stm32 4*4矩阵键盘
发布者:SereneSpirit最新更新时间:2017-09-27 来源: eefocus关键字:stm32  4*4  矩阵键盘 手机看文章 扫描二维码
随时随地手机看文章
stm32f030开发板。
使用HAL库。
状态机做debounce消抖。
col列,Pin配置为PP推挽输出模式;
row行,Pin配置为Input模式,启用内部上拉电阻。
代码如下:
.h文件
  1. /*
  2. * Name: keypad.h
  3. * Faq: www.mazclub.com
  4. */
  5. #ifndef KEYPAD_H
  6. #define KEYPAD_H
  7.
  8. #include "stm32f0xx_hal.h"
  9. //#include "pinname.h"
  10.
  11.
  12.
  13.
  14. #define COLS (GPIO_PIN_3|GPIO_PIN_4|GPIO_PIN_5|GPIO_PIN_6)
  15.
  16. #define PORT_COL GPIOB
  17. #define KEYy0    GPIO_PIN_6
  18. #define KEYy1    GPIO_PIN_5
  19. #define KEYy2    GPIO_PIN_4
  20. #define KEYy3    GPIO_PIN_3
  21.
  22. #define PORT_ROW GPIOA
  23. #define KEYx0    GPIO_PIN_12
  24. #define KEYx1    GPIO_PIN_11
  25. #define KEYx2    GPIO_PIN_10
  26. #define KEYx3    GPIO_PIN_9
  27.
  28. // 读pin
  29. //#define In(GPIO_Pin) (PORT_KEY->IDR & GPIO_Pin)
  30. #define In(GPIO_Pin) HAL_GPIO_ReadPin(PORT_ROW, GPIO_Pin)
  31. // 写1到Pin
  32. //#define High(GPIO_Pin) PORT_KEY->BSRR = GPIO_Pin
  33. #define High(GPIO_Pin) HAL_GPIO_WritePin(PORT_COL, GPIO_Pin, GPIO_PIN_SET)
  34. // 写0到Pin
  35. //#define Low(GPIO_Pin) PORT_KEY->BSRR = (uint32_t)GPIO_Pin << 16
  36. #define Low(GPIO_Pin) HAL_GPIO_WritePin(PORT_COL, GPIO_Pin, GPIO_PIN_RESET)
  37.
  38. /*
  39. *  0  1  2   3
  40. *  4  5  6   7
  41. *  8  9  10  11
  42. *  12 13 14  15
  43. */
  44.
  45. typedef enum {
  46.     Key_Up = 0x02,
  47.     Key_Left = 0x03,
  48.     Key_Right = 0x04,
  49.     Key_Down = 0x08,
  50.     Key_Power =  0x09,
  51.     Key_Mode = 0x0a,
  52.     Key_None = 0xFF
  53. } KeyPressed;
  54.
  55. static const int row_count = 4;
  56. static const int col_count = 4;
  57.
  58. uint16_t bus_out(void);
  59.
  60. void Keypad(void);
  61. char AnyKey(void);
  62. char SameKey(void);
  63. char ScanKey(void);
  64. void FindKey(void);
  65. void ClearKey(void);
  66. void Read(void);
  67. /** Start the keypad interrupt routines */
  68. void Start(void);
  69. /** Stop the keypad interrupt routines */
  70. void Stop(void);
  71. void Cols_out(uint16_t v);
  72. void Scan_Keyboard(void);
  73. KeyPressed getKey(void);
  74. #endif // KEYPAD_H
.c文件
  1. /*
  2. * Name: keypad.cpp
  4. */
  5.
  6. #include "keypad.h"
  7.
  8. // State:
  9. char KeyState;
  10. // Bit pattern after each scan:
  11. char KeyCode;
  12. // Output value from the virtual 74HC922:
  13. KeyPressed KeyValue;
  14. // KeyDown is set if key is down:
  15. char KeyDown;
  16. // KeyNew is set every time a new key is down:
  17. char KeyNew;
  18. // 映射表
  19. char KeyTable[12][2];
  20. // Pin of Row
  21. uint16_t _rows[] = {KEYx0, KEYx1, KEYx2, KEYx3};
  22. uint16_t _cols[] = {KEYy0, KEYy1, KEYy2, KEYy3};
  23.
