基于stm32f103zet6的RTC学习
发布者:码农闲散人最新更新时间:2017-09-07 来源: eefocus关键字:stm32f103zet6  RTC 手机看文章 扫描二维码
随时随地手机看文章
RTC配置
一、秒中断的配置,RTC就是一个定时器而已,没什么大不了的!
1、NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
NVIC_PriorityGroup,: specifies the priority grouping bits length.
This parameter can be one of the following values:
NVIC_PriorityGroup_0: 0 bits for pre-emption priority 4 bits for subpriority
NVIC_PriorityGroup_1: 1 bits for pre-emption priority 3 bits for subpriority
NVIC_PriorityGroup_2: 2 bits for pre-emption priority 2 bits for subpriority
NVIC_PriorityGroup_3: 3 bits for pre-emption priority 1 bits for subpriority
NVIC_PriorityGroup_4: 4 bits for pre-emption priority 0 bits for subpriority
//意思很明朗,唯一需要理解的就是pre-emption(主优先级)subpriority(副优先级);
2、NVIC_InitTypeDef NVIC_InitStructure;
一个这样的结构体,找到手册
数据成员
uint8_t  NVIC_IRQChannel
FunctionalState  NVIC_IRQChannelCmd
uint8_t  NVIC_IRQChannelPreemptionPriority
uint8_t  NVIC_IRQChannelSubPriority
3、NVIC_IRQChannel他的描述如下
Specifies the IRQ channel to be enabled or disabled.
取值
NonMaskableInt_IRQn  2 Non Maskable Interrupt
MemoryManagement_IRQn  4 Cortex-M3 Memory Management Interrupt
BusFault_IRQn  5 Cortex-M3 Bus Fault Interrupt
UsageFault_IRQn  6 Cortex-M3 Usage Fault Interrupt
SVCall_IRQn  11 Cortex-M3 SV Call Interrupt
DebugMonitor_IRQn  12 Cortex-M3 Debug Monitor Interrupt
PendSV_IRQn  14 Cortex-M3 Pend SV Interrupt
SysTick_IRQn  15 Cortex-M3 System Tick Interrupt
WWDG_IRQn  Window WatchDog Interrupt
PVD_IRQn  PVD through EXTI Line detection Interrupt
TAMPER_IRQn  Tamper Interrupt
RTC_IRQn  RTC global Interrupt
FLASH_IRQn  FLASH global Interrupt
RCC_IRQn  RCC global Interrupt
EXTI0_IRQn  EXTI Line0 Interrupt
EXTI1_IRQn  EXTI Line1 Interrupt
EXTI2_IRQn  EXTI Line2 Interrupt
EXTI3_IRQn  EXTI Line3 Interrupt
EXTI4_IRQn  EXTI Line4 Interrupt
DMA1_Channel1_IRQn  DMA1 Channel 1 global Interrupt
DMA1_Channel2_IRQn  DMA1 Channel 2 global Interrupt
DMA1_Channel3_IRQn  DMA1 Channel 3 global Interrupt
DMA1_Channel4_IRQn  DMA1 Channel 4 global Interrupt
DMA1_Channel5_IRQn  DMA1 Channel 5 global Interrupt
DMA1_Channel6_IRQn  DMA1 Channel 6 global Interrupt
DMA1_Channel7_IRQn  DMA1 Channel 7 global Interrupt
4、NVIC_IRQChannelCmd
Specifies whether the IRQ channel defined in NVIC_IRQChannel will be enabled or disabled.
This parameter can be set either to ENABLE or DISABLE
5、NVIC_IRQChannelPreemptionPriority
抢占优先级
6、NVIC_IRQChannelSubPriority
子优先级
配置应该是
NVIC_IRQChannel = RCC_IRQn
NVIC_IRQChannelCmd= ENABLE
NVIC_IRQChannelPreemptionPriority = 1
NVIC_IRQChannelSubPriority = 0
对照着着源代码看,没有人恩和问题的
二、接下来看个RTC配置函数
    RTC_Configuration();
1、使能外设时钟:包括预备区域时钟和功耗控制时钟
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR | RCC_APB1Periph_BKP, ENABLE);
2、使能BKP寄存器
  PWR_BackupAccessCmd(ENABLE);
3、初始化BKP寄存器,并且置为默认值
  BKP_DeInit();
4、RTC使用的是低速的外部时钟,那么首先打开低速外部时钟
  RCC_LSEConfig(RCC_LSE_ON);
5、等待外部时钟是否起振,是否准备好?
