00,0x38,0xE1,0xC0,0x00,
0x00,0x03,0xC6,0x3C,0x00,0x33,0x9F,0xF0,0x03,0x8F,0xC0,0x00,0x30,0xC1,0xC0,0x00,
0x00,0x3F,0xEF,0xFE,0x00,0x03,0x1C,0xE0,0x07,0x01,0xCC,0x00,0x31,0xF1,0x80,0x00,
0x00,0x79,0xDF,0xBC,0x00,0x06,0x18,0xC0,0x0E,0x01,0xFE,0x00,0x77,0xF9,0x80,0x00,
0x00,0x01,0xB0,0x30,0x01,0xC6,0x19,0xC0,0x1E,0x7F,0xDE,0x00,0x6F,0x83,0x80,0x00,
0x00,0x23,0xAC,0x60,0x0F,0xE6,0xF1,0x80,0x3E,0x7B,0x38,0x00,0x61,0x83,0x00,0x00,
0x00,0x37,0x0E,0x00,0x0F,0xC7,0xB7,0x80,0xEC,0x63,0x30,0x00,0xE3,0x03,0x00,0x00,
0x00,0x3E,0x0E,0x00,0x01,0x8F,0x37,0x01,0xCC,0x6F,0xF0,0x00,0xC7,0xF7,0x00,0x00,
0x00,0x1E,0x0C,0x00,0x03,0x1E,0x66,0x03,0x0C,0x7F,0x00,0x01,0xFF,0xE6,0x00,0x00,
0x00,0x1E,0x1C,0x00,0x03,0x1C,0x60,0x02,0x19,0xAC,0x00,0x01,0x96,0x06,0x00,0x00,
0x00,0x3E,0x3E,0x00,0x03,0x18,0x60,0x00,0x19,0xFC,0x00,0x03,0x86,0x0E,0x00,0x00,
0x00,0x7E,0x36,0x00,0x03,0x00,0xC0,0x00,0x38,0x78,0x00,0x03,0x06,0x0C,0x00,0x00,
0x00,0xE6,0x67,0x00,0x03,0x00,0xC0,0x00,0x30,0x78,0x00,0x06,0x0C,0x0C,0x00,0x00,
0x01,0xC6,0xC3,0x80,0x7F,0xF0,0xC0,0x00,0x30,0xFE,0x00,0x0E,0x0C,0x1C,0x00,0x00,
0x03,0x81,0x83,0xC0,0x78,0xFF,0x80,0x00,0x61,0xCF,0x80,0x1C,0x08,0x18,0x00,0x00,
0x06,0x07,0x03,0xE0,0x00,0x1F,0xFF,0xE0,0x67,0x07,0xE0,0x38,0x18,0xF8,0x00,0x00,
0x08,0x0E,0x01,0xF8,0x00,0x07,0xFF,0x80,0xCE,0x03,0xF8,0x60,0x00,0x70,0x00,0x00,
0x00,0x18,0x01,0xF8,0x00,0x01,0xFC,0x00,0xC0,0x01,0xFC,0xC0,0x00,0x70,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x06,0x00,0x00,0x00,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x07,0x00,0x00,0x00,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x06,0x00,0x00,0x00,0x0C,0xE0,0x00,0x01,0xE0,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x0E,0x00,0x00,0x00,0x3F,0xE0,0x00,0xFF,0xF0,0x00,0x38,0x00,0xE0,0x00,
0x00,0x00,0x0C,0x00,0x00,0x0F,0xFF,0x80,0x00,0xF8,0xF0,0x00,0x38,0x00,0xE0,0x00,
0x00,0x00,0x0C,0xF0,0x00,0x0F,0xC7,0x00,0x00,0x60,0xE0,0x00,0x38,0x00,0xE0,0x00,
0x00,0x00,0x1F,0xF0,0x00,0x01,0x8E,0x00,0x00,0x60,0xC0,0x00,0x70,0x01,0xC0,0x00,
0x00,0x07,0xFF,0x80,0x00,0x01,0x8C,0x00,0x00,0xE1,0x80,0x00,0x70,0x01,0xC0,0x00,
0x00,0x07,0xF8,0x00,0x00,0x01,0x98,0x00,0x00,0xDF,0xC0,0x00,0x70,0x01,0xC0,0x00,
0x00,0x00,0x78,0x00,0x00,0x01,0xBF,0xE0,0x00,0xFF,0x00,0x00,0x60,0x01,0x80,0x00,
0x00,0x00,0xFC,0x00,0x00,0x7F,0xFF,0xE0,0x00,0xC0,0x00,0x00,0xE0,0x03,0x80,0x00,
0x00,0x01,0xFE,0x00,0x00,0x7F,0xF8,0x00,0x00,0x00,0x00,0x00,0xC0,0x03,0x00,0x00,
