AVR Mega16 PAL/NTSC制式 B/W 信号模拟
发布者:koimqerolulk最新更新时间:2018-10-17 来源: eefocus关键字:AVR  Mega16  PAL  NTSC制式  信号模拟 手机看文章 扫描二维码
随时随地手机看文章
资料参考
http://www.rickard.gunee.com/projects/video/pic/howto.php
http://tinyvga.com/avr-sdram-vga
http://www.serasidis.gr/circuits/colour_bar_gen/colour_bar_gen.htm
http://belogic.com/uzebox/index.asp
AVR <wbr>Mega16 <wbr>PAL/NTSC制式 <wbr>B/W <wbr>信号模拟
以下引用自 http://eyetap.org/ece385/lab5.htm
SEQUENCE:
  • Horizontal sync (hsync) pulse: Start each scanline with 0.3V, then 0V for 4.7us (microseconds), and then back to 0.3V. This tells the TV to start drawing a new scanline
  • The "Back Porch": A transition region of 0.3V for 5.9us between the hsync pulse and the visible region, off the left edge of the TV
  • Visible scan region: This is the part you actually see. 0.3V shows up as black, 1V as white, everything in between is greyscale. The visible region lasts for 51.5us
  • The "Front Porch": A transition region of 0.3V for 1.4us before the hsync pulse of the next line, off the right edge of the TV
  • Vertical sync (vsync) pulse: Lines 243-262 of each frame (off the bottom of the TV) start with 0.3V for 4.7us, and the rest is 0V. This tells the TV to prepare for a new frame. Think of it as just 0V with an inverted sync pulse
       代码模拟的PAL信号时序,SPI输出f_cpu/2=16Mhz/2=8Mhz.
        #include
关键字:AVR  Mega16  PAL  NTSC制式  信号模拟 引用地址:AVR Mega16 PAL/NTSC制式 B/W 信号模拟
上一篇:AVR使用范例--使用Bootloader 升级芯片内程序详解
下一篇:AVR Mega8 V-USB general & multimedia keys via IR transmitor
推荐阅读最新更新时间:2024-03-16 16:16
功率50W到300W的AC-DC LED应用
  在功率50W到300W的AC-DCLED应用广泛用于街道照明及大功率区域照明应用中,可以采用不同的LED驱动方案,假定其输入电压规格为90至264Vac,功率因数高于0.95能效达90%。   此类应用可以采用下述不同方案,适合不同应用要求:   NCP1652:改进型单段式PFC   NCP1607/8+NCP1377:临界导电模式PFC+准谐振电流模式PWM   NCP1607/8+NCP1396:临界导电模式PFC+半桥谐振LLC   NCP1901:最新型两段式(PFC+更高效率半桥谐振LLC)   例如,在50W-150W的AC-DCLED应用中,既可以采用NCP1652这样的改进型单段式PFC控制器,也
[电源管理]
功率50<font color='red'>W</font>到300<font color='red'>W</font>的AC-DC LED应用
基于51单片机的2.0-R61503B 8bits TFT彩屏刷屏触摸驱动程序
单片机源程序如下: #include reg52.h #include gui.h #include touch.h void main() { uchar rst = 0; //--多出来两个值使用来在内存上面跟别的变量分隔的--// uchar xValue = {0, 0, 0, 0, 0, 0}, yValue = {0, 0, 0, 0, 0, 0}; long x, y; TFT_Init(); rst = 1; while(1) { if(rst == 1) { TFT_Cl
