ARM9的中断体系结构
发布者:Meiren520最新更新时间:2018-04-15 来源: eefocus关键字:ARM9  中断体系结构 手机看文章 扫描二维码
随时随地手机看文章
实验的目的:
当TQ2440开发板的按键按下的时候,触发中断,点亮LED灯。
实验的源程序:
*s3c24xx.h
/* WOTCH DOG register */
#define     WTCON           (*(volatile unsigned long *)0x53000000)
/* SDRAM regisers */
#define     MEM_CTL_BASE    0x48000000
#define     SDRAM_BASE      0x30000000
/* NAND Flash registers */
#define NFCONF              (*(volatile unsigned int  *)0x4e000000)
#define NFCMD               (*(volatile unsigned char *)0x4e000004)
#define NFADDR              (*(volatile unsigned char *)0x4e000008)
#define NFDATA              (*(volatile unsigned char *)0x4e00000c)
#define NFSTAT              (*(volatile unsigned char *)0x4e000010)
/*GPIO registers*/
#define GPBCON              (*(volatile unsigned long *)0x56000010)
#define GPBDAT              (*(volatile unsigned long *)0x56000014)
#define GPFCON              (*(volatile unsigned long *)0x56000050)
#define GPFDAT              (*(volatile unsigned long *)0x56000054)
#define GPFUP               (*(volatile unsigned long *)0x56000058)
#define GPGCON              (*(volatile unsigned long *)0x56000060)
#define GPGDAT              (*(volatile unsigned long *)0x56000064)
#define GPGUP               (*(volatile unsigned long *)0x56000068)
#define GPHCON              (*(volatile unsigned long *)0x56000070)
#define GPHDAT              (*(volatile unsigned long *)0x56000074)
#define GPHUP               (*(volatile unsigned long *)0x56000078)
/*UART registers*/
#define ULCON0              (*(volatile unsigned long *)0x50000000)
#define UCON0               (*(volatile unsigned long *)0x50000004)
#define UFCON0              (*(volatile unsigned long *)0x50000008)
#define UMCON0              (*(volatile unsigned long *)0x5000000c)
#define UTRSTAT0            (*(volatile unsigned long *)0x50000010)
#define UTXH0               (*(volatile unsigned char *)0x50000020)
#define URXH0               (*(volatile unsigned char *)0x50000024)
#define UBRDIV0             (*(volatile unsigned long *)0x50000028)
/*interrupt registes*/
#define SRCPND              (*(volatile unsigned long *)0x4A000000)
#define INTMOD              (*(volatile unsigned long *)0x4A000004)
#define INTMSK              (*(volatile unsigned long *)0x4A000008)
#define PRIORITY            (*(volatile unsigned long *)0x4A00000c)
