51的测试程序(主要是用仿真串口进行测试)
发布者:自在堂最新更新时间:2016-11-17 来源: eefocus关键字:测试程序  仿真串口 手机看文章 扫描二维码
随时随地手机看文章
#include
#include
#include "lcd_51.h"
#include "delay_51.h"
#include "24c64.h"
#include "key.h"
//#include "adc0832.h"
#define    uchar    unsigned char
#define    uint     unsigned int
//adc0832部分
uchar ReadAdc0832( uchar channel ) reentrant;
//ADC0832端口定义
#define     ADC0832_SCK_H      P1_1 = 1
#define     ADC0832_SCK_L      P1_1 = 0
#define     ADC0832_DIDO_H     P1_2 = 1
#define     ADC0832_DIDO_L     P1_2 = 0
#define     ADC0832_DIDO       P1_2
#define     ADC0832_CS_H       P1_0 = 1
#define     ADC0832_CS_L       P1_0 = 0
//按键部分
uchar sure = 0;
uchar model = 0;
uchar add_b = 0;
uint  add_p = 0x0000;
//串口部分
//uchar flag44 = 0;
//uchar flagadc0832 = 0;
//uchar flag24c64 = 0;
//uchar flagshumaguang = 0;
uchar flagwhole = 5;
//uchar flagno = 1;
uchar flagfillallow = 0;
uchar flagsendmessage44 = 0;
uchar flagsendmessageadc0832 = 0;
uchar flagsendmessageshumaguang = 0;
uchar flagsendmessage24c64 = 0;
uchar flagdoing24c64 = 0;
//波特率宏定义
#define RELOAD_COUNT 0xfd; //SMOD=1, crystal=11.0592, baud= 19200
//#define RELOAD_COUNT 0xFa //SMOD=1, crystal=11.0592, baud= 9600
//#define RELOAD_COUNT 0xf4 //SMOD=1, crystal=11.0592, baud= 4800
//#define RELOAD_COUNT 0xe8 //SMOD=1, crystal=11.0592, baud= 2400
//缓冲区
#define  Rec_Max       9   //定义最大值
#define  COMRECSIZE    16  //定义缓冲区大小
uchar    Rec_buf[COMRECSIZE];
uchar    *Point2Rec_buf;    //定义指向数组Rec_buf的指针
uchar    Rec_n = 0;        //接收字节个数初始化为0
uchar    RecFullFlag = 0;  //接收满标志初始化为0
//-----------------------------------------------------串口部分接口函数--------------------------------------------------
** 函数名:串口初始化函数
** 例子  : UART_Init();
void UART_Init( void )
 SCON |= 0x50;     //串口工作方式1, 波特率可变, 波特率由T1决定, 允许接收位REN = 1. 无奇偶校验位
 PCON |= 0x80;     //波特率加倍
 TMOD |= 0x20;     //T1, 8位自动, 方式2, 之所以选择工作方式2是因为它有自动加载功能,可以避免程序反复装入初值引起的误差
 TH1 = RELOAD_COUNT; //赋初值高8位TH     RELOAD_COUNT由前宏定义
 TL1 = RELOAD_COUNT; //赋初值低8位TH
 ES = 1;             //开串口中断
 ET1 = 0;            //禁止T1中断允许, 以免产生不必要的中断带来的频率误差
 TR1 = 1;         //打开T1
 //EA = 1;           //注意, 还没有打开全局中断
//串口接收中断服务程序
void serial_INT4( void ) interrupt 4
    if( RI )
     RI = 0;                  //硬件置位,软件清零
  if( flagdoing24c64 == 0 )
  switch( SBUF )
   case '1':
     //4*4
     flagwhole = 1;
     flagsendmessage44 = 1;
     LCD_write_string( 1, 0, " made by hebei   " );
        LCD_write_string( 2, 0, " TEST 4*4 --> 0   " );
    }  break;
   case '2':
     //ADC
     flagwhole = 2;
     flagsendmessageadc0832 = 1;
        LCD_write_string( 2, 1, "TEST ADC-->        " );
    }  break;
   case '3':
     //shumaguang
     flagwhole = 3;
     flagsendmessageshumaguang = 1;
