一直有一个想法就是用 C++ 去做 STM32 的开发,但是很少有这方面的资料。经过一段时间的思考,决定在官方的 ll 库的基础上做一层 C++ 的简单封装。因为官方的库基本实现了全系列的 MCU 都是相同的 API 接口,所以 C++ 封装后的库也有很好的移植性。原理性的东西就不讲理了,直接上代码。
stm32f4xx_xgpio.h 文件
* \file stm32f4xx_xgpio.h
* \author XinLi
* \version v1.0
* \date 20-March-2018
* \brief Header file for general purpose I/O module.
* \attention
Copyright © 2018 XinLi
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see
#ifndef STM32F4XX_XGPIO_H
#define STM32F4XX_XGPIO_H
#include
#include "stm32f4xx_ll_gpio.h"
/*! General purpose I/O module. */
class XGpio
public:
/*! Enumerate GPIO ports. */
enum GpioPort
PortA = (uint32_t)GPIOA, /*!< GPIO port A. */
PortB = (uint32_t)GPIOB, /*!< GPIO port B. */
PortC = (uint32_t)GPIOC, /*!< GPIO port C. */
#ifdef GPIOD
PortD = (uint32_t)GPIOD, /*!< GPIO port D. */
#endif // GPIOD
#ifdef GPIOE
PortE = (uint32_t)GPIOE, /*!< GPIO port E. */
#endif // GPIOE
#ifdef GPIOF
PortF = (uint32_t)GPIOF, /*!< GPIO port F. */
#endif // GPIOF
#ifdef GPIOG
PortG = (uint32_t)GPIOG, /*!< GPIO port G. */
#endif // GPIOG
#ifdef GPIOH
PortH = (uint32_t)GPIOH, /*!< GPIO port H. */
#endif // GPIOH
#ifdef GPIOI
PortI = (uint32_t)GPIOI, /*!< GPIO port I. */
#endif // GPIOI
#ifdef GPIOJ
PortJ = (uint32_t)GPIOJ, /*!< GPIO port J. */
#endif // GPIOJ
#ifdef GPIOK
PortK = (uint32_t)GPIOK, /*!< GPIO port K. */
#endif // GPIOK
/*! Enumeration of GPIO pins. */
enum GpioPin
Pin0 = LL_GPIO_PIN_0, /*!< GPIO pin 0. */
Pin1 = LL_GPIO_PIN_1, /*!< GPIO pin 1. */
Pin2 = LL_GPIO_PIN_2, /*!< GPIO pin 2. */
Pin3 = LL_GPIO_PIN_3, /*!< GPIO pin 3. */
Pin4 = LL_GPIO_PIN_4, /*!< GPIO pin 4. */
Pin5 = LL_GPIO_PIN_5, /*!< GPIO pin 5. */
Pin6 = LL_GPIO_PIN_6, /*!< GPIO pin 6. */
Pin7 = LL_GPIO_PIN_7, /*!< GPIO pin 7. */
Pin8 = LL_GPIO_PIN_8, /*!< GPIO pin 8. */
Pin9 = LL_GPIO_PIN_9, /*!< GPIO pin 9. */
Pin10 = LL_GPIO_PIN_10, /*!< GPIO pin 10. */
Pin11 = LL_GPIO_PIN_11, /*!< GPIO pin 11. */
Pin12 = LL_GPIO_PIN_12, /*!< GPIO pin 12. */
Pin13 = LL_GPIO_PIN_13, /*!< GPIO pin 13. */
Pin14 = LL_GPIO_PIN_14, /*!< GPIO pin 14. */
Pin15 = LL_GPIO_PIN_15, /*!< GPIO pin 15. */
/*! Enumeration of GPIO modes. */
enum GpioMode
ModeInput = LL_GPIO_MODE_INPUT, /*!< GPIO input mode. */
ModeOutput = LL_GPIO_MODE_OUTPUT, /*!< GPIO output mode. */
ModeAlternate = LL_GPIO_MODE_ALTERNATE, /*!< GPIO alternate function mode. */
ModeAnalog = LL_GPIO_MODE_ANALOG, /*!< GPIO analog mode. */
/*! Enumeration of GPIO output types. */
enum GpioOutput
OutputPushPull = LL_GPIO_OUTPUT_PUSHPULL, /*!< GPIO push-pull output. */
OutputOpenDrain = LL_GPIO_OUTPUT_OPENDRAIN, /*!< GPIO open-drain output. */
/*! Enumeration of GPIO output speeds. */
enum GpioSpeed
SpeedLow = LL_GPIO_SPEED_FREQ_LOW, /*!< GPIO low output speed. */
