stm32编程过程经常定义变量类型,经常担心数据运算过程中 超过变量类型范围。因为在编程过程中,不同的CPU,其数据类型的意义各不相同,所以一定要注意相应变量数据类型的定义和转换,否则在计算中可能会出现不确定的错误。所以下面列出常见数据类型:
一、C语言数据类型
stm32使用的数据类型定义在 stm32f4xx.h中
整型定义:
#include "core_cm4.h" /* Cortex-M4 processor and core peripherals */
#include "system_stm32f4xx.h"
#include /** @addtogroup Exported_types * @{ */ /*!< STM32F10x Standard Peripheral Library old types (maintained for legacy purpose) */ typedef int32_t s32; typedef int16_t s16; typedef int8_t s8; typedef const int32_t sc32; /*!< Read Only */ typedef const int16_t sc16; /*!< Read Only */ typedef const int8_t sc8; /*!< Read Only */ typedef __IO int32_t vs32; typedef __IO int16_t vs16; typedef __IO int8_t vs8; typedef __I int32_t vsc32; /*!< Read Only */ typedef __I int16_t vsc16; /*!< Read Only */ typedef __I int8_t vsc8; /*!< Read Only */ typedef uint32_t u32; /*常用类型*/ typedef uint16_t u16; typedef uint8_t u8; typedef const uint32_t uc32; /*!< Read Only */ typedef const uint16_t uc16; /*!< Read Only */ typedef const uint8_t uc8; /*!< Read Only */ typedef __IO uint32_t vu32; typedef __IO uint16_t vu16; typedef __IO uint8_t vu8; typedef __I uint32_t vuc32; /*!< Read Only */ typedef __I uint16_t vuc16; /*!< Read Only */ typedef __I uint8_t vuc8; /*!< Read Only */ 浮点型: #if !defined(__STRICT_ANSI__) || defined(__USE_C99_MATH) /* C99 additions */ typedef float float_t; typedef double double_t; 注:还有float 浮点型 编译器中不能看到其定义(估计已编译了)。 而uint32_t 、uint16_t、uint8_t在哪里定义?在stdint.h文件中,详见下面: /* exact-width signed integer types */ typedef signed char int8_t; typedef signed short int int16_t; typedef signed int int32_t; typedef signed __int64 int64_t; /* exact-width unsigned integer types */ typedef unsigned char uint8_t; typedef unsigned short int uint16_t; typedef unsigned int uint32_t; typedef unsigned __int64 uint64_t; /* minimum values of exact-width signed integer types */ #define INT8_MIN -128 /* s8 占用1个byte,数据范围 -2^7 到 (2^7-1) */ #define INT16_MIN -32768 /* s16 占用2个byte,数据范围 -2^15 到 (2^15-1) */ #define INT32_MIN (~0x7fffffff) /* -2147483648 is unsigned s32 占用 4个byte,数据范围 -2^31 到 (2^31-1) */ #define INT64_MIN __ESCAPE__(~0x7fffffffffffffffll) /* -9223372036854775808 is unsigned int64_t占用8个byte,数据范围 -2^63 到 (2^63-1) */ /* maximum values of exact-width signed integer types */ #define INT8_MAX 127 #define INT16_MAX 32767 #define INT32_MAX 2147483647 #define INT64_MAX __ESCAPE__(9223372036854775807ll) /* maximum values of exact-width unsigned integer types */ #define UINT8_MAX 255 /* u8 占用1个byte, 数据范围 0 - 2^8*/ #define UINT16_MAX 65535 /* u16 占用2个byte, 数据范围 0 - 2^16*/ #define UINT32_MAX 4294967295u /* u32 占用4个byte, 数据范围 0 - 2^32*/ #define UINT64_MAX __ESCAPE__(18446744073709551615ull) 由上述可知: 1、有符号整型 s8 占用1个byte,数据范围 -2^7 到 (2^7-1) s16 占用2个byte,数据范围 -2^15 到 (2^15-1) s32 占用 4个byte,数据范围 -2^31 到 (2^31-1)2^31 = 2147483647 int64_t占用8个byte,数据范围 -2^63 到 (2^63-1) 2^63 = 9223372036854775807ll 2、无符号整型 u8 占用1个byte, 数据范围 0 - 2^8 u16 占用2个byte, 数据范围 0 - 2^16 u32 占用4个byte, 数据范围 0 - 2^32 2^32 = 4294967295 uint64_t 占用8个byte, 数据范围 0 - 2^64 2^64 = 18446744073709551615 3、浮点型 float ——4个byte,有符号型,可以表达负数/小数; Float 类型至少要能精确表示到小数点后6位。 double——8个byte,有符号型,可以表达负数/小数;Double 类型至少要能精确到小数点后 10 位。 二、不同数据类型混合运算 在C语言中,不同类型的数据间是可以混合运算的。在进行运算时,不同类型的数据要先转换成同一类型,然后进行运算。转换的规则如下: 注意:箭头的方向只表示数据类型级别的高低,由低向高转换,这个转换过程是一步到位的。 (三)数据类型转换规则 各类数据类型的转换,分为两种方式:隐式(编译软件自动完成),显式(程序强制转换) 隐式转换规则: 字符必须先转换为整数(C语言规定字符类型数据和整型数据之间可以通用) short型转换为int型(同属于整型) float型数据在运算时一律转换为双精度(double)型,以提高运算精度(同属于实型) 赋值时,一律是右部值转换为左部类型 [注] 当整型数据和双精度数据进行运算时,C先将整型数据转换成双精度型数据,再进行运算,结果为双精度类型数据 当字符型数据和实型数据进行运算时,C先将字符型数据转换成实型数据,然后进行计算,结果为实型数据 显式转换规则: 例:(int)(x+y); 注:强制类型转换时,得到一个所需要的中间变量,原来变量的类型未发生变化。
设计资源 培训 开发板 精华推荐
- LT3477IFE 10V 至 2 个白光 LED、具有 PWM 调光的降压-升压模式的典型应用电路
- EVAL-AD7193EBZ,用于 AD7193、24 位、4.8KSPS ADC 的评估板,用于医疗
- EVAL-AD7793EBZ,AD7793 评估板,24 位,470SPS,用于热电偶的 3CH ADC
- sHMIctrl-电容50AF
- LTC3119EFE 具有温度校正功能的光伏面板输入铅酸充电器的典型应用电路 (1MHz)
- Si4113GM-EVB,Si4113G-BM PLL 频率合成器评估板
- MAXREFDESGPS_B:如何在不消耗电池的情况下将GPS添加到您的产品
- ADS1232验证板
- 用于 LED 照明的 16 个 LED 白光 LED 驱动器
- LTC3615HFE 双路 4MHz、3A 同步降压型 DC/DC 转换器的典型应用
