#include "stm32f10x_lib.h"
#include "stdio.h"
#define USART1_DR_Base 0x40013804
#define SENDBUFF_SIZE 10240
vu8 SendBuff[SENDBUFF_SIZE];
vu8 RecvBuff[10];
vu8 recv_ptr;
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
void DMA_Configuration(void);
void USART1_Configuration(void);
int fputc(int ch, FILE *f);
void Delay(void);
int main(void)
u16 i;
#ifdef DEBUG
debug();
#endif
recv_ptr = 0;
RCC_Configuration();
GPIO_Configuration();
NVIC_Configuration();
DMA_Configuration();
USART1_Configuration();
printf("\r\nSystem Start...\r\n");
printf("Initialling SendBuff... \r\n");
for(i=0;i
SendBuff[i] = i&0xff;
printf("Initial success!\r\nWaiting for transmission...\r\n");
//发送去数据已经准备好,按下按键即开始传输
while(GPIO_ReadInputDataBit(GPIOD, GPIO_Pin_3));
printf("Start DMA transmission!\r\n");
//这里是开始DMA传输前的一些准备工作,将USART1模块设置成DMA方式工作
USART_DMACmd(USART1, USART_DMAReq_Tx, ENABLE);
//开始一次DMA传输!
DMA_Cmd(DMA1_Channel4, ENABLE);
//等待DMA传输完成,此时我们来做另外一些事,点灯
//实际应用中,传输数据期间,可以执行另外的任务
while(DMA_GetFlagStatus(DMA1_FLAG_TC4) == RESET)
LED_1_REV; //LED翻转
Delay(); //浪费时间
//DMA传输结束后,自动关闭了DMA通道,而无需手动关闭
//下面的语句被注释
//DMA_Cmd(DMA1_Channel4, DISABLE);
printf("\r\nDMA transmission successful!\r\n");
while (1)
//USART_SendData(USART1, (u8) ch);
USART1->DR = (u8) ch;
while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET)
return ch;
void Delay(void)
u32 i;
for(i=0;i<0xF0000;i++);
return;
ErrorStatus HSEStartUpStatus;
//使能外部晶振
RCC_HSEConfig(RCC_HSE_ON);
//等待外部晶振稳定
HSEStartUpStatus = RCC_WaitForHSEStartUp();
//如果外部晶振启动成功,则进行下一步操作
if(HSEStartUpStatus==SUCCESS)
//设置HCLK(AHB时钟)=SYSCLK
RCC_HCLKConfig(RCC_SYSCLK_Div1);
//PCLK1(APB1) = HCLK/2
RCC_PCLK1Config(RCC_HCLK_Div2);
//PCLK2(APB2) = HCLK
RCC_PCLK2Config(RCC_HCLK_Div1);
//FLASH时序控制
//推荐值:SYSCLK = 0~24MHz Latency=0
// SYSCLK = 24~48MHz Latency=1
// SYSCLK = 48~72MHz Latency=2
FLASH_SetLatency(FLASH_Latency_2);
//开启FLASH预取指功能
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
//PLL设置 SYSCLK/1 * 9 = 8*1*9 = 72MHz
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
//启动PLL
RCC_PLLCmd(ENABLE);
//等待PLL稳定
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
//系统时钟SYSCLK来自PLL输出
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
//切换时钟后等待系统时钟稳定
while(RCC_GetSYSCLKSource()!=0x08);
//下面是给各模块开启时钟
//启动GPIO
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | \
RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD,\
ENABLE);
//启动AFIO
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
//启动USART1
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
//启动DMA时钟
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
GPIO_InitTypeDef GPIO_InitStructure;
//PC口4567脚设置GPIO输出,推挽 2M
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
GPIO_Init(GPIOC, &GPIO_InitStructure);
//KEY2 KEY3 JOYKEY
//位于PD口的3 4 11-15脚,使能设置为输入
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_11 | GPIO_Pin_12 |\
GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_Init(GPIOD, &GPIO_InitStructure);
//USART1_TX
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
//USART1_RX
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
NVIC_InitTypeDef NVIC_InitStructure;
#ifdef VECT_TAB_RAM
// Set the Vector Table base location at 0x20000000
NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else
// Set the Vector Table base location at 0x08000000
NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
//设置NVIC优先级分组为Group2:0-3抢占式优先级,0-3的响应式优先级
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
//串口接收中断打开
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
USART_InitTypeDef USART_InitStructure;
USART_InitStructure.USART_BaudRate = 9600;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Tx | USART_Mode_Rx;
USART_Init(USART1, &USART_InitStructure);
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
USART_Cmd(USART1, ENABLE);
DMA_InitTypeDef DMA_InitStructure;
//DMA设置:
//设置DMA源:内存地址&串口数据寄存器地址
//方向:内存-->外设
//每次传输位:8bit
//传输大小DMA_BufferSize=SENDBUFF_SIZE
//地址自增模式:外设地址不增,内存地址自增1
//DMA模式:一次传输,非循环
//优先级:中
DMA_DeInit(DMA1_Channel4);
DMA_InitStructure.DMA_PeripheralBaseAddr = USART1_DR_Base;
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)SendBuff;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
DMA_InitStructure.DMA_BufferSize = SENDBUFF_SIZE;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
DMA_InitStructure.DMA_Priority = DMA_Priority_Medium;
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
DMA_Init(DMA1_Channel4, &DMA_InitStructure);
上一篇:Cortex-M3 USB的“JoyStickMouse”例程结构分析(二)
下一篇:STC89C52上的读写MMA7455程序
推荐阅读最新更新时间:2024-03-16 15:43
