多任务 51单片机纯C语言内核V1.03
发布者:chaxue1987最新更新时间:2020-04-27 来源: eefocus关键字:多任务  51单片机  纯C语言  内核V1 手机看文章 扫描二维码
随时随地手机看文章
#include
#define uchar unsigned char
#define uint unsigned int
#define ulong unsigned long
Task_creat(1),Task_creat(2),Task_creat(3)
[task1][task2][task3][idel]...
Task_destroy(2)
[task1][idel][task3][idel]...
Task_destroy(1)
[idel][idel][task3][idel]...
Task_creat(4)
[task4][idel][task3][idel]...
TaskOrder[i]<->TaskCounter[i]<->TaskCountValue[i]
#define TASKNUM 10 //任务空间
#define TASKREALNUM 9
#define STACKLENGTH 10
uchar TaskCharge = TASKNUM;
uchar TaskNowRuning = 0;
//函数调用原型
uchar TaskOrder [TASKNUM] = {0};  //任务表
uchar TaskCounter [TASKNUM] = {0};
uchar TaskCountValue [TASKNUM] = {0};
uchar TaskPriority [TASKNUM] = {0};
uchar TaskStack [STACKLENGTH] = {0}; //任务栈
uchar TaskStackHead;
uchar TaskStackEnd;
struct flag
 uchar TaskFinish :1;
struct flag SysBit;
//-----------------调试用---------------------
uint Timerlengh;
uint Timerlenghhigh;
uint Timerlenghlow;
ulong SysCounter;
ulong SysCountShow;
uint SysOnems;
void Core_ini (void);
void Idel (void);
void Task_creat (uchar task_id,uchar task_count,uchar task_pri);
void Task_destory (uchar task_id);
void Idle (void)
 TaskLib[0] = &Idle;
 TaskLib[1] = &f1;
 TaskLib[2] = &f2;
 TaskLib[3] = &f3;
 TaskLib[4] = &f4;
 TaskLib[5] = &f5;
 TaskLib[6] = &f6;
 TaskLib[7] = &f7;
 TaskLib[8] = &f8;
 TaskLib[9] = &f9;
 TaskOrder [0] = 0;    //生成系统任务task0
 TaskStackHead = 0;
 TaskStackEnd = 0;
 SysBit.TaskFinish = 0;
 Timerlengh = 0;
 Timerlenghhigh = 0;
 Timerlenghlow = 0xffff;
 SysCounter = 0;
 SysCountShow = 0;
 SysOnems = 0;
 uchar i;
 uchar taskseat;
 i = 1;
 taskseat = 0;
 while (taskseat == 0)
  if (TaskOrder[i] == 0)
   TaskOrder[i] = task_id;   //任务生成
   TaskPriority [i] = task_pri;
   TaskCounter[i] = 0;
   TaskCountValue[i] += task_count;
   taskseat = 1;
  else
   if (i < TASKREALNUM)
    i++;
   else
    taskseat = 1;  //无空位
 uchar i;
 uchar taskaway;
 i = 1;
 taskaway = 0;
 while (taskaway == 0)
  if (TaskOrder[i] == task_id)
   TaskOrder[i] = 0;   //任务删除
   TaskPriority [i] = 0;
   TaskCounter[i] = 0;
   TaskCountValue[i] = 0;
   taskaway = 1;