#define INTPND              (*(volatile unsigned long *)0x4A000010)
#define INTOFFSET           (*(volatile unsigned long *)0x4A000014)
#define SUBSRCPND           (*(volatile unsigned long *)0x4A000018)
#define INTSUBMSK           (*(volatile unsigned long *)0x4A00001c)
/*external interrupt registers*/
#define EINTMASK            (*(volatile unsigned long *)0x560000a4)
#define EINTPEND            (*(volatile unsigned long *)0x560000a8)
@ File:head.S
@ 功能:初始化,设置中断模式、管理模式的栈,设置好中断处理函数
.extern     main
.text
.global _start
_start:
@ 异常向量,本程序中,除Reset和HandleIRQ外,其它异常都没有使用
    b   Reset
@ 0x04: 未定义指令中止模式的向量地址
HandleUndef:
    b   HandleUndef
@ 0x08: 管理模式的向量地址,通过SWI指令进入此模式
HandleSWI:
    b   HandleSWI
@ 0x0c: 指令预取终止导致的异常的向量地址
HandlePrefetchAbort:
    b   HandlePrefetchAbort
@ 0x10: 数据访问终止导致的异常的向量地址
HandleDataAbort:
    b   HandleDataAbort
@ 0x14: 保留
HandleNotUsed:
    b   HandleNotUsed
@ 0x18: 中断模式的向量地址
    b   HandleIRQ
@ 0x1c: 快中断模式的向量地址
HandleFIQ:
    b   HandleFIQ
Reset:
    ldr sp, =4096           @ 设置栈指针,以下都是C函数,调用前需要设好栈
    bl  disable_watch_dog   @ 关闭WATCHDOG,否则CPU会不断重启
    msr cpsr_c, #0xd2       @ 进入中断模式
    ldr sp, =3072           @ 设置中断模式栈指针
    msr cpsr_c, #0xd3       @ 进入管理模式
    ldr sp, =4096           @ 设置管理模式栈指针,
                            @ 其实复位之后,CPU就处于管理模式,
                            @ 前面的“ldr sp, =4096”完成同样的功能,此句可省略
    bl  init_led            @ 初始化LED的GPIO管脚
    bl  init_irq            @ 调用中断初始化函数,在init.c中
    msr cpsr_c, #0x53       @ 设置I-bit=0,开IRQ中断
    ldr lr, =halt_loop      @ 设置返回地址
    ldr pc, =main           @ 调用main函数
halt_loop:
    b   halt_loop
HandleIRQ:
    sub lr, lr, #4                  @ 计算返回地址
    stmdb   sp!,    { r0-r12,lr }   @ 保存使用到的寄存器
                                    @ 注意,此时的sp是中断模式的sp
                                    @ 初始值是上面设置的3072
    ldr lr, =int_return             @ 设置调用ISR即EINT_Handle函数后的返回地址
    ldr pc, =EINT_Handle            @ 调用中断服务函数,在interrupt.c中
int_return:
    ldmia   sp!,    { r0-r12,pc }^  @ 中断返回, ^表示将spsr的值复制到cpsr
注:ARM9的异常向量表:
 * init.c: 进行一些初始化
#include "s3c24xx.h"
 * LED1,LED2,LED4对应GPB5、GPB6、GPB7、GPB8
#define GPB5_out (1<<(5*2))
#define GPB6_out (1<<(6*2))
#define GPB7_out (1<<(7*2))
#define GPB8_out (1<<(8*2))
#define GPB5_msk (3<<(5*2))
#define GPB6_msk (3<<(6*2))
