GPIO寄存器有:输出寄存器(ODR),输入寄存器(IDR),方向寄存器(DDR),控制寄存器1(CR1)和控制寄存器2(CR2).后面三个寄存器组和可以配置为8种GPIO的模式,如下图:
而固件库函数给出了8中模式,在上面的基础上加入了输出高/输出低电平的状态。
GPIO_Mode_In_FL_No_IT浮空输入无中断 | Input floating, no external interrupt |
GPIO_Mode_In_PU_No_I上拉输入无中断 | Input pull-up, no external interrupt |
GPIO_Mode_In_FL_IT 浮空输入有中断 | Input floating, external interrupt |
GPIO_Mode_In_PU_IT 上拉输入有中断 | Input pull-up, external interrupt |
GPIO_Mode_Out_OD_Low_Fast 开漏-输出低-高速 |
Output open-drain, low level, 10MHz |
GPIO_Mode_Out_PP_Low_Fast 推挽-输出低-高速 |
Output push-pull, low level, 10MHz |
GPIO_Mode_Out_OD_Low_Slow 开漏-输出低-低速 |
Output open-drain, low level, 2MHz |
GPIO_Mode_Out_PP_Low_Slow 推挽-输出低-低速 |
Output push-pull, low level, 2MHz |
GPIO_Mode_Out_OD_HiZ_Fast 开漏-输出高阻-高速 |
Output open-drain, high-impedance level, 10MHz |
GPIO_Mode_Out_PP_High_Fast 推挽-输出高-高速 |
Output push-pull, high level, 10MHz |
GPIO_Mode_Out_OD_HiZ_Slow 开漏-输出高阻-低速 |
Output open-drain, high-impedance level, 2MHz |
GPIO_Mode_Out_PP_High_Slow 推挽-输出高-低速 |
Output push-pull, high level, 2MHz |
下面是GPIO操作的应用,GPIO写操作---板上的两个LED灯闪烁的代码
void main(void)
/* Infinite loop */
GPIO_Init(LED1_PORT, LED1_PIN, GPIO_Mode_Out_PP_Low_Fast);
GPIO_Init(LED2_PORT, LED2_PIN, GPIO_Mode_Out_PP_Low_Fast);
while (1)
GPIO_ToggleBits(LED1_PORT, LED1_PIN);
Delay(0xFFFF);
GPIO_ToggleBits(LED2_PORT, LED2_PIN);
Delay(0xFFFF);
GPIO读操作---查询按键点亮LED
void main(void)
/* Infinite loop */
GPIO_Init(LED1_PORT,LED1_PIN,GPIO_Mode_Out_PP_Low_Fast);
//输出低电平-高速10M
GPIO_Init(KEY_PORT,KEY_PIN,GPIO_Mode_In_FL_No_IT);
//输入浮空-无中断
while (1)
if(GPIO_ReadInputDataBit(KEY_PORT,KEY_PIN))
GPIO_WriteBit(LED1_PORT,LED1_PIN,RESET);
else
GPIO_WriteBit(LED1_PORT,LED1_PIN,SET);
上一篇:STM8L探索套件学习笔记-EXTI外部中断(二)
下一篇:XMEGA128学习笔记11-定时器TC
推荐阅读最新更新时间:2024-03-16 14:41
