#include#define INT8U unsigned char #define INT16 Uunsigned int #define WRITE_BURST 0x40//连续写入 #define READ_SINGLE 0x80//读 #define READ_BURST 0xC0//连续读 #define BYTES_IN_RXFIFO 0x7F //接收缓冲区的有效字节数 #define CRC_OK 0x80 //CRC校验通过位标志 //**************CC1100接口********* sbit GDO0=P3^3; sbit GDO2=P1^4; sbit MISO=P1^2; sbit MOSI=P1^1; sbit SCK=P3^2; sbit CSN=P1^3; //***********按键**************** sbit KEY1 =P3^6; sbit KEY2 =P3^7; //***************数码管位选**************** sbitled3=P2^0; sbitled2=P2^1; sbitled1=P2^2; sbitled0=P2^3; //***************蜂鸣器*********************** sbit BELL=P3^4; //***************温度传感器***************** sbit DQ=P3^5 ; //******************************************** INT8U seg[10]={0xC0,0xCF,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90}; //0~~9段码 INT8U seg1[10]={0x40,0x4F,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10}; INT8U data temp_data[2]={0x00,0x00}; INT8U dispaly[8]; //更多功率参数设置可详细参考DATACC1100英文文档中第48-49页的参数表 INT8U PaTabel[8] = {0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60}; //0dBm void SpiInit(void); void CpuInit(void); void RESET_CC1100(void); void POWER_UP_RESET_CC1100(void); void halSpiWriteReg(INT8U addr, INT8U value); void halSpiWriteBurstReg(INT8U addr, INT8U *buffer, INT8U count); void halSpiStrobe(INT8U strobe); INT8U halSpiReadReg(INT8U addr); void halSpiReadBurstReg(INT8U addr, INT8U *buffer, INT8U count); INT8U halSpiReadStatus(INT8U addr); void halRfWriteRfSettings(void); void halRfSendPacket(INT8U *txBuffer, INT8U size); INT8U halRfReceivePacket(INT8U *rxBuffer, INT8U *length); //**************** void delay1(INT16U i); void ds_reset(void); void write_byte(INT8U value); INT8U read_byte(void); void read_temp(); void work_temp(); //******************** // CC1100 STROBE, CONTROL AND STATUS REGSITER #define CCxxx0_IOCFG2 0x00 // GDO2 output pin configuration #define CCxxx0_IOCFG1 0x01 // GDO1 output pin configuration #define CCxxx0_IOCFG0 0x02 // GDO0 output pin configuration #define CCxxx0_FIFOTHR 0x03 // RX FIFO and TX FIFO thresholds #define CCxxx0_SYNC1 0x04 // Sync word, high INT8U #define CCxxx0_SYNC0 0x05 // Sync word, low INT8U #define CCxxx0_PKTLEN 0x06 // Packet length #define CCxxx0_PKTCTRL1 0x07 // Packet automation control #define CCxxx0_PKTCTRL0 0x08 // Packet automation control #define CCxxx0_ADDR 0x09 // Device address #define CCxxx0_CHANNR 0x0A // Channel number #define CCxxx0_FSCTRL1 0x0B // Frequency synthesizer control #define CCxxx0_FSCTRL0 0x0C // Frequency synthesizer control #define CCxxx0_FREQ2 0x0D // Frequency control word, high INT8U #define CCxxx0_FREQ1 0x0E // Frequency control word, middle INT8U #define CCxxx0_FREQ0 0x0F // Frequency control word, low INT8U #define CCxxx0_MDMCFG4 0x10 // Modem configuration #define CCxxx0_MDMCFG3 0x11 // Modem configuration #define CCxxx0_MDMCFG2 0x12 // Modem configuration #define CCxxx0_MDMCFG1 0x13 // Modem configuration #define CCxxx0_MDMCFG0 0x14 // Modem configuration #define CCxxx0_DEVIATN 0x15 // Modem deviation setting #define CCxxx0_MCSM2 0x16 // Main Radio Control State Machine configuration #define CCxxx0_MCSM1 0x17 // Main Radio Control State Machine configuration #define CCxxx0_MCSM0 0x18 // Main Radio Control State Machine configuration #define CCxxx0_FOCCFG 0x19 // Frequency Offset Compensation configuration #define CCxxx0_BSCFG 0x1A // Bit Synchronization configuration #define CCxxx0_AGCCTRL2 0x1B // AGC control #define CCxxx0_AGCCTRL1 0x1C // AGC control #define CCxxx0_AGCCTRL0 0x1D // AGC control #define CCxxx0_WOREVT1 0x1E // High INT8U Event 0 timeout #define CCxxx0_WOREVT0 0x1F // Low INT8U Event 0 timeout #define CCxxx0_WORCTRL 0x20 // Wake On Radio control #define CCxxx0_FREND1 0x21 // Front end RX configuration #define CCxxx0_FREND0 0x22 // Front end TX configuration #define CCxxx0_FSCAL3 0x23 // Frequency synthesizer calibration #define CCxxx0_FSCAL2 0x24 // Frequency synthesizer calibration #define CCxxx0_FSCAL1 0x25 // Frequency synthesizer calibration #define CCxxx0_FSCAL0 0x26 // Frequency synthesizer calibration #define CCxxx0_RCCTRL1 0x27 // RC oscillator configuration #define CCxxx0_RCCTRL0 0x28 // RC oscillator configuration #define CCxxx0_FSTEST 0x29 // Frequency synthesizer calibration control #define CCxxx0_PTEST 0x2A // Production test #define CCxxx0_AGCTEST 0x2B // AGC test #define CCxxx0_TEST2 0x2C // Various test settings #define CCxxx0_TEST1 0x2D // Various test settings #define CCxxx0_TEST0 0x2E // Various test settings // Strobe commands #define CCxxx0_SRES 0x30 // Reset chip. #define CCxxx0_SFSTXON 0x31 // Enable and calibrate frequency synthesizer (if MCSM0.FS_AUTOCAL=1). // If in RX/TX: Go to a wait state where only the synthesizer is // running (for quick RX / TX turnaround). #define CCxxx0_SXOFF 0x32 // Turn off crystal oscillator. #define CCxxx0_SCAL 0x33 // Calibrate frequency synthesizer and turn it off // (enables quick start). #define CCxxx0_SRX 0x34 // Enable RX. Perform calibration first if coming from IDLE and // MCSM0.FS_AUTOCAL=1. #define CCxxx0_STX 0x35 // In IDLE state: Enable TX. Perform calibration first if // MCSM0.FS_AUTOCAL=1. If in RX state and CCA is enabled: // Only go to TX if channel is clear. #define CCxxx0_SIDLE 0x36 // Exit RX / TX, turn off frequency synthesizer and exit // Wake-On-Radio mode if applicable. #define CCxxx0_SAFC 0x37 // Perform AFC adjustment of the frequency synthesizer #define CCxxx0_SWOR 0x38 // Start automatic RX polling sequence (Wake-on-Radio) #define CCxxx0_SPWD 0x39 // Enter power down mode when CSn goes high. #define CCxxx0_SFRX 0x3A // Flush the RX FIFO buffer. #define CCxxx0_SFTX 0x3B // Flush the TX FIFO buffer. #define CCxxx0_SWORRST 0x3C // Reset real time clock. #define CCxxx0_SNOP 0x3D // No operation. May be used to pad strobe commands to two // INT8Us for simpler software. #define CCxxx0_PARTNUM 0x30 #define CCxxx0_VERSION 0x31 #define CCxxx0_FREQEST 0x32 #define CCxxx0_LQI 0x33 #define CCxxx0_RSSI 0x34 #define CCxxx0_MARCSTATE 0x35 #define CCxxx0_WORTIME1 0x36 #define CCxxx0_WORTIME0 0x37 #define CCxxx0_PKTSTATUS 0x38 #define CCxxx0_VCO_VC_DAC 0x39 #define CCxxx0_TXBYTES 0x3A #define CCxxx0_RXBYTES 0x3B #define CCxxx0_PATABLE 0x3E #define CCxxx0_TXFIFO 0x3F #define CCxxx0_RXFIFO 0x3F // RF_SETTINGS is a data structure which contains all relevant CCxxx0 registers typedef struct S_RF_SETTINGS { INT8U FSCTRL2;// INT8U FSCTRL1; // Frequency synthesizer control. INT8U FSCTRL0; // Frequency synthesizer control. INT8U FREQ2; // Frequency control word, high INT8U. INT8U FREQ1; // Frequency control word, middle INT8U. INT8U FREQ0; // Frequency control word, low INT8U. INT8U MDMCFG4; // Modem configuration. INT8U MDMCFG3; // Modem configuration. INT8U MDMCFG2; // Modem configuration. INT8U MDMCFG1; // Modem configuration. INT8U MDMCFG0; // Modem configuration. INT8U CHANNR; // Channel number. INT8U DEVIATN; // Modem deviation setting (when FSK modulation is enabled). INT8U FREND1; // Front end RX configuration. INT8U FREND0; // Front end RX configuration. INT8U MCSM0; // Main Radio Control State Machine