@ File:head.s
@ 功能:设置SDRAM,将程序复制到SDRAM,然后跳到SDRAM继续执行
.text
.global _start
_start:
@函数disable_watch_dog, memsetup, init_nand, nand_read_ll在init.c中定义
ldr sp, =4096 @设置堆栈
bl disable_watch_dog @关WATCH DOG
bl memsetup @初始化SDRAM
bl nand_init @初始化NAND Flash
@将NAND Flash中地址4096开始的1024字节代码(main.c编译得到)复制到SDRAM中
@nand_read_ll函数需要3个参数:
ldr r0, =0x30000000 @1. 目标地址=0x30000000,这是SDRAM的起始地址
mov r1, #4096 @2. 源地址 = 4096,连接的时候,main.c中的代码都存在NAND Flash地址4096开始处
mov r2, #1024 @3. 复制长度= 1024(bytes),对于本实验的main.c,这是足够了
bl nand_read @调用C函数nand_read
ldr sp, =0x34000000 @设置栈
ldr lr, =halt_loop @设置返回地址
ldr pc, =main @b指令和bl指令只能前后跳转32M的范围,所以这里使用向pc赋值的方法进行跳转
halt_loop:
b halt_loop
#define WTCON (*(volatile unsigned long *)0x53000000)
#define MEM_CTL_BASE 0x48000000
void disable_watch_dog();
void memsetup();
WTCON = 0;
void memsetup()
int i = 0;
unsigned long *p = (unsigned long *)MEM_CTL_BASE;
unsigned long const mem_cfg_val[]={ 0x22011110, //BWSCON
0x00000700, //BANKCON0
0x00000700, //BANKCON1
0x00000700, //BANKCON2
0x00000700, //BANKCON3
0x00000700, //BANKCON4
0x00000700, //BANKCON5
0x00018005, //BANKCON6
0x00018005, //BANKCON7
0x008C07A3, //REFRESH
0x000000B1, //BANKSIZE
0x00000030, //MRSRB6
0x00000030, //MRSRB7
for(; i < 13; i++)
p[i] = mem_cfg_val[i];
nand.c
#define GSTATUS1 (*(volatile unsigned int *)0x560000B0)
#define BUSY 1
typedef unsigned int S3C24X0_REG32;
typedef struct {
S3C24X0_REG32 NFCONF;
S3C24X0_REG32 NFCMD;
S3C24X0_REG32 NFADDR;
S3C24X0_REG32 NFDATA;
S3C24X0_REG32 NFSTAT;
S3C24X0_REG32 NFECC;
} S3C2410_NAND;
typedef struct {
S3C24X0_REG32 NFCONT;
S3C24X0_REG32 NFMECCD0;
S3C24X0_REG32 NFMECCD1;
S3C24X0_REG32 NFSECCD;
S3C24X0_REG32 NFESTAT0;
S3C24X0_REG32 NFESTAT1;
S3C24X0_REG32 NFMECC0;
S3C24X0_REG32 NFMECC1;
S3C24X0_REG32 NFSECC;
S3C24X0_REG32 NFSBLK;
S3C24X0_REG32 NFEBLK;
} S3C2440_NAND;
typedef struct {
void (*nand_reset)(void);
void (*wait_idle)(void);
void (*nand_select_chip)(void);
void (*nand_deselect_chip)(void);
void (*write_cmd)(int cmd);
void (*write_addr)(unsigned int addr);
unsigned char (*read_data)(void);
}t_nand_chip;
static S3C2410_NAND * s3c2410nand = (S3C2410_NAND *)0x4e000000;
static S3C2440_NAND * s3c2440nand = (S3C2440_NAND *)0x4e000000;
static t_nand_chip nand_chip;
void nand_init(void);
void nand_read(unsigned char *buf, unsigned long start_addr, int size);
static void nand_reset(void);
static void wait_idle(void);
static void nand_select_chip(void);
static void nand_deselect_chip(void);
static void write_cmd(int cmd);
static void write_addr(unsigned int addr);
static unsigned char read_data(void);
static void s3c2410_nand_reset(void);
static void s3c2410_wait_idle(void);
static void s3c2410_nand_select_chip(void);
static void s3c2410_nand_deselect_chip(void);
static void s3c2410_write_cmd(int cmd);
static void s3c2410_write_addr(unsigned int addr);
static unsigned char s3c2410_read_data();
static void s3c2440_nand_reset(void);
static void s3c2440_wait_idle(void);
static void s3c2440_nand_select_chip(void);
static void s3c2440_nand_deselect_chip(void);
static void s3c2440_write_cmd(int cmd);
static void s3c2440_write_addr(unsigned int addr);
static unsigned char s3c2440_read_data(void);
s3c2410_nand_select_chip();
s3c2410_write_cmd(0xff); // 复位命令
