#define uchar unsigned char #define uint unsigned int char b[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6, 0xa1,0x86,0x8e,0x8c,0xc1,0xce,0x91,0x89,0xc7,0xff}; // 共阴极字符码 //延时函数,用于实现程序中的短暂延时,表示延时cnt个毫秒 void delay(unsigned int cnt) { unsigned char i; while(cnt--) { for(i=220;i>0;i--) ; } } //键盘扫描程序 uchar keyboardscan(void) { uchar sccode,recode; P1=0xf0; //P1口附初值 if((P1&0xf0)!=0xf0)//如果P1口电平不等于0xf0,表示有按键按下 { delay(20); //延时20毫秒后再判断,看是否还有按键按下,次步为软件防抖 if((P1&0xf0)!=0xf0)//继续判断是否有按键按下 { sccode=0xfe; //进行逐行判断 while((sccode&0x10)!=0) { P1=sccode; if((P1&0xf0)!=0xf0) { recode=(P1&0xf0|0x0f); switch((~sccode)+(~recode)) { // 下面是键盘的编码识别 case 0x11: return(1); break; case 0x21: return(2); break; case 0x41: return(3); break; case 0x81: return(11); break;//返回对应的键值0~15 case 0x12: return(4); break; case 0x22: return(5); break; case 0x42: return(6); break; case 0x82: return(12); break; case 0x14: return(7); break; case 0x24: return(8); break; case 0x44: return(9); break; case 0x84: return(13); break; case 0x18: return(10); break; case 0x28: return(15); break; case 0x48: return(16); break; case 0x88: return(14); break; default:break; } } else sccode = (sccode<<1)|0x01; } } } return(0xff); //如果没有按键按下,则返回0xff } void output(uchar number) { P0=b[number/10]; P2=b[number%10]; } int yunsuan(uchar a,uchar b,uchar c) { switch(c) { case 1:return(a/b);break; case 2:return(a*b);break; case 3:return(a-b);break; case 4:return(a+b);break; } } void main(void) //主函数 { unsigned char n1,n2,key,index,a; n1=n2=index=0; P0=P2=b[0]; while(1) { key = keyboardscan();//键盘扫描,看是否有按键按下 if(key != 0xff)//如果有按键按下,则key不再是0xff了,显示该按键键值 { if(key<10) { if(!index) n1=key%10; else n2=key%10; output(key%10); } else if(key==15) { n1=n2=index=0; output(0); } else if(key==16) { if(!index) output(n1); else { a=yunsuan(n1,n2,index); a=a%100; output(a); n1=a; n2=index=0; } } else { if(index==0||n2==0) index=key-10; else { a=yunsuan(n1,n2,index); a=a%100; output(a); n1=a; n2=0; index=key-10; } } } } }
上一篇:51单片机驱动超声波测距模块C51程序
下一篇:51单片机驱动1602液晶的C程序
推荐阅读最新更新时间:2024-03-16 14:04
设计资源 培训 开发板 精华推荐
- 科学家研发基于AI的身份验证工具 可保护车辆免受网络攻击威胁
- Microchip推出广泛的IGBT 7 功率器件组合,专为可持续发展、电动出行和数据中心应用而设计
- 面向未来驾驶体验 博世推出新型微电子技术
- 英飞凌与马瑞利合作 利用AURIX™ TC4x MCU系列推动区域控制单元创新
- 5C超充,该怎么卷?
- 《2025年度中国汽车十大技术趋势》正式揭晓!你最看好哪个?
- Microchip推出新型VelocityDRIVE™软件平台和车规级多千兆位以太网交换芯片,支持软件定义汽车
- 英特尔中国正式发布2023-2024企业社会责任报告
- can转485数据是如何对应的
- MCU今年的重点:NPU和64位