configuration. INT8U FOCCFG; // Frequency Offset Compensation Configuration. INT8U BSCFG; // Bit synchronization Configuration. INT8U AGCCTRL2; // AGC control. INT8U AGCCTRL1; // AGC control. INT8U AGCCTRL0; // AGC control. INT8U FSCAL3; // Frequency synthesizer calibration. INT8U FSCAL2; // Frequency synthesizer calibration. INT8U FSCAL1; // Frequency synthesizer calibration. INT8U FSCAL0; // Frequency synthesizer calibration. INT8U FSTEST; // Frequency synthesizer calibration control INT8U TEST2; // Various test settings. INT8U TEST1; // Various test settings. INT8U TEST0; // Various test settings. INT8U IOCFG2; // GDO2 output pin configuration INT8U IOCFG0; // GDO0 output pin configuration INT8U PKTCTRL1; // Packet automation control. INT8U PKTCTRL0; // Packet automation control. INT8U ADDR; // Device address. INT8U PKTLEN; // Packet length. } RF_SETTINGS; [page] /************寄存器配置***************/ const RF_SETTINGS rfSettings = { 0x00, 0x08, // FSCTRL1 Frequency synthesizer control. 0x00, // FSCTRL0 Frequency synthesizer control. 0x10, // FREQ2 Frequency control word, high byte. 0xA7, // FREQ1 Frequency control word, middle byte. 0x62, // FREQ0 Frequency control word, low byte. 0x5B, // MDMCFG4 Modem configuration. 0xF8, // MDMCFG3 Modem configuration. 0x03, // MDMCFG2 Modem configuration. 0x22, // MDMCFG1 Modem configuration. 0xF8, // MDMCFG0 Modem configuration. 0x00, // CHANNR Channel number. 0x47, // DEVIATN Modem deviation setting (when FSK modulation is enabled). 0xB6, // FREND1 Front end RX configuration. 0x10, // FREND0 Front end RX configuration. 0x18, // MCSM0 Main Radio Control State Machine configuration. 0x1D, // FOCCFG Frequency Offset Compensation Configuration. 0x1C, // BSCFG Bit synchronization Configuration. 0xC7, // AGCCTRL2 AGC control. 0x00, // AGCCTRL1 AGC control. 0xB2, // AGCCTRL0 AGC control. 0xEA, // FSCAL3 Frequency synthesizer calibration. 0x2A, // FSCAL2 Frequency synthesizer calibration. 0x00, // FSCAL1 Frequency synthesizer calibration. 0x11, // FSCAL0 Frequency synthesizer calibration. 0x59, // FSTEST Frequency synthesizer calibration. 0x81, // TEST2 Various test settings. 0x35, // TEST1 Various test settings. 0x09, // TEST0 Various test settings. 0x0B, // IOCFG2 GDO2 output pin configuration. 0x06, // IOCFG0D GDO0 output pin configuration. Refer to SmartRF?Studio User Manual for detailed pseudo register explanation. 0x04, // PKTCTRL1 Packet automation control. 0x05, // PKTCTRL0 Packet automation control. 0x00, // ADDR Device address. 0x0c // PKTLEN Packet length. }; //******************** //函数名:delay(unsigned int s) //输入:时间 //输出:无 //功能描述:普通廷时,内部用 //******************** static void delay(unsigned int s) { unsigned int i; for(i=0; i sync transmitted while (!GDO0); // Wait for GDO0 to be cleared -> end of packet while (GDO0); halSpiStrobe(CCxxx0_SFTX); } void setRxMode(void) { halSpiStrobe(CCxxx0_SRX);//进入接收状态 } INT8U halRfReceivePacket(INT8U *rxBuffer, INT8U *length) { INT8U status[2]; INT8U packetLength; INT8U i=(*length)*4; // 具体多少要根据datarate和length来决定 halSpiStrobe(CCxxx0_SRX);//进入接收状态 delay(2); while (GDO0) { delay(2); --i; if(i<1) return 0; } if ((halSpiReadStatus(CCxxx0_RXBYTES) & BYTES_IN_RXFIFO)) //如果接的字节数不为0 { packetLength = halSpiReadReg(CCxxx0_RXFIFO);//读出第一个字节,此字节为该帧数据长度 if (packetLength <= *length) //如果所要的有效数据长度小于等于接收到的数据包的长度 { halSpiReadBurstReg(CCxxx0_RXFIFO, rxBuffer, packetLength); //读出所有接收到的数据 *length = packetLength;//把接收数据长度的修改为当前数据的长度 // Read the 2 appended status bytes (status[0] = RSSI, status[1] = LQI) halSpiReadBurstReg(CCxxx0_RXFIFO, status, 2); //读出CRC校验位 halSpiStrobe(CCxxx0_SFRX);//清洗接收缓冲区 return (status[1] & CRC_OK);//如果校验成功返回接收成功 } else { *length = packetLength; halSpiStrobe(CCxxx0_SFRX);//清洗接收缓冲区 return 0; } } else return 0; } //*************************************** void ds_reset(void) { char temp=1; while(temp) { while(temp) { DQ=1;_nop_();_nop_(); DQ=0; delay1(80); DQ=1; delay1(9); temp=DQ; } delay1(64); temp=~DQ; } DQ=1; } //************************************ void delay1(INT16U i) { for(;i>0;i--); } //********************************************* void write_byte(INT8U value) { INT8U i; for(i=8;i>0;i--) { DQ=1;_nop_();_nop_(); DQ=0;_nop_();_nop_();_nop_();_nop_();_nop_(); DQ=value&0x01; delay1(9); value>>=1; } DQ=1; delay1(1); } //****************************************************************** INT8U read_byte(void) { INT8U i; INT8U value1=0; for(i=8;i>0;i--) { DQ=1;_nop_();_nop_(); value1>>=1; DQ=0; _nop_();_nop_();_nop_();_nop_(); DQ=1; _nop_();_nop_();_nop_();_nop_(); if(DQ) value1|=0x80; delay1(9); } DQ=1; return(value1); } //*********************************** void read_temp() { ds_reset(); write_byte(0xcc); write_byte(0xbe); temp_data[0]=read_byte(); temp_data[1]=read_byte(); ds_reset(); write_byte(0xcc); write_byte(0x44); } //************************************** void work_temp() { INT8U n=0; if(temp_data[1]>127) { temp_data[1]=(256-temp_data[1]);//负值 temp_data[0]=(256-temp_data[0]); n=1; } dispaly[6]=((temp_data[0]&0xf0)>>4)|((temp_data[1]&0x0f)<<4); dispaly[5]=dispaly[6]/100;//百位 dispaly[4]=dispaly[6]%100;// dispaly[2]=dispaly[4]/10;//十位 dispaly[1]=dispaly[4]%10;//个位 switch(temp_data[0]&0x0f)//小数位 { case 0x0f:dispaly[0]=9;break; case 0x0e:dispaly[0]=9;break; case 0x0d:dispaly[0]=8;break; case 0x0c:dispaly[0]=8;break; case 0x0b:dispaly[0]=7;break; case 0x0a:dispaly[0]=6;break; case 0x09:dispaly[0]=6;break; case 0x08:dispaly[0]=5;break; case 0x07:dispaly[0]=4;break; case 0x06:dispaly[0]=4;break; case 0x05:dispaly[0]=3;break; case 0x04:dispaly[0]=3;break; case 0x03:dispaly[0]=2;break; case 0x02:dispaly[0]=1;break; case 0x01:dispaly[0]=1;break; case 0x00:dispaly[0]=1;break; default:break; } if(n)//负值时显示aa,正直显示dd { dispaly[3]=0x11;// } else dispaly[3]=0x22; } //***************************************************************************************** void disdignit() { char i; //if(temp[0]) { for(i=0;i<3;i++) { P0=0xC6; led0=0; delay1(40); led0=1; P0=seg[dispaly[0]]; led1=0; delay1(40); led1=1; P0=seg1[dispaly[1]]; led2=0; delay1(40); led2=1; P0=seg[dispaly[2]]; led3=0; delay1(40); led3=1; } } } void main(void) { INT8U leng =0; INT8U tf =0; INT8U TxBuf[8]={0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08}; // 8字节, 如果需要更长的数据包,请正确设置 INT8U RxBuf[8]={0}; CpuInit(); POWER_UP_RESET_CC1100(); halRfWriteRfSettings(); halSpiWriteBurstReg(CCxxx0_PATABLE, PaTabel, 8); //halRfSendPacket(TxBuf,8);// Transmit Tx buffer data delay(6000); while(1) { read_temp(); work_temp(); delay1(500); disdignit(); halRfSendPacket(dispaly,4);// Transmit Tx buffer data } }
上一篇:单片机制作的时钟程序
下一篇:基于NRF24L01无线模块的STC89C52单片机接收(RX)C语言程序
推荐阅读最新更新时间:2024-03-16 14:23
设计资源 培训 开发板 精华推荐
- ADI和\"西北模电王\"邀您一起下载研读《新概念模拟电路》系列第一本电子书《晶体管》
- 有奖直播:基于GaN 的高频(1.2MHz)高效率 1.6kW 高密度临界模式 (CrM) 图腾柱功率因数校正 (PFC)转换器的应用介绍
- Keysight示波器主题月有奖系列活动之 注册大奖天天抽 抢楼踩中亦有奖
- 【EEWORLD第四十三届】2012年10月社区明星人物揭晓!
- ADI有奖直播:储能系统助力电动汽车快充站的建设 8月31日上午10:00-11:30 为您揭晓!
- EEWorld 2018年度最具影响力网友评选
- 4小时实战+剖析:TI工程师教你快速上手 各种无线产品开发 (限量$14售CC1352R1无线开发板,助你参与动手实验)
- 福禄克有奖直播|新型8.5位数字多用表技术发展及应用
- 学C2000精品课程,低价抢购 C2000 LaunchPad!