  else
    i++;
   else
    taskaway = 1;  //无空位
void WatchDog (void)
#define timeH 0xfc
#define timeL 0x17 //1ms减去入栈误差
void timer0_ini (void)
 TMOD = 0x01;
   TH0 = timeH;
   TL0 = timeL;
   TR0 = 1;
   ET0 = 1;
   EA = 1;
void timer0 (void) interrupt 1
 uchar i;
 TR0 = 0;
 TL0 = timeL;
 TH0 = timeH;
 TR0 = 1;
//---------------------watchdog更新--------------------
//---------------------计数维护---------------------------
//-------------------优先级排序(倒排序)-----------------
//------------------------任务出栈------------------------
//-------------------------调试用--------------------------
 Timerlengh = (TH0 * 256 + TL0) - 0xfc17;
 if (Timerlenghhigh < Timerlengh)
  Timerlenghhigh = Timerlengh;
 if (Timerlenghlow > Timerlengh)
  Timerlenghlow = Timerlengh;
void main (void)
 SP = 0x70;
 Core_ini ();
 Task_creat (1,10,1);
 Task_creat (2,10,2);
 Task_creat (3,10,3);
 Task_creat (4,10,4);
 Task_creat (5,10,5);
 Task_creat (6,10,6);
 Task_creat (7,10,7);
 Task_creat (8,10,8);
 Task_creat (9,10,9);
// Task_destory (4);
 timer0_ini ();
 WatchDog ();
 for ( ; ; )
//函数调用原型
  SysBit.TaskFinish = 1;
  while (SysBit.TaskFinish)
//   SysCounter++;
特点:
1.时间片轮转调度
2.多任务
3.优先级并发控制
4.内核消耗小
5.任务任意载入删除
6.实时性强
关键字:多任务  51单片机  纯C语言  内核V1 引用地址:多任务 51单片机纯C语言内核V1.03
上一篇:简单的51单片机多任务操作系统(C51)
下一篇:pc上用C语言模拟51多任务的案例程序
推荐阅读最新更新时间:2024-11-20 17:32
如何快速零基础到入门51单片机(二)
此讲我们主要介绍如何安装Keil5与STC-ISP 一 Keil5软件一共有许多版本,我们现在学的是51单片机所以我们要选择C51这个版本。(建议使用破解版) 华维单片机编程:免费领!单片机入门到高级开挂学习路径(附教程+工具) 37 赞同 · 8 评论 文章 破解版使用方法:先打开Keil_Lic.exe,然后进入Keil软件时不能双击进入,要先点击鼠标右键,选择以管理员的身份进入. 点击File然后选中License Management(许可证管理),把CID中的内容复制下来,填入Keil_Lic.exe中的CID处,点击生成按钮,然后把生成的代码复制,退出Keil_Lic.exe,回到K
[单片机]
如何快速零基础到入门<font color='red'>51单片机</font>(二)
51单片机是什么_51单片机入门自学
  51单片机是什么   51单片机是对所有兼容Intel8031指令系统的单片机的统称。该系列单片机的始祖是Intel的8004单片机,后来随着Flashrom技术的发展,8004单片机取得了长足的进展,成为应用最广泛的8位单片机之一,其代表型号是ATMEL公司的AT89系列,它广泛应用于工业测控系统之中。很多公司都有51系列的兼容机型推出,今后很长的一段时间内将占有大量市场。51单片机是基础入门的一个单片机,还是应用最广泛的一种。需要注意的是51系列的单片机一般不具备自编程能力。   51单片机入门自学   作为一个初学者,如何51单片机入门?   实际上,其实不需要多少东西,会简单的C语言,知道51单片机的基本结构就可以了。
[单片机]
基于51单片机多功能太阳能路灯的设计与实现