0x00,0x03,0xB7,0x00,0x00,0x60,0x00,0x00,0x00,0x00,0x3C,0x00,0xC0,0x03,0x00,0x00,
0x00,0x07,0x67,0x00,0x00,0x60,0x00,0x00,0x03,0x9F,0xFE,0x00,0x80,0x02,0x00,0x00,
0x00,0x0E,0x63,0x80,0x00,0xE0,0x00,0x01,0xFF,0xCF,0x1E,0x01,0x80,0x06,0x00,0x00,
0x00,0x1C,0xE1,0xE0,0x00,0xC0,0x00,0x00,0xE3,0x9C,0x38,0x01,0x80,0x06,0x00,0x00,
0x00,0x38,0xC1,0xF8,0x01,0xC0,0x00,0x00,0xC3,0x18,0x30,0x00,0x00,0x00,0x00,0x00,
0x00,0xE0,0xFC,0xFE,0x03,0x80,0x00,0x01,0xC7,0x18,0x60,0x00,0x00,0x00,0x00,0x00,
0x01,0xDF,0xF8,0xFE,0x03,0x00,0x00,0x01,0x8E,0x1B,0xE0,0x07,0x00,0x1C,0x00,0x00,
0x07,0x07,0x80,0x00,0x07,0x00,0x00,0x01,0xFF,0x3F,0xE0,0x07,0x00,0x1C,0x00,0x00,
0x0C,0x03,0x80,0x00,0x0E,0x00,0x00,0x01,0xF0,0x38,0x00,0x0F,0x00,0x3C,0x00,0x00,
0x00,0x03,0x00,0x00,0x1C,0x00,0x00,0x01,0x00,0x20,0x00,0x06,0x00,0x18,0x00,0x00,
0x00,0x03,0x00,0x00,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x03,0x00,0x00,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x02,0x00,0x01,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
void Lcd_init(void) //初始化LCD
Delaynms(10); //启动等待,等LCM讲入工作状态
  CS=1;
  Write_char(0,0x30);  //8 位介面,基本指令集
  Write_char(0,0x0c);  //显示打开,光标关,反白关
  Write_char(0,0x01);  //清屏,将DDRAM的地址计数器归零
void Write_char(bit start, unsigned char ddata) //写指令或数据
unsigned char start_data,Hdata,Ldata;
  if(start==0)
start_data=0xf8; //写指令
    else
    start_data=0xfa;  //写数据
  Hdata=ddata&0xf0;  //取高四位
  Ldata=(ddata<<4)&0xf0;  //取低四位
  Send_byte(start_data);  //发送起始信号
  Delaynms(5); //延时是必须的
  Send_byte(Hdata);      //发送高四位
  Delaynms(1);  //延时是必须的
  Send_byte(Ldata);  //发送低四位
void Send_byte(unsigned char bbyte) //发送一个字节
unsigned char i;
  for(i=0;i<8;i++)
    SID=bbyte&0x80; //取出最高位
  SCLK=1;
    SCLK=0;
    bbyte<<=1; //左移
void Delaynms(unsigned int di) //延时
unsigned int da,db;
  for(da=0;da
    for(db=0;db<10;db++);
void Disp_img(unsigned char  *img) //图形方式12864显示字模221 横向取膜
unsigned char i,j;
unsigned int k = 0;
Write_char(0,0x36); //图形方式
for(i=0;i<32;i++)
Write_char(0,0x80+i);
Write_char(0,0x80);
    for(j=0;j<16;j++)
Write_char(1,img[k++]);
  for(i=0;i<32;i++)
Write_char(0,0x88);
    for(j=0;j<16;j++)
void Clr_Scr(void)//清屏函数
Write_char(0,0x01);
{ //设置LCD显示的起始位置,X为行,Y为列
    unsigned char address;
switch(x)
case 0: address = 0x80 + y; break;
    case 1: address = 0x80 + y; break;
case 2: address = 0x90 + y; break;
    case 3: address = 0x88 + y; break;
case 4: address = 0x98 + y; break;
default:address = 0x80 + y; break;
    Write_char(0, address);