  while (RCC_GetFlagStatus(RCC_FLAG_LSERDY) == RESET){}
6、外部时钟已经打开,那么还要将RTC的时钟设置为外部低速时钟
  RCC_RTCCLKConfig(RCC_RTCCLKSource_LSE);
7、设置完后,需要使能外部时钟
  RCC_RTCCLKCmd(ENABLE);
8、等待RTC寄存器的时钟同步
  RTC_WaitForLastTask();
9、等待最后一个向RTC寄存器写的指令已经完成
10、接下来就是RTC中断的配置了Enables or disables the specified RTC interrupts
  RTC_ITConfig(RTC_IT_SEC, ENABLE); Second interrupt ,使能second interrupt
11、  RTC_WaitForLastTask();
12、设置RTC的与分频系数
  RTC_SetPrescaler(32767); /* RTC period = RTCCLK/RTC_PR = (32.768 KHz)/(32767+1) */
13、  RTC_WaitForLastTask();
有一点要注意的是当我们做完一些对RTC的初始化之后,然后会对RTC的寄存器进行写,那么,为了防止
产生错误,需要等待指令已经我那成也就是RTC_WaitForLastTask();
至此RTC的基本配置也完成了
三、接着当我们需要从串口输入时钟时间的时候,我们看一个函数Time_Adjust
1、一上来就  RTC_WaitForLastTask();
等待操作完,这个没有坏处;
2、改变当前的时间值
  RTC_SetCounter(Time_Regulate());
3、还是一样的RTC_WaitForLastTask();
那么仔细来看看这个Time_Regulate是如何实现的。
void Time_Adjust(void)
  /* Wait until last write operation on RTC registers has finished */
  /* Change the current time */
唯独有个函数
  RTC_SetCounter(Time_Regulate()); Sets the RTC counter value.
貌似是设置秒的函数。
四、
1、  RCC_ClearFlag(); 这是清除复位标识的函数
2、  Time_Show();
五、重点来了。。。
上面为依据野火提供的示例程序,我想使用野火的板子测试肯定是没有问题的,现在关键是我是自己做的最
小系统,所以有很多地方没有注意,比如在这个低速外部晶振的地方,我发发现一直没有振起来,在网上查
了资料,说是因为对这个负载电容要求比较高,因为实验室暂时没有这个电容,所以没办法,只能修改使用
的时钟,我这里使用内部低速晶振来给RTC提供时钟,所以有下面代码需要修改
就是将选择时钟源的地方把那三行代码修改为
RCC_LSICmd(ENABLE);//!!!使用内部低速晶振
while (RCC_GetFlagStatus(RCC_FLAG_LSIRDY) == RESET);
RCC_RTCCLKConfig(RCC_RTCCLKSource_LSI);
对应的分频系数也需要修改了!!!
这样做测试就没有问题了!
具体原因就在转载的那篇博文里面。。。。
关键字:stm32f103zet6  RTC 引用地址:基于stm32f103zet6的RTC学习
上一篇:基于stm32f103zet6的DS1302学习
下一篇:基于stm32f103zet6的DMA学习
推荐阅读最新更新时间:2024-03-16 15:36
MSP430单片机RTC操作-TimeA实现的实时时钟
//******************************************************************************* // D13x Demo - 利用Timer_A及中断实现RTC,观察LED灯的闪烁频率 // // 描述:利用Timer_A及中断实现RTC;通过 P1 异或 来取反 P1.5; // 系统处于休眠状态LPM3,中断时唤醒执行P1.5切换 // ACLK= n/a, MCLK= SMCLK= default DCO ~ 800k // // MSP430F13x // ------------------- // /|\| XIN|- // | | | 32kHz /
[单片机]
STM32F030使用RTC周期性唤醒STOP模式
首先,F030与F072的RTC唤醒功能是不一样的,在相关定义文件stm32f0xx_exti.h中有如下定义: #define EXTI_Line17 ((uint32_t)0x00020000) /*! Internal interrupt line 17 Connected to the RTC Alarm event */ #define EXTI_Line20 ((uint32_t)0x00100000) /*! Internal interrupt line 20
[单片机]
STM32f103ZET6定时器TIM3使用通道1输出PWM程序
