注意:数据的运算可能会超过变量定义的类型 ,所以定义变量时要注意!
STM32F4内的变量类型定义:在stdint中
/* exact-width signed integer types */
typedef signed char int8_t;
typedef signed short int int16_t;
typedef signed int int32_t;//在32位环境里,int代表4个字节32位
typedef signed __INT64 int64_t;
/* exact-width unsigned integer types */
typedef unsigned char uint8_t;
typedef unsigned short int uint16_t;
typedef unsigned int uint32_t;
typedef unsigned __INT64 uint64_t;
/* 7.18.1.2 */
/* smallest type of at least n bits */
/* minimum-width signed integer types */
typedef signed char int_least8_t;
typedef signed short int int_least16_t;
typedef signed int int_least32_t;
typedef signed __INT64 int_least64_t;
/* minimum-width unsigned integer types */
typedef unsigned char uint_least8_t;
typedef unsigned short int uint_least16_t;
typedef unsigned int uint_least32_t;
typedef unsigned __INT64 uint_least64_t;
/* 7.18.1.3 */
/* fastest minimum-width signed integer types */
typedef signed int int_fast8_t;
typedef signed int int_fast16_t;
typedef signed int int_fast32_t;
typedef signed __INT64 int_fast64_t;
/* fastest minimum-width unsigned integer types */
typedef unsigned int uint_fast8_t;
typedef unsigned int uint_fast16_t;
typedef unsigned int uint_fast32_t;
typedef unsigned __INT64 uint_fast64_t;
/* 7.18.1.4 integer types capable of holding object pointers */
#if __sizeof_ptr == 8
typedef signed __INT64 intptr_t;
typedef unsigned __INT64 uintptr_t;
#else
typedef signed int intptr_t;
typedef unsigned int uintptr_t;
#endif
/* 7.18.1.5 greatest-width integer types */
typedef signed __LONGLONG intmax_t;
typedef unsigned __LONGLONG uintmax_t;
#if !defined(__cplusplus) || defined(__STDC_LIMIT_MACROS)
/* 7.18.2.1 */
/* minimum values of exact-width signed integer types */
#define INT8_MIN -128
#define INT16_MIN -32768
#define INT32_MIN (~0x7fffffff) /* -2147483648 is unsigned */
#define INT64_MIN __INT64_C(~0x7fffffffffffffff) /* -9223372036854775808 is unsigned */
/* maximum values of exact-width signed integer types */
#define INT8_MAX 127
#define INT16_MAX 32767
#define INT32_MAX 2147483647
#define INT64_MAX __INT64_C(9223372036854775807)
/* maximum values of exact-width unsigned integer types */
#define UINT8_MAX 255
#define UINT16_MAX 65535
#define UINT32_MAX 4294967295u
#define UINT64_MAX __UINT64_C(18446744073709551615)
参考:https://blog.csdn.net/f1engmin11/article/details/70946471 和上述库文件中的一致
上一篇:stm32F4XX之独立看门狗 HAL库
下一篇:STM32堆栈大小及位置
推荐阅读最新更新时间:2024-03-16 16:22
