读写24LCxx系列的EEPROM的实例程序
发布者:Weasel最新更新时间:2018-03-12 来源: eefocus关键字:读写24LCxx系列  EEPROM 手机看文章 扫描二维码
随时随地手机看文章
;*    ? PIC16F877A ?I2C Master 家Α???﹃?Α EEPROM ?絛ㄒ祘Α  *
;* Written by:  Richard Yang                                *
;*              Sr. Corporate Application Engineer            *
;*              MicroChip Technology Inc.                *
;* Date:        Oct. 2nd '2002                            *
;* Revision: 1.00                                    *
; This source code provides a demonstration of the MSSP peripheral
; on the PIC16F87x MCU.
;***********      The subroutines for EEPROM      *****************
; EE_Random_Read  ; EEPROM Random address Read from EEPROM
; EE_SEQU_Read  ; EEPROM Sequential Read form EEPROM
; EE_Ack_Check  ; Polling current status of EEPROM
; EE_Page_Write  ; Page Write function for EEPROM
; EE_Byte_Write  ; Write a byte to EEPROM with address setting
;***********      The subroutines for I2C      *****************
; Init_I2C_Master  ; Initial I2C Module for Master Mode , 7-bit address
; StartI2C  ; Send a START Condition !!
; StopI2C  ; Send s STOP Condition
; RstartI2C  ; Send a Repeat Start conditional to I2C
; Non_Ack  ; Send a Non-acknowLEDge signal to I2C
; An_Ack  ; Send a acknowledge signal to I2C
; Sebd_Byte  ; Send a byte to I2C bus
; RecI2C    ; Enable Read a byte form slave device
; I2C_Done  : Wait the I2C completed the currect process
  list p=16f877a
  #i nclude
;      ﹚竡跑计?RAM???
  CBLOCK 0x20
  I2C_CTRl
  I2C_Addr
  I2C_Data
  I2C_Page_Length
  D_Count
  ENDC
  cblock 0x40
  I2C_Page_Buffer:8
  I2C_SEQU_Buffer:8
  endc
;      ﹚竡い耞?既?竟??
w_temp  EQU 0x72
status_temp EQU 0x73
pclath_temp EQU 0x74
;      ﹚竡 I2C ???の竲?
EEPROM_CMD equ 0xA0  ; Device adress of Slave Point
EE_Read  equ .1
EE_Write equ .0
#define  SCL PORTC,3  ; I2C SCL PIN
#define  SDA PORTC,4  ; I2C SDA pin
; Locates startup code @ the reset vector
Reset_Addr
  org  0x00
  nop
  goto Main_Init
  org  0x04
  goto ISR
;**** The Start Address of ISR is 0x004
;**** "PUSH" & "POP" ?ㄏノ絛ㄒ : 続ノ?钩 PIC16F877 ΤSHARE BANK ?PIC
ISR
Push  movwf  w_temp            ; save off current W register contents
  movf STATUS,w          ; move status register into W register
  movwf status_temp        ; save off contents of STATUS register
  movf PCLATH,W
  movwf pclath_temp
;        Put your interrupt code here
Pop  movf pclath_temp,W
  movwf PCLATH
  movf    status_temp,w    ; retrieve copy of STATUS register
  movwf STATUS            ; restore pre-isr STATUS register contents
  swapf  w_temp,f
  swapf  w_temp,w          ; restore pre-isr W register contents
  retfie                    ; return from interrupt
Main_Init
  pagesel Init_I2C_Master  ; Set PAGE to PCLATH Register
      call    Init_I2C_Master  ; Init the MSSP for I2C Master
      banksel I2C_Ctrl
  movlw EEPROM_CMD  ; Load EEPROM command address @ 0xA0
  movwf I2C_Ctrl
Main
;* ???代刚祘Α穦?盢?舱计?(0x40-0x47)糶??RMA0x40-0x47??竚
;* ?ノPage Write?よΑ盢8??じ舱?戈?糶? EEPROM ?