        LCD_write_string( 2, 0, "TEST shumaguang  " );
    }  break;
   case '4':
     //24C64
     flagwhole = 4;
     flagsendmessage24c64 = 1;
     LCD_write_string( 1, 1, "0000 >0 is      " );  //
     LCD_write_string( 2, 0, "                 ");
    }  break;
     case '5':
     //结束
     flagwhole = 5;
         LCD_write_string( 2, 0, "    NO TEST       " );
    }  break;
  if( flagdoing24c64 == 1 )
  if( flagfillallow == 1 )
      Rec_buf[Rec_n++] = SBUF;
      if( Rec_n == Rec_Max )
       RecFullFlag = 1;
 return;
** 函数名:串口发送一个字符
** 例子  : UART_Sendstr( 'a' );
** 说明  : UART_SendCh(10);  //
**      UART_SendCh(13);  //回车换行
void UART_SendCh( uchar Tmp_char )
 TI = 0;
 SBUF = Tmp_char;
 while( !TI )
** 函数名:串口发送字符串函数
** 例子  : UART_Sendstr( "how are you?" );
void UART_SendStr( uchar *str )
 ES=0;      //disable uart0 interrupt;
 while( *str )
   TI = 0;
  SBUF = ( *str );
  ++str;
  while( !TI )
  {;}   //waitting for sending finished.
 TI=0;
 ES=1;
//-----------------------------------------------------串口部分接口函数结束--------------------------------------------------
//-----------------------------------------------------外部中断0部分接口函数(24c64按键)--------------------------------------------------
//外中断初始化
void Int0init( void )
 EX0 = 1;  //允许外中断0
 IT0 = 1;  //边沿触发
void modelchang( void )
    model++;
 model %= 3;    //model在0-2之间
 switch( model )
  case 0: LCD_write_char( 1, 0, ' ' ); LCD_write_char( 1, 6, ' ' ); break;
  case 1: LCD_write_char( 1, 0, '>' ); LCD_write_char( 1, 6, ' ' ); break;
  case 2: LCD_write_char( 1, 0, ' ' ); LCD_write_char( 1, 6, '>' );  break;
  default: break;
void add( void )
 uint k = add_p;
    switch( model )
        case 1:
       add_p++;
    add_p %= 0x000A;
    LCD_write_char( 1, 4, ( add_p & 0x000f ) + 0x30 ); break;
  case 2:
    add_b %= Rec_Max;
    LCD_write_char( 1, 7, ( add_b & 0x000f ) + 0x30 );
    LCD_write_char( 1, 12, I2cReadDataFromAddr( 0xa0, k + add_b ) ); //从24C64里面读数据
    add_b++;
    break;
  default : break;
//确定
void ok( void )
 sure = 1;
//外中断0服务程序
void int0_int( void ) interrupt 0
 EA = 0;   //禁止再次外中断
 if( ( P3 & 0x3c ) != 0x3c )
   delay_nms( 20 );             //去除抖动
  if( ( ( P3 & 0x3c ) != 0x3c ) )
   switch( P3 & 0x3c )
           //模式
           case 0x30 : modelchang(); break;
           //加
           case 0x28 : add(); break;
           //确定
           case 0x18 : ok(); break;
           default : break;
 EA = 1;   //打开外中断
//-----------------------------------------------------外部中断0部分接口函数结束--------------------------------------------------
//-----------------------------------------------------芯片74HC595以及74HC139部分接口函数(数码管)--------------------------------------------------
//595端口定义
