数码管显示的电子时钟C51程序
发布者:LogicLeaper最新更新时间:2015-07-27 来源: 51hei关键字:数码管显示  电子时钟  C51程序 手机看文章 扫描二维码
随时随地手机看文章
功能:
    实现电子时钟显示(C)
定义:
    P3口位选,P1口段选,P0.0,P0.1,P0.2为调时口
时间:
    2010—11—26
说明:
    仿真存在问题,这可能是仿真软件的问题,需要将段位扫描反调
 实际运行的结果是正确的
#include
unsigned char code dispcode[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x00};
unsigned char dispbitcode[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsigned char dispbuf[8]={0,0,16,0,0,16,0,0};
unsigned char dispbitcnt;
unsigned char second;
unsigned char minite;
unsigned char hour;
unsigned int tcnt;
unsigned char mstcnt;
unsigned char i,j;
void main(void)
       TMOD=0x02;
       TH0=0x06;
       TL0=0x06;
       TR0=1;
       ET0=1;
       EA=1;
       while(1)
              if(P0_0==0)
                     for(i=5;i>0;i--)
                            for(j=248;j>0;j--);
                     if(P0_0==0)
                            second++;
                            if(second==60)
                                   second=0;
                            dispbuf[0]=second%10;
                            dispbuf[1]=second/10;
                            while(P0_0==0);
              if(P0_1==0)
                     for(i=5;i>0;i--)
                            for(j=248;j>0;j--);
                     if(P0_1==0)
                            minite++;
                            if(minite==60)
                                   minite=0;
                            dispbuf[3]=minite%10;
                            dispbuf[4]=minite/10;
                            while(P0_1==0);
              if(P0_2==0)
                     for(i=5;i>0;i--)
                            for(j=248;j>0;j--);
                     if(P0_2==0)
                            hour++;
                            if(hour==24)
                                   hour=0;
                            dispbuf[6]=hour%10;
                            dispbuf[7]=hour/10;
                            while(P0_2==0);
void t0(void) interrupt 1 using 0
       mstcnt++;
       if(mstcnt==8)
              mstcnt=0;
              P1=dispcode[dispbuf[dispbitcnt]];
              P3=dispbitcode[dispbitcnt];
              dispbitcnt++;
              if(dispbitcnt==8)
                     dispbitcnt=0;
       tcnt++;
       if(tcnt==4000)
              tcnt=0;
              second++;
              if(second==60)
                     second=0;
                     minite++;
                     if(minite==60)
                            minite=0;
                            hour++;
                            if(hour==24)
                                   hour=0;
              dispbuf[6]=hour%10;
              dispbuf[7]=hour/10;
 [page]
功能:
    实现电子时钟显示(C)
定义:
    P2口位选,P0口段选
时间:
    2010—11—26
#include
code unsigned char tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
unsigned char StrTab[6];
unsigned char minute=30,hour=12,second=0;
void Displaypro(void)
    StrTab[0]=tab[second%10];
    StrTab[1]=tab[second/10];
    StrTab[2]=tab[minute%10];
    StrTab[3]=tab[minute/10];
    StrTab[4]=tab[hour%10];
    StrTab[5]=tab[hour/10];
main()
    TMOD |=0x01;
    TH0=0xd8;
    TL0=0xf0;
    ET0=1;
    TR0=1;
    TMOD |=0x10;
    TH1=0xF8;
    TL1=0xf0;
    ET1=1;
    TR1=1;
    EA =1;
    while(1){;}
void time1_isr(void) interrupt 3
    static unsigned char num;
    TH1=0xf8;
    TL1=0xf0;
    switch (num)
        case 0:P2=0x01;P0=StrTab[num];break;
        case 1:P2=0x02;P0=StrTab[num];break;
        case 2:P2=0x04;P0=StrTab[num];break;
        case 3:P2=0x08;P0=StrTab[num];break;
        case 4:P2=0x10;P0=StrTab[num];break;
        case 5:P2=0x20;P0=StrTab[num];break;
        default:break;
    num++;
    if(num==6)
    num=0;
void tim(void) interrupt 1