;* 秈︽?篈?盎代EEPROM琌??ЧΘ糶??笆??程?盢?糶
;* ??戈??Sequential Read?よΑ眖EEPROM弄?ㄓ??I2C_SEQU_Bufferい
Test_Page_RW
  movlw 0x08
  movwf I2C_Page_Length
  movlw I2C_Page_Buffer
_Fill_RAM movwf FSR
  movwf INDF
  incf FSR,W
  decfsz I2C_Page_Length,F
  goto _Fill_RAM
Test_Page_Write
;  banksel I2C_Ctrl
  movwf I2C_Ctrl
  movlw 0x10    ; Select EEPROM location at 0x00
  movwf I2C_Addr
  movlw .8
  call EE_Page_Write
  call EE_Ack_Check
  banksel I2C_Ctrl
  movwf I2C_Ctrl
  movlw 0x10
  movwf I2C_Addr
  movlw .8
  call EE_SEQU_Read
  goto $
;* ???代刚祘Α穦?糶????じ舱?戈?糶? EEPROM い
;* ?秈︽?篈?盎代琌??ЧΘ糶??笆??程?盢?糶
;* ??戈??眖EEPROM弄?ㄓ??I2C_Data既?竟い
Test_1byte_RW
   banksel I2C_CTRl
   movwf I2C_Ctrl
   movlw 0x00    ; Select EEPROM LOCation at 0x00
   movwf I2C_Addr
   movlw 0xAA    ; Write data 0x5A to location 0x00 of EEPROM
   movwf I2C_Data
   call EE_Byte_Write
Test2  call EE_Ack_Check  ; Polling AcknowLEDge for next aCCess
   banksel I2C_Data
   movlw 0x00    ; Clear I2C data buffer
   movwf I2C_Data
Test3
   banksel I2C_Ctrl
   movwf I2C_Ctrl
   movlw 0x00
   movwf I2C_Addr
   call EE_Random_Read
   goto  $
;*           Random Read a Byte from EEPROM
;* Input:
;*     - I2C_Ctrl : Control Byte of EEPROM
;*      - I2C_Addr : Location of EEPROM
;* Output:
;*      - I2C_Data : Read Data from EEPROM
; Send Command for RANDOM READ :
; " Start+ 0xA0 + EE_Address + ReStart + 0xA1 + Read_Data + NAck + Stop "
EE_Random_Read
    call StartI2C  ; Set SSPCON2.SEN
   bcf  I2C_Ctrl,0  ; set for write Command
   movf I2C_Ctrl,W  ; Send Slave Address to I2C Bus
   call Send_Byte
   movf I2C_Addr,W  ; Send out the Rendom address of EEPROM
   call Send_Byte
   call RstartI2C  ; Send a Repeat Start to I2C
   bsf  I2C_Ctrl,0  ; set for Read Command
   call Send_Byte
   call RecI2C  ; Enable I2C Receive
   BANKSEL SSPBUF
   movf SSPBUF,W ; Save to I2C_Data First !!
   movwf I2C_Data
   call Non_Ack  ; Initial NACK Response !!
   call StopI2C  ; Initial STOP Condition
   return
;*                Sequential Read from EEPROM
;* Input:
;*      - I2C_Addr : Start Location of EEPROM
;*     - I2C_Page_Length : How many byte need to read
;* Output:
;*      - I2C_SEQU_Buffer : Sequential Read Data buffer
EE_SEQU_Read
   call Send_Byte
   call Send_Byte
   call Send_Byte
   movlw I2C_SEQU_Buffer
   movwf FSR
_Sequ_Loop call RecI2C   ; Enable I2C Receive
   BANKSEL SSPBUF
   movwf INDF
   incf FSR,F
   goto _Cont_Read
   goto _End_Read
_Cont_Read call An_Ack
   goto _Sequ_Loop
_End_Read call Non_Ack   ; Initial NACK Response !!
   return
;*              EEPROM Acknowledge Polling
;*     --  The routine will polling the ACK
;*           response from EEPROM
;*    --  ACK=0 return
;*   --  ACK=1 send Restart & loop check
EE_Ack_Check
   bcf  I2C_Ctrl,0  ; Clear for Write Command
   call Send_Byte
_Ack_Polling
   BANKSEL SSPCON2
   btfss SSPCON2,ACKSTAT ; Check ACKSTAT bit , 0 = ACK , 1 = NACK
   goto ACK_Return  ; Ack = 0 ; EEPROM is Ready
_Ack_Hi        ; Ack = 1 ; EEPROM is Busy for Write
   call Delay_mS  ; Delay 500uS for next Ack polling
   call Send_Byte
   goto _Ack_Polling
ACK_Return
   return
;*           Page Write 1 to 8 Bytes to EEPROM
;*  Input:
;*   - I2C_Page_Buffer: RAM location of Data
;*     - I2C_Page_Length : Data length count
; Send Command for PAGE WRITE :
; " Start+ 0xA0 + EE_Address + W_Data 0+ .. + W_Data N + Stop "
EE_Page_Write
   movf I2C_Page_Length,W
   btfsc STATUS,Z
   return
   call Send_Byte
   movf I2C_Addr,W  ; Send out the Command
   call Send_Byte
   movwf FSR
_W1   movf INDF,W
   call Send_Byte
   incf FSR,F
   goto _W1
   return
;*               Write a Byte to EEPROM
;* Input:
;*      - I2C_Data : Data to EEPROM
; Send Command for BYTE WRITE :
; " Start+ 0xA0 + EE_Address + Write_Data + Stop "
EE_Byte_Write
   bcf  I2C_CTRl,0  ; Clear for Write Command
   call Send_Byte
   call Send_Byte
   movf I2C_Data,W  ; Send out the Data
   call Send_Byte
   return
;   As following subroutines perform commonly used I2C functions.