#define GPB7_msk (3<<(7*2))
#define GPB8_msk (3<<(8*2))
 * K1,K2,K3,K4对应GPF1、GPF4、GPF2、GPF0
#define GPF0_int     (0x2<<(0*2))
#define GPF1_int     (0x2<<(1*2))
#define GPF2_int     (0x2<<(2*2))
#define GPF4_int     (0x2<<(4*2))
#define GPF0_msk    (3<<(0*2))
#define GPF1_msk    (3<<(1*2))
#define GPF2_msk    (3<<(2*2))
#define GPF4_msk    (3<<(4*2))
 * 关闭WATCHDOG,否则CPU会不断重启
void disable_watch_dog(void)
    WTCON = 0;  // 关闭WATCHDOG很简单,往这个寄存器写0即可
void init_led(void)
// LED1,LED2,LED3,LED4对应的4根引脚设为输出
GPBCON &= ~(GPB5_msk | GPB6_msk | GPB7_msk | GPB8_msk);
GPBCON |= GPB5_out | GPB6_out | GPB7_out | GPB8_out;
 * 初始化GPIO引脚为外部中断
 * GPIO引脚用作外部中断时,默认为低电平触发、IRQ方式(不用设置INTMOD)
void init_irq( )
// K1,K2,K3,K4对应的4根引脚设为中断功能
GPFCON &= ~(GPF0_msk | GPF1_msk | GPF2_msk | GPF4_msk);
GPFCON |= GPF0_int | GPF1_int | GPF2_int | GPF4_int;
    // 对于EINT4,需要在EINTMASK寄存器中使能它
    EINTMASK &= ~(1<<4);
     * 设定优先级:
     * ARB_SEL0 = 00b, ARB_MODE0 = 0: REQ1 > REQ2 > REQ3,即EINT0 > EINT1 > EINT2
     * 仲裁器1、6无需设置
     * 最终:
     * EINT0 > EINT1> EINT2 > EINT4 即K4 > K1 > K3 > K2
    PRIORITY = (PRIORITY & ((~0x01) | ~(0x3<<7)));
    // EINT0、EINT1、EINT2、EINT4_7使能
    INTMSK   &= (~(1<<0)) & (~(1<<1)) & (~(1<<2)) & (~(1<<4));
*interrupt.c
void EINT_Handle()
    unsigned long oft = INTOFFSET;
    unsigned long val;
*            即 EINT1, ETIN4, EINT2, EINT0
*            oft为 1, 4, 2, 0 (对应INTMSK寄存器)
    switch( oft )
        // K1被按下
        case 1:
            GPBDAT |= (0xF<<5);   // 所有LED熄灭
            GPBDAT &= ~(1<<5);      // LED1点亮
            break;
        // K2被按下
        case 4:
            GPBDAT &= ~(1<<6);      // LED2点亮
            break;
        // K3被按下
        case 2:
            GPBDAT &= ~(1<<7);      // LED3点亮
            break;
        // K4被按下
        case 0:
            GPBDAT &= ~(1<<8);      // LED4点亮
            break;
        default:
            break;
    //清中断
    if( oft == 4 )
        EINTPEND = (1<<4);   // EINT4_7合用IRQ4
    SRCPND = 1<     INTPND = 1< }
*main.c
int main()
    while(1);
    return 0;
*Makefile
objs := head.o init.o interrupt.o main.o
int.bin: $(objs)
arm-linux-ld -Ttext 0x00000000 -o int_elf $^
arm-linux-objcopy -O binary -S int_elf $@
arm-linux-objdump -D -m arm int_elf > int.dis
%.o:%.c
arm-linux-gcc -Wall -O2 -c -o $@ $<
%.o:%.S
clean:
rm -f int.bin int_elf int.dis *.o
