深入理解ARM体系架构(S3C6410)---S3C6410复位
发布者:堕落的猫最新更新时间:2016-06-23 来源: eefocus关键字:ARM体系架构  S3C6410  复位 手机看文章 扫描二维码
随时随地手机看文章
reset
S3C6410X has three types ofreset signals and SYSCON can place the system into one of three resets.
• Hardware reset: It isgenerated by asserting XnRESET. It is an uncompromised, ungated, total andcomplete reset that is used when you do not require information in system anymore. It fully initializes all system.
• Watchdog reset: It isgenerated by a special hardware block, i.e., watchdog timer. When the system ishanged due to an unpredictable software error, the hardware block monitorsinternal hardware status and generates reset signal to escape from this status.
• Wakeup reset: It is generatedwhen S3C6410X wake up from SLEEP mode. Since internal hardware states are notavailable any more after SLEEP mode, they must be initialized.
Hardwarereset
当XnRESET 引脚被声明后,系统内的所有单元(除了RTC 之外)复位到预先定义好的状态时,硬件复位被调用。在这段期间,将发生下面的动作:所有内部寄存器和ARM1176 内核都到预先定义好的复位状态。所有引脚都得到它们的复位状态。当XnRESET 被声明的同时,XnRSTOUT 引脚就被声明了。
XnRESET是不被屏蔽的,始终保持使能状态。XnRESET 的声明,无论先前为何模式,S3C6410 都进入复
位状态。XnRSET 必须持有足够长的时间允许内部稳定和传播。
The hardwarereset is invoked when XnRESET pin is asserted and all units in the system(except RTC) are reset to pre-defined states. During this period, the followingactions occur.
• All internalregisters and ARM1176 core go to the pre-defined reset states.
• All pins gettheir reset state.
• XnRSTOUT pinis asserted when XnRESET is asserted.
XnRESET isun-maskable and is always enabled. Upon assertion of XnRESET, S3C6410X entersinto reset state regardless of the previous mode. XnRSET must be held longenough to allow internal stabilization and propagation of the reset state toenter proper reset state.
Powerregulator for S3C6410X must be stable prior to the deassertion of XnRESET.Otherwise, it may damage S3C6410X and the operation is unpredictable. Figure3-17 is the timing diagram of power-on reset and pll turn-on sequence.
Watchdogreset
当软件挂起时,看门狗复位被调用。因此,在看门狗不能及时喂到时,就会发出超时命令。在看门狗复位期间,有以下动作发生:
除了ALIVE 和RTC 模块,所有模块进入预先定义好的复位状态。所有引脚都进入复位状态。在看门狗复位期间,nRSTOUT 引脚被声明。
在正常模式和闲置模式下,看门狗可被激活,并可产生超时信号。当看门狗定时器超时并复位使能时,其
可被调用。因此,下列依次发生:
1) WDT 产生超时信号。
2) SYSCON 调用复位信号,初始化内部IP。
3)包括nRSTOUT 复位被声明,直到复位计数器RST_STABLE 被终止。
Watchdog resetis invoked when a software hang-up. Then, the software cannot initialize aregister within WDT and WDT makes time-out signals for watchdog reset. As theoccurrence of watchdog reset means that system has fatal problem, it behaveslike external reset except reset status register. During the watchdog reset,the
followingactions occur:
• All blocksexcept reset status register in ALIVE block go to their pre-defined resetstate.
• The nRSTOUTpin is asserted during watchdog reset.
Watchdog resetcan be activated in NORMAL and IDLE mode, since WDT can generate time-outsignal. It is invoked when watchdog timer and reset are enabled. Then, thefollowing sequence occurs:
1. WDTgenerate time-out signal.
2. SYSCONinvokes reset signals and initialize internal IPs.
3. The resetincluding nRSTOUT will be asserted until the reset counter, RST_STABLE, isexpired.
Wakeupreset
Wakeup reset is invoked whenS3C6410 is woken-up from SLEEP by a wakeup event. The details are described inSLEEP mode section.
