8*8点阵流水显示程序与原理
发布者:创意探险最新更新时间:2017-12-29 来源: eefocus关键字:8*8点阵  流水显示 手机看文章 扫描二维码
随时随地手机看文章
首先是让汉字能够静态显示,显示一段时间后(时间可能很短)把所显示的汉字编码移一位重新送出,比如要向左移动,原本显示在第一列的数据就丢弃了,把第二列的数据送到第一列上显示,依次移动显示一屏,显示一段时间再进行一次移动,人们看起来也就是移动的了。
这是程序:调试过的
硬件连接可以去这里:
#include
//sbit A=P2^0;
//sbit B=P2^1;
//sbit C=P2^2;
//sbit select=P2^3;
sbit clk=P3^0;        //595串行时钟端
sbit da=P3^1;         //595串行数据端
sbit enable=P3^2;
/************************************字库**********************************************/
unsigned char code stable[]={/*--  文字:  天  --*/
/*--  宋体12;  此字体下对应的点阵为:宽x高=16x16   --*/
0x00,0x00,0x80,0x40,0x40,0x42,0x20,0x42,0x10,0x42,0x08,0x42,0x06,0x42,0x01,0xFE,
0x02,0x42,0x04,0x42,0x08,0x42,0x10,0x42,0x30,0x42,0x60,0x42,0x20,0x40,0x00,0x00,
/*--  文字:  天  --*/
/*--  文字:  快  --*/
0x00,0x70,0x00,0x00,0xFF,0xFF,0x00,0x08,0x80,0xB0,0x40,0x88,0x30,0x88,0x0E,0x88,
0x01,0xFF,0x06,0x88,0x08,0x88,0x30,0x88,0x60,0xF8,0xC0,0x80,0x40,0x80,0x00,0x00,
/*--  文字:  乐  --*/
0x00,0x00,0x20,0x00,0x18,0x40,0x0C,0xFC,0x07,0x44,0x12,0x44,0x20,0x44,0x40,0x46,
0x3F,0xFA,0x00,0x42,0x00,0x43,0x02,0x43,0x0C,0x42,0x38,0x40,0x10,0x00,0x00,0x00,
/*--  文字:  !  --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xF8,0xDF,0xFC,
0xDF,0xFC,0x01,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
/*--  文字:  欢  --*/
0x20,0x14,0x10,0x24,0x4C,0x44,0x43,0x84,0x43,0x64,0x2C,0x1C,0x20,0x20,0x10,0x18,
0x0C,0x0F,0x03,0xE8,0x06,0x08,0x18,0x08,0x30,0x28,0x60,0x18,0x20,0x08,0x00,0x00,
/*--  文字:  迎  --*/
0x40,0x40,0x20,0x41,0x1F,0xCE,0x20,0x04,0x40,0x00,0x47,0xFC,0x42,0x04,0x41,0x02,
0x40,0x02,0x5F,0xFC,0x40,0x04,0x42,0x04,0x44,0x04,0x43,0xFC,0x40,0x00,0x00,0x00,
/*--  文字:  来  --*/
0x20,0x00,0x20,0x80,0x10,0x84,0x10,0x84,0x08,0x94,0x04,0xA4,0x02,0xC4,0xFF,0xFF,
0x01,0x84,0x02,0xC4,0x04,0xB4,0x08,0x94,0x18,0x84,0x30,0x84,0x10,0x80,0x00,0x00,
/*--  文字:  我  --*/
0x04,0x20,0x04,0x20,0x42,0x22,0x82,0x22,0x7F,0xFE,0x01,0x21,0x01,0x21,0x10,0x20,
0x10,0x20,0x08,0xFF,0x07,0x20,0x1A,0x22,0x21,0xAC,0x40,0x20,0xF0,0x20,0x00,0x00,
/*--  文字:  的  --*/
0x00,0x00,0x7F,0xF8,0x10,0x8C,0x10,0x8B,0x10,0x88,0x3F,0xF8,0x00,0x40,0x00,0x30,
0x00,0x8F,0x03,0x08,0x26,0x08,0x40,0x08,0x20,0x08,0x1F,0xF8,0x00,0x00,0x00,0x00,
/*--  文字:  空  --*/
0x00,0x10,0x40,0x0C,0x40,0x84,0x41,0x44,0x41,0x24,0x41,0x14,0x41,0x05,0x7F,0x06,
0x41,0x04,0x41,0x14,0x41,0x24,0x41,0x44,0x40,0x84,0x40,0x14,0x00,0x0C,0x00,0x00,
/*--  文字:  间  --*/
0x00,0x00,0xFF,0xF8,0x00,0x01,0x00,0x06,0x00,0x00,0x07,0xF0,0x04,0x92,0x04,0x92,
0x04,0x92,0x04,0x92,0x07,0xF2,0x40,0x02,0x80,0x02,0x7F,0xFE,0x00,0x00,0x00,0x00,
/*--  文字:  天  --*/
                                 行显示子程序
                     实质是给当前行中的所有列传送两字节的数据
void hang_disp(unsigned char temp1,unsigned char temp2)
unsigned char i;
for(i=0;i<16;i++)
