前言
最近在调试STM32F2XX系列ADC多通道DMA采集时,发现采集的AD值大于4095,有的65000多了,这是什么节奏?adc不是12位吗,最大才0xfff,即4095,怎么会出现这种情况呢?难到是adc数据对齐方式出现问题了,adc的对齐明明设置的是右对齐啊,神马情况?
ADC结构体参数分析
百思不得adc之姐,只能keil单步调试,一步一步查看adc结构体的参数。我使用的是adc dma方式采集,共9个通道。初始化程序如下:
void ADC_DMA_Config(void)
ADC_InitTypeDef ADC_InitStructure;
ADC_CommonInitTypeDef ADC_CommonInitStructure;
DMA_InitTypeDef DMA_InitStructure;
GPIO_InitTypeDef GPIO_InitStructure;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2 | RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_GPIOC, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
DMA_InitStructure.DMA_Channel = DMA_Channel_0;
DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)&ADC1->DR;
DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&ADC_ConvertedValue;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
DMA_InitStructure.DMA_BufferSize = Sample_Num*Channel_Num;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
DMA_Init(DMA2_Stream0, &DMA_InitStructure);
DMA_Cmd(DMA2_Stream0, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 |GPIO_Pin_2 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_3 | GPIO_Pin_5;
GPIO_Init(GPIOC, &GPIO_InitStructure);
/* ADC Common Init **********************************************************/
ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
ADC_CommonInit(&ADC_CommonInitStructure);
ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
ADC_InitStructure.ADC_ScanConvMode = ENABLE;
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
ADC_InitStructure.ADC_NbrOfConversion = 9;
ADC_Init(ADC1, &ADC_InitStructure);
ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_3Cycles);
ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_3Cycles);
ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_3Cycles);
ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 4, ADC_SampleTime_3Cycles);
ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 5, ADC_SampleTime_3Cycles);
ADC_RegularChannelConfig(ADC1, ADC_Channel_7, 6, ADC_SampleTime_3Cycles);
ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 7, ADC_SampleTime_3Cycles);
ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 8, ADC_SampleTime_3Cycles);
ADC_RegularChannelConfig(ADC1, ADC_Channel_15, 9, ADC_SampleTime_3Cycles);
ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE);
ADC_DMACmd(ADC1, ENABLE);
ADC_Cmd(ADC1, ENABLE);
其中涉及adc的初始化结构体代码部分如下:
一步一步调式发现结构体有一项ADC_ExternalTrigConv是0x08002d54,这一项并没有初始化对其赋值,忘记给结构体的这一项赋值了。最后这个值通过ADC_Init函数赋值给CR2的时候,第11位(也就是数据对其位)是1了,左对齐了!!!!!
下面来重点分析下adc初始化结构体中的各项参数的意义:
对于STM32,在使用ADC的时候需要配置几个参数。
(1) 第一个参数是ADC_Mode,这里设置为独立模式:
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
在这个模式下,双ADC不能同步,每个ADC接口独立工作。所以如果不需要ADC同步或者只是用了一个ADC的时候,就应该设成独立模式了。
(2) 第二个参数是ADC_ScanConvMode,这里设置为DISABLE。
如果只是用了一个通道的话,DISABLE就可以了,如果使用了多个通道的话,则必须将其设置为ENABLE。
(3) 第三个参数是ADC_ContinuousConvMode,这里设置为ENABLE,即连续转换。
如果设置为DISABLE,则是单次转换。两者的区别在于连续转换直到所有的数据转换完成后才停止转换,而单次转换则只转换一次数据就停止,要再次触发转换才可以。所以如果需要一次性采集1024个数据或者更多,则采用连续转换。
