STC90/89系列内部 EEPROM 放数据(C语言)
发布者:悠闲之旅最新更新时间:2018-02-01 来源: eefocus关键字:STC90  89系列  EEPROM  放数据 手机看文章 扫描二维码
随时随地手机看文章
#include
#include         /* use _nop_() function */
//sfr16 DPTR = 0x82;
/*        新增特殊功能寄存器定义        */
sfr     ISP_DATA    =   0xe2;
sfr     ISP_ADDRH    =   0xe3;
sfr     ISP_ADDRL    =   0xe4;
sfr     ISP_CMD    =   0xe5;
sfr     ISP_TRIG    =   0xe6;
sfr     ISP_CONTR    =   0xe7;
/* 定义命令 */
#define READ_AP_and_Data_Memory_Command                0x01        /*  字节读数据存储区   */
#define PROGRAM_AP_and_Data_Memory_Command          0x02        /*  字节编程数据存储区 */
#define SECTOR_ERASE_AP_and_Data_Memory_Command     0x03        /*  扇区擦除数据存储区 */
typedef     unsigned char    INT8U;        /* 8 bit 无符号整型  */
typedef     unsigned int    INT16U;     /* 16 bit 无符号整型 */
#define        DELAY_CONST         60000
/* 定义常量 */
#define ERROR   0
#define OK      1
sbit        Begin_LED       =        P1^0;
sbit        ERROR_LED       =       P1^3;
sbit        OK_LED            =       P1^7;
/* 定义Flash 操作等待时间 */
#define        MCU_CLOCK_40MHz
//#define         MCU_CLOCK_20MHz
//#define        MCU_CLOCK_10MHz
//#define        MCU_CLOCK_5MHz
#ifdef MCU_CLOCK_40MHz
        #define WAIT_TIME        0x00
#endif
#ifdef MCU_CLOCK_20MHz
        #define WAIT_TIME        0x01
#endif
#ifdef MCU_CLOCK_10MHz
        #define WAIT_TIME        0x02
#endif
#ifdef MCU_CLOCK_5MHz
        #define WAIT_TIME        0x03
#endif
/* 调试控制项 */
//#define         DEBUG_STC89C_LE58RD+
#define         DEBUG_STC89C_LE52RC
//#define USED_BYTE_QTY_IN_ONE_SECTOR                1
//#define USED_BYTE_QTY_IN_ONE_SECTOR                2
//#define USED_BYTE_QTY_IN_ONE_SECTOR                4
//#define USED_BYTE_QTY_IN_ONE_SECTOR                8
//#define USED_BYTE_QTY_IN_ONE_SECTOR                16
//#define USED_BYTE_QTY_IN_ONE_SECTOR                32
//#define USED_BYTE_QTY_IN_ONE_SECTOR                64
#define USED_BYTE_QTY_IN_ONE_SECTOR                128
//#define USED_BYTE_QTY_IN_ONE_SECTOR                256
//#define USED_BYTE_QTY_IN_ONE_SECTOR                512
INT8U xdata protect_buffer[USED_BYTE_QTY_IN_ONE_SECTOR];
#ifdef DEBUG_STC89C_LE58RD+                        //STC89C58RD+,  89LE58RD+
        #define DEBUG_AP_Memory_Begin_Sector_addr        0x0000
        #define DEBUG_AP_Memory_End_Sector_addr         0x7e00
        #define DEBUG_AP_Memory_End_Byte_addr           0x7fff
        #define DEBUG_Data_Memory_Begin_Sector_addr     0x8000
#endif
#ifdef DEBUG_STC89C_LE52RC                        //STC89C52RC,        89LE52RC
        #define DEBUG_AP_Memory_End_Sector_addr            0x1e00
        #define DEBUG_AP_Memory_End_Byte_addr            0x1fff
        #define DEBUG_Data_Memory_Begin_Sector_addr        0x2000
#endif
/* 打开 ISP,IAP 功能 */
void ISP_IAP_enable(void)
    EA    =    0;    /* 关中断 */
    ISP_CONTR    =    ISP_CONTR & 0x18;       /* 0001,1000 */
    ISP_CONTR    =    ISP_CONTR | WAIT_TIME;
    ISP_CONTR    =    ISP_CONTR | 0x80;       /* 1000,0000 */
/* 关闭 ISP,IAP 功能 */
void ISP_IAP_dISAble(void)
    ISP_CONTR    =    ISP_CONTR & 0x7f;    /* 0111,1111 */