  24. //构造函数
  25. void Keypad(void)
  26. {
  27.
  28.    Stop();
  29.    KeyState = 0; // 按键状态初始 0
  30. }
  31.
  32.
  33. //扫描键盘
  34. void Scan_Keyboard(void){
  35. switch (KeyState) {
  36.   case 0: {
  37.   if (AnyKey()) {
  38.     char scankey = ScanKey();
  39.     if (scankey != 0xff)
  40.         KeyCode = scankey;
  41.
  42.     KeyState = 1;
  43.   }
  44.
  45.   break;
  46.   }
  47.   case 1: {
  48.   if (SameKey()) {
  49.     FindKey();
  50.     KeyState = 2;
  51.   }
  52.   else
  53.     KeyState = 0;
  54.
  55.   break;
  56.   }
  57.   case 2: {
  58.     if (SameKey()) {
  59.     }
  60.     else
  61.       KeyState = 3;
  62.
  63.     break;
  64.     }
  65.   case 3: {
  66.     if (SameKey()) {
  67.       KeyState = 2;
  68.     }
  69.     else {
  70.       ClearKey();
  71.       KeyState = 0;
  72.     }
  73.
  74.     break;
  75.    }
  76.   }
  77. // func end
  78. }
  79.
  80. // 有键按下
  81. char AnyKey(void) {
  82.  //Start();  //拉低
  83.
  84.  int r = -1;
  85.  for (r = 0; r < row_count; r++) {
  86.      if (In(_rows[r]) == 0)  // In macro
  87.          break;
  88.  }
  89.
  90.  //Stop();  //恢复
  91.
  92.  if (!(0 <= r && r < row_count))
  93.     return 0;
  94.  else
  95.     return 1;
  96. }
  97.
  98. // 键按下, 键值相同
  99. char SameKey(void) {
  100.
  101.   // char KeyCode_new = KeyCode;
  102.   char KeyCode_new = ScanKey();
  103.   if (KeyCode == KeyCode_new)
  104.     return 1;
  105.   else
  106.     return 0;
  107. }
  108.
  109. // 扫描键
  110. char ScanKey(void) {
  111.
  112.  /* 行扫描 */
  113.     int r = -1;
  114.     for (r = 0; r < row_count; r++) {
  115.         if (In(_rows[r]) == 0)  // In macro
  116.             break;
  117.     }
  118.
  119.     /* 若没有找到有效行,返回 */
  120.     if (!(0 <= r && r < row_count)) {
  121.       return 0xff;
  122.
  123.     }
  124.
  125.     /* 列扫描,找出行上哪个被拉低 */
  126.     int c = -1;
  127.     for (c = 0; c < col_count; c++) {
  128.         // 轮流输出列线
  129.         Cols_out(~(1 << c));
  130.
  131.         if (In(_rows[r]) == 0)  // In macro
  132.             break;
  133.     }
  134.
  135.     /* 给所有的列重新充电 */
  136.     Start();
  137.
  138.     /* 若没有找到有效列,返回 */
  139.     if (!(0 <= c && c < col_count))
  140.         return 0xff;
  141.
  142.     return r * col_count + c;
  143.
  144. }
  145.
  146. // FindKey compares KeyCode to values in KeyTable.
  147. // If match, KeyValue, KeyDown and KeyNew are updated.
  148. void FindKey(void) {
  149.  KeyValue = (KeyPressed)KeyCode;
  150.  KeyDown = 1;
  151.  KeyNew = 1;
  152. }
  153.
  154.
  155. void ClearKey(void) {
  156.  KeyDown = 0;
  157. }
  158.
  159. KeyPressed getKey(void) {
  160.   if(KeyNew)
  161.   {
  162.     KeyNew = 0;
  163.     return KeyValue;
  164.   }
  165.   else
  166.     return Key_None;
  167. }
  168.