    随着社会发展的步伐日益加快,人们对新型能源地开发利用程度不断加大,太阳能作为一种新型能源,越来越受到人们的重视,合理有效的利用好太阳能,已逐步成为节能环保的一种趋势。西藏太阳能资源居中国首位,也是世界上最丰富的地区之一,全年平均日照时数在3 000小时左右。因此为了更环保、更加节能,合理有效地利用太阳能,我们设计出一款多功能太阳能路灯。文中采用C8051F020作为主控芯片,通过51单片机控制片内高速AD对紫外线传感器、温度传感器、光照度传感器等进行采样,对拉萨环境进行监测(特别是紫外线强度的监测),相关数据参数经过LCD显示,用户可通过需要显示广告信息,如进行公益广告,商业广告相关信息的宣传;同时利用具有高效节能的LED
[电源管理]
基于<font color='red'>51单片机</font>多功能太阳能路灯的设计与实现
基于8051单片机的超声波发生器设计方案
本设计的超声波发生器是利用单片机生成初始信号,然后经过一系列处理电路的作用后生成用来杀灭水蚤的超声波,成本低、效果好,可以在农业上加以采用。在此对3个模块进行设计:   (1)信号发生模块。12 MHz的8051单片机硬件连接及其程序设计。   (2)信号处理模块。驱动电路设计(CD4069非门集成芯片);倍频电路设计(S9014或ECGl08三极管、104普通电容、11 257.9 nH自制电感、1 kΩ电阻);整波电路设计(CD4069非门集成芯片);和频电路设计(CD4081与门集成芯片);选频电路设计(S9014或ECGl08三极管、104普通电容、112.58 nH自制电感、1 kΩ电阻)。   (3)信号检
[单片机]
KST51单片机:通过中断实现矩阵按键的次数检测与消抖
以Key4为例,使用定时中断2ms进行消抖,对连续8次(16ms)的按键状态进行判断. 如果全部为1则弹起,将按键当前状态(Keysta)为1; 全部为0则按下,将按键当前状态(Keysta)置0; 其余状态都为抖动,按键当前状态不变。 在主程序里对按键状态进行判断,如果按键当前状态(Keysta)与按键历史状态(backup)不同,则说明按键状态发生变化。程序中是弹起时,按键次数改变,将最新的按键次数送给数码管显示,将按键历史状态更新为当前状态并进行下一次判断。源代码如下: #include reg52.h sbit ADDR0 = P1^0; sbit ADDR1 = P1^1; sbit ADDR2
[单片机]
KST<font color='red'>51单片机</font>:通过中断实现矩阵按键的次数检测与消抖
使用51单片机点亮我们的点阵灯
通过前面我们都知道点亮我们的不管是点阵,数码管,还是LED灯,不仅要熟悉我们的代码还要会看我们的原理图和真值表,所以我们如果真的要写代码倒是其次的,首先我们得学会看我们的原理图和真值表,但是认识那个我们可以在网上找教程的,所以啊我这里就不去重诉别人的话了。那么我们今天要讨论什么问题勒!?我们今天讲一下点阵吧,点阵说实话对于单片机来说虽然并不是最重要的,但是点阵却是我们单片机中花样最多的之一。可能说到这么有人会说了,学了单片机我们有什么用呢,那么我们可以留意一下我们身边的一些物品,比如我们常在街上可以看见一些商店利用那些LED灯做出的花样,什么闪烁啊,各种图形变化啊,其实和我们的点阵原理都很像,不过他们那些控制的位更多,而我们51
[单片机]
51单片机演奏乐曲的程序
sbit SPK = P1^7 ;指定扬声器接口 ORG 0000H LJMP START ORG 000BH LJMP T0_INT ORG 001BH LJMP T1_INT ;------------------------------------------------------------ B_ZQ_TAB: ;定时半周期初始值数据表(数据的意义可见前一篇博文) DW 63625, 63833, 64019, 64104, 64260, 64400, 64524 ;低音区:1 2 3 4 5 6 7 DW 64580,
[单片机]
用优质开关稳压电源供电的STK6303合并式功放
大家知道,音频功率放大器实际上为电源调制器,故电源供给系统的地位的功放中举足轻重,有人甚至说一台好的功放,其电源成本应占一半以上。时下的功放,无论是国外的还是国内的,大都用传统的整流滤波电源,而选用理想的优秀高频高频高速开关电源的厂商还很少,究其原因除成本外,主要认为高频电源尚存在射频干扰、高频泄漏、反应速率稍差以及声染等问题。其实,有新型号为AA-12480的显示器精密开关电源,较好地解决了上述问题,成本也较低,把它们运用于功放,效果出色,现介绍给爱好者们参考。 电路原理如图3-51所示,功放部分采用日本三洋公司制造的STK6303大功率厚膜集成电路,其供电电压最大可达正负50V,输出电流可达10A左右。单片电路的稳压供电正
[电源管理]
用优质开关稳压电源供电的STK63<font color='red'>03</font>合并式功放
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