实验的问题总结:
I.刚开始程序会执行head.S文件,第一条指令是b reset指令。在reset中,我们可以知道:
设置了reset模式下的栈,因为我们之后需要调用C语言函数,而C语言函数的局部变量是需要栈来保存的。
然后我们可以看到,执行了这样一条指令:msr cpsr_c, #0xd2
其原因可以看一下解释:
/***************************MRS 和 MSR*********************************
     MRS R0, CPSR               读取CPSR的内容写入R0
     MSR CPSR, R0               读取R0的内容写入CPSR
     MSR CPSR_f, R0             读取R0的24-31的内容写入CPSR的24-31bit
     MSR CPSR_c, R0             读取R0的0-7的内容写入CPSR的0-7bit
     MSR CPSR_fc, R0
     MSR CPSR_f, #0xf0000000    将0xf写入CPSR的24-31bit
     所有的CPSR可以替换成SPSR
***************************MRS 和 MSR*********************************/
/****************************CPSR***********************************
CPSR格式如下所示。SPSR和CPSR格式相同。
31     30     29    28     27     26               7     6     5     4     3     2     1     0
N      Z      C     V      Q     DNM(RAZ)          I     F     T     M4    M3    M2    M1    M0
***条件标志位***
N——本位设置成当前指令运算结果的bit[31]的值。当两个表示的有符号整数运算时,n=1表示运算结果为负数,n=0表示结果为正书或零。
Z——z=1表示运算的结果为零;z=0表示运算的结果不为零。对于CMP指令,Z=1表示进行比较的两个数大小相等。
C——下面分四种情况讨论C的设置方法:
在加法指令中(包括比较指令CMP),当结果产生了进位,则C=1,表示无符号运算发生上溢出;其他情况C=0。
在减法指令中(包括减法指令CMP),当运算中发生错位,则C=0,表示无符号运算数发生下溢出;其他情况下C=1。
对于包含移位操作的非加减运算指令,C中包含最后一次溢出的的位的数值。对于其他非加减运算指令,C位的值通常不受影响。
V——对于加减运算指令,当操作数和运算结果为二进制的补码表示的带符号数时,V=1表示符号为溢出;通常其他指令不影响V位。
***Q标识位***
在ARM V5的E系列处理器中,CPSR的bit[27]称为q标识位,主要用于指示增强的dsp指令是否发生了溢出。同样的spsr的bit[27]位也称为q标识位,用于在异常中断发生时保存和恢复CPSR中的Q标识位。
在ARM V5以前的版本及ARM V5的非E系列的处理器中,Q标识位没有被定义。
***CPSR中的控制位***
CPSR的低八位I、F、T、M[4:0]统称为控制位。当异常中断发生时这些位发生变化。在特权级的处理器模式下,软件可以修改这些控制位。
**中断禁止位I,F:当I=1时禁止IRQ中断,当F=1时禁止FIQ中断
**T控制位:T控制位用于控制指令执行的状态,即说明本指令是ARM指令还是Thumb指令。对于ARM V4以更高版本的T系列ARM处理器,T控制位含义如下:
T=0表示执行ARM指令
T=1表示执行Thumb指令
对于ARM V5以及更高版本的非T系列处理器,T控制位的含义如下
T=0表示执行ARM指令
T=1表示强制下一条执行的指令产生未定指令中断
***M控制位***
M控制位控制处理器模式,具体含义如下:
M[4:0] 处理器模式    可访问的寄存器
ob10000 user     pc,r14~r0,CPSR
0b10001 FIQ      PC,R14_FIQ-R8_FIQ,R7~R0,CPSR,SPSR_FIQ
0b10010 IRQ      PC,R14_IRQ-R13_IRQ,R12~R0,CPSR,SPSR_IRQ
0B10011 SUPERVISOR    PC,R14_SVC-R13_SVC,R12~R0,CPSR,SPSR_SVC
0b10111 ABORT     PC,R14_ABT-R13_ABT,R12~R0,CPSR,SPSR_ABT
0b11011 UNDEFINEED    PC,R14_UND-R8_UND,R12~R0,CPSR,SPSR_UND
0b11111 SYSTEM     PC,R14-R0,CPSR(ARM V4以及更高版本)
*****************************CPSR*************************************/
看完这两点,你就知道为什么要设置的值为#0xd2。接下来是设置中断模式下的栈指针。同上,因为每种模式下的栈寄存器是不共用的。