;      You CAN use these subroutines for your I2C aCCess
;*** Initial I2Cmodule fot 7-bit I2C Master Mode with 100Kcps @4MHz
Init_I2C_Master
   BANKSEL TRISC   ; Initial PortC,bit 3 & 4 as Input
    bsf  SCL    ; RC3 = SCL  ,  RC4 = SDA
   bsf  SDA
    BANKSEL PORTC
    bsf  SCL    ; SCL = Hi
    bsf  SDA    ; SDA = Hi
   movlw b'00101000'  ; I2C Master Mode, CLOCk Rate: FOSC/(4*SSPADD+1)
   movwf SSPCON   ;
         banksel SSPADD
         movlw   .9              ; This gives 100KHz I2C clock @ 4MHz
   movwf   SSPADD   ; (4MHz/4) / (9+1)= 100KHz
       movlw   b'10000000'     ; DISAble slew rate control,
         movwf   SSPSTAT   ; and clear status bits
          movlw   b'00000000'     ; Set SCL,SDA into Ready status
         movwf   SSPCON2
   return
;******   Send START condition to bus   *******
StartI2C    ; Initiate the I2C START condition.
         banksel SSPCON2
          bsf     SSPCON2,SEN
         goto I2C_Done
;******   Send STOP condition to bus   *******
StopI2C
        banksel SSPCON2
         bsf     SSPCON2,PEN
         goto I2C_Done
;******   Send RESTART condition to bus   *******
RstartI2C
         banksel SSPCON2
         bsf     SSPCON2,RSEN
         goto I2C_Done
;******   Send a Non-AcknowLEDge status to bus (ACK=1)    *******
Non_Ack
         banksel SSPCON2
         bsf     SSPCON2,ACKDT    ; Set the ACK bit
         bsf     SSPCON2,ACKEN    ; Initiate the NACK sequence.
         goto I2C_Done
;******   Send an Acknowledge status to bus (ACK=0)     *******
An_Ack
          banksel SSPCON2
         bcf     SSPCON2,ACKDT    ; Clear the ACK bit
         goto I2C_Done
;******   Send data to I2C bus from Wreg.     *******
Send_Byte
   banksel SSPBUF
   movwf SSPBUF
   goto I2C_Done
;******   Enable I2C Receive for Master Mode     *******
RecI2C
        banksel SSPCON2
         bsf     SSPCON2,RCEN    ; Set the receive enable bit.
   goto I2C_Done
;******  Check the I2C stage is completed   ********
I2C_Done
         banksel PIR1
    btfss   PIR1,SSPIF ; Poll for SSPIF
         goto    $-1
         bcf     PIR1,SSPIF
         return
Delay_mS
   banksel D_Count
   movlw .124   ; Load .5mS Dealy Value
    movwf D_Count
_D_mS  nop
   decfsz D_Count,F
   goto _D_mS
   return
; *********** End Of Program !!!!!
