main.c
#include #include int main(void) { GPIO_InitTypeDef InitStruct; RCC->AHB1ENR |= (1<<7); InitStruct.GPIO_Pin = GPIO_Pin_9; InitStruct.GPIO_Mode = GPIO_Mode_OUT; InitStruct.GPIO_OType = GPIO_OType_PP; InitStruct.GPIO_PuPd = GPIO_PuPd_UP; InitStruct.GPIO_Speed = GPIO_Speed_25MHz; GPIO_Init(GPIOH, &InitStruct); while(1); } void SystemInit(void) { } stm32f4xx.h #ifndef __STM32F4XX_H #define __STM32F4XX_H #define __IO volatile typedef unsigned int uint32_t; typedef unsigned short uint16_t; typedef unsigned char uint8_t; //----------------------基地址赋值------------------------ #define PERIPH_BASE ((unsigned int)0x40000000) #define APB1PERIPH_BASE PERIPH_BASE #define APB2PERIPH_BASE (PERIPH_BASE + 0x00010000) #define AHB1PERIPH_BASE (PERIPH_BASE + 0x00020000) #define AHB2PERIPH_BASE (PERIPH_BASE + 0x10000000) #define AHB3PERIPH_BASE (PERIPH_BASE + 0X60000000) //GPIO 寄存器 #define GPIOA_BASE AHB1PERIPH_BASE #define GPIOB_BASE (AHB1PERIPH_BASE + 0x00000400) #define GPIOC_BASE (AHB1PERIPH_BASE + 0x00000800) #define GPIOD_BASE (AHB1PERIPH_BASE + 0x00000C00) #define GPIOE_BASE (AHB1PERIPH_BASE + 0x00001000) #define GPIOF_BASE (AHB1PERIPH_BASE + 0x00001400) #define GPIOG_BASE (AHB1PERIPH_BASE + 0x00001800) #define GPIOH_BASE (AHB1PERIPH_BASE + 0x00001C00) #define GPIOI_BASE (AHB1PERIPH_BASE + 0x00002000) //复位和时钟控制 #define RCC_BASE (AHB1PERIPH_BASE + 0x00003800) //外设时钟使能寄存器 #define RCC_AHB1ENR *((unsigned int *)(RCC_BASE + 0X30)) typedef struct { __IO uint32_t MODER; __IO uint32_t OTYPER; __IO uint32_t OSPEEDR; __IO uint32_t PUPDR; __IO uint32_t IDR; __IO uint32_t ODR; __IO uint16_t BSRRL; __IO uint16_t BSRRH; __IO uint32_t LCKR; __IO uint32_t AFR[2]; }GPIO_TypeDef; typedef struct { __IO uint32_t CR; __IO uint32_t PLLCFGR; __IO uint32_t CFGR; __IO uint32_t CIR; __IO uint32_t AHB1RSTR; __IO uint32_t AHB2RSTR; __IO uint32_t AHB3RSTR; __IO uint32_t RESERVED0; //此处为适用于其他芯片版本的APB1RSTR __IO uint32_t APB1RSTR; __IO uint32_t RESERVED1[2]; //此处为适用于其他芯片版本的APB2RSTR __IO uint32_t APB2RSTR; __IO uint32_t AHB1ENR; __IO uint32_t AHB2ENR; __IO uint32_t AHB3ENR; //后面还有很多,省略... }RCC_TypeDef; //------------------定义访问外设的结构体指针--------------------- #define GPIOA ((GPIO_TypeDef *) GPIOA_BASE) #define GPIOB ((GPIO_TypeDef *) GPIOB_BASE) #define GPIOC ((GPIO_TypeDef *) GPIOC_BASE) #define GPIOD ((GPIO_TypeDef *) GPIOD_BASE) #define GPIOE ((GPIO_TypeDef *) GPIOE_BASE) #define GPIOF ((GPIO_TypeDef *) GPIOF_BASE) #define GPIOG ((GPIO_TypeDef *) GPIOG_BASE) #define GPIOH ((GPIO_TypeDef *) GPIOH_BASE) #define GPIOI ((GPIO_TypeDef *) GPIOI_BASE) #define RCC ((RCC_TypeDef *) RCC_BASE) #endif /* __STM32F4XX_H */ stm32f4xx_gpio.c #include #include void GPIO_SetBits(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin) //Set bits { GPIOx->BSRRL = GPIO_Pin; } void GPIO_ResetBits(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin) //Reset bits { GPIOx->BSRRH = GPIO_Pin; } void GPIO_Init(GPIO_TypeDef* GPIOx, GPIO_InitTypeDef* GPIO_InitStruct) //Find the pin, and initialize the GPIO { uint32_t pinpos = 