STM32F4xx的HAL部分已经提供了SD的driver,初始化时的IO PIN等放在HAL_SD_MspInit。
void HAL_SD_MspInit(SD_HandleTypeDef *hsd)
GPIO_InitTypeDef GPIO_InitStruct;
__HAL_RCC_GPIOC_CLK_ENABLE();
__HAL_RCC_GPIOD_CLK_ENABLE();
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Pull = GPIO_PULLUP;
GPIO_InitStruct.Speed = GPIO_SPEED_FAST;
GPIO_InitStruct.Alternate = GPIO_AF12_SDIO;
/*SDIO GPIO Configuration
PC8 ------> SDIO_D0
PC9 ------> SDIO_D1
PC10 ------> SDIO_D2
PC11 ------> SDIO_D3
PC12 ------> SDIO_CK
PD2 ------> SDIO_CMD
GPIO_InitStruct.Pin = GPIO_PIN_8 | GPIO_PIN_9 | GPIO_PIN_10 | GPIO_PIN_11 | GPIO_PIN_12;
HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
GPIO_InitStruct.Pin = GPIO_PIN_2;
HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
__HAL_RCC_SDIO_CLK_ENABLE();
__SDIO_CLK_ENABLE();
hsd->Instance = SDIO;
hsd->Init.ClockEdge = SDIO_CLOCK_EDGE_RISING;
hsd->Init.ClockBypass = SDIO_CLOCK_BYPASS_DISABLE;
hsd->Init.ClockPowerSave = SDIO_CLOCK_POWER_SAVE_DISABLE;
hsd->Init.BusWide = SDIO_BUS_WIDE_1B;
hsd->Init.HardwareFlowControl = SDIO_HARDWARE_FLOW_CONTROL_DISABLE;
hsd->Init.ClockDiv = SDIO_TRANSFER_CLK_DIV;
定义两个变量
SD_HandleTypeDef hsd;
HAL_SD_CardInfoTypedef SDCardInfo;
main函数中初始化SD卡的相关代码:
__IO HAL_SD_ErrorTypedef errorstate = SD_OK;
errorstate = HAL_SD_Init(&hsd, &SDCardInfo);
if(SD_OK == errorstate)
errorstate = HAL_SD_WideBusOperation_Config(&hsd, SDIO_BUS_WIDE_4B);
if(SD_OK != errorstate)
while(1);
HAL_SD_Init()函数中会先调用HAL_SD_MspInit()初始化PIN和clk等。
需要注意的是初始化时bus width只能设置成1bit,然后通过
HAL_SD_WideBusOperation_Config(&hsd, SDIO_BUS_WIDE_4B)来切换成4位模式,在初始化时直接设置成4位是无效的。
完成以上工作后就可以通过HAL_SD_ReadBlocks()和HAL_SD_WriteBlocks()来完成block形式的读写操作了,需要FATFS的话可以参考其它例子。
上一篇:stm32CubeMX HAL库中延时的几种方式解析
下一篇:stm32f405 HAL库串口接收错误
推荐阅读最新更新时间:2024-03-16 16:09
