总结:开始是在keil4里看代码,很混乱,后来把他粘到Notepad编辑器,一点击就可以看出这个子函数到哪结束
- #if defined (STM32F10X_LD_VL) || (defined STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)
- /* #define SYSCLK_FREQ_HSE HSE_VALUE */
- #define SYSCLK_FREQ_24MHz 24000000
- #else
- /* #define SYSCLK_FREQ_24MHz 24000000 */
- /* #define SYSCLK_FREQ_36MHz 36000000 */
- /* #define SYSCLK_FREQ_48MHz 48000000 */
- /* #define SYSCLK_FREQ_56MHz 56000000 */
- #define SYSCLK_FREQ_72MHz 72000000
- #endif
下面定义的SystemCoreClock 变量是为了方便取出几种情况下系统时钟的实际值,例SYSCLK_FREQ_24MHz 也就是24000000。
- #ifdef SYSCLK_FREQ_HSE
- uint32_t SystemCoreClock = SYSCLK_FREQ_HSE; /*!< System Clock Frequency (Core Clock) */
- #elif defined SYSCLK_FREQ_24MHz
- uint32_t SystemCoreClock = SYSCLK_FREQ_24MHz; /*!< System Clock Frequency (Core Clock) */
- #elif defined SYSCLK_FREQ_36MHz
- uint32_t SystemCoreClock = SYSCLK_FREQ_36MHz; /*!< System Clock Frequency (Core Clock) */
- #elif defined SYSCLK_FREQ_48MHz
- uint32_t SystemCoreClock = SYSCLK_FREQ_48MHz; /*!< System Clock Frequency (Core Clock) */
- #elif defined SYSCLK_FREQ_56MHz
- uint32_t SystemCoreClock = SYSCLK_FREQ_56MHz; /*!< System Clock Frequency (Core Clock) */
- #elif defined SYSCLK_FREQ_72MHz
- uint32_t SystemCoreClock = SYSCLK_FREQ_72MHz; /*!< System Clock Frequency (Core Clock) */
- #else /*!< HSI Selected as System Clock source */
- uint32_t SystemCoreClock = HSI_VALUE; /*!< System Clock Frequency (Core Clock) */
- #endif
- static void SetSysClock(void)
- SetSysClockToHSE();
- SetSysClockTo24();
- SetSysClockTo36();
- SetSysClockTo48();
- SetSysClockTo56();
- SetSysClockTo72();
- #endif
- /* If none of the define above is enabled, the HSI is used as System clock
- source (default after reset) */
- * @brief Selects HSE as System clock source and configure HCLK, PCLK2
- * and PCLK1 prescalers.
- * @note This function should be used only after reset.
- * @param None
- * @retval None
- static void SetSysClockToHSE(void)
- * @brief Sets System clock frequency to 24MHz and configure HCLK, PCLK2
- * @param None
- * @retval None
- static void SetSysClockTo24(void)
- * @brief Sets System clock frequency to 36MHz and configure HCLK, PCLK2
- * @param None
- * @retval None
- static void SetSysClockTo36(void)
- * @brief Sets System clock frequency to 72MHz and configure HCLK, PCLK2
- * @param None
- * @retval None
- static void SetSysClockTo72(void)
上一篇:端口复用和重映射
下一篇:STM32嵌入式微控制器快速上手——笔记
推荐阅读最新更新时间:2024-03-16 14:43