    ISP_TRIG    =    0x00;
    EA            =   1;                    /* 开中断 */
/* 字节读 */
INT8U byte_read(INT16U byte_addr)
    ISP_ADDRH    =    (INT8U)(byte_addr >> 8);
    ISP_ADDRL    =    (INT8U)(byte_addr & 0x00ff);
    ISP_CMD        =    ISP_CMD    &    0xf8;        /* 1111,1000 */
    ISP_CMD        =    ISP_CMD    |    READ_AP_and_Data_Memory_Command;        /* 0000,0001 */
    ISP_IAP_enable();
    ISP_TRIG    =    0x46;
    ISP_TRIG    =    0xb9;
    _nop_();
    ISP_IAP_disable();
    return (ISP_DATA);
/* 扇区擦除 */
INT8U sector_erase(INT16U sector_addr)
    INT16U get_sector_addr    =    0;
    get_sector_addr            =    (sector_addr & 0xfe00); /* 1111,1110,0000,0000; 取扇区地址 */
    ISP_ADDRH                =    (INT8U)(get_sector_addr >> 8);
    ISP_ADDRL                =    0x00;
    ISP_CMD    =    ISP_CMD    |    SECTOR_ERASE_AP_and_Data_Memory_Command;    /* 0000,0011 */
    ISP_IAP_enable();
    ISP_TRIG    =    0x46;        /* 触发ISP_IAP命令 */
    ISP_TRIG    =    0xb9;        /* 触发ISP_IAP命令 */
     _nop_();
    ISP_IAP_disable();
    return OK;
/* 字节编程 */
INT8U byte_program(INT16U byte_addr, INT8U original_data)
    ISP_CMD        =    ISP_CMD    |    PROGRAM_AP_and_Data_Memory_Command;        /* 0000,0010 */
    ISP_DATA    =    original_data;
    ISP_IAP_enable();
    _nop_();
    ISP_IAP_disable();
    return    OK;
/* 字节编程并校验 */
INT8U byte_program_and_verify(INT16U byte_addr, INT8U original_data)
    ISP_IAP_enable();
    ISP_TRIG    =    0x46;
    ISP_TRIG    =    0xb9;
    _nop_();
    ISP_DATA    =    0x00;
    _nop_();
    ISP_IAP_disable();
    if(ISP_DATA    ==    original_data)
        return    OK;
    else
        return    ERROR;
/* 写数据进 数据Flash存储器, 只在同一个扇区内写,不保留原有数据    */
/* begin_addr,被写数据Flash开始地址;counter,连续写多少个字节; array[],数据来源    */
INT8U sequential_write_flash_in_one_sector(INT16U begin_addr, INT16U counter, INT8U array[])
    INT16U    i    =    0;
    INT16U    in_sector_begin_addr    =    0;
    INT16U    sector_addr    =    0;
    /* 判是否是有效范围,此函数不允许跨扇区操作 */
    if(counter > USED_BYTE_QTY_IN_ONE_SECTOR)
        return    ERROR;
    in_sector_begin_addr =        begin_addr & 0x01ff;         /* 0000,0001,1111,1111 */
    if( (in_sector_begin_addr + counter) > USED_BYTE_QTY_IN_ONE_SECTOR )
        return ERROR;
    /* 擦除 要修改/写入 的扇区 */
    sector_addr    =    (begin_addr & 0xfe00);    /* 1111,1110,0000,0000; 取扇区地址 */
    ISP_ADDRH    =    (INT8U)(sector_addr >> 8);
    ISP_ADDRL    =    0x00;
    ISP_IAP_enable();
    _nop_();
    for(i = 0; i< counter; i++)
        /* 写一个字节 */
        ISP_ADDRH    =    (INT8U)(begin_addr >> 8);
        ISP_ADDRL    =    (INT8U)(begin_addr & 0x00ff);
        ISP_DATA    =    array[i];
        _nop_();
        /* 读回来 */
        ISP_DATA    =    0x00;
        _nop_();
        /*  比较对错 */
        if(ISP_DATA != array[i])
            ISP_IAP_disable();
            return ERROR;
        begin_addr++;
    ISP_IAP_disable();
    return    OK;
/* 写数据进数据Flash存储器(EEPROM), 只在同一个扇区内写,保留同一扇区中不需修改的数据    */
INT8U write_flash_with_protect_in_one_sector(INT16U begin_addr, INT16U counter, INT8U array[])
