这里探究了以下stm32 外部时钟的用法。
这里用的是stm32f103rbt6,usart2,外部晶振11.0592Mhz。
先看时钟树吧
这是上图的配置:
void RCC_Init(void)
ErrorStatus HSEStartUpStatus;
RCC_DeInit();
RCC_HSEConfig(RCC_HSE_ON); //设置外部高速晶振(HSE)
HSEStartUpStatus = RCC_WaitForHSEStartUp(); //等待HSE起振
if(HSEStartUpStatus == SUCCESS) //SUCCESS:HSE晶振稳定且就绪
RCC_HCLKConfig(RCC_SYSCLK_Div1); //设置AHB时钟(HCLK),RCC_SYSCLK_Div1——AHB时钟 = 系统时钟
RCC_PCLK2Config(RCC_HCLK_Div1); //设置高速AHB时钟(PCLK2),RCC_HCLK_Div1——APB2时钟 = HCLK
RCC_PCLK1Config(RCC_HCLK_Div2); //设置低速AHB时钟(PCLK1),RCC_HCLK_Div2——APB1时钟 = HCLK / 2
FLASH_SetLatency(FLASH_Latency_2); //设置FLASH存储器延时时钟周期数,FLASH_Latency_2 2延时周期
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); // 选择FLASH预取指缓存的模式,预取指缓存使能
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_2);
// 设置PLL时钟源及倍频系数,PLL的输入时钟 = HSE时钟频率;RCC_PLLMul_2——PLL输入时钟x 2
RCC_PLLCmd(ENABLE);//使能PLL
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);//检查指定的RCC标志位(PLL准备好标志)设置与否
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
//设置系统时钟(SYSCLK),RCC_SYSCLKSource_PLLCLK——选择PLL作为系统时钟,11.0592x2
while(RCC_GetSYSCLKSource() != 0x08); //PLL返回用作系统时钟的时钟源,0x08:PLL作为系统时钟
RCC_GetClocksFreq(&RCC_ClocksStatus);
这里的配置和上面的时钟树意义对应,下面读取时钟的函数可以得到各种时钟的值了。可以验证一下,你自己推算的对不对了。
if (usartxbase == USART1_BASE)
apbclock = RCC_ClocksStatus.PCLK2_Frequency;
else
apbclock = RCC_ClocksStatus.PCLK1_Frequency;
/* Determine the integer part */
if ((USARTx->CR1 & CR1_OVER8_Set) != 0)
/* Integer part computing in case Oversampling mode is 8 Samples */
integerdivider = ((25 * apbclock) / (2 * (USART_InitStruct->USART_BaudRate)));
其中读取时钟的函数RCC_GetClocksFreq函数如下:
void RCC_GetClocksFreq(RCC_ClocksTypeDef* RCC_Clocks)
uint32_t tmp = 0, pllmull = 0, pllsource = 0, presc = 0;
#ifdef STM32F10X_CL
uint32_t prediv1source = 0, prediv1factor = 0, prediv2factor = 0, pll2mull = 0;
#endif /* STM32F10X_CL */
#if defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || defined (STM32F10X_HD_VL)
uint32_t prediv1factor = 0;
#endif
/* Get SYSCLK source -------------------------------------------------------*/
tmp = RCC->CFGR & CFGR_SWS_Mask;
switch (tmp)
case 0x00: /* HSI used as system clock */
RCC_Clocks->SYSCLK_Frequency = HSI_VALUE;
break;
case 0x04: /* HSE used as system clock */
RCC_Clocks->SYSCLK_Frequency = HSE_VALUE;
break;
case 0x08: /* PLL used as system clock */
/* Get PLL clock source and multiplication factor ----------------------*/
pllmull = RCC->CFGR & CFGR_PLLMull_Mask;
pllsource = RCC->CFGR & CFGR_PLLSRC_Mask;
#ifndef STM32F10X_CL
pllmull = ( pllmull >> 18) + 2;
if (pllsource == 0x00)
{/* HSI oscillator clock divided by 2 selected as PLL clock entry */
RCC_Clocks->SYSCLK_Frequency = (HSI_VALUE >> 1) * pllmull;
else
prediv1factor = (RCC->CFGR2 & CFGR2_PREDIV1) + 1;
/* HSE oscillator clock selected as PREDIV1 clock entry */
RCC_Clocks->SYSCLK_Frequency = (HSE_VALUE / prediv1factor) * pllmull;
#else
/* HSE selected as PLL clock entry */
if ((RCC->CFGR & CFGR_PLLXTPRE_Mask) != (uint32_t)RESET)
{/* HSE oscillator clock divided by 2 */
RCC_Clocks->SYSCLK_Frequency = (HSE_VALUE >> 1) * pllmull;
else
RCC_Clocks->SYSCLK_Frequency = HSE_VALUE * pllmull;
#endif
#else
pllmull = pllmull >> 18;
if (pllmull != 0x0D)
pllmull += 2;
else
{ /* PLL multiplication factor = PLL input clock * 6.5 */