II.接下来,我们重点看一下 ldr lr, =halt_loop 这条指令,为什么在调用main函数之前需要设置lr寄存器呢?不设置难道不可以么?
具体解释如下:
在跳转的时候,PC的值会赋给lr寄存器。
在汇编调用C语言的时候,不一定非得配置lr寄存器,这要看你调用完C语言后想再往下执行哪条指令,
若接下来执行的指令刚好是C语言完了之后的这条指令,那么这种情况下可以不用设置,因为CPU会自动将lr = lr - 4,
也就是接下来该执行的一条指令,若你想再调用C语言之后,是跳转到某处的一标号,此时需要设置lr。
III.接下来,若发生中断的时候,CPU会自动让PC跳转到 HandleIRQ 去执行对应的指令。
然后,我们可以看到:sub lr, lr, #4
为什么要将lr的值减4呢?具体解释如下:
我们知道在ARM 架构里,PC值指向当前执行指令的地址加8处,也就是说, 当执行指令A(地址0x8000)时,PC 等于指令C 的地址(0x8008)。
假如指令A 是“BL”指令,则当执行该指令时,会把PC(=0x8008)保存到LR 寄存器里面,但是接下去处理器会马上对LR 进行一个自动的调整动作:
LR=LR-0x4。这样,最终保存在 LR 里面的是 B 指令的地址,所以当从 BL 返回时,LR 里面正好是正确的返回地址。同样的调整机制在所有LR
自动保存操作中都存在,比如进入中断响应时,处理器所做的LR 保存中,也进行了一次自动调整,并且调整动作都是LR=LR-0x4。
下面,我们对不同类型的异常的返回地址依次进行说明:
假设在指令A 处(地址0x8000)发生了异常,进入异常响应后,LR 上经过调整保存的地址值应该是B 的地址0x8004。
1、 如果发生的是软件中断,即A 是“SWI”指令
异常是由指令本身引起的,从 SWI 中断返回后下一条执行指令就是B,正好是LR 寄存器保存的地址, 所以只要直接把LR 恢复给PC。
MOVS pc, lr
2、 发生的是Undefined instruction异常
异常是由指令本身引起的,从异常返回后下一条执行指令就是B,正好是LR 寄存器保存的地址, 所以只要直接把LR 恢复给PC。
MOVS pc, lr
3、 发生的是IRQ或FIQ中断
因为指令不可能被中断打断,所以A指令执行完以后才能响应中断,此时PC已更新,指向指令D的地址(地址0x800C),
LR 上经过调整保存的地址值是C 的地址0x8008。中断返回后应该执行B指令,所以返回操作是:
SUBS pc, lr, #4
4、 发生的是Prefetch Abort异常
该异常并不是处理器试图从一个非法地址取指令时触发,取出的指令只是被标记为非法,按正常处理流程放在流水线上,
在执行阶段触发Prefetch Abort异常,此时LR 上经过调整保存的地址值是B 的地址0x8004。异常返回应该返回到A指令,
尝试重新取指令,所以返回操作是:
SUBS pc, lr, #4
5、 发生的是“Data Abort”
CPU访问存储器时触发该异常,此时PC指向指令D的地址(地址0x800C),LR 上经过调整保存的地址值是C 的地址0x8008。
异常返回后,应回到指令A,尝试重新操作存储器,所以返回操作是:
SUBS pc, lr, #8
这就是为什么我们需要将lr的值减4,具体可以参考我转载的博客。
IV.然后我们可以看得这样一条指令:stmdb   sp!,    { r0-r12,lr },它是和 ldmia   sp!,    { r0-r12,pc }^ 指令对应起来的。
在跳转到中断服务程序之前,先保存用到的寄存器,在完成中断服务程序之后,又恢复寄存器。其中,lr和pc是对应起来的。
也就是说,恢复寄存器后,pc中保存的值是lr寄存器中的。所以当执行完这条指令之后,就又跳回来了。
关键字:ARM9  中断体系结构 引用地址:ARM9的中断体系结构
上一篇:ARM9的系统时钟和串口(非流控 + 非FIFO + 查询方式)
下一篇:ARM9的存储控制器
推荐阅读最新更新时间:2024-03-16 15:59
基于ARM9的嵌入式网关的研究
   摘 要: 介绍了一种基于ARM9的嵌入式以太网的设计方案。基于ARM内核微处理器S3C2410的功能特点及其外扩组成部分,分析了以太网控制器芯片RTL8019AS的性能以及与S3C2410的接口。在软件设计上,分析了BootLoader的作用,介绍了Linux的移植,并给出了通信程序的流程图,实现了嵌入式以太网的数据传输。    关键词: 嵌入式系统;网关;ARM;移植    引 言   无所不在的网络给网络接入设备带来了巨大的发展机遇。而随着网络接入市场的迅速增长,嵌入式网络接入开始成为嵌入式系统技术中最令人关注的一个领域。在嵌入式网络技术的推动下将会形成这样一个局面:在网络上传输的信息中,将有70%的信息来自嵌入式
[嵌入式]
ARM9 MMU映射问题三
对 MMU映射地址一 里面的程序 unsigned long *mmu_tlb_base = (unsigned long *)0x30000000; virtuladdr = 0xA0000000; physicaladdr = 0x56000000; *(mmu_tlb_base + (virtuladdr 20)) = (physicaladdr & 0xFFF00000) | MMU_SECDESC; 我自己理解为: virtuladdr 为虚拟空间各段基地址,virtuladdr 20为段描述符的各段的位置,即第几