#define     HC595_SHCP_H       P0_0 = 1
#define     HC595_SHCP_L       P0_0 = 0
#define     HC595_DS_H         P0_1 = 1
#define     HC595_DS_L         P0_1 = 0
#define     HC595_STCP_H       P0_2 = 1
#define     HC595_STCP_L       P0_2 = 0
//139端口定义
#define     HC139A_H            P0_3 = 1
#define     HC139A_L            P0_3 = 0
#define     HC139B_H            P0_4 = 1
#define     HC139B_L            P0_4 = 0
//共阳a-7 b-6 c-5 d-4 e-3 f-2 g-1 h-0
uchar code Atab[] =     //注意,此处要定义为code
        0x03,/*0*/
        0x9F,/*1*/
        0x25,/*2*/
        0x0D,/*3*/
        0x99,/*4*/
        0x49,/*5*/
        0x41,/*6*/
        0x1F,/*7*/
        0x01,/*8*/
        0x09,/*9*/
//139译码
void HC139_Sendbyte( uchar senddata )
    switch( senddata )
        case 0: HC139A_L; HC139B_L; break;
        case 1: HC139A_H; HC139B_L; break;
        case 2: HC139A_L; HC139B_H; break;
        case 3: HC139A_H; HC139B_H; break;
        default: break;
** 函数作用:向595发送一个字节数据的低n位
** 入口参数:要写的字节 senddata
** 返回值  : 无
void HC595_Send( uchar Btemp )
    uchar i;
    for( i = 0; i < 8; i++ )
        if( 0x01 & Btemp )    //先发送低位, 再发高位
        HC595_DS_H;
        else
        HC595_DS_L;
        HC595_SHCP_L;
  //asm("nop");
        HC595_SHCP_H;
  //asm("nop");
        Btemp = Btemp >> 1;
 //锁存
 HC595_STCP_L;
 //delay_nus( 1 );
 HC595_STCP_H;
//数码管显示
void NumDisplay( unsigned char Bit, unsigned char num )
    HC139_Sendbyte( Bit );
 HC595_Send( Atab[num] );   //第3位数字显示数num
//注意此函数在循环体中使用
//内部包含5ms延时
void DataDisp( long int datal )
    uchar i;
 unsigned int wei[4];
    wei[0] = datal / 1000;
 wei[1] = (datal - wei[0] * 1000) / 100;
 wei[2] = (datal - wei[0] * 1000 - wei[1] * 100) / 10;
    wei[3] = datal % 10;
 //显示停留时间
    for( i = 0; i < 5; i++ )
    NumDisplay( 0,wei[0] );
    delay_nms( 3 );
    NumDisplay( 1, wei[1] );
    delay_nms( 3 );
    NumDisplay( 2, wei[2] );
    delay_nms( 3 );
    NumDisplay( 3, wei[3] );
    delay_nms( 3 );
//-----------------------------------------------------芯片74HC595以及74HC139部分接口函数(数码管)结束--------------------------------------------------
//-----------------------------------------------------ADC0832驱动部分函数--------------------------------------------------
** 函数名 :ADC0832读数据程序
** 入口   :需转换通道channel  [0:1]
** 返回   : 无符号字符型 uchar
** 例子   : Data_adc = ReadAdc0832( 0 );   //读取adc0832芯片的0通道模拟电压
** 说明   : 使用时请在芯片加上精准电压源, 建议用专用芯片
//工作时序
//当cs由高变低时,选中ADC0832。在时钟的上升沿,DI端的数据移入ADC0832内部的多路地址移位寄存器。
//在第一个时钟期间,Dl为高,表示启动位,紧接着输入两位配置位。当输入启动位和配置位后,选通输入模拟通道,转换开始。
//转换开始后,经过一个时钟周期延迟,以使选定的通道稳定。ADC0832接着在第4个时钟下降沿输出转换数据。
//数据输出时先输出最高位(D7~DO);输出完转换结果后,又以最低位开始重新输出一遍数据(D7~DO),两次发送的最低位共用。当片选cS
//为高时,内部所有寄存器清0,输出变为高阻态。如果要再进行一次模傲转换,片选cs必须再次从高向低跳变,后面再输入启动位和配置位
//adc0832读数据
    uchar i = 0;