  169. void Start(void)
  170. {
  171.     /* 列输出0, 拉低行 */
  172.     PORT_COL->BRR = COLS;
  173. }
  174.
  175. void Stop(void)
  176. {
  177.     /* 列输出1,使行不被拉低 */
  178.     PORT_COL->BSRR = COLS;
  179. }
  180.
  181. // cols bus output
  182. void Cols_out(uint16_t v)
  183. {
  184.   if ((v & 0x01) > 0) //0b001
  185.     High(_cols[0]);
  186.   else
  187.     Low(_cols[0]);
  188.
  189.   if ((v & 0x02) > 0) //0b010
  190.     High(_cols[1]);
  191.   else
  192.     Low(_cols[1]);
  193.
  194.   if ((v & 0x04) > 0) //0b100
  195.     High(_cols[2]);
  196.   else
  197.     Low(_cols[2]);
  198.
  199.   if ((v & 0x08) > 0) //0b100
  200.     High(_cols[3]);
  201.   else
  202.     Low(_cols[3]);
  203.
  204. }
关键字:stm32  4*4  矩阵键盘 引用地址:stm32 4*4矩阵键盘
上一篇:stm32定时器之Output Compare
下一篇:理解stm32开漏输出与推挽输出
推荐阅读最新更新时间:2024-03-16 15:38
STM32串口中断 RXNE TXE
RXNE中断 (使能位为RXNEIE) 串口接收寄存器非空中断, 通过读取接收寄存器清除中断标志位 TXE中断(使能位为TXEIE) 串口发送寄存器空中断, 当不需要发送数据时,需要失能此中断,否则由于满足发送寄存器为空的条件,会一直进入中断 通过写接收寄存器清除中断标志位,当发送完成时寄存器为空,此位又会被被硬件置1 进入中断时,需要判断中断标志位和中断使能位,当两个标志位同时为1时才满足中断的条件,否则由于不同中断源共用中断入口而导致错误。(如RXNE触发了中断,此时TXE标志位也可能为1,若没有对TXEIE位进行判断可能会误认为产生了TXE中断,造成错误)
[单片机]
无源型低成本两线制4-20mA电流转模拟电压信号I/V转换信号隔离器
ISO 4-20mA-O系列(SIP12 Pin封装)两线制无源型4-20mA转电压信号隔离转换器,可以将输入有源4-20mA的电流信号隔离转换成电压信号I/V转换输出。该方案采用两线制输入回路供电方式,独有高效信号回路窃电技术,无须外接工作电源,大大简化了用户的设计,降低用户布线成本。该模块内部包含有电流信号调制解调电路、信号耦合隔离变换电路、电源逆变电路、减法电路,缓冲处理输出电路等,很小的输入等效电阻,使该产品能够从传感器信号输出回路中采集电流信号,并能达到输入20mA信号时电压降 ≤10V。以满足用户无需外接辅助电源而实现信号远距离、无失真传输变换的需要。
[嵌入式]
无源型低成本两线制<font color='red'>4</font>-20mA电流转模拟电压信号I/V转换信号隔离器
苹果4寸新机消息整理
    市场传闻许久的4寸iPhone可能将在近期内发表,同时预期以更快速度进入市场,我们将近期传闻内容作整理,让大家可在新机实际发表之前作简单回顾。 苹果为什么要推4寸新机? 由于目前在美国、欧洲市场仍有多数使用者偏好4寸机种,加上iPhone 5s在市场销售也已经有一段时间,因此苹果可能针对此类市场需求提供新机,并且加入更多应用在iPhone 6、iPhone 6s系列硬体设计与功能,藉此吸引这些用户族群可进一步移转到主流产品,同时也预期可增加本身服务使用比例,例如Apple Pay、iCloud等。 名称就叫“iPhone se”? 目前苹果尚未对外公布,因此目前绝大部分都是市场揣测消息,但有部分说法
