STM32F407外扩SRAM配置
发布者:RadiantEyes最新更新时间:2018-07-23 来源: eefocus关键字:STM32F407  外扩SRAM 手机看文章 扫描二维码
随时随地手机看文章
以下SRAM的程序是在清时代STM32F407开发板上测试通过
开发板PCB完整工程连接:http://www.cirmall.com/circuit/7 ... F%EF%BC%81#/details
淘宝连接:https://item.taobao.com/item.htm?id=557618550100
bsp_SRAM.c文件
#include "sram.h"
#include "usart.h"
//本程序只供学习使用,未经作者许可,不得用于其它任何用途
//STM32F407开发板
//外部SRAM 驱动代码
//All rights reserved
//使用NOR/SRAM的 Bank1.sector3,地址位HADDR[27,26]=10
//对IS61LV25616/IS62WV25616,地址线范围为A0~A17
//对IS61LV51216/IS62WV51216,地址线范围为A0~A18
#define Bank1_SRAM3_ADDR    ((u32)(0x68000000))
//初始化外部SRAM
void FSMC_SRAM_Init(void)
GPIO_InitTypeDef  GPIO_InitStructure;
FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure;
  FSMC_NORSRAMTimingInitTypeDef  readWriteTiming;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB|RCC_AHB1Periph_GPIOD|RCC_AHB1Periph_GPIOE|RCC_AHB1Periph_GPIOF|RCC_AHB1Periph_GPIOG, ENABLE);//使能PD,PE,PF,PG时钟
  RCC_AHB3PeriphClockCmd(RCC_AHB3Periph_FSMC,ENABLE);//使能FSMC时钟
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;//PB15 推挽输出,控制背光
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//普通输出模式
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//100MHz
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉
  GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化 //PB15 推挽输出,控制背光
GPIO_InitStructure.GPIO_Pin = (3<<0)|(3<<4)|(0XFF<<8);//PD0,1,4,5,8~15 AF OUT
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用输出
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz
  GPIO_Init(GPIOD, &GPIO_InitStructure);//初始化
  GPIO_InitStructure.GPIO_Pin = (3<<0)|(0X1FF<<7);//PE0,1,7~15,AF OUT
  GPIO_Init(GPIOE, &GPIO_InitStructure);//初始化
  GPIO_InitStructure.GPIO_Pin = (0X3F<<0)|(0XF<<12);//PF0~5,12~15
  GPIO_Init(GPIOF, &GPIO_InitStructure);//初始化
GPIO_InitStructure.GPIO_Pin =(0X3F<<0)| GPIO_Pin_10;//PG0~5,10
  GPIO_Init(GPIOG, &GPIO_InitStructure);//初始化
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource0,GPIO_AF_FSMC);//PD0,AF12
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource1,GPIO_AF_FSMC);//PD1,AF12
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource4,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource5,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource8,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource9,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource10,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource11,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOD,GPIO_PinSource12,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource13,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource14,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOD,GPIO_PinSource15,GPIO_AF_FSMC);//PD15,AF12
  GPIO_PinAFConfig(GPIOE,GPIO_PinSource0,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE,GPIO_PinSource1,GPIO_AF_FSMC);
GPIO_PinAFConfig(GPIOE,GPIO_PinSource7,GPIO_AF_FSMC);//PE7,AF12
  GPIO_PinAFConfig(GPIOE,GPIO_PinSource8,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE,GPIO_PinSource9,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE,GPIO_PinSource10,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE,GPIO_PinSource11,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE,GPIO_PinSource12,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE,GPIO_PinSource13,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE,GPIO_PinSource14,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOE,GPIO_PinSource15,GPIO_AF_FSMC);//PE15,AF12
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource0,GPIO_AF_FSMC);//PF0,AF12