SpeedMedium = LL_GPIO_SPEED_FREQ_MEDIUM, /*!< GPIO medium output speed. */
SpeedHigh = LL_GPIO_SPEED_FREQ_HIGH, /*!< GPIO high output speed. */
SpeedVeryHigh = LL_GPIO_SPEED_FREQ_VERY_HIGH, /*!< GPIO very high output speed. */
/*! Enumeration of GPIO pull-up/pull-down. */
enum GpioPull
PullNo = LL_GPIO_PULL_NO, /*!< GPIO no pull. */
PullUp = LL_GPIO_PULL_UP, /*!< GPIO pull-up. */
PullDown = LL_GPIO_PULL_DOWN, /*!< GPIO pull-down. */
/*! Enumeration of GPIO alternate functions. */
enum GpioAlternate
Alternate0 = LL_GPIO_AF_0, /*!< GPIO alternate function 0. */
Alternate1 = LL_GPIO_AF_1, /*!< GPIO alternate function 1. */
Alternate2 = LL_GPIO_AF_2, /*!< GPIO alternate function 2. */
Alternate3 = LL_GPIO_AF_3, /*!< GPIO alternate function 3. */
Alternate4 = LL_GPIO_AF_4, /*!< GPIO alternate function 4. */
Alternate5 = LL_GPIO_AF_5, /*!< GPIO alternate function 5. */
Alternate6 = LL_GPIO_AF_6, /*!< GPIO alternate function 6. */
Alternate7 = LL_GPIO_AF_7, /*!< GPIO alternate function 7. */
Alternate8 = LL_GPIO_AF_8, /*!< GPIO alternate function 8. */
Alternate9 = LL_GPIO_AF_9, /*!< GPIO alternate function 9. */
Alternate10 = LL_GPIO_AF_10, /*!< GPIO alternate function 10. */
Alternate11 = LL_GPIO_AF_11, /*!< GPIO alternate function 11. */
Alternate12 = LL_GPIO_AF_12, /*!< GPIO alternate function 12. */
Alternate13 = LL_GPIO_AF_13, /*!< GPIO alternate function 13. */
Alternate14 = LL_GPIO_AF_14, /*!< GPIO alternate function 14. */
Alternate15 = LL_GPIO_AF_15, /*!< GPIO alternate function 15. */
/*! Enumeration of GPIO levels. */
enum GpioLevel
LevelLow = 0, /*!< GPIO low level. */
LevelHigh = 1, /*!< GPIO high level. */
XGpio(GpioPort port, GpioPin pin, GpioMode mode = ModeInput);
virtual ~XGpio();
void setPort(GpioPort port);
GpioPort getPort() const;
void setPin(GpioPin pin);
GpioPin getPin() const;
void setMode(GpioMode mode);
GpioMode getMode() const;
void setOutput(GpioOutput output);
GpioOutput getOutput() const;
void setSpeed(GpioSpeed speed);
GpioSpeed getSpeed() const;
void setPull(GpioPull pull);
GpioPull getPull() const;
void setAlternate(GpioAlternate alternate);
GpioAlternate getAlternate() const;
void setLevel(GpioLevel level);
GpioLevel getLevel();
void toggle();
bool open();
void close();
bool isOpen() const;
private:
GpioPort port;
GpioPin pin;
GpioMode mode;
GpioOutput output;
GpioSpeed speed;
GpioPull pull;
GpioAlternate alternate;
GpioLevel level;
bool openFlag;
XGpio(const XGpio &) = delete;
XGpio & operator = (const XGpio &) = delete;
#endif // STM32F4XX_XGPIO_H
stm32f4xx_xgpio.cpp 文件
* \file stm32f4xx_xgpio.cpp
* \author XinLi
* \version v1.0
* \brief General purpose I/O module driver.