[手机便携]
官宣:荣耀30系列支持4K超暗光视频、支持AIS视频超级防抖
此前荣耀官宣荣耀30系列新品发布会将于4月15日举行 。荣耀业务部副总裁(产品)熊军民也确认荣耀30系列将首发麒麟985芯片。 今(12)日,荣耀30系列的新特性也被曝光,支持4K超暗光视频、AIS视频超级防抖、1920fps超级慢动作等功能。 综合集微网此前报道,荣耀30系列还有以下信息: 1.充电快:搭载40W超级快充,获得莱茵安全快充认证,无线快充也没有缺席。 2.音量足:搭载全频段大振幅双扬声器,音色细腻,听感极为震撼。Histen智能音效,游戏听声辨位。 3.有高刷:有网友问荣耀30系列有没有高刷新率的屏幕,荣耀业务部副总裁(产品)熊军民回应说一个都不少,必须有。 4.真轻薄:熊军民发微博称荣耀30系列中的荣耀30机
[手机便携]
或为EOS R套机镜头 佳能公布RF 24-70/4专利
来自CanonRumors的消息,佳能近日公布了一项新的镜头专利技术。据专利描述文件显示,这是一支RF 24-70mm f/4 L IS USM镜头,内含12枚镜片,这或许将成为未来新款EOS R相机的套机镜头。 RF 24-70mm f/4 L IS USM镜头专利 ·RF 24-70mm f/4L IS USM:   焦距:24.71-39.93-67.99   光圈值:4.12-4.12-4.12   半场角:41.20-28.45-17.65   图像高度:21.64-21.64-21.64   整体镜头长度:99.36-108.69-132.25   BF:13.50-24.36-42.60    ·编辑观点:
[家用电子]
STM32的RCC配置流程
在STM32中,有五个时钟源,为HSI、HSE、LSI、LSE、PLL。 ①HSI是高速内部时钟,RC振荡器,频率为8MHz。 ②HSE是高速外部时钟,可接石英/陶瓷谐振器,或者接外部时钟源,频率范围为4MHz~16MHz。 ③LSI是低速内部时钟,RC振荡器,频率为40kHz。 ④LSE是低速外部时钟,接频率为32.768kHz的石英晶体。 ⑤PLL为锁相环倍频输出,其时钟输入源可选择为HSI/2、HSE或者HSE/2。倍频可选择为2~16倍,但是其输出频率最大不得超过72MHz。 用户可通过预分频器配置AHB,APB2,APB1总线的频率,AHB和APB2域的最大频率是72MHZ。APB1域的最大允许频
[单片机]
分区域升级 三星S4 Mini"品尝棒棒糖"
    虽然2015年不少老款智能机都陆续升级Android 5.0,但也有个别产品的升级前景不太乐观,三星S4 Mini就是其中之一。英国运营商Three不久前通过推特表示,三星S4 Mini将无缘Android 5.0。 三星S4 Mini     至于其中的原因Three表示三星S4 Mini的存储空间限制是一大因素,而三星官方也向Three确认了这一原因。三星S4 Mini于2013年发布,是一款机身紧凑功能也比较全面的产品。   不过根据最新消息,Three设在爱尔兰的分支机构表示三星S4 Mini存在Android 5.0的升级包,或许这款产品会根据不同的地域来更新,而更新的时间表现在还不清楚。
[手机便携]
基于STM32 MCU应用的EMC指南之软件篇
在基于微控制器的电子系统中,强壮的软件设计是提高 EMC 性能的主要因素。必须尽量在项目设计阶段的早期考虑 EMC 干扰导致的问题。EMC 导向的软件提高了应用的安全性和可靠性。强化 EMC 性能的软件的实施成本低,可提高最终的抗扰性能,并节约硬件和开发成本。用户应考虑到模拟或数字数据受到的 EMC 干扰,就像任何其它应用参数一样。 EMC 干扰导致的问题示例: 微控制器无响应 程序计数器失控 执行意外指令 地址指向错误 子程序执行错误 寄生复位和 / 或寄生中断 IP 配置损坏 I/O 失灵 软件故障的后果示例: 产品意外响应 上下文丢失 进程中的意外分支 中断丢失 数据完整性缺失 输入值误读 01使用看门狗或时间控制 为了
[单片机]
基于<font color='red'>STM32</font> MCU应用的EMC指南之软件篇
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