{ // 中英文字符串显示函数
LCD_set_xy( X, Y );
    while (*s)
Write_char( 1, *s );
   s ++;
Delaynms(1);
void LCD_Write_number(unsigned char s)// 数字显示函数
Write_char(1,num[s]);
Delaynms(1);
void Lcd_Mark2(void)
Clr_Scr();//清屏
LCD_Write_string(1,0,znwk);//
LCD_Write_string(2,0,waves);//
LCD_Write_string(3,7,CM);//
 void Conut(void) //计算距离,如果更改精度可在此修改
  time=TH0*256+TL0;
  TH0=0;
  TL0=0;
  S=time*1.87/100;       //算出来是CM  11。0592M晶振   须修改
  if(S>200)          //这里需要调试
  PLAYE=1;
Delaynms(1);
PLAYE=0;
  if(flag==1)      //超出测量
  flag=0;
  LCD_set_xy( 3, 4 );
  LCD_Write_number(13);
  LCD_Write_number(12);
  LCD_set_xy( 3, 5 );
else
  disbuff[1]=S00/100;
  disbuff[2]=S000/10;
  disbuff[3]=S00 ;
  LCD_set_xy( 3, 4 );
  LCD_Write_number(disbuff[1]);
  LCD_set_xy( 3, 5 );
  LCD_Write_number(disbuff[2]);
  LCD_Write_number(disbuff[3]);
void delayms(unsigned int ms)
unsigned char i=100,j;
for(;ms;ms--)
while(--i)
j=10;
while(--j);
     void zd0() interrupt 1 //T0中断用来计数器溢出,超过测距范围
    flag=1; //中断溢出标志
   void  StartModule()         //T1中断用来扫描数码管和计800MS启动模块
 TX=1;                 //800MS  启动一次模块
 _nop_();
 _nop_();
 _nop_();
 _nop_();
 _nop_();
 _nop_();
 _nop_();
 _nop_();
 _nop_();
 _nop_();
 _nop_();
 _nop_();
 _nop_();
 _nop_();
 _nop_();
 _nop_();
 _nop_();
 _nop_();
 _nop_();
 _nop_();
 _nop_();
 TX=0;
void main(void)
    TMOD=0x01;   //设T0为方式1,GATE=1
TH0=0;
TL0=0;
TR0=1;
Lcd_init();       //设置液晶显示器
Clr_Scr();        //清屏
Disp_img(logo);  //显示欢迎使用本产品LOGO
Delaynms(1000);
Lcd_init();       //从图形显示状态下返回
    Lcd_Mark2();
REC=0;  //录音先录好   如果不能先录好这里就有可能不能用
PLAYE=0;  //上升沿触发
PLAYL=0;  //高电平触发
while(1)
StartModule();
        //计算
while(!RX); //当RX为零时等待
TR0=1;    //开启计数
while(RX); //当RX为1计数并等待
TR0=0; //关闭计数
Conut();
delayms(80); //80MS
关键字:12864液晶  超声波测距  语音播报 引用地址:12864液晶的超声波测距与语音播报电路及程序
上一篇:单片机最小系统_按键控制数码管显示
下一篇:基于51单片机DS1302四位数码管可调时钟
推荐阅读最新更新时间:2024-03-16 13:50
LCD12864中文液晶屏显示
单片机源程序如下: /* ***************************************************** */ /* ***************************************************** */ // 工 程 : 51单片机开发板 // 文件名 : LCD12864.c // 处理器 : STC89C52RC // 编译环境 : Keil4 C51 // 系统时钟 : 11.0592MHZ // 版 本 : V1.0 // 生成日期 : 2017-09-20 // 修改日期
[单片机]
LCD<font color='red'>12864</font>中文<font color='red'>液晶</font>屏显示
12864-ST7920液晶绘图的介绍
基于ST7920控制的12864液晶用于字符显示很方便的,但网友说用它显示图形并不合适,原因就是它绘图时先要关闭显示,绘完后又要打开,速度会较慢。我没有用过别的液晶,手中只有这一款,摆弄了几天,掌握了一点东西, 写出来共享。 首先,我们知道,图形都是由像素点组成的,绘图的基础其实就是画点。只要我们能点亮液晶的任意一个像素点,那么绘图就不是什么难事了。万丈高楼平地起嘛,先要做的,当然是要打好基础。 ST7920提供了用于绘图的GDRAM(graph display RAM)。共 64×32 个字节的空间(由扩充指令设定绘图 RAM 地址),最多可以控制 256×64点阵的二维绘图缓冲空间。在它的Da tasheet给出了GD