* \attention
#include "stm32f4xx_xgpio.h"
#include "stm32f4xx_ll_bus.h"
static __IO uint16_t openFlagPortA = 0;
static __IO uint16_t openFlagPortB = 0;
static __IO uint16_t openFlagPortC = 0;
#ifdef GPIOD
static __IO uint16_t openFlagPortD = 0;
#endif // GPIOD
#ifdef GPIOE
static __IO uint16_t openFlagPortE = 0;
#endif // GPIOE
#ifdef GPIOF
static __IO uint16_t openFlagPortF = 0;
#endif // GPIOF
#ifdef GPIOG
static __IO uint16_t openFlagPortG = 0;
#endif // GPIOG
#ifdef GPIOH
static __IO uint16_t openFlagPortH = 0;
#endif // GPIOH
#ifdef GPIOI
static __IO uint16_t openFlagPortI = 0;
#endif // GPIOI
#ifdef GPIOJ
static __IO uint16_t openFlagPortJ = 0;
#endif // GPIOJ
#ifdef GPIOK
static __IO uint16_t openFlagPortK = 0;
#endif // GPIOK
\brief Open the general purpose I/O clock.
\param port: GPIO port.
static void OpenGpioClock(XGpio::GpioPort port)
if(port == XGpio::PortA)
LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOA);
else if(port == XGpio::PortB)
LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOB);
else if(port == XGpio::PortC)
LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOC);
#ifdef GPIOD
else if(port == XGpio::PortD)
LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOD);
#endif // GPIOD
#ifdef GPIOE
else if(port == XGpio::PortE)
LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOE);
#endif // GPIOE
#ifdef GPIOF
else if(port == XGpio::PortF)
LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOF);
#endif // GPIOF
#ifdef GPIOG
else if(port == XGpio::PortG)
LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOG);
#endif // GPIOG
#ifdef GPIOH
else if(port == XGpio::PortH)
LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOH);
#endif // GPIOH
#ifdef GPIOI
else if(port == XGpio::PortI)
LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOI);
#endif // GPIOI
#ifdef GPIOJ
else if(port == XGpio::PortJ)
LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOJ);
#endif // GPIOJ
#ifdef GPIOK
else if(port == XGpio::PortK)
LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOK);
#endif // GPIOK
\brief Close the general purpose I/O clock.
static void CloseGpioClock(XGpio::GpioPort port)
LL_AHB1_GRP1_DisableClock(LL_AHB1_GRP1_PERIPH_GPIOA);
LL_AHB1_GRP1_DisableClock(LL_AHB1_GRP1_PERIPH_GPIOB);
LL_AHB1_GRP1_DisableClock(LL_AHB1_GRP1_PERIPH_GPIOC);
#ifdef GPIOD
LL_AHB1_GRP1_DisableClock(LL_AHB1_GRP1_PERIPH_GPIOD);
#endif // GPIOD
#ifdef GPIOE
LL_AHB1_GRP1_DisableClock(LL_AHB1_GRP1_PERIPH_GPIOE);
#endif // GPIOE
#ifdef GPIOF
LL_AHB1_GRP1_DisableClock(LL_AHB1_GRP1_PERIPH_GPIOF);
#endif // GPIOF
#ifdef GPIOG
LL_AHB1_GRP1_DisableClock(LL_AHB1_GRP1_PERIPH_GPIOG);
#endif // GPIOG
#ifdef GPIOH
LL_AHB1_GRP1_DisableClock(LL_AHB1_GRP1_PERIPH_GPIOH);
#endif // GPIOH
#ifdef GPIOI
LL_AHB1_GRP1_DisableClock(LL_AHB1_GRP1_PERIPH_GPIOI);
#endif // GPIOI
#ifdef GPIOJ
LL_AHB1_GRP1_DisableClock(LL_AHB1_GRP1_PERIPH_GPIOJ);
#endif // GPIOJ
#ifdef GPIOK
LL_AHB1_GRP1_DisableClock(LL_AHB1_GRP1_PERIPH_GPIOK);
#endif // GPIOK
\brief Set the general purpose I/O pin flag.
