详细的代码和仿真情况如下:(我的硬件系统是本站的min Mega16/32 + JTAG ICE)
- #include "config.h"
- struct _PID
- float PVn; //反馈信号变量
- float SPn; //设定值
- float Mn; //PID运算结果
- float Kc; //比例系数
- float Ts; //采样时间(ms)
- float Ti; //积分时间(ms)
- float Td; //微分时间(ms)
- float Mx; //积分项调整参数
- float PVn_1;//前一次反馈变量
- float MPn; //比例项的结果值
- float MIn; //积分项的结果值
- float MDn; //微分项的结果值
- struct _PID *myPID;
- void init_myPID(void);
- void init_ports(void);
- void init_device(void);
- float MPn_value(struct _PID *PID);
- float MIn_value(struct _PID *PID);
- float MDn_value(struct _PID *PID);
- float Mx_value(struct _PID *PID);
- float Mn_value(struct _PID *PID);
- void main (void)
- init_device();
- init_myPID();
- myPID->SPn = 155.5;
- myPID->Kc = 13.2;
- myPID->Ts = 0.2;
- myPID->Ti = 600.0;
- myPID->Td = 0.0;
- myPID->PVn = 108.2;
- while(1)
- myPID->MPn = MPn_value(myPID);
- myPID->MDn = MDn_value(myPID);
- myPID->Mx = Mx_value(myPID);
- myPID->MIn = MIn_value(myPID);
- myPID->Mn = Mn_value(myPID);
- myPID->PVn_1 = myPID->PVn;
- myPID->PVn = 0.0;
- myPID->SPn = 0.0;
- myPID->Mn = 0.0;
- myPID->Kc = 0.0;
- myPID->Ts = 0.0;
- myPID->Ti = 0.0;
- myPID->Td = 0.0;
- myPID->Mx = 0.0;
- myPID->PVn_1 = 0.0;
- myPID->MPn = 0.0;
- myPID->MIn = 0.0;
- myPID->MDn = 0.0;
- PORTA = 0x00; //If ADC Function was be used,the PORTA could`t set bit 1
- DDRA = 0x00; //the port set input mode.
- PORTB = 0x00;
- DDRB = 0x00;
- PORTC = 0x00; //m103 output on
ly - DDRC = 0x00;
- PORTD = 0x00;
- DDRD = 0x00;
- CLI();
- init_ports();
- MCUCR = 0x00; //Set Power control(State:Close)
- GICR = 0x00; //Set boot guide(State:Close).
- SEI(); //re-enable interrupts
- //all peripherals are now initialized
- // 计算 比例项的值
- float myMPn = 0.0;
- myMPn = PID->Kc *( PID->SPn - PID->PVn);
- return myMPn;
- //计算积分项的值
- float myMIn = 0.0;
- myMIn = PID->Kc*(PID->Ts/PID->Ti)*(PID->SPn - PID->PVn) + PID->Mx;
- return myMIn;
- //计算微分项的值
- float myMDn = 0.0;
- myMDn = PID->Kc * (PID->Td/PID->Ts) * (PID->PVn_1 - PID->PVn);
- return myMDn;
- //计算PID的结果
- float myMn = 0.0;
- myMn = PID->MPn + PID->MIn + PID->MDn;
- return myMn;
- //计算积分项的调整值
- float myMx = 0.0;
- if(PID->Mn > 1.0)
- myMx = 1.0 - (PID->MPn + PID->MDn);
- else if(PID->Mn < 0.0)
- myMx = -(PID->MPn + PID->MDn);
- return myMx;
运行到PID初始化函数:void init_myPID(void)时的仿真结果如下:无法全部初始化为0
运行到:
myPID->SPn = 155.5;
myPID->Kc = 13.2;
myPID->Ts = 0.2;
myPID->Ti = 600.0;
myPID->Td = 0.0;
myPID->PVn = 108.2;
重新赋值后,部分参数Ts并不为0.2
上一篇:AVR ISP下载线在AVR Studio环境下的下载方法
下一篇:avr中断使用例子
推荐阅读最新更新时间:2024-03-16 15:10