总结: TIM3_CH1输出口为PA6(重映射为PB4),PB5位DS0接口。 1.使用重映射之后,原始IO口不再有输出;本例子中,若使用部分重映射,则 PA6映射到PB4中,所以仅仅PB4有波形输出;飞线连接PB4与PB5即可观察PWM呼吸灯效果。 2.使用IO口前务必初始化,本例子中开始仅仅初始化了PB5口,而没有初始化PA6导致一直验证失败;正点原子给出程序中是由通道2直接映射到PB5因此只需要初始化PB5口即可,不存在上述问题。 3.除了正常输出输入信号之外,输出PWM以及其他功能均属于IO口的复用功能。 #include stm32f10x.h #include led.h #include ti
[单片机]
STM32F103ZET6 — USART
串口通信介绍 UART串口通信,使用三线即可进行最基本的数据收发传送: 在数据线上的 Timing 遵循标准的串口通信协议,由起始位,数据,校验位,停止位组成,数据传输 LSB - MSB: 板载 USART 资源介绍 当然,由于电平不一样,使用 RS232 标准进行串口数据传送,需要增加 MAX3232 进行电平转换,再接PC: 单板上的 T1IN 和 R1OUT 接到了 STM32 芯片的 USART1 的 TXD/RXD 管脚,故单板上使用了 USART1 来作为 RS232 和 PC 机进行数据传送: USART 初始化配置 既然确定了使用了芯片上的 USART1,要正确使用该功能,需要进行如下配置:
[单片机]
<font color='red'>STM32F103ZET6</font> — USART
STM学习笔记--RTC
对于STM中RTC部分 1:首先明白其时钟来源,时钟源于3个部分,HSE/28;LSE(32.768KHz);LSI(40KHz);时钟经过可编程预分频器(20bits)RTC_PRLH/RTC_PRLL RTC_DIVH/RTC_DIVL,产生最长时间1S的RTC时间基准TR_CLK,可产生秒中断。TR_CLK周期累加(RTC_CNT计数)并与RTC_ALR(32bits)寄存器比较,若相等则可产生闹钟中断。若RTC_CNT计数溢出,也会产生溢出中断。对RTC的操作,是通过APB1接口,其APB1接口是由APB1总线时钟驱动(P1CLK),用来与APB1总线接口的。 注:预产生中断,必须使能相应的中断位。RTC_CRH(OWIE
[单片机]
STM学习笔记--<font color='red'>RTC</font>
RTC实验讲解
一。RTC实时时钟知识复习 1. 工作原理框图 RTC_CNT寄存器会在TR_CLK的控制下每个时钟周期加1,比如1970年,我们把RTC_CNT设置一个值为N,那么它每一秒加1,不停的加1,我们可以读取这个值,就可以确定我们当前的时间。 2. 配置RTC的步骤 二。RTC实验程序讲解 rtc.h #ifndef __RTC_H #define __RTC_H //Mini STM32开发板 //RTC实时时钟 驱动代码 //正点原子@ALIENTEK //2010/6/6 #include sys.h //时间结构体 typedef struct { vu8 hour; vu8 min; vu8
[单片机]
<font color='red'>RTC</font>实验讲解
stm32l0 rtc休眠周期自动唤醒文档整理
一、周期性自动唤醒--手册文档说明 周期性唤醒标志由 16 位可编程自动重载递减计数器生成。唤醒定时器范围可扩展至 17 位。 可通过 RTC_CR 寄存器中的 WUTE 位来使能此唤醒功能。 唤醒定时器的时钟输入可以是: 2、4、8 或 16 分频的 RTC 时钟 (RTCCLK)。 当 RTCCLK 为 LSE (32.768 kHz) 时,可配置的唤醒中断周期介于 122 µs 和 32 s 之 间,且分辨率低至 61 µs。 ·ck_spre(通常为 1 Hz 内部时钟)。 当ck_spre 频率为 1 Hz 时,可得到的唤醒时间为 1s 到 36h 左右,分辨率为 1 秒。这 一较大的可编程时间范
[单片机]
stm32l0 <font color='red'>rtc</font>休眠周期自动唤醒文档整理
STM32复习笔记(十二)RTC实时时钟(低功耗待机唤醒)
一、RTC实时时钟特征与原理: ★ RTC (Real Time Clock):实时时钟 ★ RTC是个独立的定时器。RTC模块拥有一个连续计数的计数器,在相应的软件配置下,可以提供时钟日历的功能。修改计数器的值可以重新设置当前时间和日期。 ★ RTC模块和时钟配置系统(RCC_BDCR寄存器)是在后备区域,即在系统复位或从待机模式唤醒后RTC的设置和时间维持不变。但是在系统复位后,会自动禁止访问后备寄存器和RTC,以防止对后备区域(BKP)的意外写操作。所以在要设置时间之前, 先要取消备份区域(BKP)写保护。 (1)RTC特征: (2)RTC工作原理框图: (3)RTC由两部分组成: APB1接口:用来和APB1总
[单片机]
STM32复习笔记(十二)<font color='red'>RTC</font>实时时钟(低功耗待机唤醒)
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