    INT16U    i    =    0;
    INT16U    byte_addr    =    0;
        return ERROR;
    /* 假定从扇区的第0个字节开始,到USED_BYTE_QTY_IN_ONE_SECTOR-1个字节结束,后面部分不用,程序易编写    */
        return ERROR;
    /* 将该扇区数据 0 - (USED_BYTE_QTY_IN_ONE_SECTOR-1) 字节数据读入缓冲区保护 */
    byte_addr        =   sector_addr;            /* 扇区地址为扇区首字节地址                 */
    ISP_IAP_enable();
    for(i = 0; i < USED_BYTE_QTY_IN_ONE_SECTOR; i++)
        ISP_TRIG    =    0x46;
        ISP_TRIG    =    0xb9;
        _nop_();
        protect_buffer[i]    =    ISP_DATA;
        byte_addr++;
    /* 将要写入的数据写入保护缓冲区的相应区域,其余部分保留 */
    for(i = 0; i < counter; i++)
        protect_buffer[in_sector_begin_addr] = array[i];
        in_sector_begin_addr++;
    /* 擦除 要修改/写入 的扇区 */
    ISP_ADDRL    =    0x00;
    _nop_();
    /* 将保护缓冲区的数据写入 Data Flash, EEPROM */
    for(i = 0; i< USED_BYTE_QTY_IN_ONE_SECTOR; i++)
        /* 写一个字节 */
        ISP_DATA    =    protect_buffer[i];
        _nop_();
        /* 读回来 */
        ISP_DATA    =    0x00;
        _nop_();
        /*  比较对错 */
        if(ISP_DATA != protect_buffer[i])
            ISP_IAP_disable();
            return ERROR;
        byte_addr++;
    ISP_IAP_disable();
    return OK;
/* 测试常量数组 */
INT8U code Test_array_total[512]        =
        0x00,        0x01,        0x02,        0x03,        0x04,        0x05,        0x06,        0x07,
        0x08,        0x09,        0x0a,        0x0b,        0x0c,        0x0d,        0x0e,        0x0f,
        0x10,        0x11,        0x12,        0x13,        0x14,        0x15,        0x16,        0x17,
        0x18,        0x19,        0x1a,        0x1b,        0x1c,        0x1d,        0x1e,        0x1f,
        0x20,        0x21,        0x22,        0x23,        0x24,        0x25,        0x26,        0x27,
        0x28,        0x29,        0x2a,        0x2b,        0x2c,        0x2d,        0x2e,        0x2f,
        0x30,        0x31,        0x32,        0x33,        0x34,        0x35,        0x36,        0x37,
        0x38,        0x39,        0x3a,        0x3b,        0x3c,        0x3d,        0x3e,        0x3f,
        0x40,        0x41,        0x42,        0x43,        0x44,        0x45,        0x46,        0x47,
        0x48,        0x49,        0x4a,        0x4b,        0x4c,        0x4d,        0x4e,        0x4f,
        0x50,        0x51,        0x52,        0x53,        0x54,        0x55,        0x56,        0x57,
        0x58,        0x59,        0x5a,        0x5b,        0x5c,        0x5d,        0x5e,        0x5f,
        0x60,        0x61,        0x62,        0x63,        0x64,        0x65,        0x66,        0x67,
        0x68,        0x69,        0x6a,        0x6b,        0x6c,        0x6d,        0x6e,        0x6f,
        0x70,        0x71,        0x72,        0x73,        0x74,        0x75,        0x76,        0x77,
        0x78,        0x79,        0x7a,        0x7b,        0x7c,        0x7d,        0x7e,        0x7f,
        0x80,        0x81,        0x82,        0x83,        0x84,        0x85,        0x86,        0x87,
        0x88,        0x89,        0x8a,        0x8b,        0x8c,        0x8d,        0x8e,        0x8f,
