1.GPIO 的正确设置
GPIO_InitTypeDef GPIO_InitStructure; /* Enable GPIOD clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE); /* Configure PD.03, PC.04, as input floating */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 ; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_Init(GPIOD, &GPIO_InitStructure); GPIO_EXTILineConfig(GPIO_PortSourceGPIOD, GPIO_PinSource3); //PD3作为外部中断引脚
其中GPIO_EXITLineConfig函数的声明如下:
/ * @brief Selects the GPIO pin used as EXTI Line. * @param GPIO_PortSource: selects the GPIO port to be used as source for EXTI lines. * This parameter can be GPIO_PortSourceGPIOx where x can be (A..G). * @param GPIO_PinSource: specifies the EXTI line to be configured. * This parameter can be GPIO_PinSourcex where x can be (0..15). * @retval None */ void GPIO_EXTILineConfig(uint8_t GPIO_PortSource, uint8_t GPIO_PinSource)
2.中断初始化
EXTI_InitTypeDef EXTI_InitStructure; // Configure EXTI Line3 to generate an interrupt on falling edge EXTI_InitStructure.EXTI_Line = EXTI_Line3; EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling; EXTI_InitStructure.EXTI_LineCmd = ENABLE; EXTI_Init(&EXTI_InitStructure); GPIO_EXTILineConfig(GPIO_PortSourceGPIOD, GPIO_PinSource4); // Configure EXTI Line4 to generate an interrupt on falling edge EXTI_InitStructure.EXTI_Line = EXTI_Line4; EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling; EXTI_InitStructure.EXTI_LineCmd = ENABLE; EXTI_Init(&EXTI_InitStructure);
3.在NVIC_Configuration 中Configures the NVIC and Vector Table base address.
/* Configure the Priority Group to 2 bits */ NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); /* enabling interrupt */ NVIC_InitStructure.NVIC_IRQChannel=TIM2_IRQChannel; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); /* Enable the EXTI3 Interrupt on PD.3 */ NVIC_InitStructure.NVIC_IRQChannel = EXTI3_IRQChannel; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); /* Enable the EXTI4 Interrupt on PD.4 */ NVIC_InitStructure.NVIC_IRQChannel = EXTI4_IRQChannel; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure);
4.在stm32f0x_it.c 中写入 中断处理函数
/* * Function Name : EXTI3_IRQHandler * Description : This function handles External interrupt Line 3 request. * Input : None * Output : None * Return : None */ void EXTI3_IRQHandler(void) { if(EXTI_GetITStatus(EXTI_Line3) != RESET) { // Led_RW_ON(); GPIO_SetBits(GPIOC, GPIO_Pin_4| GPIO_Pin_5 ); /* Clear the EXTI line 9 pending bit */ EXTI_ClearITPendingBit(EXTI_Line3); } } /* * Function Name : EXTI4_IRQHandler * Description : This function handles External interrupt Line 4 request. * Input : None * Output : None * Return : None */ void EXTI4_IRQHandler(void) { if(EXTI_GetITStatus(EXTI_Line4) != RESET) { //Led_RW_OFF(); GPIO_ResetBits(GPIOC, GPIO_Pin_4 | GPIO_Pin_5); /* Clear the EXTI line 9 pending bit */ EXTI_ClearITPendingBit(EXTI_Line4); } }