pllmull = 13 / 2;
else
{/* PREDIV1 selected as PLL clock entry */
/* Get PREDIV1 clock source and division factor */
prediv1source = RCC->CFGR2 & CFGR2_PREDIV1SRC;
if (prediv1source == 0)
{ /* HSE oscillator clock selected as PREDIV1 clock entry */
else
{/* PLL2 clock selected as PREDIV1 clock entry */
/* Get PREDIV2 division factor and PLL2 multiplication factor */
prediv2factor = ((RCC->CFGR2 & CFGR2_PREDIV2) >> 4) + 1;
pll2mull = ((RCC->CFGR2 & CFGR2_PLL2MUL) >> 8 ) + 2;
RCC_Clocks->SYSCLK_Frequency = (((HSE_VALUE / prediv2factor) * pll2mull) / prediv1factor) * pllmull;
break;
default:
break;
/* Compute HCLK, PCLK1, PCLK2 and ADCCLK clocks frequencies ----------------*/
/* Get HCLK prescaler */
tmp = RCC->CFGR & CFGR_HPRE_Set_Mask;
tmp = tmp >> 4;
presc = APBAHBPrescTable[tmp];
/* HCLK clock frequency */
RCC_Clocks->HCLK_Frequency = RCC_Clocks->SYSCLK_Frequency >> presc;
/* Get PCLK1 prescaler */
tmp = RCC->CFGR & CFGR_PPRE1_Set_Mask;
tmp = tmp >> 8;
/* PCLK1 clock frequency */
RCC_Clocks->PCLK1_Frequency = RCC_Clocks->HCLK_Frequency >> presc;
/* Get PCLK2 prescaler */
tmp = RCC->CFGR & CFGR_PPRE2_Set_Mask;
tmp = tmp >> 11;
/* PCLK2 clock frequency */
RCC_Clocks->PCLK2_Frequency = RCC_Clocks->HCLK_Frequency >> presc;
/* Get ADCCLK prescaler */
tmp = RCC->CFGR & CFGR_ADCPRE_Set_Mask;
tmp = tmp >> 14;
presc = ADCPrescTable[tmp];
/* ADCCLK clock frequency */
RCC_Clocks->ADCCLK_Frequency = RCC_Clocks->PCLK2_Frequency / presc;
stm32f10x.h
#if !defined HSE_VALUE
#ifdef STM32F10X_CL
#define HSE_VALUE ((uint32_t)25000000) /*!< Value of the External oscillator in Hz */
#else
#define HSE_VALUE ((uint32_t)11059200) /*!< Value of the External oscillator in Hz */
#endif /* HSE_VALUE */
void USART_Init(USART_TypeDef* USARTx, USART_InitTypeDef* USART_InitStruct)
uint32_t tmpreg = 0x00, apbclock = 0x00;
uint32_t integerdivider = 0x00;
uint32_t fractionaldivider = 0x00;
uint32_t usartxbase = 0;
RCC_ClocksTypeDef RCC_ClocksStatus;
/* Check the parameters */
assert_param(IS_USART_ALL_PERIPH(USARTx));
assert_param(IS_USART_BAUDRATE(USART_InitStruct->USART_BaudRate));
assert_param(IS_USART_WORD_LENGTH(USART_InitStruct->USART_WordLength));
assert_param(IS_USART_STOPBITS(USART_InitStruct->USART_StopBits));
assert_param(IS_USART_PARITY(USART_InitStruct->USART_Parity));
assert_param(IS_USART_MODE(USART_InitStruct->USART_Mode));
assert_param(IS_USART_HARDWARE_FLOW_CONTROL(USART_InitStruct->USART_HardwareFlowControl));
/* The hardware flow control is available only for USART1, USART2 and USART3 */
if (USART_InitStruct->USART_HardwareFlowControl != USART_HardwareFlowControl_None)
assert_param(IS_USART_123_PERIPH(USARTx));
usartxbase = (uint32_t)USARTx;
/*---------------------------- USART CR2 Configuration -----------------------*/
tmpreg = USARTx->CR2;
/* Clear STOP[13:12] bits */
tmpreg &= CR2_STOP_CLEAR_Mask;
/* Configure the USART Stop Bits, Clock, CPOL, CPHA and LastBit ------------*/
/* Set STOP[13:12] bits according to USART_StopBits value */
tmpreg |= (uint32_t)USART_InitStruct->USART_StopBits;
/* Write to USART CR2 */
USARTx->CR2 = (uint16_t)tmpreg;
/*---------------------------- USART CR1 Configuration -----------------------*/
上一篇:STM32F4之串口(三)
下一篇:STM32 systick做为系统时间使用(非简单延时)
推荐阅读最新更新时间:2024-11-13 11:02