s3c2410_wait_idle();
s3c2410_nand_deselect_chip();
int i;
volatile unsigned char *p = (volatile unsigned char *)&s3c2410nand->NFSTAT;
while(!(*p & BUSY))
for(i=0; i<10; i++);
int i;
s3c2410nand->NFCONF &= ~(1<<11);
s3c2410nand->NFCONF |= (1<<11);
volatile unsigned char *p = (volatile unsigned char *)&s3c2410nand->NFCMD;
*p = cmd;
int i;
volatile unsigned char *p = (volatile unsigned char *)&s3c2410nand->NFADDR;
*p = addr & 0xff;
*p = (addr >> 9) & 0xff;
*p = (addr >> 17) & 0xff;
*p = (addr >> 25) & 0xff;
static unsigned char s3c2410_read_data(void)
volatile unsigned char *p = (volatile unsigned char *)&s3c2410nand->NFDATA;
return *p;
s3c2440_nand_select_chip();
s3c2440_write_cmd(0xff); // 复位命令
s3c2440_wait_idle();
s3c2440_nand_deselect_chip();
int i;
volatile unsigned char *p = (volatile unsigned char *)&s3c2440nand->NFSTAT;
while(!(*p & BUSY))
int i;
s3c2440nand->NFCONT &= ~(1<<1);
s3c2440nand->NFCONT |= (1<<1);
volatile unsigned char *p = (volatile unsigned char *)&s3c2440nand->NFCMD;
*p = cmd;
int i;
volatile unsigned char *p = (volatile unsigned char *)&s3c2440nand->NFADDR;
*p = addr & 0xff;
volatile unsigned char *p = (volatile unsigned char *)&s3c2440nand->NFDATA;
return *p;
nand_chip.nand_reset();
nand_chip.wait_idle();
int i;
nand_chip.nand_select_chip();
nand_chip.nand_deselect_chip();
nand_chip.write_cmd(cmd);
nand_chip.write_addr(addr);
return nand_chip.read_data();
#define TACLS 0
#define TWRPH0 3
#define TWRPH1 0
if ((GSTATUS1 == 0x32410000) || (GSTATUS1 == 0x32410002))
nand_chip.nand_reset = s3c2410_nand_reset;
nand_chip.wait_idle = s3c2410_wait_idle;
nand_chip.nand_select_chip = s3c2410_nand_select_chip;
nand_chip.nand_deselect_chip = s3c2410_nand_deselect_chip;
nand_chip.write_cmd = s3c2410_write_cmd;
nand_chip.write_addr = s3c2410_write_addr;
nand_chip.read_data = s3c2410_read_data;
s3c2410nand->NFCONF = (1<<15)|(1<<12)|(1<<11)|(TACLS<<8)|(TWRPH0<<4)|(TWRPH1<<0);
else
nand_chip.nand_reset = s3c2440_nand_reset;
nand_chip.wait_idle = s3c2440_wait_idle;
nand_chip.nand_select_chip = s3c2440_nand_select_chip;
nand_chip.nand_deselect_chip = s3c2440_nand_deselect_chip;
nand_chip.write_cmd = s3c2440_write_cmd;
nand_chip.write_addr = s3c2440_write_addr;
nand_chip.read_data = s3c2440_read_data;
s3c2440nand->NFCONF = (TACLS<<12)|(TWRPH0<<8)|(TWRPH1<<4);
s3c2440nand->NFCONT = (1<<4)|(1<<1)|(1<<0);
nand_reset();
#define NAND_SECTOR_SIZE 512
#define NAND_BLOCK_MASK (NAND_SECTOR_SIZE - 1)
int i, j;
if ((start_addr & NAND_BLOCK_MASK) || (size & NAND_BLOCK_MASK)) {
return ;
nand_select_chip();
for(i=start_addr; i < (start_addr + size);) {
write_cmd(0);
write_addr(i);
wait_idle();
for(j=0; j < NAND_SECTOR_SIZE; j++, i++) {
*buf = read_data();
buf++;
return ;
main 函数
#define GPBCON (*(volatile unsigned long *)0x56000010)
#define GPBDAT (*(volatile unsigned long *)0x56000014)
#define GPB5_out (1<<(5*2))
#define GPB6_out (1<<(6*2))
#define GPB7_out (1<<(7*2))
#define GPB8_out (1<<(8*2))
void wait(unsigned long dly)
for(; dly > 0; dly--);
int main(void)
unsigned long i = 0;
GPBCON = GPB5_out|GPB6_out|GPB7_out|GPB8_out; // 将LED1-4对应的GPB5/6/7/8四个引脚设为输出
while(1){
wait(30000);
GPBDAT = (~(i<<5)); // 根据i的值,点亮LED1-4
if(++i == 16)
i = 0;
return 0;
