程序存储器
如果要将数据(如常量,字符串,等等)放在FLASH里,用户需要指明数据类型__ATTR_PROGMEM__。为了方便使用,AVR-GCC定义了一些更直观的符号,如下表所示。
类型数据定义
typedef void PROGMEM prog_void
typedef char PROGMEM prog_char
typedef unsigned char PROGMEM prog_uchar
typedef int8_t PROGMEM prog_int8_t
typedef uint8_t PROGMEM prog_uint8_t
typedef int16_t PROGMEM prog_int16_t
typedef uint16_t PROGMEM prog_uint16_t
typedef int32_t PROGMEM prog_int32_t
typedef uint32_t PROGMEM prog_uint32_t
typedef int64_t PROGMEM prog_int64_t
typedef uint64_t PROGMEM prog_uint64_t
宏定义:定义FLASH空间的指针类型
#define PROGMEM __ATTR_PROGMEM__
#define PSTR(s) ((const PROGMEM char *)(s))
#define PGM_P const prog_char *
#define PGM_VOID_P const prog_void *
宏函数:执行LPM/ELPM指令从FLASH里取数
#define pgm_read_byte_near(address_short) __LPM((uint16_t)(address_short))
#define pgm_read_word_near(address_short) __LPM_word((uint16_t)(address_short))
#define pgm_read_dword_near(address_short) __LPM_dword((uint16_t)(address_short))
#define pgm_read_byte_far(address_long) __ELPM((uint32_t)(address_long))
#define pgm_read_word_far(address_long) __ELPM_word((uint32_t)(address_long))
#define pgm_read_dword_far(address_long) __ELPM_dword((uint32_t)(address_long))
#define pgm_read_byte(address_short) pgm_read_byte_near(address_short)
#define pgm_read_word(address_short) pgm_read_word_near(address_short)
#define pgm_read_dword(address_short) pgm_read_dword_near(address_short)
库函数
4. strchr_P
用法:iPGM_P strchr_P( PGM_P s, int val);
说明:功能与strchr()类似。第二个参数指向程序存储器内的字符串。
5.strcmp_P
用法:int strcmp(char const *, PGM_P);
说明:功能与strcmp()类似。第二个参数指向程序存储器内的字符串。
6.strcpy_P
用法:char* strcpy_P(char *, PGM_P);
说明:功能与strcpy()类似。第二个参数指向程序存储器内的字符串。
7.strcat_P
用法:char * strcat_P(char *, PGM_P);
说明:功能与strcat()类似。第二个参数指向程序存储器内的字符串。
8.strlen_P
用法:size_t strlen_P(PGM_P);
说明:功能与strlen()类似。第二个参数指向程序存储器内的字符串。
9.strncmp_P
用法:size_t strncmp_P(char const*, PGM_P, size_t);
说明:功能与strncmp()类似。第二个参数指向程序存储器内的字符串。
10.strncpy_P
用法:size_t strncpy_P(char*, PGM_P, size_t);
说明:功能与strncpy()类似。第二个参数指向程序存储器内的字符串。
关键字:AVR GCC 程序存储器 api
引用地址:
AVR-GCC程序存储器api
推荐阅读最新更新时间:2024-03-16 15:16
一种基于AVR单片机的工频干扰滤除快速算法
摘要:提出了一种利用数字滤波器滤除工频干扰的快速算法。这种算法从AVR单片机内部硬件乘法器的特点出发,采用分配系统数法进行低通数字滤波器设计。经过VMLAB集成开发环境的仿真验证,算法速度快、代码效率高、滤波效果理想。
关键词:单片机 定点小数 FIR 工频干扰 分配系数法 VMLAB
工频干扰广泛存在各种工业现场中,其产生的途径主要包括输电馈线、照明设备、发动机以及各种电子仪器设备等。一般可以通过滤波电路消除工频干扰,但这必将增加硬件结构的复杂程度。实际上,还可以采用数字信号处理的相关算法,通过软件滤波器滤除工频干扰。软件滤波算法的采用,无疑会在简化电路结构的同时,使系统的硬件资源得到更加充分的利用,并达到降低产品成本的要求