(4) 第四个参数是ADC_ExternalTrigConv,即选择外部触发模式。这里只讲三种:
1、第一种是最简单的软件触发,参数一般为ADC_ExternalTrigConv_None(注意STM32F2XX系列这个有点蹊跷,后面会讲这个)。设置好后还要记得调用库函数:
ADC_SoftwareStartConvCmd(ADC1, ENABLE);
void ADC_SoftwareStartConv(ADC_TypeDef* ADCx)
/* Check the parameters */
assert_param(IS_ADC_ALL_PERIPH(ADCx));
/* Enable the selected ADC conversion for regular group */
ADCx->CR2 |= (uint32_t)ADC_CR2_SWSTART;
#define ADC_CR2_SWSTART ((uint32_t)0x40000000)
/*! ADC_SoftwareStartConv函数里直接置位CR2的ADC_CR2_SWSTART位,这样触发就启动了。 2、第二种是定时器通道输出触发。共有这几种:ADC_ExternalTrigConv_T1_CC1、ADC_ExternalTrigConv_T1_CC2、ADC_ExternalTrigConv_T2_CC2、 ADC_ExternalTrigConv_T3_T以及ADC_ExternalTrigConv_T4_CC4。定时器输出触发比较麻烦,还需要设置相应的定时器。以 ADC_ExternalTrigConv_T2_CC2触发为例设置相应的定时器: void TIM2_Configuration(void) { TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; TIM_TimeBaseStructure.TIM_Prescaler = 4; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseStructure.TIM_Period = 0XFF; TIM_TimeBaseStructure.TIM_ClockDivision = 0; TIM_TimeBaseStructure.TIM_RepetitionCounter = 0; TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure); TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_Pulse = 0X7F; TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low; TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set; //配置CC2的属性。若CC3作为ADC的触发源,则应改为TIM_OC3Init(TIM2, &TIM_OCInitStructure); TIM_OC2Init(TIM2, &TIM_OCInitStructure); TIM_Cmd(TIM2, ENABLE); TIM_CtrlPWMOutputs(TIM2, ENABLE); } 这样设置之后就可以用定时器2的输出触发了,至于触发的周期,设置TIM2的时间即可。这里不再赘述。 3、第三种是外部引脚触发,对于规则通道,选择EXTI线11和TIM8_TRGO作为外部触发事件;而注入通道组则选择EXTI线15和TIM8_CC4作为外部触发事件。 (5) 第五个参数是ADC_DataAlign,这里设置为ADC_DataAlign_Right右对齐方式。建议采用右对齐方式,因为这样处理数据会比较方便。当然如果要从高位开始传输数据,那么采用左对齐优势就明显了。 (6) 第六个参数是ADC_NbrOfChannel,顾名思义:通道的数量。要是到多个通道采集数据的话就得设置一下这个参数。此外在规则通道组的配置函数中也许将各个通道的顺序定义一下,如: ADC_RegularChannelConfig(ADC1,ADC_Channel_13,1,ADC_SampleTime_13Cycles5); ADC_RegularChannelConfig(ADC1,ADC_Channel_14,2,ADC_SampleTime_13Cycles5); 多通道数据传输时有一点还要注意:若一个数组为ADC_ValueTab[4],且设置了两个通道:通道1和通道2,则转换结束后,ADC_ValueTab[0]和ADC_ValueTab[2]存储的是通道1的数据,而ADC_ValueTab[1]和ADC_ValueTab[3]存储的是通道2的数据。如果数组容量大则依次类推。 补充一点:在使用DMA传输数据的时候,需要设置外设地址和存储器地址,外设地址当然就是ADC的地址了,而存储器的地址如果使用8位数据的话,存储器必须定义为8位缓冲区;如果使用16位数据格式的话,存储器则为16位缓冲器,不可定义为32位或更多,否则,数据将出错。 问题的解决方法 上面分析了adc结构体的参数,下面再来单独看看ADC_ExternalTrigConv这一项。 在stm32f2xx_adc.h文件中有这个成员的参数定义,发现里面并没有ADC_ExternalTrigConv_None这个常见的定义。 /** @defgroup ADC_extrenal_trigger_sources_for_regular_channels_conversion * @{ */ #define ADC_ExternalTrigConv_T1_CC1 ((uint32_t)0x00000000) #define ADC_ExternalTrigConv_T1_CC2 ((uint32_t)0x01000000) #define ADC_ExternalTrigConv_T1_CC3 ((uint32_t)0x02000000) #define ADC_ExternalTrigConv_T2_CC2 ((uint32_t)0x03000000) #define ADC_ExternalTrigConv_T2_CC3 ((uint32_t)0x04000000) #define ADC_ExternalTrigConv_T2_CC4 ((uint32_t)0x05000000) #define ADC_ExternalTrigConv_T2_TRGO ((uint32_t)0x06000000) #define ADC_ExternalTrigConv_T3_CC1 ((uint32_t)0x07000000) #define ADC_ExternalTrigConv_T3_TRGO ((uint32_t)0x08000000) #define ADC_ExternalTrigConv_T4_CC4 ((uint32_t)0x09000000) #define ADC_ExternalTrigConv_T5_CC1 ((uint32_t)0x0A000000) #define ADC_ExternalTrigConv_T5_CC2 ((uint32_t)0x0B000000) #define ADC_ExternalTrigConv_T5_CC3 ((uint32_t)0x0C000000) #define ADC_ExternalTrigConv_T8_CC1 ((uint32_t)0x0D000000) #define ADC_ExternalTrigConv_T8_TRGO ((uint32_t)0x0E000000) #define ADC_ExternalTrigConv_Ext_IT11 ((uint32_t)0x0F000000) 再来看看stm32f10x_adc.h文件中的ADC_ExternalTrigConv的参数定义: /** @defgroup ADC_external_trigger_sources_for_regular_channels_conversion * @{ */ #define ADC_ExternalTrigConv_T1_CC1 ((uint32_t)0x00000000) /*!< For ADC1 and ADC2 */ #define ADC_ExternalTrigConv_T1_CC2 ((uint32_t)0x00020000) /*!< For ADC1 and ADC2 */ #define ADC_ExternalTrigConv_T2_CC2 ((uint32_t)0x00060000) /*!< For ADC1 and ADC2 */ #define ADC_ExternalTrigConv_T3_TRGO ((uint32_t)0x00080000) /*!< For ADC1 and ADC2 */ #define ADC_ExternalTrigConv_T4_CC4 ((uint32_t)0x000A0000) /*!< For ADC1 and ADC2 */ #define ADC_ExternalTrigConv_Ext_IT11_TIM8_TRGO ((uint32_t)0x000C0000) /*!< For ADC1 and ADC2 */ #define ADC_ExternalTrigConv_T1_CC3 ((uint32_t)0x00040000) /*!< For ADC1, ADC2 and ADC3 */ #define ADC_ExternalTrigConv_None ((uint32_t)0x000E0000) /*!< For ADC1, ADC2 and ADC3 */ //f2xx系列并没有这个定义 #define ADC_ExternalTrigConv_T3_CC1 ((uint32_t)0x00000000) /*!< For ADC3 only */ #define ADC_ExternalTrigConv_T2_CC3 ((uint32_t)0x00020000) /*!< For ADC3 only */ #define ADC_ExternalTrigConv_T8_CC1 ((uint32_t)0x00060000) /*!< For ADC3 only */ #define ADC_ExternalTrigConv_T8_TRGO ((uint32_t)0x00080000) /*!< For ADC3 only */ #define ADC_ExternalTrigConv_T5_CC1 ((uint32_t)0x000A0000) /*!< For ADC3 only */ #define ADC_ExternalTrigConv_T5_CC3 ((uint32_t)0x000C0000) /*!< For ADC3 only */ 对比发现stm32f2xx系列并没有ADC_ExternalTrigConv_None这个定义,很是奇怪,现在还不明白ST的工程师为什么做这个变动。 那么问题怎么解决呢? 一种是进行adc结构体的初始化操作,在配置之前恢复默认值。即调用ADC_StructInit(&ADC_InitStructure);修改如下: ADC_StructInit(&ADC_InitStructure);//新增加的 ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b; ADC_InitStructure.ADC_ScanConvMode = ENABLE; ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None; ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; ADC_InitStructure.ADC_NbrOfConversion = 9; ADC_Init(ADC1, &ADC_InitStructure); 调用ADC_StructInit(&ADC_InitStructure)语句,ADC_ExternalTrigConv会恢复默认值0。如下: 另一种方法是直接配置该参数为0,如下: ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b; ADC_InitStructure.ADC_ScanConvMode = ENABLE; ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None; ADC_InitStructure.ADC_ExternalTrigConv= 0;//新增加的 ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; ADC_InitStructure.ADC_NbrOfConversion = 9; ADC_Init(ADC1, &ADC_InitStructure); 这两种方法都可以解决adc采样对齐方式异常问题。 但是ADC_ExternalTrigConv= 0在stm32f2xx_adc.h中其实是对应ADC_ExternalTrigConv_T1_CC1的。 也就是说调用软件触发函数ADC_SoftwareStartConv函数里直接置位CR2的ADC_CR2_SWSTART位也可以触发定时器触发方式的adc通道。
上一篇:STM32——多通道ADC的DMA方式采集方法
下一篇:STM32—DMA使用
推荐阅读最新更新时间:2024-03-16 16:23
