// NAME: main.c
// DESC: TQ2440串口UART测试程序
#include "def.h"
#include "option.h"
#include "2440addr.h"
#include
#include
#include
#include
#include
static volatile int uart_port = 0;
void uart_init(int pclk,int buad,int ch)
//UART初始化:端口使能、功能设定、波特率、设置数据格式
rGPHCON = (rGPHCON & ~(0xfff<<4)) | (0xaaa<<4);//端口RX[0:2]、TX[0:2]功能
rGPHUP = rGPHUP | (0x7<<1); //端口GPH[1:3]禁止上拉
rUFCON0 = 0x0; //禁止FIFO
rUFCON1 = 0x0; //禁止FIFO
rUFCON2 = 0x0; //禁止FIFO
rUMCON0 = 0x0; //禁止AFC
rUMCON1 = 0x0; //禁止AFC
//Normal:No parity:One stop:8-bits 中断响应 UART clock: PCLK
rULCON0 = (rULCON0 & ~0xff) | ((0x0<<6)|(0x0<<3)|(0x0<<2)|(0x3));
rUCON0 = (rUCON0 & ~0x3ff) | ((0x1<<9)|(0x1<<6)|(0x1<<2)|(0x1));
rUBRDIV0 = ((int)(pclk/16./buad+0.5)-1);
rULCON1 = (rULCON1 & ~0xff) | ((0x0<<6)|(0x0<<3)|(0x0<<2)|(0x3));
rUCON1 = (rUCON1 & ~0x3ff) | ((0x1<<9)|(0x1<<6)|(0x1<<2)|(0x1));
rUBRDIV1 = ((int)(pclk/16./buad+0.5)-1);
rULCON2 = (rULCON2 & ~0xff) | ((0x0<<6)|(0x0<<3)|(0x0<<2)|(0x3));
rUCON2 = (rUCON2 & ~0x3ff) | ((0x1<<9)|(0x1<<6)|(0x1<<2)|(0x1));
rUBRDIV2 = ((int)(pclk/16./buad+0.5)-1);
uart_port = ch; //设置串口端口号
// 串口发送函数
void uart_send_byte(int data)
if(0 == uart_port)
if(data == 'n')
while(!(rUTRSTAT0 & 0x2));
rUTXH0 = 'n';
rUTXH0 = data;
else if(1 == uart_port)
if(data == 'n')
while(!(rUTRSTAT1 & 0x2));
rUTXH1 = 'n';
rUTXH1 = data;
else if(2 == uart_port)
if(data == 'n')
while(!(rUTRSTAT2 & 0x2));
rUTXH2 = 'n';
rUTXH2 = data;
void uart_send_string(char *string)
while(*string)
uart_send_byte(*string++);
void uart_printf(char *fmt,...)
va_list ap;
char string[256];
va_start(ap,fmt);
vsprintf(string,fmt,ap);
uart_send_string(string);
va_end(ap);
// 串口接收函数
void uart_tx_empty(void)
if(0 == uart_port)
while(!(rUTRSTAT0 & 0x4));//等待Tx为空
if(1 == uart_port)
while(!(rUTRSTAT1 & 0x4));//等待Tx为空
if(2 == uart_port)
while(!(rUTRSTAT2 & 0x4));//等待Tx为空
char uart_get_ch(void)
if(0 == uart_port)
while(!(rUTRSTAT0 & 0x1));//等待Rx被读
return rURXH0; //读缓存寄存器
while(!(rUTRSTAT1 & 0x1));//等待Rx被读
return rURXH1; //读缓存寄存器
while(!(rUTRSTAT2 & 0x1));//等待Rx被读
return rURXH2; //读缓存寄存器
return 0;
char uart_get_key(void)
if(0 == uart_port)
if(rUTRSTAT0 & 0x1) //Rx被读
else
return 0;
if(1 == uart_port)
if(rUTRSTAT1 & 0x1) //Rx被读
else
return 0;
if(2 == uart_port)
if(rUTRSTAT2 & 0x1) //Rx被读
else
return 0;
return 0;
void uart_get_string(char *string)
char *string1 = string;
char c = 0;
while((c = uart_get_ch())!='r')
if(c == 'b')
if((int)string1 < (int)string)
uart_printf("bb");
string--;
else
*string++ = c;
uart_send_byte(c);
*string = '�';
uart_send_byte('n');
int uart_get_intnum(void)
char str[30];
char *string = str;
int base = 10;
int minus = 0;
int result = 0;
int last_index;
int i;
uart_get_string(string);
if(string[0] == '-')
minus = 1;
string++;
if(string[0] == '0' && (string[1] == 'x' || string[1] == 'X'))
base = 16;
string = string + 2;
last_index = strlen(string)-1;
if(last_index < 0)
return -1;
if(string[last_index] == 'h' || string[last_index] == 'H')
base = 16;
string[last_index] = 0;
last_index--;
if(base == 10)
//atoi将字符串转换为整型值
result = atoi(string);
result = minus ? (-1*result) : result;
else
for(i=0;i<=last_index;i++)
//判断字符是否为英文字母,当为英文字母a-z或A-Z时,返回非零值,否则返回零。
if(isalpha(string[i]))
//isupper 判断字符是否为大写英文字母,当c为大写英文字母,返回非零值,否则返回零。
if(isupper(string[i]))
result = (result<<4) + string[i]-'A'+10;
else
result = (result<<4) + string[i]-'a'+10;
else
result = (result<<4) + string[i]-'0'+10;
return result;
int uart_get_intnum_gj(void)
char string[16];
char *p_string = string;
char c;
int i = 0;
int data = 0;
while((c = uart_get_ch()) != 'r')
if(c == 'b')
p_string--;
else
*p_string++ = c;
//uart_send_byte(c);
*p_string = '�';
i=0;
while(string[i] != '�')
] data = data*10;
if(string[i]
return -1;
data = data +(string[i]-'0');
i++;
return data;
void Main(void)
uart_init(50000000,115200,0);
while(1)
if('-' == uart_get_ch())
uart_printf("+n");
if('+' == uart_get_key())
uart_printf("-n");
上一篇:TQ2440裸奔程序:串口UART打印printf测试程序
下一篇:ARM9:如何将linux2.6.38内核移植到TQ2440
推荐阅读最新更新时间:2024-03-16 16:18