[单片机]
<font color='red'>12864</font>-ST7920<font color='red'>液晶</font>绘图的介绍
超声波测距测温的工作原理
超声波测距测温的工作原理是:超声波数字测距是利用超声波发射, 通过被测物体的反射回波接收后的时差来测量被测距离的,是一种非接触式测量仪器.因超声波在大气中的传波速度与温度有关,如0摄氏度时每秒为331.36米,20摄氏度时每秒为343.38米.因此该测距测温控制器采用了温度传感器DS18B20,把随环境温度变化的信号送入 单片机 ,MCU读取外界温度变化的数值后进行内部运算,并校正各种环境温度下测距的误差值,利用该功能方便地实现了测温显示. 使用超声波测距器利用了超声波在空气中传播特性,它有很多特点如: 测定物位距离时不接触被测物体,无活动部分,安装,调试简单,无维修,保养方便,测量精度高,作为物位测量控制器. 测量控制料位
[单片机]
<font color='red'>超声波测距</font>测温的工作原理
基于声光探测的汽车定位系统
汽车定位系统用于检测汽车停车位置参数和车箱几何参数,为机械手在车箱范围内作业提供平面坐标数据,是车载货物自动作业控制系统的组成部分。目前的汽车定位系统多用齿轮传动的机械移位红外线扫描方式或基于视频图像的人工画界方式,前者定位速度慢,后者定位精度低,可靠性差,都难以满足实际定位对速度、精度和可靠性的要求。文中采用红外线电子移位逐行高速扫描技术和超声波测距技术实现汽车定位,具有可调定位速度和适应恶劣天气的能力,还采用多种措施,提高系统的抗干扰能力和可维护性能,实现了快速、高精度、高可靠定位的目标。利用Delphi开发主控软件,实现数据处理,完成定位结果的显示、输出,工作参数设置和状态检测,具有良好的开放性,方便与各种控制系统接口。
[嵌入式]
基于STM32F411的cm级超声波测距系统
本项目通过HC-SR04超声波传感器和STM32F411开发板,以精确到cm的精度测量目标物体的距离。 STM32F411RE开发板 x1 HC-SR04超声波传感器 x1 跳线 若干 其中,HC-SR04超声波传感器可以0.3cm精度读取2-400cm范围距离,而且超声波发射器和接收器组合在一起,适合大多数个人爱好项目。主要性能包括: 工作电源:5VDC 工作电流:15mA 工作频率:40KHz 最大距离:4m 最小距离:2cm 测量角度:15度 分辨率:0.3cm 触发输入信号:10uS TTL脉冲 回升输出信号:TTL脉冲,与测量成距离成正比 当传感器接收到一个触发信号,就发出一个40KHz突发信号
[单片机]
基于STM32F411的cm级<font color='red'>超声波测距</font>系统
12864LCD液晶显示屏中文资料
一、 概述 二、 带中文字库的128X64是一种具有4位/8位并行、2线或3线串行多种接口方式,内部含有国标一级、二级简体中文字库的点阵图形液晶显示模块;其显示分辨率为128×64, 内置8192个16*16点汉字,和128个16*8点ASCII字符集.利用该模块灵活的接口方式和简单、方便的操作指令,可构成全中文人机交互图形界面。可以显示8×4行16×16点阵的汉字. 也可完成图形显示.低电压低功耗是其又一显著特点。由该模块构成的液晶显示方案与同类型的图形点阵液晶显示模块相比,不论硬件电路结构或显示程序都要简洁得多,且该模块的价格也略低于相同点阵的图形液晶模块。 三、 基本特性: (1)、低电源电压(VDD:+3.0-
[单片机]
STC89C51单片机对超声波测距学习板的控制原理解析
1.功能 超声波测距学习板可应用于汽车倒车、建筑施工工地以及一些工业现场的位置监控,也可用于如液位、井深、管道长度的测量等场合。要求测量范围在0-27~4.00m,测量精度1cm,测量时与被测物体无直接接触。能够清晰稳定地显示测量结果。 2.基本原理 超声波发生器内部结构有两个压电晶片和一个共振板。当它的两极外加脉冲信号,其频率等于压电晶片的固有振荡频时,压电晶片将会发生共振,并带动共振板振动,便产生超声波。反之,如果两电极间未外加电压,当共振板接收到超声波本时,将压迫压电晶片作振动,将机械能转换为电信号,就成为超声波接收器。在超声探测电路中,发射端得到输出脉冲为一系列方波,其宽度为发射超声的时间间隔,被测物距离越大,脉冲宽度
[单片机]
STC15单片机使用HC-SR04超声波测距模块
【HC-SR04】 HC-HR04超声波测距可提供2cm-400cm的非接触式距离感测功能,测距精度可达3mm。 基本工作原理 1、采用IO口TRIG触发测距,给最少10us的高电平信呈。 2、模块自动发送8个40KHz的方波,自动检测是否有信号返回。 3、有信号返回,通过IO口ECHO输出一个高电平,高电平持续时间就是超声波从发射到返回的时间。测试距离=(高电平时间*声速(340m/s))/2. 时序图 以上时序图表明你只需要提供一个10uS以上脉冲触发信号,该模块内部将:发出8个40kHz周期电平并检测回波。一.旦检测到有回波信号则输出回响信号。回响信号的脉冲宽度与所测的距离成正比。由此通过发射信号
[单片机]
STC15单片机使用HC-SR04<font color='red'>超声波测距</font>模块
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