[应用]
NRF24L01无线模块接收-AVR程序代码
#include #include #include lcd12864.h #define uint unsigned int #define uchar unsigned char #define MISO PINB.6 #define SCK PORTB.7 #define MOSI PORTB.5 #define CSN PORTC.0 #define CE PORTC.1 #define IRQ PORTC.2 #define CONFIG 0x00 // 配置收发状态,CRC校验模式以及收发状态响应方式 #define EN_AA 0x01//自动应答使能 #define EN_RXADDR 0x02
[单片机]
AVR单片机复位介绍
AVR复位时所有的I/O 寄存器都被设置为初始值,程序从复位向量处开始执行。复位向量处的 指令必须是绝对跳转JMP 指令,以使程序跳转到复位处理例程。 AVR的复位信号源有五个: 上电复位。电源电压低于上电复位门限 VPOT 时, MCU 复位。 外部复位。引脚 RESET 上的低电平持续时间大于最小脉冲宽度时MCU 复位。 看门狗复位。看门狗使能并且看门狗定时器溢出时复位发生。 掉电检测复位。掉电检测复位功能使能,且电源电压低于掉电检测复位门限 VBOT 时 MCU 即复位。 JTAG AVR复位。复位寄存器为1 时MCU 复位。 上电复位 上电复位(POR) 脉冲由片内检测电路产生,POR电路保证器件在上电时复
[单片机]
第40章 STM32F429的LCD控制器LTDC基础知识和HAL库API
40.1 初学者重要提示 本章40.2小节中的几个知识点比较重要,比如DE同步模式和HV同步模式的区别,Alpha混合,水平消隐和垂直消隐等知识点尤其重要,需要大家理解透彻。 40.2 LTDC基础知识 LTDC的几个关键知识点放在开头说: 1、STM32F429的LTDC最大支持1024*768分辨率,且支持硬件双图层。实际支持的分辨率可能比1024*768要高一点,因为最终可以支持的最大分辨率是芯片后期定标的。 2、支持32位色,24位色,16位色和8位色。 3、可编程窗口位置和大小,可编程行同步,场同步和数据使能信号的极性。 4、查色表 (CLUT,Color look-up table),每个图层最高可
[单片机]
ATtiny13 时钟源
ATtiny13芯片有如下几种通过Flash熔丝位进行选择的时钟源。时钟输入到AVR时钟发生器,再分配到相应的模块。 不同的时钟选项将在后续部分进行介绍。当 CPU 自掉电模式或省电模式唤醒之后,被选 择的时钟源用来为启动过程定时,保证振荡器在开始执行指令之前进入稳定状态。当CPU 从复位开始工作时,还有额外的延迟时间以保证在 MCU 开始正常工作之前电源达到稳定 电平。这个启动时间的定时由看门狗振荡器完成。看门狗溢出时间所对应的 WDT 振荡器 周期数列于 Table 3。 缺省时钟源 器件出厂时 CKSEL = “10”, SUT = “10”,且 CKDIV8 编程。这个缺省设置的时钟源是 9.6MHz 的内部 RC
[单片机]
IAR For AVR 两线串行接口 TWI 应用
ATMEL的TWI 和 PHILIPS的IIC 基本上应该是算一个东西,但是他们在名义上是不同的,这样谁都不用支付给对方使用费。他们的协议是一样的,所有我们作为使用者基本可以简单的看成 TWI就是IIC 。 废话说完,开始正题。这次是关于在ATMega16 平台下的硬件IIC(还不太习惯说TWI)的使用。在ATMega16的Datasheet里我们可以看到很强大的功能,主从设置很多。本文只说一种最常用的方式,那就是 ATMega16 硬件TWI 的 扫描发送 和 扫描读取 。 首先要明确TWI 发送和接受的流程: 发送: 1,设定数据传输波特率 2,发送START信号,等待应答 ==》 《==
[单片机]
FLASH存储器测试程序原理和几种通用的测试方法
1.引言 随着当前移动存储技术的快速发展和移动存储市场的高速扩大,FLASH型存储器的用量迅速增长。FLASH芯片由于其便携、可靠、成本低等优点,在移动产品中非常适用。市场的需求催生了一大批FLASH芯片研发、生产、应用企业。为保证芯片长期可靠的工作,这些企业需要在产品出厂前对FLASH存储器进行高速和细致地测试,因此,高效FLASH存储器测试算法的研究就显得十分必要。 不论哪种类型存储器的测试,都不是一个十分简单的问题,不能只将存储器内部每个存储单元依次测试一遍就得出结论,这是因为每一个存储单元的改变都有可能影响存储器内部其他单元的变化(这种情况又是常常发生的)。这种相关性产生了巨大的测试工作量。另外,FLASH存储器有其自
[测试测量]
建立一个属于自己的AVR的RTOS(第一篇:函数的运行)
简介:第一篇:函数的运行 在一般的单片机系统中,是以前后台的方式(大循环+中断)来处理数据和作出反应的。 例子如下: makefile的设定:运行WinAvr中的Mfile,设定如下 MCUType:mega8 Optimizationlevel:s Debugformat:AVR-COFF C/C++sourcefile:选译要编译的C文件 #include avr/io.h voidfun1(void) { unsignedchari=0; while(1) { PORTB=i++; PORTC=0x01 (i%8); } } intmain(void) {
[单片机]