    uchar outdata = 0;
    //初始化: 选通 数据口保持高电平
    ADC0832_CS_L;   // 使能
    ADC0832_DIDO_H; //
    ADC0832_SCK_L;  //第一次触发
    _nop_();
 _nop_();
    ADC0832_SCK_H;  //
    _nop_();
 _nop_();
 //模拟通道的选择及单端输入和差分输入的选择
 ADC0832_DIDO_H;
    ADC0832_SCK_L;  //第二次触发
 _nop_();
 _nop_();
    ADC0832_SCK_H;
    _nop_();
 _nop_();
 if( channel == 1 )
         ADC0832_DIDO_H;
    else
         ADC0832_DIDO_L;
 ADC0832_SCK_L;  //第三次触发
    _nop_();
 _nop_();
 ADC0832_SCK_H;
 _nop_();
 _nop_();
    ADC0832_SCK_L;
 _nop_();
 _nop_();
    ADC0832_DIDO_H;   //置为输入准备读数据
    ADC0832_SCK_H;
 _nop_();
 _nop_();
 outdata = 0;     //初始化
    //读数据D7~D0
    for( i = 1; i <= 8; i++ )
         if( ADC0832_DIDO == 1 )
     outdata |= 0x01;
   ADC0832_SCK_H;
         ADC0832_SCK_L;
         outdata = outdata << 1; //左移一位
    //此函数不再读数据D0~D7  (注意D0位重叠)
    ADC0832_CS_H;        //禁止
 return outdata;
//-----------------------------------------------------ADC0832驱动部分函数结束--------------------------------------------------
//显示标签
void sendlogo( void )
 UART_SendCh(10);       //
 UART_SendCh(13);
 UART_SendStr( "                       Test Message            " );
 UART_SendCh(10);       //
 UART_SendCh(13);
 UART_SendStr( "***************************************************************************" );
 UART_SendCh(10);       //
 UART_SendCh(13);
 UART_SendStr( "                                  1  --->  test 4*4                 " );
 UART_SendCh(10);       //
 UART_SendCh(13);
 UART_SendStr( "                                  2  --->  test ADC0832        " );
 UART_SendCh(10);       //
 UART_SendCh(13);
 UART_SendStr( "                                  3  --->  test shumaguang          " );
 UART_SendCh(10);       //
 UART_SendCh(13);       //
 UART_SendStr( "                                  4  --->  test I2C(24C64)           " );
 UART_SendCh(10);       //
 UART_SendCh(13);
 UART_SendStr( "                                  5  --->  no  test                  " );
 UART_SendCh(10);       //
 UART_SendCh(13);
 UART_SendCh(10);       //
 UART_SendCh(13);
 UART_SendStr( "  06AotoControl   QiXi.Qin   dongxixiaonanbei@163.com" );
 UART_SendCh(10);       //
 UART_SendCh(13);
 UART_SendCh(10);       //
 UART_SendCh(13);
 UART_SendStr( "Please enter you want to test   -------->     " );
//总初始化
void Device_init( void )
 LCD_init();
 Int0init();
 UART_Init();
 EA = 1;
//~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~主函数~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
void main( void )
 uchar tmp;
 uint shu = 9999;  //数码管初值
 uchar new = 0;
 uchar old = 0;
 Device_init();   //总初始化
    while( 1 )
  EA = 0;  //禁止中断,以免写液晶时出现不必要显示的字符
  //4*4
  if( flagwhole == 1 )
   if( flagsendmessage44 == 1 )
