STM32组合设备实现USB转双串口
发布者:CelestialMagic最新更新时间:2018-09-09 来源: eefocus关键字:STM32  USB转双串口 手机看文章 扫描二维码
随时随地手机看文章
串口及其中断初始化
void USART1Init(void)
  GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
USART_InitStructure.USART_BaudRate = 9600;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No ;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
USART_Init(USART1, &USART_InitStructure);
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
USART_ClearFlag(USART1,USART_FLAG_TC);
USART_Cmd(USART1, ENABLE);
void NVIC_USART1_Init(void)
  NVIC_InitTypeDef NVIC_InitStructure;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
串口发送一个字节函数
void Usart1SendByte(char byte)//发送一个字节 硬件连接选用的为USART1
USART1->SR;
USART_SendData(USART1, (uint8_t) byte);
while( USART_GetFlagStatus(USART1,USART_FLAG_TC)!= SET);
数据打包发送函数
 void ADC_ConvertSend(float value)
 unsigned char temp[6];
 char CheckStart='~';//数据传输开始
 char CheckEnd='!';//表示一次传输完成
 unsigned short i=0,j=0;
float floatVariable=value;
unsigned char *pdata = (unsigned char *)&floatVariable;
 temp[0]=CheckStart;//数据包头
for(i=0;i<4;i++)
temp[i+1] = *pdata++;//float转BYTE
temp[5]=CheckEnd;//数据包尾
for( j=0;j<6;j++)
  Usart1SendByte(temp[j]);
关键字:STM32  USB转双串口 引用地址:STM32组合设备实现USB转双串口
上一篇:STM32开发 -- UART应用层通信协议分析
下一篇:matlab与stm32之间利用串口通信记录
推荐阅读最新更新时间:2024-03-16 16:13
你的STM32芯片FLASH容量真如ST官方选型手册那样吗?
如果某一个天项目经理提出一个需求,要求在现有STM32产品基础上,内部FLASH增加64K字库,你脑海中首先会想到什么? 1先说点其它 一般对于初学者来说,内部FLASH完全足够,跑一个简单的裸机Demo,或者一个RTOS加上两个任务的Demo,对于现在的MCU完全没有压力。 但是,一旦你接触到实际项目,你会发现很多地方都会开支FLASH,而且有些项目占用FLASH还不小。比如:某种特定算法,加载字库,甚至放两张图片在FLASH里面。 再拿一个IAP应用编程的例子来说:一般对升级这个功能做的好一点的,会有一块区域(备份区域)与应用程序差不多大小的FLASH区域。就是说:为了保证安全,你程序下载保
[单片机]
你的<font color='red'>STM32</font>芯片FLASH容量真如ST官方选型手册那样吗?
STM32入门系列-使用库函数点亮LED软硬件分析
电路图分析 首先找来单片机的原理图,根据原理图进行相关的设计工作。 例如在上图中相同网络标号表示它们是连接在一起的,因此D1发光二极管阴极是连接在STM32的PC0管脚上,D2指示灯阴极连接在PC1管脚上,其他LED管脚以此类推。如果要使D1指示灯亮,只需要控制PC0管脚输出低电平, 如果要使D1指示灯灭,只需控制PC0输出高电平。如果你们使用的是其他板子,连接LED的管脚和极性不一样,那么只需要在程序中修改对应的GPIO管脚和输出电平状态即可,原理是一样的。 要点亮D1发光二极管,也就是让STM32的PC0管脚输出一个低电平。 库函数支持文件 如果采用的是库函数开发,需要复制创建好的库函数模板,在此模板上进行程序开发
[单片机]
<font color='red'>STM32</font>入门系列-使用库函数点亮LED软硬件分析
基于VS1003B的语音通信方法研究