[单片机]
基于51单片机的2.0-R61503<font color='red'>B</font> 8bits TFT彩屏刷屏触摸驱动程序
基于AVR单片机的I SP1362 OTG设计
0 引言 随着PDA、移动电话、数码相机、打印机等消费类产品的普及,用于这些设备与电脑、或设备与设备之间的高速数据传输技术越来越受到人们的关注。以往以计算机为核心的数据传输结构,非常不利于USB,总线在嵌入式行业的应用,也不适用于野外作业,而OTG技术的推出则可实现在没有PC的情况下,设备与设备之间的数据传输,它拓展了USB技术的应用范围。本文采用的设计方案是基于Philips公司的ISP1362 OTG控制芯片,参照最新的USB OTG技术规范,设计了一种遵循USB协议的主/从机系统。 1 ISP1362芯片的内部结构 Philips公司的ISP1362是一款符合USB 2.0总线协议的接口芯片,内部有3个USB控
[单片机]
AVR单片机入门系列(26)AVR PWM OC2
系统功能 AVR内部脉宽调制OC2输出实验,用LED指示PWM的频率,在PWM速度较低时,可观察到LED的闪烁。 硬件设计 AVR主控电路原理图 软件设计 //目标系统: 基于AVR单片机 //应用软件: ICC AVR /*01010101010101010101010101010101010101010101010101010101010101010101 ---------------------------------------------------------------------- 实验内容: AVR内部脉宽调制输出实验,用LED指示PWM的频率,在PWM速度较低时,可观察到LED的闪烁。 --
[单片机]
使用串口通信实现AVR的ISP下载
这段时间看了芯艺的AVR教程,准备自己做一个串口下载工具,想法很简单,使用串口的交互,将数据发送到AVR单片机中,在单片机中实现真正的下载功能,给其他的单片机下载程序。因为有了下载到89S52的范例,感觉应该不会有太大的技术障碍。 准备步骤: 1.先做一个简单功能的AVR开发板,包括一个流水灯、串口、下载口,还要一个使用5位的数据口,用来控制另一开发板的下载。 2.实现一个类似带调试功能的串口通讯程序,跟Windows自带的差不多的串口通信程序,仅仅在某些命令后,弹出对话框,选择需要的文件,比如WriteFlash命令后选择程序文件。 3.最后实现与原先功能相同的开发板,使用之前的开发板作为下载器,下载程序。
[单片机]
AVR应用笔记二(定时器0溢出中断)
简介:本文主要为关于定时器0溢出中断的程序处理。 //--------------------------------------------------------------------- //Copyright(c) 博控设计joecongmin 2010 All righr reserved //文件名:timer0_test1.c //文件描述:用定时器1完成100US定时,一秒钟到后取反PC1口 //外接的LED灯,实现LED灯的闪烁。 //实验目的:学习AVR 单片机的定时器0用作定时器用的方法 //当前版本号:V1.0 //完成时间:2010-4-7 13:02:45 //修改记录: //修改时间: /起草时间
[单片机]
ROHM旗下LAPIS开发高可靠性NOR Flash存储器“MR29V12852B
ROHM集团旗下的LAPIS Semiconductor公司(蓝碧石半导体)开发出128Mbit NOR Flash存储器 MR29V12852B ,该产品非常适用于对品质有高要求的车载设备和工业设备的数据存储介质。 Flash存储器根据存储数据的存储单元的排列形式不同而分为NAND型和NOR型两种。NAND型的特征是每比特的价格相对便宜,多用作手机、数码相机、数码音响等保存数字数据的存储介质;NOR型的特征是存储数据的可靠性高,多用作品质要求高的车载设备、工业设备等保存固件的存储介质。 包括Flash存储器在内的非易失性存储器,毋庸置疑会有偶发数据错误的可能性。尤其在品质要求高的车载设备和工业设备中,为了系统
[嵌入式]
ROHM旗下LAPIS开发高可靠性NOR Flash存储器“MR29V12852<font color='red'>B</font>”
输出1200V,800W,输出脉宽可调的电源电路
输出1200V,800W,输出脉宽可调的电源电路:由芯片 SG3525A 组成。
[电源管理]
输出1200V,800<font color='red'>W</font>,输出脉宽可调的电源电路
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
热门活动
换一批
更多
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
更多精选电路图
换一换 更多 相关热搜器件
更多每日新闻
随便看看