\param pin: GPIO pin.
static void SetGpioPinFlag(XGpio::GpioPort port, XGpio::GpioPin pin)
openFlagPortA |= pin;
openFlagPortB |= pin;
openFlagPortC |= pin;
#ifdef GPIOD
openFlagPortD |= pin;
#endif // GPIOD
#ifdef GPIOE
openFlagPortE |= pin;
#endif // GPIOE
#ifdef GPIOF
openFlagPortF |= pin;
#endif // GPIOF
#ifdef GPIOG
openFlagPortG |= pin;
#endif // GPIOG
#ifdef GPIOH
openFlagPortH |= pin;
#endif // GPIOH
#ifdef GPIOI
openFlagPortI |= pin;
#endif // GPIOI
#ifdef GPIOJ
openFlagPortJ |= pin;
#endif // GPIOJ
#ifdef GPIOK
openFlagPortK |= pin;
#endif // GPIOK
\brief Reset the general purpose I/O pin flag.
static void ResetGpioPinFlag(XGpio::GpioPort port, XGpio::GpioPin pin)
openFlagPortA &= ~pin;
openFlagPortB &= ~pin;
openFlagPortC &= ~pin;
#ifdef GPIOD
openFlagPortD &= ~pin;
#endif // GPIOD
#ifdef GPIOE
openFlagPortE &= ~pin;
#endif // GPIOE
#ifdef GPIOF
openFlagPortF &= ~pin;
#endif // GPIOF
#ifdef GPIOG
openFlagPortG &= ~pin;
#endif // GPIOG
#ifdef GPIOH
openFlagPortH &= ~pin;
#endif // GPIOH
#ifdef GPIOI
openFlagPortI &= ~pin;
#endif // GPIOI
#ifdef GPIOJ
openFlagPortJ &= ~pin;
#endif // GPIOJ
#ifdef GPIOK
openFlagPortK &= ~pin;
#endif // GPIOK
\brief Is a general purpose I/O pin flag set?
\retval true: General purpose I/O pin flag are set.
\retval false: General purpose I/O pin flag is not set.
static bool IsSetGpioPinFlag(XGpio::GpioPort port, XGpio::GpioPin pin)
return ((openFlagPortA & pin) == pin);
return ((openFlagPortB & pin) == pin);
return ((openFlagPortC & pin) == pin);
#ifdef GPIOD
return ((openFlagPortD & pin) == pin);
#endif // GPIOD
#ifdef GPIOE
return ((openFlagPortE & pin) == pin);
#endif // GPIOE
#ifdef GPIOF
return ((openFlagPortF & pin) == pin);
#endif // GPIOF
#ifdef GPIOG
return ((openFlagPortG & pin) == pin);
#endif // GPIOG
#ifdef GPIOH
return ((openFlagPortH & pin) == pin);
#endif // GPIOH
#ifdef GPIOI
return ((openFlagPortI & pin) == pin);
#endif // GPIOI
#ifdef GPIOJ
return ((openFlagPortJ & pin) == pin);
#endif // GPIOJ
#ifdef GPIOK
return ((openFlagPortK & pin) == pin);
#endif // GPIOK
else
return true;
\brief Is there a general purpose I/O pin set flag?
\retval true: There is a general purpose I/O pin set flag.
\retval false: There is no general purpose I/O pin set flag.
static bool IsHaveSetGpioPinFlag(XGpio::GpioPort port)
return (openFlagPortA != 0);
return (openFlagPortB != 0);
return (openFlagPortC != 0);
#ifdef GPIOD
return (openFlagPortD != 0);
#endif // GPIOD
#ifdef GPIOE
return (openFlagPortE != 0);
#endif // GPIOE
#ifdef GPIOF
return (openFlagPortF != 0);
#endif // GPIOF
#ifdef GPIOG
return (openFlagPortG != 0);
#endif // GPIOG
#ifdef GPIOH
return (openFlagPortH != 0);
#endif // GPIOH
#ifdef GPIOI
return (openFlagPortI != 0);
#endif // GPIOI
#ifdef GPIOJ
return (openFlagPortJ != 0);
#endif // GPIOJ
#ifdef GPIOK
return (openFlagPortK != 0);
#endif // GPIOK
else
return true;
\brief General purpose I/O module constructor.
\param mode: GPIO mode.