注:本文参考:http://www.61ic.com/Technology/embed/201103/31045.html
另一个示例:
配置如下:
void vcm_airbag_exti_set(void) { EXTI_InitTypeDef EXTI_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; /* Enable key GPIO clock */ RCC_AHB1PeriphClockCmd(AIRBAG_GPIO_RCC, ENABLE); GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; /* Configure pin(PD_15): airbag gpio */ GPIO_InitStructure.GPIO_Pin = AIRBAG_GPIO_PIN; GPIO_Init(AIRBAG_GPIO_PORT, &GPIO_InitStructure); RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE); //´ò¿ªEXTIʱÖÓ SYSCFG_EXTILineConfig(AIRBAG_EXTI_PORT, AIRBAG_EXTI_PIN); //ÉèÖÃPD15ΪEXTI /* Configure EXTI */ // EXTI_DeInit(); EXTI_InitStructure.EXTI_Line = AIRBAG_EXTI_LINE; //ÉèÖÃÒý½Å EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; //ÉèÖÃΪÍⲿÖжÏģʽ EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising_Falling; // ÉèÖÃÉÏÉýºÍϽµÑض¼¼ì²â EXTI_InitStructure.EXTI_LineCmd = ENABLE; //ʹÄÜÍⲿÖжÏÐÂ״̬ EXTI_Init(&EXTI_InitStructure); //¸ù¾ÝEXTI_InitStructÖÐÖ¸¶¨µÄ²ÎÊý³õʼ»¯ÍâÉèEXTI¼Ä´æÆ÷ NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //ʹÄÜÍⲿÖжÏͨµÀ NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0F; //ÏÈÕ¼ÓÅÏȼ¶4λ,¹²16¼¶ NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0F; //ÏÈÕ¼ÓÅÏȼ¶0λ,´ÓÓÅÏȼ¶4λ NVIC_Init(&NVIC_InitStructure); //¸ù¾ÝNVIC_InitStructÖÐÖ¸¶¨µÄ²ÎÊý³õʼ»¯ÍâÉèNVIC¼Ä´æÆ÷ }
中断例程:
void EXTI15_10_IRQHandler(void) { rt_interrupt_enter(); /* °²È«ÆøÄÒÓ²Ïß¼ì²â´¦Àí¡¡*/ vcm_airbag_exti_check(); /* GPSÌìÏß¿ªÂ·¼ì²â´¦Àí¡¡*/ gps_exti_check(); rt_interrupt_leave(); }
void vcm_airbag_exti_check(void) { //¼ì²éµ±Ç°ÖжϵÄ״̬ÊÇ·ñºÏ·¨ if(EXTI_GetITStatus(AIRBAG_EXTI_LINE) != RESET) { //¶ÁÈ¡¹Ü½ÅµÄ״̬,ÕâÀï·µ»Ø0±íʾ°²È«ÆøÄÒ±¬¿ª if(0 ==GPIO_ReadInputDataBit(AIRBAG_GPIO_PORT,AIRBAG_GPIO_PIN)) { recv_frame.bus_type = BTYPE_HS_CAN; recv_frame.id = 0x545; recv_frame.data_buff[0] = 0x00; recv_frame.data_buff[1] = 0x01; recv_frame.data_buff[2] = 0x00; recv_frame.data_buff[3] = 0x00; recv_frame.data_buff[4] = 0x00; recv_frame.data_buff[5] = 0x00; recv_frame.data_buff[6] = 0x00; recv_frame.data_buff[7] = 0x00; VCM_DEBUG("[vcm] warning: airbag gpio interrupt rising.\r\n"); } else { recv_frame.bus_type = BTYPE_HS_CAN; recv_frame.id = 0x545; recv_frame.data_buff[0] = 0x00; recv_frame.data_buff[1] = 0x00; recv_frame.data_buff[2] = 0x00; recv_frame.data_buff[3] = 0x00; recv_frame.data_buff[4] = 0x00; recv_frame.data_buff[5] = 0x00; recv_frame.data_buff[6] = 0x00; recv_frame.data_buff[7] = 0x00; VCM_DEBUG("[vcm] warning: airbag gpio interrupt falling.\r\n"); } rt_mq_send(&recv_frame_mq,&recv_frame,sizeof(can_bus_frame)); //ÇåÖжϱê־λ EXTI_ClearITPendingBit(AIRBAG_EXTI_LINE); } }
上一篇:ARM中外部中断的配置流程供参考
下一篇:ARM汇编外部中断
推荐阅读最新更新时间:2024-03-16 14:53
