以下是TFT的驱动函数用来显示图片,之前要将图片进行取模并保存在一下数组中:
const unsigned char code Image_pic[7128] = { };
然后只需修改程序中的红色字体的文字!
一定记住:使用TFT显示图片只需修改红黑色字体的文字,知道如何用即可,没有太大的必要亲自去写驱动函数!!!除非你有足够的精力逐句去理解,这对你也有好处.
#include
#include
#include "LCD.h"
#define NOP() _nop_()
#define TYPE_LCD_DATA 1
#define TYPE_LCD_COMMAND 0
char code reserve[3]_at_ 0x3b; //保留0x3b开始的3个字节
#define DATA P0 //定义数据输入端口并行
sbit LCD_RST = P2^7;
sbit LCD_RD = P3^2;
sbit LCD_WR = P3^3;
sbit LCD_RS = P2^5;
sbit LCD_CS = P2^6;
//以上红色字体是必须要针对实际的TFT接口连接情况进行修改的,此为应用的关键之处
uint colors[]=
0xf800,0x07e0,0x001f,0xffe0,0x0000,0x07ff,0xf81f,0xffff
void delay_ms(uint ms)
unsigned char k;
while (ms--)
for (k = 0; k < 228; k++)
void LCD_Write(uchar type, uint value)
LCD_CS = 0;
LCD_RS = type; // 0: command 1: data
LCD_WR = 0;
DATA = (uchar)value;
LCD_WR = 1;
LCD_CS = 1;
void LCD_Write_Data8(uchar value) // color data
LCD_CS = 0;
LCD_RS = 1;
LCD_WR = 0;
DATA = value;
LCD_WR = 1;
LCD_CS = 1;
void LCD_Wirte_Data16(uint value) // color data
LCD_CS = 0;
LCD_RS = 1;
LCD_WR = 0;
LCD_WR = 1;
LCD_WR = 0;
DATA = (uchar)(value>>8) ;
LCD_WR = 1;
LCD_CS = 1;
void Reg_Write(uint reg,uint value)
LCD_Write(TYPE_LCD_COMMAND,reg);
LCD_Write(TYPE_LCD_DATA,value);
void LCD_SetRamAddr(uint xStart, uint xEnd, uint yStart, uint yEnd)
uint VerPos,HorPos,StartAddr;
HorPos = (uint)(xStart | (xEnd<<8));
VerPos = (uint)(yStart | (yEnd<<8));
StartAddr = (uint)(xStart | (yStart<<8));
Reg_Write(0x09, xStart);
Reg_Write(0x10,yStart);
Reg_Write(0x11,xEnd);
Reg_Write(0x12,yEnd);
Reg_Write(0x18, xStart);
Reg_Write(0x19, yStart);
LCD_Write(TYPE_LCD_COMMAND,0x22); // 0x22
void LCD_init(void)
{ uint num;
Reg_Write(0x0001,0x0002); //MODE_SEL1
Reg_Write(0x0002,0x0012); //MODE_SEL2
Reg_Write(0x0003,0x0000); //MODE_SEL3
Reg_Write(0x0004,0x0010); //MODE_SEL3
LCD_SetRamAddr(0,127, 0,159);
for(num=20480;num>0;num--)
LCD_Wirte_Data16(0xffff);
Reg_Write(0x0005,0x0008); //VCO_MODE
Reg_Write(0x0007,0x007f); //VCOMHT_CTRL
Reg_Write(0x0008,0x0017); //VCOMLT_CTRL
Reg_Write(0x0009,0x0000); //write SRAM window start X point
Reg_Write(0x0010,0x0000); //write SRAM window start y point
Reg_Write(0x0011,0x0083); //write SRAM window end x point
Reg_Write(0x0012,0x009f); //write SRAM window end y point
Reg_Write(0x0017,0x0000); //SRAM contrl
Reg_Write(0x0018,0x0000); //SRAM x position
Reg_Write(0x0019,0x0000); //SRAM y position
Reg_Write(0x0006,0x00c5); //DAC_OP_CTRL2
delay_ms(10); //延时
void pic_play(uint Start_X, uint End_X,uint Start_Y,uint End_Y)
uint num,m;
uint dx,dy;
dx = (End_X+1)-Start_X; //计算写入数据的总数
dy = (End_Y+1)-Start_Y;
num = dx*dy<<1;
LCD_CS = 0;
LCD_SetRamAddr(Start_X,End_X-1,Start_Y,End_Y-1) ;
LCD_RS = 1;
for(m=0; m<7128; m++)
LCD_Write_Data8(Image_pic[m]);
LCD_CS = 1;
void LCD_clear(uchar n)
uint num;
LCD_SetRamAddr(0,127, 0,159);//清屏函数
for(num=20480;num>0;num--) //160*128=20480
LCD_Wirte_Data16(colors[n]);//其实质是对每一个点进行设置!
void main(void)
P2 = 0xff;
P0 = 0xff;//端口的初始化
LCD_init();//屏幕初始化
LCD_clear(6);//清屏
pic_play(7,61,8,74);
pic_play(68,122,8,74);
pic_play(7,61,82,148);
pic_play(68,122,82,148);
//设置显示图片的位置
while(1) ;