    UART_SendCh(10);       //
    UART_SendCh(13);
    UART_SendStr( "    " );
    UART_SendCh(10);       //
    UART_SendCh(13);
   new = KeyScan44();
   if( old != new )
    old = new;
    LCD_write_datalongint( 2, 14, new );
    if( new < 10 )
     LCD_write_char( 2, 15, ' ' );
  //AD采样
  if( flagwhole == 2 )
   if( flagsendmessageadc0832 == 1 )
    UART_SendCh(10);       //
    UART_SendCh(13);
    UART_SendCh(10);       //
    UART_SendCh(13);
   tmp = ReadAdc0832( 0 );
   //清除一些不必要的显示
   if( tmp < 100 )
   if( tmp < 10 )
   LCD_write_char( 2, 14, ' ' );
   //显示该值
   LCD_write_datalongint( 2, 13, tmp );
  //数码管
  if( flagwhole == 3 )
   if( flagsendmessageshumaguang == 1 )
    UART_SendCh(10);       //
    UART_SendCh(13);
    UART_SendCh(10);       //
    UART_SendCh(13);
   DataDisp( shu-- );
  //I2C(24C64)
  if( flagwhole == 4 )
   if( flagsendmessage24c64 == 1 )
    UART_SendCh(10);       //
    UART_SendCh(13);       //
    UART_SendStr( "    UART_SendCh( Rec_Max / 10 + 0x30 );
    UART_SendCh( Rec_Max % 10 + 0x30 );
    UART_SendStr( " words to the Device 24C64> " );
    UART_SendCh(10);       //
    UART_SendCh(13);       //
    flagsendmessage24c64 = 0;  //标志清0
    flagfillallow = 1;  //允许开始装入数据
    flagdoing24c64 = 1;
    Rec_n = 0;
   if( RecFullFlag == 1 )                   //如果装满
    UART_SendCh(10);       //
    UART_SendCh(13);       //
    UART_SendStr( ">>>>>You had finished sendding " );
    UART_SendCh( Rec_n / 10 + 0x30 );
    UART_SendCh( Rec_n % 10 + 0x30 );
    UART_SendStr( " words to Device 24C64!  " );
    UART_SendCh(10);       //
    UART_SendCh(13);       //
    UART_SendStr( ">>>>>you can press 3 Keys on the board to see what you had send to the 24C64, " );
    UART_SendCh(10);       //
    UART_SendCh(13);       //
    UART_SendStr( ">>>>>if you press the key *sure*, you can break out the job now, and it is the only way to break out ^_^ ");
    UART_SendCh(10);       //
    UART_SendCh(13);
    RecFullFlag = 0;
    Rec_n = 0;                               //准备重新接收
   if( sure == 1 )
    sure = 0;
    I2c_Write_n( 0xa0, add_p, Rec_buf, Rec_Max);
    LCD_write_array( 2, 2, Rec_buf ); //在1602上显示该数组字符串
    UART_SendCh(10);       //
    UART_SendCh(13);
    UART_SendCh(10);       //
    UART_SendCh(13);
    flagdoing24c64 = 0;
  //正常状态
  if( flagwhole == 5 )
   flagwhole = 0;     //置标志为0,不做任何测试
   flagdoing24c64 = 0; //任务24C64的工作正在执行标志
   sendlogo();  //显示标签
  EA = 1;  //打开全局中断
51的测试程序(主要是用仿真串口进行测试) - Mr Gvren - BeiBeiHome
关键字:测试程序  仿真串口 引用地址:51的测试程序(主要是用仿真串口进行测试)
上一篇:51单片机lcd1602的驱动程序
下一篇:AD0832的51驱动程序
推荐阅读最新更新时间:2024-03-16 15:20
基于C8051F020的示波器监控程序设计