   end
关键字:读写24LCxx系列  EEPROM 引用地址:读写24LCxx系列的EEPROM的实例程序
上一篇:使用PIC读写1-wire EEPROM DS2430的实例
下一篇:PIC16Fxxx的LCD驱动程序(适用于HD44780兼容的驱动器)
推荐阅读最新更新时间:2024-03-16 15:57
STM8 AT24CXX使用I2C接口读写EEPROM子程序
软件设计 /********************************************************************* 目 的: 建立AT24CXX操作库 目标系统: 基于STM8单片机 应用软件: Cosmic CxSTM8 *********************************************************************/ #define WD_DADR 0xa0 #define RD_DADR 0xa1 #include ws_i2c.h void AT24CXX_Init(void) { I2C_Init(); } void AT
[单片机]
初学24CXX系列EEPROM使用详解&STM32库函数I2C总线
24CXX系列芯片属于EEPROM(Electrically Erasable Programmable read only memory)即电可擦可编程只读存储器,是一种掉电后数据不丢失(不挥发)存储芯片。 24CXX系列芯片数据说明:见下表(只做参考,只表明常用24CXX器件的常用数据,具体使用请查阅器件数据手册): 如24C02BN容量=2KB,但写缓冲区(页容量)=8K 1、“型号”:24Cxx系列型号的标称C后面的参数代表其存储容量大小,单位为KB,这里的1KB=1024bit; 2、“存储容量”:24Cxx系列存储数据为8位(bit)格式,根据其容量可以计算出各型号具体存储数据的字节(Byte)数; 3
[单片机]
PIC内部EEPROM的操作
1.方法一: PIC内部EEPROM的操作 //-------------------------------------------------------- //EEPROM字节写程序 //功能: 写一个字节到内部EEPROM //入口: EEADR =地址 // EEDATA =数据 //-------------------------------------------------------- void write_eeprom ( void ) { // while ( WR ) //等待上一次写操作结束 // { // asm ( clrwdt ); //喂狗 // } EEPGD = 0 ; /
[单片机]
ATmega48 EEPROM数据存储器
ATmega48/88/168包含256/512/512字节的EEPROM数据存储器。它是作为一个独立的数据 EEPROM 的寿命至少为 100,000 次擦除周期。 EEPROM 的访问由地址寄存器,数据寄存器和控制寄存器决定。 具体的 SPI 及并行下载 EEPROM 数据请参见 P254“存储器编程”。 EEPROM 读/ 写访问 EEPROM 读/ 写访问EEPROM 的访问寄存器位于I/O 空间。 EEPROM的写访问时间由Table 3给出。自定时功能可以让用户软件监测何时可以开始写下一字节。用户操作EEPROM 需要注意如下问题:在电源滤波时间常数比较大的电路中,上电/ 下电时VCC 上升/ 下降速度会比较慢。此时C
[单片机]
ATmega48 <font color='red'>EEPROM</font>数据存储器
N76E003之模拟EEPROM
在使用STM32时,常可以将内部1flash的一部分划作数据储存区(EEPROM),用于掉电后的数据保存。而N76E003单片机也可实现类似的功能。 下图为N76E003的内存分配图,我们可以从下图中看到APROM使用的地址范围(APROM + LDROM = 18K,当LDROM为0时,APROM的地址为0000~0x47FF) 下面的程序为新唐官方所给出的例程,我只进行了粗浅的注释 //*********************************************************************************************************** // File
[单片机]
N76E003之模拟<font color='red'>EEPROM</font>
单片机学习——IIC总线及EEPROM实验之一
题目:简单的流水灯实验。用EEPROM实现。 解决方案:(c语言编程) #include reg52.h #include intrins.h #define uchar unsigned char #define uint unsigned int uchar code table ={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f ,0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe}; void delay1(uint); sbit scl=P3^3; sbit sda=P3^4; void delay() //短延时子程序 { ;; } void i
[单片机]
51读写串行EEPROM芯片at2402程序(C)
/* Name:AT24C02 存储器 的读写程序,用到I2C总线,含相对独立的I2C总线读写函数 */ #include #include #include #define DELAY_TIME 60 /*经实验,不要小于50!否则可能造成时序混乱*/ #define TRUE 1 #define FALSE 0 sbit SCL=P1^7;/*假设由P1.7和P1.6控制*/ sbit SDA=P1^6; /********** Function Definition 函数定义 ************/ void DELAY(unsigned int t) /*延时函数*/ {
[单片机]
如何提高FLASH使用寿命以实现EEPROM的功能呢 ?
一、 stm32的FLASH擦除是按整页或者整扇区擦除的,不同芯片的页或者扇区(下边统称为页)的大小是不一样的,有1K,16K,64K,128K等大小。 现在我们想要 存3个不同16bit变量的数据,1秒存一次 ,如果不做任何算法,将这3个变量存到3个不同的页的16bit地址,每次更改变量内容都要擦除一次整页(但是我们只使用了16bit的空间),根据芯片数据手册可知,保证性能的情况下flash最少擦除次数为10K,1万次。 我们就按1万次计算,理论上不到3小时我们使用的16bit地址就有损坏的风险。而且要存储的变量个数也有限,我们芯片不可能有那么多页,H7系列也就16页。所以需要一些算法处理,充分利用页的空间。 二、E
[单片机]
如何提高FLASH使用寿命以实现<font color='red'>EEPROM</font>的功能呢 ?
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
