Tiny210块设备驱动之内存模拟磁盘
发布者:电竞狂人最新更新时间:2018-10-12 来源: eefocus关键字:Tiny210  块设备驱动  内存模拟磁盘 手机看文章 扫描二维码
随时随地手机看文章
ramblock.c驱动源码:
#include "linux/module.h"
#include "linux/errno.h"
#include "linux/interrupt.h"
#include "linux/mm.h"
#include "linux/fs.h"
#include "linux/kernel.h"
#include "linux/timer.h"
#include "linux/genhd.h"
#include "linux/hdreg.h"
#include "linux/ioport.h"
#include "linux/init.h"
#include "linux/wait.h"
#include "linux/blkdev.h"
#include "linux/blkpg.h"
#include "linux/delay.h"
#include "linux/io.h"
#include "linux/gfp.h"
#include "linux/slab.h"
#include "asm/system.h"
#include "asm/uaccess.h"
#include "asm/dma.h"
#define RAMDISK_SIZE (1024*1024)
static DEFINE_SPINLOCK(ramdisk_lock);
static const struct block_device_operations ramdisk_fops = {
    .owner    = THIS_MODULE,
static struct gendisk *ramblock_disk;
static struct request_queue *ramblock_queue;
static unsigned char *ram_buff;
static int major;
static void ramblock_do_request(struct request_queue * q)
    struct request *req;
    printk("do:ramblock_do_request\n");
    req = blk_fetch_request(q);
    while (req)
        //源或目的
        unsigned long offset = blk_rq_pos(req) * 512;
        //目的或源
        //req->buffer
        //长度
        unsigned long len  = blk_rq_cur_bytes(req);
        if (rq_data_dir(req) == READ)
            memcpy(req->buffer, ram_buff+offset, len);
        else
            memcpy(ram_buff+offset, req->buffer, len);
        // wrap up, 0 = success, -errno = fail
        if (!__blk_end_request_cur(req, 0))
static int ramblock_init(void)
    //获得主设备号
    major = register_blkdev(major, "ramdisk");
    //1.分配一个gendisk结构体
    ramblock_disk = alloc_disk(16);
    //2.设置
    //2.1设置一个请求队列
    ramblock_queue = blk_init_queue(ramblock_do_request, &ramdisk_lock);
    ramblock_disk->queue = ramblock_queue;
    //2.2设置其他信息
    ramblock_disk->major = major;
    ramblock_disk->first_minor = 0;
    sprintf(ramblock_disk->disk_name, "ramdisk");
    ramblock_disk->fops = &ramdisk_fops;
    set_capacity(ramblock_disk, RAMDISK_SIZE);
    //3.硬件相关
    ram_buff = kzalloc(RAMDISK_SIZE, GFP_KERNEL);
    //4.注册
    add_disk(ramblock_disk);
    return 0;
static void ramblock_exit(void)
    unregister_blkdev(major, "ramdisk");
    del_gendisk(ramblock_disk);
    put_disk(ramblock_disk);
    blk_cleanup_queue(ramblock_queue);
    kfree(ram_buff);
module_init(ramblock_init);
module_exit(ramblock_exit);
MODULE_LICENSE("GPL");
关键字:Tiny210  块设备驱动  内存模拟磁盘 引用地址:Tiny210块设备驱动之内存模拟磁盘
上一篇:Tiny210驱动之NAND_FLASH驱动程序
下一篇:Tiny210驱动之USB设备驱动程序
推荐阅读最新更新时间:2024-03-16 16:15
Tiny210驱动之LED测试
first_drv.c驱动源码: #include linux/device.h #include linux/module.h #include linux/kernel.h #include linux/fs.h #include linux/init.h #include linux/delay.h #include asm/uaccess.h #include asm/irq.h #include asm/io.h static struct class *firstdrv_class; volatile unsigned long *gpj2con = NULL; volatile unsigned l
[单片机]
Tiny210裸机之nand_flash操作
start.S源码: .global _start _start: ldr sp, =0xD0030000 @初始化堆栈 b main //跳到main ==================================================================== main.c源码: #include command.h #include clock.h #include led.h #include uart.h #include lib.h #include nand.h #define CFG_PROMPT WY_BOOT # // Monitor Command Pr
[单片机]
OK6410设备驱动内存模拟nor_flash
ram_nor.c源码: //参考: drivers\mtd\chips\map_ram.c #include linux/module.h #include linux/types.h #include linux/kernel.h #include linux/sched.h #include linux/init.h #include asm/io.h #include asm/byteorder.h #include linux/errno.h #include linux/slab.h #include linux/delay.h #include linux/interrupt.h #inclu
[单片机]
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