        0x90,        0x91,        0x92,        0x93,        0x94,        0x95,        0x96,        0x97,
        0x98,        0x99,        0x9a,        0x9b,        0x9c,        0x9d,        0x9e,        0x9f,
        0xa0,        0xa1,        0xa2,        0xa3,        0xa4,        0xa5,        0xa6,        0xa7,
        0xa8,        0xa9,        0xaa,        0xab,        0xac,        0xad,        0xae,        0xaf,
        0xb0,        0xb1,        0xb2,        0xb3,        0xb4,        0xb5,        0xb6,        0xb7,
        0xb8,        0xb9,        0xba,        0xbb,        0xbc,        0xbd,        0xbe,        0xbf,
        0xc0,        0xc1,        0xc2,        0xc3,        0xc4,        0xc5,        0xc6,        0xc7,
        0xc8,        0xc9,        0xca,        0xcb,        0xCC,        0xcd,        0xce,        0xcf,
        0xd0,        0xd1,        0xd2,        0xd3,        0xd4,        0xd5,        0xd6,        0xd7,
        0xd8,        0xd9,        0xda,        0xdb,        0xdc,        0xdd,        0xde,        0xdf,
        0xe0,        0xe1,        0xe2,        0xe3,        0xe4,        0xe5,        0xe6,        0xe7,
        0xe8,        0xe9,        0xea,        0xeb,        0xec,        0xed,        0xee,        0xef,
        0xf0,        0xf1,        0xf2,        0xf3,        0xf4,        0xf5,        0xf6,        0xf7,
        0xf8,        0xf9,        0xfa,        0xfb,        0xfc,        0xfd,        0xfe,        0xff,
        0xff,        0xfe,        0xfd,        0xfc,        0xfb,        0xfa,        0xf9,        0xf8,
        0xf7,        0xf6,        0xf5,        0xf4,        0xf3,        0xf2,        0xf1,        0xf0,
        0xef,        0xee,        0xed,        0xec,        0xeb,        0xea,        0xe9,        0xe8,
        0xe7,        0xe6,        0xe5,        0xe4,        0xe3,        0xe2,        0xe1,        0xe0,
        0xdf,        0xde,        0xdd,        0xdc,        0xdb,        0xda,        0xd9,        0xd8,
        0xd7,        0xd6,        0xd5,        0xd4,        0xd3,        0xd2,        0xd1,        0xd0,
        0xcf,        0xce,        0xcd,        0xcc,        0xcb,        0xca,        0xc9,        0xc8,
        0xc7,        0xc6,        0xc5,        0xc4,        0xc3,        0xc2,        0xc1,        0xc0,
        0xbf,        0xbe,        0xbd,        0xbc,        0xbb,        0xba,        0xb9,        0xb8,
        0xb7,        0xb6,        0xb5,        0xb4,        0xb3,        0xb2,        0xb1,        0xb0,
        0xaf,        0xae,        0xad,        0xac,        0xab,        0xaa,        0xa9,        0xa8,
        0xa7,        0xa6,        0xa5,        0xa4,        0xa3,        0xa2,        0xa1,        0xa0,
        0x9f,        0x9e,        0x9d,        0x9c,        0x9b,        0x9a,        0x99,        0x98,
        0x97,        0x96,        0x95,        0x94,        0x93,        0x92,        0x91,        0x90,
        0x8f,        0x8e,        0x8d,        0x8c,        0x8b,        0x8a,        0x89,        0x88,
