系列函数
系列函数的定义在arch/arm/mach-s3c2410/gpio.c,相关的宏定义在include/asm-arm/arch-s3c2410/regs-gpio.h
(1)void s3c2410_gpio_setpin(unsigned int pin, unsigned intto);
设置相应GPIO口的输出值,例如:
pin=S3C2410_GPG2,to=0,则设置S3C2410_GPG2的输出值为0;
pin=S3C2410_GPG2,to=1,则设置S3C2410_GPG2的输出值为1。
函数定义:
viewplain
void s3c2410_gpio_setpin(unsigned int pin, unsigned int to)
void __iomem *base = S3C2410_GPIO_BASE(pin);
unsigned long offs = S3C2410_GPIO_OFFSET(pin);
unsigned long flags;
unsigned long dat;
local_irq_save(flags);
dat = __raw_readl(base + 0x04);
dat &= ~(1 << offs);
dat |= to << offs;
__raw_writel(dat, base + 0x04);
local_irq_restore(flags);
EXPORT_SYMBOL(s3c2410_gpio_setpin);
(2)unsigned int s3c2410_gpio_getpin(unsigned intpin);
获取相应GPIO口的值。
函数定义:
viewplain
unsigned int s3c2410_gpio_getpin(unsigned int pin)
return __raw_readl(base + 0x04) & (1<< offs);
EXPORT_SYMBOL(s3c2410_gpio_getpin);
(3)void s3c2410_gpio_cfgpin(unsigned int pin, unsigned intfunction);
设置相应GPIO口的工作模式,输入、输出、中断等。
函数定义:
viewplain
void s3c2410_gpio_cfgpin(unsigned int pin, unsigned int function)
unsigned long mask;
unsigned long con;
if (pin < S3C2410_GPIO_BANKB) {
mask = 1 << S3C2410_GPIO_OFFSET(pin);
} else {
mask = 3 << S3C2410_GPIO_OFFSET(pin)*2;
con = __raw_readl(base + 0x00);
con &= ~mask;
con |= function;
__raw_writel(con, base + 0x00);
EXPORT_SYMBOL(s3c2410_gpio_cfgpin);
(4)unsigned int s3c2410_gpio_getcfg(unsigned intpin);
获取相应GPIO口的工作模式,输入、输出、中断等。
函数定义:
viewplain
unsigned int s3c2410_gpio_getcfg(unsigned int pin)
unsigned long mask;
} else {
return __raw_readl(base) & mask;
EXPORT_SYMBOL(s3c2410_gpio_getcfg);
(5)voids3c2410_gpio_pullup(unsigned int pin, unsigned intto);
设置相应的GPIO口的电平,例如:
pin=S3C2410_GPG2,to=0,则拉低S3C2410_GPG2,也就是设置S3C2410_GPG2的值为0;
pin=S3C2410_GPG2,to=1,则拉高S3C2410_GPG2,也就是设置S3C2410_GPG2的值为1。
函数定义:
viewplain
void s3c2410_gpio_pullup(unsigned int pin, unsigned int to)
unsigned long up;
return;
up = __raw_readl(base + 0x08);
up &= ~(1L << offs);
up |= to << offs;
__raw_writel(up, base + 0x08);
EXPORT_SYMBOL(s3c2410_gpio_pullup);
(6)unsigned int s3c2410_modify_misccr(unsigned int clear,unsigned int change);
杂项设置,设置寄存器MISCCR,具体看函数定义。
函数定义:
viewplain
unsigned int s3c2410_modify_misccr(unsigned int clear, unsigned int change)
unsigned long misccr;
misccr = __raw_readl(S3C2410_MISCCR);
misccr &= ~clear;
misccr ^= change;
__raw_writel(misccr, S3C2410_MISCCR);
return misccr;
EXPORT_SYMBOL(s3c2410_modify_misccr);
(7)int s3c2410_gpio_getirq(unsigned intpin);
获取相应的GPIO口所对应的中断号。
函数定义:
viewplain
int s3c2410_gpio_getirq(unsigned int pin)
if (pin < S3C2410_GPF0 || pin > S3C2410_GPG15_EINT23)
return -1;
if (pin < S3C2410_GPG0 && pin > S3C2410_GPF7)
return -1;
if (pin < S3C2410_GPF4)
return (pin - S3C2410_GPF0) + IRQ_EINT0;
if (pin < S3C2410_GPG0)
return (pin - S3C2410_GPF4) + IRQ_EINT4;
return (pin - S3C2410_GPG0) + IRQ_EINT8;
EXPORT_SYMBOL(s3c2410_gpio_getirq);
(8)int s3c2410_gpio_irqfilter(unsigned int pin, unsignedint on, unsigned int config);
中断过滤配置,具体看函数定义。
函数定义:
viewplain
int s3c2410_gpio_irqfilter(unsigned int pin, unsigned int on,
void __iomem *reg = S3C2410_EINFLT0;
unsigned long val;
if (pin < S3C2410_GPG8 || pin > S3C2410_GPG15)
return -1;
config &= 0xff;
pin -= S3C2410_GPG8_EINT16;
reg += pin & ~3;
val = __raw_readl(reg);
val &= ~(0xff << ((pin & 3) * 8));
val |= config << ((pin & 3) * 8);
__raw_writel(val, reg);
val = __raw_readl(S3C2410_EXTINT2);
val &= ~(1 << ((pin * 4) + 3));
val |= on << ((pin * 4) + 3);
__raw_writel(val, S3C2410_EXTINT2);
return 0;
EXPORT_SYMBOL(s3c2410_gpio_irqfilter);
上一篇:让arm开发板的mnt文件夹可以显示linux虚拟机中的成为挂载
下一篇:ARM for ADS1.2
推荐阅读最新更新时间:2024-11-09 13:38
设计资源 培训 开发板 精华推荐
- 868 至 915MHz 无线射频收发器
- RSO-2412D ±12V、42mA输出DC/DC转换器的典型应用电路
- 具有错误标志的 TS39204 2A 超低压差稳压器的典型应用
- TPA6120A2YFMK
- SoCKit 开发套件提供了一个基于 Altera 片上系统 (SoC) FPGA 的强大硬件设计平台
- 使用 Infineon Technologies AG 的 TDA 16846-2G 的参考设计
- KITXMC11BOOT001TOBO1、XMC1100 微控制器评估板 64KB Flash
- LTC2938CDE 缓冲 VREF 为高电流电路供电的典型应用电路
- LT1173CS8 +20V 至 5V 降压转换器的典型应用电路
- 频谱灯+1501176A