关键字:ARM体系架构  S3C6410  复位 引用地址:深入理解ARM体系架构(S3C6410)---S3C6410复位
上一篇:深入理解ARM体系架构(S3C6410)---S3C6410看门狗源码实例
下一篇:深入理解ARM体系架构(S3C6410)---S3C6410系统时钟
推荐阅读最新更新时间:2024-03-16 14:58
s3c6410 pwm 学习
第一次自学直接看数据手册而不是大端的中文资料或者示例代码讲解。。不过这是大家必须要走过的过程。 开始吧! The 6410 RISC microprocessor comprises of five 32-bit timers. These timers are used to generate internal interrupts to the ARM subsystem. In addition, Timers 0 and 1 include a PWM function (Pulse Width Modulation), which can drive an external I/O signal. The PW
[单片机]
<font color='red'>s3c6410</font> pwm 学习
STM32F103单片机复位电路回顾
在设计“单片机控制线路板”时,一般需有4部分电路:“电源电路部分”、“晶振电路部分”、“复位电路部分”、“下载电路部分”;对不同的“IC芯片”,工作所需“电源电压”各不相同,大多为“+3.3V”或“+5.0V”;“晶振电路部分”和“复位电路部分”也需根据“芯片”对应的“datasheet”进行设计,特别是“复位电路部分”,必须参考手册,确定“低电平复位”还是“高电平复位”,否则会导致上电后“芯片无法复位工作”; 在“初代温控板V1.0”中,控制芯片为“STM32F103RCT6”,为“低电平复位”,但由于设计失误,未添加“复位电路”,如下所示: 复位电路图 如图“红色部分”所示,在“初代温控板V1.0”中,此部分电路被忽略,导
[单片机]
STM32F103单片机<font color='red'>复位</font>电路回顾
深入单片机软复位(PC跳转)
对函数指针熟悉吗?熟悉一切都容易了! 好书推荐《C陷阱与缺陷》《C专家编程》看看就上个档次就不是菜鸟了,呵呵 (*(void(*)())0) (); //就是它了! 晕了吗?没晕,不错不错,大哥,你扎这厉害呢! ((void(*)())0) (); //如果这样写呢! (**(void(*)())0) (); //如果这样写呢! 有区别吗?看下面例子 #include stdio.h void fun() { } int main() { printf("%p %p %p ", &fun, fun, *fun); return 0; } 看看结果是否大吃一惊 // 没有,大哥你扎这厉害呀 假设fp
[单片机]
关于STM8上电复位和掉电复位 以及工作电压
STM8S 为双电源MCU,外设工作电压为3V-5.5V,内核工作电压为1.8V。因MCU内部 已集成1.8V低功耗电压(LPVR)调节器,MCU工作仅需要 提供一个供电电源。 POR - Power -On Reset 上电复位 POR的功能是在VDD电压由低向高上升越过规定的阀值(VIT+)之前,保持 芯片复位,当越过这个阀值(VIT+)后的一小段时间后(Reset temporition) 结束复位开始取复位向量执行指令。 BOR - Brown Out Reset 掉电复位 在VDD 电压由高向低下降越过规定的阀值(VIT-)后,将在芯片内部产生复位。 芯片的复位地址指向0x6000(内部Bootloader)存
[单片机]
PIC16C5X的复位电路
PIC16C5X的复位电路可以由系统上电,把MCLR输入拉为低电平,或看门狗定时器溢出而产生。振荡启动定时器OST作用或MCLR输入为低电平,单片机将保持复位状态,复位时单片机处于以下状态: · 振荡器启动或工作,包括电源上升启动或睡眠唤醒启动。 · I/O控制寄存器设定为全“1”,使所有I/O引脚(PA0-PA3、PB0-PB7、PC0-PC7)处于高阻状态。 · 程序计数器PC设为全“1”,对于PIC16C54/55为1FFH,对于PIC16C56为3FFH,对于PIC16C57为7FFH。 · OPTION寄存器设为全“1”。 · 看门狗定时器WDT及其分频器清“0”。 · 状态寄存器f3的程序页
[单片机]
PIC16C5X的<font color='red'>复位</font>电路
ATmega168 外部复位
外部复位由外加于 RESET 引脚的低电平产生。当复位低电平持续时间大于最小脉冲宽度时 ( 参见 Table20) 即触发复位过程,即使此时并没有时钟信号在运行。当外加信号达到复位门限电压 VRST(上升沿)时,tTOUT 延时周期启动。延时结束后 MCU 即启动。外部复 位可由 RSTDISBL 熔丝位禁用,请参见ATmega168 PDF的P256Table120 。
[单片机]
ATmega168 外部<font color='red'>复位</font>
AVR单片机内部的复位功能解析
AVR单片机的复位:看门狗复位、上电复位、掉电复位看到大家对复位特别是AVR单片机内部的复位功能还不太清楚,现在这里简单说一下,希望在家能有个总体的认识。 AVR单片机复位大概有:上电复位、掉电复位、看门狗超时复位、外部复位,这么四种。 上电复位:就是在一通电的时候对单片机进行复位,这和我们外接RC复位电路的作用是一样的,AVR单片机内部带有上电复位功能。 掉电复位:就是在单片机运行过程中电压突然跌落,这个时候单片机会出现很多不确定的现象,所以在这个时候需要将单片机复位,让它处于一个确定的状态。这就是BOD功能,一个非常实用的功能,AVR单片机带有这个功能。 看门狗复位:这是我们常说的看门狗了,就是当程序进入某个地
[单片机]
AVR单片机内部的<font color='red'>复位</font>功能解析
如何解决AVR单片机上电复位工作混乱的问题
在单片机应用中经常需要在掉电时(包括人为的关机和偶然的外部电源故障),对运行的数据进行保存。目前,常用的方法是单独给单片机增加一个较大的电容(一般为2000 μf以上,也有用法拉级的),外部掉电后,靠大电容存储的电量缓慢放电,提供单片机向eeprom存储数据所需要的时间。所选的电容小,提供的时间短,存储数据不可靠,所选电容大提供时间长,存储数据可靠。但是随之而来的问题是,掉电后电容放电过程中,单片机的供电电压在缓慢下降,当下将到某个值但还没有降到复位门限电压之前,如果此时再次开机,则单片机不能正常启动,导致单片机重复上电后工作混乱。下面具体分析这一过程并给出解决的办法。 我们先了解一下AVR的上电复位特点。上表是AVR数据手册
[单片机]
如何解决AVR单片机上电<font color='red'>复位</font>工作混乱的问题
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
随便看看