        0x87,        0x86,        0x85,        0x84,        0x83,        0x82,        0x81,        0x80,
        0x7f,        0x7e,        0x7d,        0x7c,        0x7b,        0x7a,        0x79,        0x78,
        0x77,        0x76,        0x75,        0x74,        0x73,        0x72,        0x71,        0x70,
        0x6f,        0x6e,        0x6d,        0x6c,        0x6b,        0x6a,        0x69,        0x68,
        0x67,        0x66,        0x65,        0x64,        0x63,        0x62,        0x61,        0x60,
        0x5f,        0x5e,        0x5d,        0x5c,        0x5b,        0x5a,        0x59,        0x58,
        0x57,        0x56,        0x55,        0x54,        0x53,        0x52,        0x51,        0x50,
        0x4f,        0x4e,        0x4d,        0x4c,        0x4b,        0x4a,        0x49,        0x48,
        0x47,        0x46,        0x45,        0x44,        0x43,        0x42,        0x41,        0x40,
        0x3f,        0x3e,        0x3d,        0x3c,        0x3b,        0x3a,        0x39,        0x38,
        0x33,        0x36,        0x35,        0x34,        0x33,        0x32,        0x31,        0x30,
        0x2f,        0x2e,        0x2d,        0x2c,        0x2b,        0x2a,        0x29,        0x28,
        0x27,        0x26,        0x25,        0x24,        0x23,        0x22,        0x21,        0x20,
        0x1f,        0x1e,        0x1d,        0x1c,        0x1b,        0x1a,        0x19,        0x18,
        0x17,        0x16,        0x15,        0x14,        0x13,        0x12,        0x11,        0x10,
        0x0f,        0x0e,        0x0d,        0x0c,        0x0b,        0x0a,        0x09,        0x08,
        0x07,        0x06,        0x05,        0x04,        0x03,        0x02,        0x01,        0x00
void display_Begin_LED(void)
    Begin_LED    =    0;  /* Begin_LED on */
void off_Begin_LED(void)
    Begin_LED    =    1;  /* Begin_LED off */
void display_OK_LED(void)
    OK_LED        =    0;  /* OK_LED on */
void off_OK_LED(void)
    OK_LED        =    1;  /* OK_LED off */
void display_ERROR_LED(void)
    ERROR_LED    =    0;  /* ERROR_LED on */
void off_ERROR_LED(void)
    ERROR_LED    =    1;  /* ERROR_LED off */
void delay(INT16U counter)
    INT16U    temp    =    0;
    for(temp = counter; temp>0; temp--)
        _nop_();
        _nop_();
        _nop_();
void main()
//sbit        Begin_LED    =    P1^0;
//sbit        ERROR_LED    =    P1^3;
//sbit        OK_LED    =    P1^7;
    display_Begin_LED();
    delay(DELAY_CONST);
    sector_erase(DEBUG_Data_Memory_Begin_Sector_addr);
    if(byte_program_and_verify(DEBUG_Data_Memory_Begin_Sector_addr,0x55) == OK)
        display_OK_LED();
    else
        display_ERROR_LED();
    if(sequential_write_flash_in_one_sector(DEBUG_Data_Memory_Begin_Sector_addr, USED_BYTE_QTY_IN_ONE_SECTOR, Test_array_total))
        display_OK_LED();
    else
    if(write_flash_with_protect_in_one_sector(DEBUG_Data_Memory_Begin_Sector_addr+0x3, USED_BYTE_QTY_IN_ONE_SECTOR-0x30, Test_array_total))
        display_OK_LED();
    else
    while(1);
关键字:STC90  89系列  EEPROM  放数据 引用地址:STC90/89系列内部 EEPROM 放数据(C语言)