  设计采用高性能单片机C8051F020为控制芯片,监控示波器面板上40个按键、3个编码开关及4个电位器的状态。分别介绍了键盘、编码开关和电位器的工作原理,以及其与单片机连接的硬件电路及软件编程的实现。按键部分采用一键多义的键盘程序设计方法,给出了键码匹配子程序流程图。   监控程序负责系统中全部硬件和软件资源的分配、调度工作,它提供用户接口,使用户获得友好的工作环境,是系统设计中一个重要组成部分。   1 C8051F020单片机概述   伴随着电子技术快速的发展,越来越多的人加入电子开发的大军。在学习电子技术和研发项目的过程中,避免不了要使用一些仪器,例如万用表、示波器等等,然而对于一些非专业的爱好者,拥有一台数字示波器是比
[测试测量]
基于C80<font color='red'>51</font>F020的示波器监控程序设计
基于51单片机的智能加湿控制器设计
引言 在当下经济不断发展,科学不断进步,人类不断进化的今时今日,人们对生活品质 的要求也随之发生变化。而空气质量对人们生活的影响越来越深,湿度作为影响空气质 量的重要指标之一,对人们的生活有重要的影响,如若不注意可能会引发皮肤病和免疫 力下降以及流失水分加速衰老等一系列问题。因此,有效的洁净加湿已经成为人们生活 当中重要的要求。选用单片机为核心设计一个简易的智能加湿控制器系统,是因为单片 机应用在检测、控制领域中,成本较低,可靠性较好、适应范围较广,且具有高精度的 检测及显示,更重要的是单片机可以构成各种各样的控制系统、数据采集系统。如此设 计出一个以单片机为核心的智能加湿控制器系统,以单片机作为系统的核心控制部分, 能构造出一个
[单片机]
基于<font color='red'>51</font>单片机的智能加湿控制器设计
调试通过51单片机的万年历
//C51写的公历转农历和星期 #define uchar unsigned char #define uint unsigned int #include intrins.h code uchar year_code ={ 0x04,0xAe,0x53, //1901 0 0x0A,0x57,0x48, //1902 3 0x55,0x26,0xBd, //1903 6 0x0d,0x26,0x50, //1904 9
[单片机]
mcs51单片机加法指令(4条)有例子
算术运算 指令 共有24条,算术运算主要是执行加、减、乘、除法四则运算。另外MCS-51指令系统中有相当一部分是进行加、减1操作,BCD码的运算和调整,我们都归类为运算指令。虽然MCS-51单片机的算术逻辑单元ALU仅能对8位无符号整数进行运算,但利用进位标志C,则可进行多字节无符号整数的运算。同时利用溢出标志,还可以对带符号数进行补码运算。需要指出的是,除加、减1指令外,这类指令大多数都会对PSW(程序状态字)有影响。这在使用中应特别注意。 . 加法指令(4条) 这4条指令的作用是把立即数,直接地址、工作寄存器及间接地址内容与累加器A的内容相加,运算结果存在A中。 ADD A,#data ;(A)+#data→(A) 累加器
[单片机]
使用STM32简单控制TMC5160驱动步进电机
首先先来了解一下TMC5160的3种工作模式 TMC5160通过两个引脚来控制它的工作模式: SD _MODE和S PI _MODE。 1、当SD_MODE接地,SPI_MODE拉高,TMC5160即工作在模式1(SPI控制模式)。在该模式下,用户通过SPI接口来设置TMC5160的 寄存器 。 TMC5160使用自己的梯形曲线发生器来控制 步进电机 转动,用户需要设置:开始运动速度VSTART、第一段折线末速度V1、最大速度VMAX、停止速度VSTOP、第一段折线的加速度A1、第二段折线加速度AMAX、第四段折线的减速度 DMA X、第五段折线的减速度D1。把上面的参数设置好,再设置工作模式:速度模式和位置模式。最后再设置
[单片机]
使用STM32简单控制TMC<font color='red'>51</font>60驱动步进电机
89c51 汇编 串口发送数据
ORG 00H START: MOV SCON,#50H //设置串口方式1,允许接受 MOV TMOD,#20H MOV TH1, #0F3H //波特率为2400B/s MOV TL1, #0F3H SETB TR1 SEND: MOV A, #41H MOV P1, A //显示要发送的数据 MOV SBUF,A WAIT: JBC TI, SEND JMP
[单片机]
汉王电纸书N518畅想至尊版降价至千元内
【IT168 资讯】自汉王电纸书N518精华版降至899元后,市场反响极大,其高端的设计定位以及低端的售价,让其在关注度排行榜上迅速蹿升至前五名。而大家在关注N518精华版的时候,可能忽略了其兄弟机型,也就是汉王电纸书昔日的旗舰产品——N518畅享至尊版。这款产品不仅具有N518的全部功能,还增加了大容量存储卡、听书光盘、高端 耳机 等丰富配置,而售价仅为999元,因此也值得关注N518的网友了解一番。   N518畅享至尊版是汉王重量级型号,与N518标准版相比有多处不同:   增加为8GB容量SD卡;   随机配置真皮皮套;   内置12张听书光盘;   配置金玉之声 耳机 ;   包装超豪华大气。   配置上
[手机便携]
汉王电纸书N<font color='red'>51</font>8畅想至尊版降价至千元内
开关电源控制芯片M51995及其应用SMPS'sControlChipM51995andItsApplications
    摘要 : M51995A是 MITSUBISHI公司推出的专门为AC/DC变换而设计的离线式开关电源初级PWM控制芯片。本文详细描述它的工作原理并给出典型应用。     Abstract : M51995A is a off- line SMPS's primary PWM control chip of specific design for AC/ DC Conversion by MITSUBISHI . This paper described in detail its work principle and showed typical applications.     关键词
[应用]
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