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource1,GPIO_AF_FSMC);//PF1,AF12
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource2,GPIO_AF_FSMC);//PF2,AF12
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource3,GPIO_AF_FSMC);//PF3,AF12
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource4,GPIO_AF_FSMC);//PF4,AF12
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource5,GPIO_AF_FSMC);//PF5,AF12
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource12,GPIO_AF_FSMC);//PF12,AF12
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource13,GPIO_AF_FSMC);//PF13,AF12
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource14,GPIO_AF_FSMC);//PF14,AF12
  GPIO_PinAFConfig(GPIOF,GPIO_PinSource15,GPIO_AF_FSMC);//PF15,AF12
  GPIO_PinAFConfig(GPIOG,GPIO_PinSource0,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOG,GPIO_PinSource1,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOG,GPIO_PinSource2,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOG,GPIO_PinSource3,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOG,GPIO_PinSource4,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOG,GPIO_PinSource5,GPIO_AF_FSMC);
  GPIO_PinAFConfig(GPIOG,GPIO_PinSource10,GPIO_AF_FSMC);
  readWriteTiming.FSMC_AddressSetupTime = 0x02;//地址建立时间(ADDSET)为1个HCLK 1/36M=27ns
  readWriteTiming.FSMC_AddressHoldTime = 0x00; //地址保持时间(ADDHLD)模式A未用到
  readWriteTiming.FSMC_DataSetupTime = 0x08; ////数据保持时间(DATAST)为9个HCLK 6*9=54ns
  readWriteTiming.FSMC_BusTurnAroundDuration = 0x00;
  readWriteTiming.FSMC_CLKDivision = 0x00;
  readWriteTiming.FSMC_DataLatency = 0x00;
  readWriteTiming.FSMC_AccessMode = FSMC_AccessMode_A;//模式A
  FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM3;//  这里我们使用NE3 ,也就对应BTCR[4],[5]。
  FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable;
  FSMC_NORSRAMInitStructure.FSMC_MemoryType =FSMC_MemoryType_SRAM;// FSMC_MemoryType_SRAM;  //SRAM
  FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;//存储器数据宽度为16bit
  FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode =FSMC_BurstAccessMode_Disable;// FSMC_BurstAccessMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait=FSMC_AsynchronousWait_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
  FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
  FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;//存储器写使能
  FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
  FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable; // 读写使用相同的时序
  FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
  FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &readWriteTiming;
  FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &readWriteTiming; //读写同样时序
  FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);  //初始化FSMC配置
  FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM3, ENABLE);  // 使能BANK1区域3
bsp_SRAM.h头文件
#ifndef __SRAM_H
#define __SRAM_H
#include "sys.h"
//STM32开发板
//外部SRAM 驱动代码
void FSMC_SRAM_Init(void);
#endif
SRAM测试函数
#define EXT_SRAM_ADDR   ((uint32_t)0x68000000)
#define EXT_SRAM_SIZE (1 * 1024 * 1024)
* 函 数 名: bsp_TestExtSRAM
* 功能说明: 扫描测试外部SRAM
* 形    参: 无
* 返 回 值: 0 表示测试通过; 大于0表示错误单元的个数。
uint8_t bsp_TestExtSRAM(void)
uint32_t i;
uint32_t *pSRAM;
uint8_t *pBytes;
uint32_t err;
const uint8_t ByteBuf[4] = {0x55, 0xA5, 0x5A, 0xAA};
/* 写SRAM */
pSRAM = (uint32_t *)EXT_SRAM_ADDR;
for (i = 0; i < EXT_SRAM_SIZE / 4; i++)
*pSRAM++ = i;
/* 读SRAM */
err = 0;
if (*pSRAM++ != i)
err++;
if (err >  0)
return  (4 * err);
#if 0
/* 对SRAM 的数据求反并写入 */