XGpio::XGpio(GpioPort port, GpioPin pin, GpioMode mode)
this->port = port;
this->pin = pin;
this->mode = mode;
this->output = OutputPushPull;
this->speed = SpeedLow;
this->pull = PullNo;
this->alternate = Alternate0;
this->level = LevelLow;
this->openFlag = false;
\brief General purpose I / O module destructor.
\details Restore generic I/O to its default state(input mode, push-pull output,
low output speed, no pull, alternate function 0, low level).
XGpio::~XGpio()
close();
\brief Set general purpose I/O port.
void XGpio::setPort(GpioPort port)
if(openFlag != true)
this->port = port;
\brief Get general purpose I/O port.
\return GPIO port.
XGpio::GpioPort XGpio::getPort() const
return port;
\brief Set general purpose I/O pin.
void XGpio::setPin(GpioPin pin)
this->pin = pin;
\brief Get general purpose I/O pin.
\return GPIO pin.
XGpio::GpioPin XGpio::getPin() const
return pin;
\brief Set general purpose I/O mode.
void XGpio::setMode(GpioMode mode)
this->mode = mode;
if(openFlag == true)
LL_GPIO_SetPinMode((GPIO_TypeDef *)port, pin, mode);
\brief Get general purpose I/O mode.
\return GPIO mode.
XGpio::GpioMode XGpio::getMode() const
return mode;
\brief Set general purpose I/O output type.
\param output: GPIO output type.
void XGpio::setOutput(GpioOutput output)
this->output = output;
LL_GPIO_SetPinOutputType((GPIO_TypeDef *)port, pin, output);
\brief Get general purpose I/O output type.
\return GPIO output type.
XGpio::GpioOutput XGpio::getOutput() const
return output;
\brief Set general purpose I/O output speed.
\param speed: GPIO output speed.
void XGpio::setSpeed(GpioSpeed speed)
this->speed = speed;
LL_GPIO_SetPinSpeed((GPIO_TypeDef *)port, pin, speed);
\brief Get general purpose I/O output speed.
\return GPIO output speed.
XGpio::GpioSpeed XGpio::getSpeed() const
return speed;
\brief Set general purpose I/O pull-up/pull-down.
\param pull: GPIO pull-up/pull-down.
void XGpio::setPull(GpioPull pull)
this->pull = pull;
LL_GPIO_SetPinPull((GPIO_TypeDef *)port, pin, pull);
\brief Get general purpose I/O pull-up/pull-down.
\return GPIO pull-up/pull-down.
XGpio::GpioPull XGpio::getPull() const
return pull;
\brief Set general purpose I/O alternate function.
\param alternate: GPIO alternate function.
void XGpio::setAlternate(GpioAlternate alternate)
this->alternate = alternate;
if(pin < Pin8)
LL_GPIO_SetAFPin_0_7((GPIO_TypeDef *)port, pin, alternate);
else
LL_GPIO_SetAFPin_8_15((GPIO_TypeDef *)port, pin, alternate);
\brief Get general purpose I/O alternate function.
\return GPIO alternate function.
XGpio::GpioAlternate XGpio::getAlternate() const
return alternate;
\brief Set general purpose I/O level status.
\param level: GPIO level status.
void XGpio::setLevel(GpioLevel level)
this->level = level;
if(level != LevelLow)
LL_GPIO_SetOutputPin((GPIO_TypeDef *)port, pin);
else
LL_GPIO_ResetOutputPin((GPIO_TypeDef *)port, pin);
\brief Get general purpose I/O level status.
\return GPIO level status.
XGpio::GpioLevel XGpio::getLevel()
level = (GpioLevel)LL_GPIO_IsInputPinSet((GPIO_TypeDef *)port, pin);
return level;
\brief Toggle general purpose I/O level status.
void XGpio::toggle()
level = level != LevelLow ? LevelLow : LevelHigh;
LL_GPIO_TogglePin((GPIO_TypeDef *)port, pin);
\brief Open general purpose I/O pin.
\retval true: General purpose I/O pin open success.