上一篇:STC1256xxAD 系列 MCU 的 A/D 转换程序
下一篇:STC12C5A60S2 AD转换C语言示例程序(ADC查询方式)
推荐阅读最新更新时间:2024-03-16 15:54
MSP430FR6989系列教程之LCD
一、LCD 段式LCD本质上,它由两个互成 90 度的偏光板(偏振入射到显示屏的 光线)、带通电电极的液晶(两个偏光片之间)和一个反射背板(反射穿过显示屏所有层的光线)组成。 当某个特定段的电极不通电时,该段“截止”或呈灰色。 在此正常状态下,液晶具有可以将光偏转 90 度的扭 曲结构。 所以在未通电时,光线首先入射到第一层偏光板上并在偏转后从同一方向射出。 然后,在光线通 过液晶时,液晶使光线偏转 90 度 - 由于此时的光线相对于经过第一层偏光板时发生了偏转,因此光线能够 穿过第二层偏光板。 最后,光线经反射背板反射并经过相同的过程返回。由于光线反射回来,所以该段看 起来是亮的或者灰色的。 当某个段的电极通电时,该段“
[单片机]
MSP430FR69<font color='red'>89</font><font color='red'>系列</font>教程之LCD
PIC16F676单片机内部EEPROM的程序
BSF STATUS,RP0 CLRF EEADR ;地址0 MOVLW .9 MOVWF EEDAT ;待写数据是9 BSF EECON1,WREN ;使能写 MOVLW 0X55 MOVWF EECON2 MOVLW 0XAA MOVWF EECON2 BSF EECON1,WR ;开始写 NOP NOP ;几个NOP是另加的,怕对以下操作有影响 MOVLW .7 MOVWF EEADR ;地址7 MOVLW .6 MOVWF EEDAT ;待写数据是6 MOVLW 0X55 MOVWF
[单片机]
单片机_stc单片机eeprom 学习笔记
1,有若干个扇区,每个扇区包含512字节,一个地址存储一个字节,第一个扇区的地址从0到512. 十六进制表示是 0x0000~0x0200 2,数据擦除是按照扇区为单位的,所以要合理分配存储内容的扇区(擦除频率高的数据和频率低的数据放在不同的扇区存储) 3,eeprom操作的时候,系统时钟不供给cpu,但是系统时钟给其它外设时钟此时需要注意,如串口发送的数据可能会丢失,以及不能及时响应 4,擦除,写和读,都需要正常的等待时间,不然会影响使用寿命,和数据的正确性 5,IAP和movc二者对eeprom的操作地址不同, 实际使用中规划好需要存储的数据,和所在扇区,然后通过excel,生成eeprom文件,然后
[单片机]
单片机_stc单片机<font color='red'>eeprom</font> 学习笔记
PIC16F877A单片机的EEPROM读写
编写一个例程来说明比较好理解, 本例程的功能是将一个0x66的字符放在0x15的EEPROM中,然后在读取,如果读取成功就点亮LED灯 #include pic.h //调用头文件,16F877A单片机 __CONFIG(0xFF32); //芯片配置字,看门狗关,上电延时开,掉电检测关,低压编程关,加密,4M晶体HS振荡 #define L0 RD0 //定义L0为RD0端口 char buf;//读写数据的储存空间 void WriteEE(char addr,char data);//EEPROM写函数 char ReadEE(char addr); //EEPROM读函数 //主程序 void main() { TR
[单片机]
PIC16F877A单片机的<font color='red'>EEPROM</font>读写
51单片机学习笔记:连续读写STC89C52RC内部EEPROM存储器
STC单片机的内部EEPROM是用DATAFLASH模拟出来的,不是真正的EEPROM存储器,不能用普通的方法来操作 下面是一些注意点: 1.字节写之前要先将这个字节所在扇区的其它有效数据读取到RAM暂存(这步不是必须的) 2.暂存完之后再对整个扇区(512字节)进行擦除操作,擦拭完后,整个扇区每个地址中数据都变成0xFF 3.将欲写入的N个字节数据,用字节写函数写入EEPROM 4.将暂存到RAM的其它有用的EEPROM值再用字节写函数写回EEPROM 5.STC用FLASH模拟出来的EEPROM的字节写功能只能将1变成0,而不能将0变成1, 只有扇区擦除后数据才是全1, 例如:在地址0x21f0处第1次写11010110,
[单片机]
51单片机学习笔记:连续读写STC<font color='red'>89</font>C52RC内部<font color='red'>EEPROM</font>存储器
基于STC15W408AS单片机内部EEPROM读写接口函数
#include reg51.h #include intrins.h #define uint unsigned int #define uchar unsigned char #define ulong unsigned long typedef uchar BYTE; typedef uint WORD; sfr P1M1 = 0x91; //PxM1.n,PxM0.n =00--- Standard, 01--- push-pull sfr P1M0 = 0x92; // =10--- pure input, 11--- open drain sfr P0M1 = 0x93; sfr
[单片机]
PIC单片机的EEPROM读写实例及说明
; PIC单片机的EEPROM读写实例及说明 ;**************************************************************************** ; This is a program to test the function of reading&writting for EEPROM. ; You can observe the value of register(30H--?) buy changing "VALU" and "WRC_". ; Notice that:it must be { ADDR+WRC_ =0ffh } ! ;******************
[单片机]
意法半导体(ST)推出新的带EEPROM和嵌入式晶体的实时时钟芯片
新器件在电表应用中同时提供 三大 功能: 压缩电路板空间,提高产品可靠性,降低制造成本 中国 ,2006年11月29日 — 高性能模拟及混和信号产品的领导厂商 意法半导体(纽约证券交易所代码: STM) 推出一个高精度的串行实时时钟 (RTC) ,该芯片在一个节省空间的 18 引脚 SOIC ( 小外廓集成电路 ) 内集成了 EEPROM 和一个嵌入式晶体。ST的新产品 M41T56C64 压缩了电路板空间,提高了系统可靠性,降低了制造成本,特别适用于有计时精度和非易失性数据存储要求的应用产品。目标应用包括电表、医疗设备、自动售货机、销售点终端 (POS) 。 芯片的实时时
[新品]
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