0x00, pin = 0x00, currency = 0x00; currency = GPIO_InitStruct->GPIO_Pin; for(pinpos=0x00; pinpos<16; pinpos++) { pin = 0x01< { GPIOx->MODER &= ~(3 << (2*pinpos)); GPIOx->MODER |= (((uint32_t)GPIO_InitStruct->GPIO_Mode) << (2*pinpos)); GPIOx->PUPDR &= ~(3 << ((2*pinpos))); GPIOx->PUPDR |= (((uint32_t)GPIO_InitStruct->GPIO_PuPd)) << (2*pinpos); if((GPIO_InitStruct->GPIO_Mode == GPIO_Mode_OUT) || (GPIO_InitStruct->GPIO_Mode == GPIO_Mode_AF)) { GPIOx->OSPEEDR &= ~(3 << (2*pinpos)); GPIOx->OSPEEDR |= ((uint32_t)(GPIO_InitStruct->GPIO_Speed)<<(2*pinpos)); GPIOx->OTYPER &= ~(1 << (pinpos)); GPIOx->OTYPER |= (uint16_t)((GPIO_InitStruct->GPIO_OType)<<(pinpos)); } } } } stm32f4xx_gpio.h #include #define GPIO_Pin_0 ((uint16_t)0x0001) #define GPIO_Pin_1 ((uint16_t)0x0002) #define GPIO_Pin_2 ((uint16_t)0x0004) #define GPIO_Pin_3 ((uint16_t)0x0008) #define GPIO_Pin_4 ((uint16_t)0x0010) #define GPIO_Pin_5 ((uint16_t)0x0020) #define GPIO_Pin_6 ((uint16_t)0x0040) #define GPIO_Pin_7 ((uint16_t)0x0080) #define GPIO_Pin_8 ((uint16_t)0x0100) #define GPIO_Pin_9 ((uint16_t)0x0200) #define GPIO_Pin_10 ((uint16_t)0x0400) #define GPIO_Pin_11 ((uint16_t)0x0800) #define GPIO_Pin_12 ((uint16_t)0x1000) #define GPIO_Pin_13 ((uint16_t)0x2000) #define GPIO_Pin_14 ((uint16_t)0x4000) #define GPIO_Pin_15 ((uint16_t)0x8000) #define GPIO_Pin_ALL ((uint16_t)0xffff) //Initialize GPIO /* typedef struct { uint32_t GPIO_Pin; uint8_t GPIO_Mode; uint8_t GPIO_Speed; uint8_t GPIO_OType; uint8_t GPIO_PuPd; }GPIO_InitTypeDef; */ //----------------------------------------------------------- //GPIO typedef enum { GPIO_Mode_IN = 0X00, GPIO_Mode_OUT = 0X01, GPIO_Mode_AF = 0X02, GPIO_Mode_AN = 0X03 }GPIOMode_TypeDef; typedef enum { GPIO_OType_PP = 0x00, GPIO_OType_OD = 0x01 }GPIOOType_TypeDef; typedef enum { GPIO_Speed_2MHz = 0x00, //2MHz GPIO_Speed_25MHz = 0x01, //25MHz GPIO_Speed_50MHz = 0x10, //50MHz GPIO_Speed_100MHz = 0x11 //100MHz }GPIOSpeed_TypeDef; typedef enum { GPIO_PuPd_NOPULL = 0X00, GPIO_PuPd_UP = 0X01, GPIO_PuPd_DOWN = 0X02 }GPIOPuPd_TypeDef; //----------------------------------------------------------- typedef struct { uint32_t GPIO_Pin; GPIOMode_TypeDef GPIO_Mode; GPIOOType_TypeDef GPIO_OType; GPIOSpeed_TypeDef GPIO_Speed; GPIOPuPd_TypeDef GPIO_PuPd; }GPIO_InitTypeDef; void GPIO_SetBits(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin); void GPIO_ResetBits(GPIO_TypeDef* GPIOx, uint16_t GPIO_Pin); void GPIO_Init(GPIO_TypeDef* GPIOx, GPIO_InitTypeDef* GPIO_InitStruct);
上一篇:STM32F429 >> 14. TIM_(一)_基本定时器
下一篇:STM32F429 >> 3. STM32 固件库
推荐阅读最新更新时间:2024-11-13 13:50
设计资源 培训 开发板 精华推荐
- 具有 75ms 软启动的 LTC3638MPMSE 低输出电压纹波 250mA 稳压器的典型应用电路
- LT6656ACDC-1.25、1.25V 低功率 ADC 电压基准的典型应用
- MPC567xF-REV-KIT: MPC567XKIT416-PT, MPC567XKIT516-PT
- 使用 ON Semiconductor 的 LA4533M 的参考设计
- 使用 Analog Devices 的 LTC1148 的参考设计
- 用于确定 L6566BTR 的 OVP 和 OCP 的 IC 行为的典型外部电路 SMPS 电源的多模式控制器
- ADR445A 5 Vout 超低噪声、LDO XFET 电压基准的典型应用,具有电流吸收器和电流源
- LM2940稳压电路
- LTC3526LBEDC 锂离子至 5V 升压转换器的典型应用电路
- 适用于汽车应用的 LT3973EDD-3.3 3.3V 降压转换器的典型应用