\retval false: General purpose I/O pin open failure.
bool XGpio::open()
if(IsSetGpioPinFlag(port, pin) != true)
if(IsHaveSetGpioPinFlag(port) != true)
OpenGpioClock(port);
SetGpioPinFlag(port, pin);
if(pin < Pin8)
else
else
openFlag = true;
return true;
else
return false;
\brief Close general purpose I/O pin.
void XGpio::close()
LL_GPIO_SetPinMode((GPIO_TypeDef *)port, pin, ModeInput);
LL_GPIO_SetPinOutputType((GPIO_TypeDef *)port, pin, OutputPushPull);
LL_GPIO_SetPinSpeed((GPIO_TypeDef *)port, pin, SpeedLow);
LL_GPIO_SetPinPull((GPIO_TypeDef *)port, pin, PullNo);
if(pin < Pin8)
LL_GPIO_SetAFPin_0_7((GPIO_TypeDef *)port, pin, Alternate0);
else
LL_GPIO_SetAFPin_8_15((GPIO_TypeDef *)port, pin, Alternate0);
ResetGpioPinFlag(port, pin);
CloseGpioClock(port);
openFlag = false;
\brief Is the general purpose I/O pin open?
\retval true: General purpose I/O pin open.
\retval false: General purpose I/O pin not open.
bool XGpio::isOpen() const
return openFlag;
例程
* @file main.cpp
* @author XinLi
* @version v1.0
* @date 20-March-2018
* @brief Main program body.
* @attention
/* Header includes -----------------------------------------------------------*/
#include "main.h"
/* Macro definitions ---------------------------------------------------------*/
/* Type definitions ----------------------------------------------------------*/
/* Variable declarations -----------------------------------------------------*/
/* Variable definitions ------------------------------------------------------*/
/* Function declarations -----------------------------------------------------*/
static void SystemClock_Config(void);
/* Function definitions ------------------------------------------------------*/
* @brief Main program.
* @param None.
* @return None.
int main(void)
/* STM32F4xx HAL library initialization:
- Configure the Flash prefetch, instruction and Data caches
- Configure the Systick to generate an interrupt each 1 msec
- Set NVIC Group Priority to 4
- Global MSP (MCU Support Package) initialization
HAL_Init();
/* Configure the system clock to 168 MHz */
SystemClock_Config();
XGpio led0(XGpio::PortF, XGpio::Pin9, XGpio::ModeOutput);
XGpio led1(XGpio::PortF, XGpio::Pin10, XGpio::ModeOutput);
led0.open();
led1.open();
for(;;)
HAL_Delay(250);
led0.toggle();
HAL_Delay(250);
led1.toggle();
* @brief System Clock Configuration
* The system Clock is configured as follow :
* System Clock source = PLL (HSE)
* SYSCLK(Hz) = 168000000
* HCLK(Hz) = 168000000
* AHB Prescaler = 1
* APB1 Prescaler = 4
* APB2 Prescaler = 2
* HSE Frequency(Hz) = 8000000
* PLL_M = 8
* PLL_N = 336
* PLL_P = 2
* PLL_Q = 7
* VDD(V) = 3.3
* Main regulator output voltage = Scale1 mode
* Flash Latency(WS) = 5
* @param None
* @retval None
RCC_ClkInitTypeDef RCC_ClkInitStruct;
RCC_OscInitTypeDef RCC_OscInitStruct;
/* Enable Power Control clock */
__HAL_RCC_PWR_CLK_ENABLE();
/* The voltage scaling allows optimizing the power consumption when the device is
clocked below the maximum system frequency, to update the voltage scaling value
regarding system frequency refer to product datasheet. */
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
/* Enable HSE Oscillator and activate PLL with HSE as source */
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLM = 8;
RCC_OscInitStruct.PLL.PLLN = 336;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
RCC_OscInitStruct.PLL.PLLQ = 7;
HAL_RCC_OscConfig(&RCC_OscInitStruct);
/* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2
clocks dividers */
RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5);
/* STM32F405x/407x/415x/417x Revision Z devices: prefetch is supported */
if (HAL_GetREVID() == 0x1001)
/* Enable the Flash prefetch */
__HAL_FLASH_PREFETCH_BUFFER_ENABLE();
上一篇:STM32F4 C++ 封装库 之 EXTI
下一篇:STM32F4(读取芯片ID)
推荐阅读最新更新时间:2024-03-16 16:00