      if(i==8)temp2=temp1;          /***前8位即一字节传送完之后,传送该行的第二字节***/
      if(temp2&0x01)da=1;          /****数据从端口输出****/
      else          da=0;          /****生成一上升沿,595上升沿接受数据****/
      clk=0;clk=1;clk=0;
      temp2=temp2>>1;
  enable=0;enable=1;enable=0;      /****595并行输出使能****/
                             清行子程序
   如果没有清行程序,该行显示完转到下一行时595的输出还没有变,还是上一行的数据 ,因为程序中是先选定行,
再向595传数据的,所以下一行开始时有一段时间是显示合一行的内容的,这段时间就是向595传两个字节数据的时间。
void hang_clear()
unsigned char i;
for(i=0;i<16;i++)
      da=0;     /***595的输出连接的是点阵的阴极,所以让595输出高电平,可以使得该行的LED熄灭****/
      clk=0;clk=1;clk=0;
unsigned int count=0;
unsigned char move=0;
void disp()
unsigned char i;
unsigned int j;
count++;
for(i=0;i<16;i++)
   P2=i;                                           /*****选定行*****/
   //hang_disp(stable[2*(i+move)],stable[2*(i+move)+1]);          /***从字库中取数据****/
  hang_disp(~stable[2*(i+move)],~stable[2*(i+move)+1]);   /***从字库中取数据再取反,能实现反显****/
   for(j=0;j<10;j++);   /***显示和清零间加以延时,以便显示明显,可以自行调节,也可以去掉***/
   hang_clear();
if(count==10)     /***调节移动的速度***/
    count=0;
    move++;
    if(move==192)    /***调节移动的字数***n=move/16***/
         move=0;
main()
while(1)
     disp();
关键字:8*8点阵  流水显示 引用地址:8*8点阵流水显示程序与原理
上一篇:一个按键实现三个LED的亮灭延时控制
下一篇:KEIL中的ISD51仿真软件详细使用说明
推荐阅读最新更新时间:2024-03-16 15:50
51单片机复习:8*8led点阵
有两种,一种列为低电压通,行为高电压为通,我们可以依次将每一列接低电压,也就依次点亮 然后利用行的电压来控制点亮,如果有一行电压为低,那一行的Led灯都不会亮 第二种反之,列为高低压则通,行为低电压则通,两者同时符合,则对应的灯点亮 74H595芯片 在我使用的普中51单片机中,其控制行电压,而P0口则控制列电压 其有三个引脚,SER(串行数据输入),SCLK(移位储存器时钟输入),CLK(数据储存器时钟输入) 我是这样理解他们的,SER负责传送数据,每一次只能接受一位,而SCLK上升沿让移位有效,而CLK上升沿让整个数据的传输有效
[单片机]
8*8LED点阵显示0-9
电路很简单8*8点阵的行和列分别接在单片机的p3口和p1口,我测试成功. #include AT89X52.H unsigned char code tab ={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f}; unsigned char code digittab ={ {0x00,0x00,0x3e,0x41,0x41,0x41,0x3e,0x00}, //0 {0x00,0x00,0x00,0x00,0x21,0x7f,0x01,0x00}, //1 {0x00,0x00,0x27,0x45,0x45,0x
[单片机]
8x8LED点阵显示数字和汉字
8x8LED点阵原理 当 MR 为高电平,OE 为低电平时,数据在 SHCP 上升沿进入移位寄存器,在 STCP 上升沿输出到并行端口。 74595 的数据端: QA–QH: 八位并行输出端,可以直接控制数码管的 8 个段。 QH’: 级联输出端。我将它接下一个 595 的 SI 端。 SI: 串行数据输入端。74595 的控制端说明: /SCLR(10 脚): 低点平时将移位寄存器的数据清零。通常我将它接 Vcc。 SCK(11 脚):上升沿时数据寄存器的数据移位。 QA– QB– QC– …– QH;下 降沿移位寄存器数据不变。(脉冲宽度: 5V 时,大于几十纳秒就行了。) RCK(12 脚):上升沿时移位寄存器的数
[单片机]
<font color='red'>8</font>x<font color='red'>8</font>LED<font color='red'>点阵</font><font color='red'>显示</font>数字和汉字
51单片机8X8点阵贪吃蛇游戏(带proteus仿真)
一共六关 吃20个就到下一关 // i 单片机论坛 /i :http://www.51hei.com/bbs/ #include reg51.h #define uchar unsigned char #define SNAKE 20 //最大长度 #define TIME 50 //显示延时时间 #define SPEED 71 //速度控制 //#define keyenable 1 sbit keyenable=P3^6; //方向使能 /*sbit keyx=P0^1; //左右 sbit key
[单片机]
51单片机<font color='red'>8</font>X<font color='red'>8</font><font color='red'>点阵</font>贪吃蛇游戏(带proteus仿真)
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
随便看看