*pSRAM = ~*pSRAM;
pSRAM++;
/* 再次比较SRAM的数据 */
err = 0;
if (*pSRAM++ != (~i))
err++;
if (err >  0)
return (4 * err);
#endif
/* 测试按字节方式访问, 目的是验证 FSMC_NBL0 、 FSMC_NBL1 口线 */
pBytes = (uint8_t *)EXT_SRAM_ADDR;
for (i = 0; i < sizeof(ByteBuf); i++)
*pBytes++ = ByteBuf[i];
/* 比较SRAM的数据 */
err = 0;
if (*pBytes++ != ByteBuf[i])
err++;
if (err >  0)
return err;
return 0;
多次复位,多次测试后稳定正常测试通过
在GUI上电应用只要传入地址即可
关键字:STM32F407  外扩SRAM 引用地址:STM32F407外扩SRAM配置
上一篇:使用J-link+J-Flash给STM32芯片烧写序列号
下一篇:STM32移植STemWin后使用四点或两点触摸校准
推荐阅读最新更新时间:2024-03-16 16:09
stm32f407之ADC(操作寄存器)
ADC 12位ADC是一种逐次逼近型模拟数字转换器。它有多达19个通道,可测量16个外部和2个内部信号源和Vbat通道。各通道的A/D转换可以单次、连续、扫描或间断模式执行。ADC的结果可以左对齐或右对齐方式存储在16位数据寄存器中。 模拟看门狗特性允许应用程序检测输入电压是否超出用户定义的高/低阀值。 有16个多路通道。 通道选择: 可以把转换组织成两组:规则组和注入组。在任意多个通道上以任意顺序进行的一系列转换构成成组转换。例如,可以如下顺序完成转换:通道3、通道8、通道2、通道2、通道0、通道2、通道2、通道15。 规则组由多达16个转换组成。规则通道和它们的转换顺序在ADC_SQRx寄存器中选择。规则组中转换
[单片机]
<font color='red'>stm32f407</font>之ADC(操作寄存器)
stm32f407】DAC实验
描述 STM32F4的DAC模块(数字/模拟转换模块)是12位数字输入,电压输出型的DAC。DAC可以配置为8位或12位模式,也可以与DMA控制器配合使用。DAC工作在12位模式时,数据可以设置成左对齐或右对齐。DAC模块有2个输出通道,每个通道都有单独的转换器。在双DAC模式下,2个通道可以独立地进行转换,也可以同时进行转换并同步地更新2个通道的输出。DAC可以通过引脚输入参考电压Vref+(通ADC共用)以获得更精确的转换结果。 STM32F4的DAC模块主要特点有: ① 2个DAC转换器:每个转换器对应1个输出通道 ② 8位或者12位单调输出 ③ 12位模式下数据左对齐或者右对齐 ④ 同步更新功能
[单片机]
【<font color='red'>stm32f407</font>】DAC实验
STM32F407时钟设置
这里我们写一个RCC配置函数来说明各函数的用途,其中HSE = 8MHz。 /** * @说明 配置STM32F407的时钟系统 * @参数 无 * @返回 无 * @说明 void Clock_Config(void) 按如下表格配置时钟 * *================================================================== * Supported STM32F4xx device revision | Rev A *------------------------------------------------------------------
[单片机]
STM32F405与STM32F407CAN配置
STM32F405与STM32F407CAN配置略有不同,不同之处在于407多了一个电平拉高拉低模式,配置时一定要注意。 其次,要开CAN2,必须开CAN1,因为CAN1是主,CAN2是从;开了CAN中断,一定要写中断处理函数并及时清除中断标志位,否则程序会卡死。 405的配置: GPIO_InitTypeDef GPIO_InitStruct; RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE); RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE); RCC_APB1PeriphClockCmd(RCC_A
[单片机]
keil5 stm32f407 环境转stm32f103 解决方法
问题:下载程序一直报错,是因为我之前是f4的库,现在的程序是f103的 ,所以环境需重新配置 解决办法:https://jingyan.baidu.com/album/25648fc18dfbb09190fd004a.html?picindex=10 打开keil软件 按下图标记点击操作 第三步,点击蓝色的一串字体,进入官网下载pack包, 下载完后到下载路径,会发现pack,双击。pack, 双击pac包,进入安装界面,确定好路径,点击‘Next' , 安装完成,点击’Finish' 进入keil软件,点击‘魔术棒’-----》device ---- 会发现多了stm32f103的包
[单片机]
keil5 <font color='red'>stm32f407</font> 环境转stm32f103 解决方法
Stm32f407DISCOVEY学习uart串口波特率乱总结
这几天调试Stm32f407DISCOVEY。由于没有串口现成的库函数例程,就用的神州王开发板上的例程直接调,结果串口输出老是乱,115200波特率;;试着把它换到 38400居然可以打印,相差3倍多;真相只有一个,进过调试摸索百度,终于找到原因; .时钟频率不对 由于时钟频率是在库文件里自动定义好的,一开始没有发现,但是波特率一直不对,后来发现问题在库文件里定义的外部晶振是25M,而DISCOVERY的板子上用的是8M的晶振,故产生的主频不对,需要改两个地方,①所以在 stm32f4xx.h中改 #if !defined (HSE_VALUE) #define HSE_VALUE ((uint32_t)8000000) /*!
[单片机]
STM32F407的定时器时钟频率
//实验的思路为对TIM3进行初始化后,进入死循环等到TIM3的溢出中断,当TIM3_CNT的值等于TIM3_ARR时, 就会产生TIM3的中断,进入中断处理函数;TIM3_CNT从0开始计数。 // 看一下时钟频率 根据时钟树得到TIM3挂载在APB1时钟上,APB1来自SYSCLK时钟,是来自PLLCLK,有HSE时钟经过分频-倍频-分频得到的; stm32F407中时钟HSE的频率为8M,在systemInit()中,先分频M=8;再倍频N=336;再分频P=2;得到SYSCLK的频率为168Hz,在使用定时器TIM时,需要进行分频,APB1的时钟频率为42Mhz,这里进行了4分频。
[单片机]
<font color='red'>STM32F407</font>的定时器时钟频率
Stm32F407 SPI1 全双工DMA 收发数据
最近被 ESP8266 的设计整崩溃了, 一个半的 串口 真的 坑。 为了让 我毕设中的 ESP8266 和 Stm32F4 单片机进行数据传输,我需要找到一种除了 串口意外的 通讯方式(吐槽一下,要是用串口的话 真的太简单啊) 最终我盯上了 SPI 的协议 所以就有这个博客。 这是我的 一个试验程序。 声明一下 这个博客中的主要代码不是我写的,是我在网上找到的 原作者是 在这里向原作者致敬,如果您不希望我写这个博客 那么请联系我。 我这里只是分享一下代码的思路(我的代码做了一定的自己的修改) 这是GPIO的 初始化部分,其中的PA4是NSS 引脚 这里我使用的是软件NSS所以就单独配置一下输出 手册中的引脚复用
[单片机]
<font color='red'>Stm32F407</font> SPI1 全双工DMA 收发数据
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
