硬件 mini2440核心板,另外一块带串口的单片机学习板(挂着DS18B20),学习板连续输出DS18B20的温度值,波特率19200。
在一个文件夹里新建一个文件,我的是voltage_set.c(以后用来调压)
#include
#include
#include
#include
#include
#include
#include
#include
#include
#define FALSE -1
#define TRUE 1
int speed_arr[] = { B38400, B19200, B9600, B4800, B2400, B1200, B300, //
B38400, B19200, B9600, B4800, B2400, B1200, B300, };
int name_arr[] = {38400, 19200, 9600, 4800, 2400, 1200, 300,
38400, 19200, 9600, 4800, 2400, 1200, 300, };
void set_speed(int fd, int speed)
int i;
int status;
struct termios Opt;
tcgetattr(fd, &Opt);
for ( i= 0; i < sizeof(speed_arr) / sizeof(int); i++)
if (speed == name_arr[i])
tcflush(fd, TCIOFLUSH);
cfsetispeed(&Opt, speed_arr[i]);
cfsetospeed(&Opt, speed_arr[i]);
status = tcsetattr(fd, TCSANOW, &Opt);
if (status != 0)
perror("tcsetattr fd1");
return;
tcflush(fd,TCIOFLUSH); //????
int set_Parity(int fd,int databits,int stopbits,int parity)
struct termios options; //?¨???????á??
if ( tcgetattr( fd,&options) != 0) //?×???????????????è??options??,±???
perror("SetupSerial 1");
return(FALSE);
options.c_cflag &= ~CSIZE; //?????è??c_cflag??????°?????????????
switch (databits)
case 7:
options.c_cflag |= CS7; //?è??c_cflag????????????7??
break;
case 8:
options.c_cflag |= CS8; //?è??c_cflag????????????8??
break;
default:
fprintf(stderr,"Unsupported data size\n"); //???????????§??
return (FALSE);
switch (parity) //?è?????????é??c_cflag??c_iflag???§
case 'n':
case 'N':
options.c_cflag &= ~PARENB;
options.c_iflag &= ~INPCK;
break;
case 'o':
case 'O': options.c_cflag |= (PARODD | PARENB);
options.c_iflag |= INPCK;
break;
case 'e':
case 'E':
options.c_cflag |= PARENB;
options.c_cflag &= ~PARODD;
break;
default:
fprintf(stderr,"Unsupported parity\n");
return (FALSE);
switch (stopbits)
case 1:
options.c_cflag &= ~CSTOPB;
break;
case 2:
options.c_cflag |= CSTOPB;
break;
default:
fprintf(stderr,"Unsupported stop bits\n");
return (FALSE);
if (parity != 'n')
options.c_cc[VTIME] = 150; // 15 seconds
options.c_cc[VMIN] = 0;
tcflush(fd,TCIFLUSH);
if (tcsetattr(fd,TCSANOW,&options) != 0)
perror("SetupSerial 3");
return (FALSE);
return (TRUE);
int OpenDev(char *Dev)
int fd = open( Dev, O_RDWR ); //| O_NOCTTY | O_NDELAY????·?????open????
if (-1 == fd)
perror("Can't Open Serial Port");
return -1;
else
return fd;
int main(int argc, char **argv)
int fd;
int nread;
char buff[512];
char *dev ="/dev/ttySAC1";
fd = OpenDev(dev);
if (fd>0)
printf("Open Serial succeed\n");
set_speed(fd,19200);
else
printf("Can't Open Serial Port!\n");
exit(0);
if (set_Parity(fd,8,1,'N')== FALSE)
printf("Set Parity Error\n");
exit(1);
while(1)
int i;
// char buff1[2]={0x5a,0x5a};
// write(fd,buff1,1);
while((nread = read(fd,buff,512))>0)
printf("\nLen %d\n",nread);
buff[nread+1]='\0';
for(i=0;i
printf("0x%x",buff[i]);
printf("\n");
//close(fd);
//exit(0);
完了之后arm-linux-gcc -o voltage_set voltage_set.c
生成voltage_set
下载到mini2440核心板中
执行#./voltage_set
把学习板的地与核心板的地相连,学习板的TX与核心板的RX2相连就可以看到温度值了,当然,我用16进制显示在超级终端上,关掉程序用ctrl+c
