串口的中断类型:
#define USART_IT_PE ((uint16_t)0x0028)
#define USART_IT_TXE ((uint16_t)0x0727)
#define USART_IT_TC ((uint16_t)0x0626)
#define USART_IT_RXNE ((uint16_t)0x0525)
#define USART_IT_IDLE ((uint16_t)0x0424)
#define USART_IT_LBD ((uint16_t)0x0846)
#define USART_IT_CTS ((uint16_t)0x096A)
#define USART_IT_ERR ((uint16_t)0x0060)
#define USART_IT_ORE ((uint16_t)0x0360)
#define USART_IT_NE ((uint16_t)0x0260)
#define USART_IT_FE ((uint16_t)0x0160)
USART_IT_PE 奇偶错误中断
USART_IT_TXE发送中断
USART_IT_TC 传输完成中断
USART_IT_RXNE 接收中断
USART_IT_IDLE 空闲总线中断
USART_IT_LBD LIN中断检测中断
USART_IT_CTS CTS中断
USART_IT_ERR 错误中断
该程序中用到的就是串口的空闲中断:当总线是一个字节周期内没有收到数据时触发
串口的配置如下:
void uart_init(u32 bound){
GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1|RCC_APB2Periph_GPIOA, ENABLE);
NVIC_InitTypeDef NVIC_InitStructure;
//IO口相关配置
USART_DeInit(USART1);
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//IO口速率
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
//串口中断配置
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
USART_InitStructure.USART_Parity = USART_Parity_No;//没有奇偶校验位
USART_InitStructure.USART_BaudRate = bound; //波特率设置
USART_InitStructure.USART_WordLength = USART_WordLength_8b;//8位数据位
USART_InitStructure.USART_StopBits = USART_StopBits_1;//1位停止位
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流配置
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//串口收发模式
USART_Init(USART1, &USART_InitStructure);
USART_ITConfig(USART1, USART_IT_IDLE, ENABLE);
USART_Cmd(USART1, ENABLE);
串口中断配置:
void USART1_IRQHandler(void)
if(USART_GetITStatus(USART1, USART_IT_IDLE) != RESET)
DMA_Cmd(DMA1_Channel5,DISABLE);
recok=1;
lenth=USART1->DR;//软件清空空闲中断标志位
lenth=USART1->SR;
lenth=32-DMA_GetCurrDataCounter(DMA1_Channel5);//获取当前接收的数据量
USART_RX_BUF[lenth]=0;//在buff最后加入空字符
DMA1_Channel5->CNDTR=32;//重新设置传输量为32
DMA_Cmd(DMA1_Channel5,ENABLE);
DMA配置:
void MYDMA_Config(DMA_Channel_TypeDef* DMA_CHx,u32 cpar,u32 cmar,u16 cndtr)
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);//使能DMA时钟
DMA_DeInit(DMA_CHx);
DMA1_MEM_LEN=cndtr;
DMA_InitStructure.DMA_PeripheralBaseAddr = cpar;//外设地址
DMA_InitStructure.DMA_MemoryBaseAddr = cmar; //内存地址
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //传输方向外设到内存
DMA_InitStructure.DMA_BufferSize = cndtr; //传输量
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//外设地址不自增
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //内存地址自增
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
DMA_InitStructure.DMA_Mode = DMA_Mode_Normal; //普通模式
DMA_InitStructure.DMA_Priority = DMA_Priority_High;//高优先级
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
DMA_Init(DMA_CHx, &DMA_InitStructure);
主函数中需要进行的配置:
MYDMA_Config(DMA1_Channel5,(u32)&USART1->DR,(u32)USART_RX_BUF,32);//传输方向设置为USART1->DR到USART_RX_BUF 传输大小为32字节
USART_DMACmd(USART1,USART_DMAReq_Rx,ENABLE);//允许DMA请求
当标志为recok位1时表示接受完成 在主函数中等待recok位1就可以了
上一篇:STM32 总线空闲 + DMA 方式接收
下一篇:STM32CubeMX:UART(DMA空闲方式)
推荐阅读最新更新时间:2024-03-16 16:05
设计资源 培训 开发板 精华推荐
- 微灵医疗李骁健:脑机接口技术正在开启意识与AI融合的新纪元
- USB Type-C® 和 USB Power Delivery:专为扩展功率范围和电池供电型系统而设计
- 景昱医疗耿东:脑机接口DBS治疗技术已实现国产替代
- 首都医科大学王长明:针对癫痫的数字疗法已进入使用阶段
- 非常见问题解答第223期:如何在没有软启动方程的情况下测量和确定软启动时序?
- 兆易创新GD25/55全系列车规级SPI NOR Flash荣获ISO 26262 ASIL D功能安全认证证书
- 新型IsoVu™ 隔离电流探头:为电流测量带来全新维度
- 英飞凌推出简化电机控制开发的ModusToolbox™电机套件
- 意法半导体IO-Link执行器电路板为工业监控和设备厂商带来一站式参考设计
- Melexis采用无磁芯技术缩小电流感测装置尺寸