简介:在通指装备模拟训练器材研发中,经常会遇到需要模拟实现语音通话功能的情况。常规的解决方案是在计算机上通过高级语言编程实现对声音的采集和播放,并通过局域网进行传输。考虑到语音通信的模块化和可控性,文中以STM32F107VCT6作为核心处理器,采用VS1003B作为语音采集和播放器件,通过CAN总线实现语音和信令传输,设计实现了一种低成本、高质量的语音通信方法。 1 VS1003B解码芯片介绍 VS1003B是由芬兰VLSI公司出品的一款单芯片的MP3/WMA/MIDI音频解码和ADPCM编码芯片,其内部电路如图1所示。由图可见,VS1003B包含一个高性能、具有自主产权的低功耗DSP处理器内核VSDSP,工作数据存储器
[单片机]
基于VS1003B的语音通信方法研究
STM32移植USB驱动总结
//=========================By xiaowei /* */ //========================= 1、硬件介绍 1、SGM7227,USB高速切换开关,OE是芯片使能,低电平才能使总线导通; S脚是切换控制; USB协议 https://segmentfault.com/a/1190000015995506 2、软件移植 移植文件分析 stm32自带USB接口,OTG-FS(全速)和OTG-HS(高速),因为stm32f4只带有高速PHY,想使用高速模式,就需要外扩高速PHY,在此为USB3300。 系统配置一个Device端口,一个Host端口; Device端
[单片机]
<font color='red'>STM32</font>移植<font color='red'>USB</font>驱动总结
STM32学习手记:数据的保存与毁灭
从51开始,单片机玩了很长时间了,有51,PIC,AVR等等,早就想跟潮流玩玩ARM,但一直没有开始,原因-----不知道玩了ARM可以做什么(对我自己而言)。如果为学习而学习,肯定学不好。然后cortex-m3出来了,据说,这东西可以替代单片机,于是马上开始关注。也在第一时间开始学习,可惜一开始就有点站错了队,选错了型(仍是对我自己而言)。我希望这种芯片应该是满大街都是,随便哪里都可以买得到,但我选的第一种显然做不到。为此,大概浪费了一年多时间吧,现在,回到对我来说是正确的道路上来啦,边学边写点东西 这里写的是我的学习的过程,显然,很多时候会是不全面的,不系统的,感悟式的,甚至有时会是错误的,有些做法会是不专业的。
[单片机]
<font color='red'>STM32</font>学习手记:数据的保存与毁灭
STM32学习笔记3——stm32系统时钟树
①HSI 是内部高速时钟, RC 振荡器, 频率为 8MHz。 可作为系统时钟或 PLL 锁相环的输入。 ②HSE 是外部高速时钟。 可通过外接一个频率范围是 4-16MHz 的时钟或者晶振。 HSE 可以作为系统时钟和 PLL 锁相环输入, 还可以经过 128 分频后输入给 RTC。 ③LSI 是内部低速时钟, RC 振荡器, 频率大约为 40K, 可供独立看门狗和 RTC 使用, 并且独立看门狗只能使用 LSI 时钟。 ④LSE 是外部低速时钟,芯片上有相应的外部低速时钟管脚。 通常在此管脚上外接一个 32.768KHz 的晶振, 供 RTC使用。 ⑤PLL 是锁相环, 用于倍频输出。
[单片机]
<font color='red'>STM32</font>学习笔记3——<font color='red'>stm32</font>系统时钟树
STM32中断系统详解
1.中断的基本概念 1.1处理器中的中断:在处理器中,CPU正在执行某一段代码时遇到内部或者外部的紧急事件需要处理,暂停当前执行的代码、转而去处理紧急事件,处理完毕后继续执行之前的代码。 1.2中断的意义:中断可以提高CPU运行的效率、避免对某一事件状态的不断轮询损耗CPU资源,同时可以对紧急事件做实时处理;中断在计算机多任务处理中尤为重要(如:uCOS、FreeRTOS),可以实现多线程、多任务的处理; 1.3中断处理的过程:进入中断之前处理器将自动保存现场到堆栈中(现场:程勋运行的当前位置、变量的值等),根据中断向量表中的地址运行对应的中断服务程序,在退出中断前处理器会将之前保存在堆栈中的现场进行恢复(称之为出栈)、完
[单片机]
<font color='red'>STM32</font>中断系统详解
stm32定时器优先级
什么是优先级   优先级是具有高抢占式优先级的中断可以在具有低抢占式优先级的中断处理过程中被响应,即中断嵌套,或者说高抢占式优先级的中断可以嵌套低抢占式优先级的中断。   当两个中断源的抢占式优先级相同时,这两个中断将没有嵌套关系,当一个中断到来后,如果正在处理另一个中断,这个后到来的中断就要等到前一个中断处理完之后才能被处理。如果这两个中断同时到达,则中断控制器根据他们的响应优先级高低来决定先处理哪一个;如果他们的抢占式优先级和响应优先级都相等,则根据他们在中断表中的排位顺序决定先处理哪一个。 stm32定时器优先级   STM32 可以支持的 68 个外部中断通道,已经固定的分配给相应的外部设备。每个中断通道都具备自己
[单片机]
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
随便看看