[单片机]
ARM9在高精度生化分析仪温度控制系统中的应用
1 引言 ARM9越来越广泛的应用于各种生物电子仪器中,全自动生化分析仪是一个典型的应用。生化分析仪检测分析过程中温度对检测结果具有很大的影响,被检样品和试剂只有在指定的温度下检测才能保证生化检验结果的可靠性。生化分析仪的温控系统往往具有非线性、时滞性等特点,应用常规PID控制达不到理想的效果。本系统以ARM9处理器作为控制系统核心,实现模糊自整定PID控制算法。经测试,该系统精度高,稳定性好,响应快,反应盘控温于现行的标准检测温度37℃,控温精度为土0.1℃,显示精度为±0.01℃,完全满足临床使用要求。 2 系统总体设计及主要硬件实现 2.1 系统总体设计 系统结构如图1所示。系统主要由测温器件、A
[单片机]
基于ARM9的嵌入式网关的研究
   摘 要: 介绍了一种基于ARM9的嵌入式以太网的设计方案。基于ARM内核微处理器S3C2410的功能特点及其外扩组成部分,分析了以太网控制器芯片RTL8019AS的性能以及与S3C2410的接口。在软件设计上,分析了BootLoader的作用,介绍了Linux的移植,并给出了通信程序的流程图,实现了嵌入式以太网的数据传输。    引 言   无所不在的网络给网络接入设备带来了巨大的发展机遇。而随着网络接入市场的迅速增长,嵌入式网络接入开始成为嵌入式系统技术中最令人关注的一个领域。在嵌入式网络技术的推动下将会形成这样一个局面:在网络上传输的信息中,将有70%的信息来自嵌入式系统,也许将有数以亿计的汽车、通信设备、家用电气以
[嵌入式]
基于嵌入式ARM9痕量毒气检测系统的研究
有毒有害气体对人体的伤害问题越来越突出 ,如工业作业产生的有毒有害气体泄露;室内空气中醛、苯等超标导致的“致病建筑物综合症”;导弹等发射产生有毒气体对士兵身体的损害;汽车内有害气体超标导致的头晕、咳嗽等症状。传统毒气检测方法如分光光度法、非色散红外分析法 和气相色谱法,都存在着灵敏度易受干扰、不易实现现场检测等缺陷,其他如滴定或者比色法、气体传感器直接检测法等,耗时较长、操作复杂、选择性较差。 相对于传统检测方法的不足,卟啉传感器由于其优良光敏特性 和对于微量气体的快速、准确响应成为毒气检测的理想传感器。卟啉阵列传感器采用金属卟啉作为传感器的气体敏感膜,与不同气体接触后,金属卟啉分子间键、程度和张力不同,吸收光谱改变也不同
[工业控制]
基于嵌入式<font color='red'>ARM9</font>痕量毒气检测系统的研究
基于Linux的嵌入式视觉系统设计方案
1 引言 视觉系统在现代工业生产自动化系统中应用非常广泛,主要集中于药品检测分装、印刷色彩检测、集成电路生产、精密电子产品装配、智能机器人识别导航等领域。随着Internet 的普及,现代社会已进入后PC 时代,嵌入式技术越来越与人们的生活紧密结合。 嵌入式视觉系统可通过USB 总线等将图像的获取、图像处理、显示设备集成于一体,成本相对较低,体积小巧,可以方便地安装在载体身上,故研究嵌入式的视觉系统具有一定的实际意义。 2 嵌入式视觉系统总体方案设计 嵌入式视觉系统由嵌入式硬件平台、操作系统、图像采集和图像显示四大部分组成,原理框图如下图1 所示。 图1 视觉系统原理框图 S3C2410X 芯片是韩国三星电子公司推
[单片机]
基于Linux的嵌入式视觉系统设计方案
基于ARM9和Linux的嵌入式打印终端系统
1 嵌入式打印终端系统 的设计原理 图1 打印终端原理图 嵌入式打印终端原理连接图如图1所示。主要由开发板、主机、打印机和扫描仪四部分组成。主机是一台PC机。开发板采用的是三星公司S3C2410开发板,ARM9的核,跑的是2.4内核版本的嵌入式Linux操作系统。扫描仪为超市等用的手持扫描仪。再加一台微型打印机接在开发板的GPIO口上。 工作流程为:开发板将扫描仪的数据从串口读出,然后通过网口将数据发送给主机进行检索处理。开发板等待直至接收到主机处理完毕的数据后转发给打印机,将信息打印出来。 2 嵌入式打印终端系统的硬件设计 2.1硬件开发平台S3C2410结构 三星公司的S
[单片机]
基于<font color='red'>ARM9</font>和Linux的嵌入式打印终端系统
基于ARM9和μC/OS-II的SD卡文件系统的实现
随着嵌入式式技术的不断发展,ARM处理器凭借其高性能、廉价、耗能低的优质特性而得到广泛应用。文中主要针对货车动态称重系统中大量实时载重数据存取的需求,在ARM9嵌入式处理器和μC/OS-II操作系统基础上,设计实现了一种SD卡文件系统。该系统具有实时性强、存取速率高、易维护,易移植等特点。 1 硬件接口电路设计 本系统硬件开发平台处理器为S3C2440A,是三星公司推出的16/32位RISC微处理器,ARM920T内核,主频400 MHz,最高可达533 MHz,内部具有丰富的系统外围控制器和多种通信接口。SD卡支持SPI和SD两种通信模式,S3C2440A具有SD卡接口,支持SD总线模式,所以不再像低端的ARM处理器
[单片机]
基于<font color='red'>ARM9</font>和μC/OS-II的SD卡文件系统的实现
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