    static unsigned char count;
    TH0=0xd8;
    TL0=0xf0;
    count++;
    switch (count)
        case 0:
        case 20:
        case 40:
        case 60:
        case 80:Displaypro();break;
        default:break;
    if (count==100)
        count=0;
        second++;
        if(second==60)
            second=0;
            minute++;
            if(minute==60)
                minute=0;
                hour++;
                if(hour==24)
                    hour=0;
//源代码下载 :http://www.51hei.com/f/szc511.rar
关键字:数码管显示  电子时钟  C51程序 引用地址:数码管显示的电子时钟C51程序
上一篇:步进电机带指针在标尺上移动并显示坐标及相对坐标
下一篇:我的电子钟c程序完整代码
推荐阅读最新更新时间:2024-03-16 14:26
51单片机数码管静态显示和动态显示原理及实验 夜猫子
数码管 多位数码管,即是两个或两个以上单个数码管并列集中在一起形成一体的数码管。当多位一体时,它们内部的公共端是独立的,而负责显示什么数字的段线全部是连接在一起的,独立的公共端可以控制多位一体中的哪一位数码管点亮,而连接在一起的段线可以控制这个能点亮数码管亮什么数字,通常我们把公共端叫做“位选线”,连接在一起的段线叫做“段选线”有了这两个线后,通过单片机及外部驱动电路就可以控制任意的数码管显示。一般一位数码管有10个引脚,二位数码管也是10个引脚,四位数码管是12个引脚。 为了更方便区分段选和位选,请看下原理图: 如图为两个4位一体的数码管,可以看到与8个com相连的是两个数码管的位选,位选与引脚相连,所以位选控制那个灯亮。段
[单片机]
51单片机<font color='red'>数码管</font>静态<font color='red'>显示</font>和动态<font color='red'>显示</font>原理及实验 夜猫子
51单片机实习-数码管动态显示4399(模块化编程)
#include reg52.h sbit wei0=P1^0; sbit wei1=P1^1; sbit wei2=P1^2; sbit wei3=P1^3; int zxm ={0x98,0x98,0xb0,0x99}; void delay(int i) { while(i--) { int j=0; for(;j 115;j++); } } void display() { int i; for( i=0;i 4;i++) { switch(i) { case 0: wei0=0,wei1=1,wei2=1,wei3=1;break; case
[单片机]
51单片机实习-<font color='red'>数码管</font>动态<font color='red'>显示</font>4399(模块化编程)
基于51单片机的电子时钟课程设计
第一章 设计目的及要求 1.目的 通过对电子时钟系统进行编程与Protues仿真,进一步掌握单片机的组成,P1、P0、P2、P3口的应用,蜂鸣器的应用,定时中断程序的编写及应用,对之前学习的单片机课程进行回顾与应用;初步掌握Protues仿真方法以及用keil软件编写程序的方法。 2.题目与要求 本次课程设计的题目为:电子时钟的设计,其具体要求为: (1)能实现时、分、秒的显示; (2)能实现12、24小时制的切换; (3)能设定时间; (4)能设定闹钟; 整个系统要设计键盘和显示器,利用单片机内部时钟完成定时器的定时设计。 第二章 理论基础 1.AT89C52芯片 AT89C52芯片的引脚图如图1所示。 图1 AT
[单片机]
基于51单片机的<font color='red'>电子时钟</font>课程设计
基于51单片机的数码管动态显示
#include reg52.h #include intrins.h #define uchar unsigned char #define uint unsigned int sbit P2_6=P2^6; //数码管位选74HC573锁存端 sbit P2_7=P2^7; //数码段位选74HC573锁存端 oid delay(uchar xms); //声明函数delay()原型,延时函数 void display(char *ptr); uchar code seg = {0x3f,0x06,0x5b,0x4f,0x66, //段码表:0,1,2,3,4 0x6d,0x7d,0x07,0x7f,0x6f, //段码表
[单片机]
C51的PID程序
//主程序====================================================== #include Main.h #include PID_f1.h /* ............................................................... */ /* ............................................................... */ void main(void) { float x,y,z; while(1) { x = PID_Control(y,z); } }
[单片机]
跑秒程序-数码管显示
/* 程序效果:跑秒,同时显示四位数码管 版权所有:http://www.51hei.com 转载请保留. P1控制数码管的位 P2控制段 注意:如果无法在keil里编译,请删除每一行的所有前导空白, */ #include reg52.h //头文件 #define uchar unsigned char //宏定义 #define uint unsigned int void display(); //函数声明 uchar code table ={0x3f,0x06,0x5b,//数码管显示的数值 0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f}; void delay(uchar x) //延
[单片机]
简易星三角启动电机 单片机C51程序
当电机较大时,启动是个必须注意的问题。比较简单且用的很多的是星三角启动,这里写出了星三角启动的核心部分。每一个IO口接上继电器,再控制交流接触器,就OK了。但,要注意,星、角交流接触器一定要互锁,否则一旦某个交流接触器粘连,就造成短路了。 #include reg51.h sbit K1=P3^1; //按键1,控制第1个继电器启动 sbit K2=P3^2; //按键2,控制第2个继电器启动 sbit J1=P1^5; //星接继电器 sbit J2=P1^6; //星点继电器 sbit J3=P1^7; //角继电器 void Delay_1ms(unsigned int t) { unsigned int x, y;
[单片机]
51单片机开发系列三_数码管动态扫描显示
数码管由于发光亮度强,指示效果好,非常适合于电梯楼层等数值显示应用中。对于一位数码管,可以采用静态显示,但实际应用中都是需要显示多位数值,数码管模块也只能动态显示,因此笔者在这里简单分析一下数码管动态扫描驱动的实现。 1. 数码管原理概述 数码管由多个发光二极管封装在一起组成“8”字型的器件,引线已在内部连接完成,只引出它们的各个笔划,公共电极。数码管实际上是由七个发光管组成8字形构成的,加上小数点就是8个。这些段分别由字母a,b,c,d,e,f,g,dp来表示。数码管根据内部接法又可分成共阳极数码管和共阴极数码管。共阳数码管是指将所有发光二极管的阳极接到一起形成公共阳极(COM)的数码管(如下图SM*10501),共阴数码管是
[单片机]
51单片机开发系列三_<font color='red'>数码管</font>动态扫描<font color='red'>显示</font>
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
热门活动
换一批
更多
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
