前言
本文作为bq24195的I2C使用教程,主要涉及I2C通信代码的实现以及一些注意事项,硬件部分稍有涉及但不是主要内容。
正文
硬件连接图:
I2C的上拉电阻10K或4.7K都行,阻值影响的是跳变沿的时间,即使fast mode I2C通信的频率也才400k左右,所以影响不大。
软件例程
我们用的是G2553的硬件I2C,有中断法和查询法,不想用中断的可以用查询法。如果选择了低功耗,建议用中断法。
MSP430G2553硬件I2C驱动-中断法
IT已经给我们准备好了,直接照搬msp430g2xx3_usci_i2c_standard_master.c例程就行。稍微整理一下做成i2c.h和i2c.c文件,力求简洁美观。
* i2c.h
#ifndef I2C_H_
#define I2C_H_
#include #define SLAVE_ADDR 0x6B //BQ24195 #define MAX_BUFFER_SIZE 20 //****************************************************************************** // General I2C State Machine *************************************************** //****************************************************************************** typedef enum I2C_ModeEnum{ IDLE_MODE, NACK_MODE, TX_REG_ADDRESS_MODE, RX_REG_ADDRESS_MODE, TX_DATA_MODE, RX_DATA_MODE, SWITCH_TO_RX_MODE, SWITHC_TO_TX_MODE, TIMEOUT_MODE } I2C_Mode; void initClockTo16MHz(); void initI2C(); void CopyArray(uint8_t *source, uint8_t *dest, uint8_t count); I2C_Mode I2C_Master_WriteReg(uint8_t dev_addr, uint8_t reg_addr, uint8_t *reg_data, uint8_t count); I2C_Mode I2C_Master_ReadReg(uint8_t dev_addr, uint8_t reg_addr, uint8_t count); #endif /* I2C_H_ */ 下面是i2c.c文件: /* * i2c.c */ #include #include #include #include "i2c.h" I2C_Mode MasterMode = IDLE_MODE; uint8_t TransmitRegAddr = 0; uint8_t ReceiveBuffer[MAX_BUFFER_SIZE] = {0}; uint8_t RXByteCtr = 0; uint8_t ReceiveIndex = 0; uint8_t TransmitBuffer[MAX_BUFFER_SIZE] = {0}; uint8_t TXByteCtr = 0; uint8_t TransmitIndex = 0; I2C_Mode I2C_Master_ReadReg(uint8_t dev_addr, uint8_t reg_addr, uint8_t count) { /* Initialize state machine */ MasterMode = TX_REG_ADDRESS_MODE; TransmitRegAddr = reg_addr; RXByteCtr = count; TXByteCtr = 0; ReceiveIndex = 0; TransmitIndex = 0; /* Initialize slave address and interrupts */ UCB0I2CSA = dev_addr; IFG2 &= ~(UCB0TXIFG + UCB0RXIFG); // Clear any pending interrupts IE2 &= ~UCB0RXIE; // Disable RX interrupt IE2 |= UCB0TXIE; // Enable TX interrupt UCB0CTL1 |= UCTR + UCTXSTT; // I2C TX, start condition __bis_SR_register(CPUOFF + GIE); // Enter LPM0 w/ interrupts return MasterMode; } I2C_Mode I2C_Master_WriteReg(uint8_t dev_addr, uint8_t reg_addr, uint8_t *reg_data, uint8_t count) { /* Initialize state machine */ MasterMode = TX_REG_ADDRESS_MODE; TransmitRegAddr = reg_addr; //Copy register data to TransmitBuffer CopyArray(reg_data, TransmitBuffer, count); TXByteCtr = count; RXByteCtr = 0; ReceiveIndex = 0; TransmitIndex = 0; /* Initialize slave address and interrupts */ UCB0I2CSA = dev_addr; IFG2 &= ~(UCB0TXIFG + UCB0RXIFG); // Clear any pending interrupts IE2 &= ~UCB0RXIE; // Disable RX interrupt IE2 |= UCB0TXIE; // Enable TX interrupt UCB0CTL1 |= UCTR + UCTXSTT; // I2C TX, start condition __bis_SR_register(CPUOFF + GIE); // Enter LPM0 w/ interrupts return MasterMode; } void CopyArray(uint8_t *source, uint8_t *dest, uint8_t count) { uint8_t copyIndex = 0; for (copyIndex = 0; copyIndex < count; copyIndex++) { dest[copyIndex] = source[copyIndex]; } } void initClockTo16MHz() { if (CALBC1_16MHZ==0xFF) // If calibration constant erased { while(1); // do not load, trap CPU!! } DCOCTL = 0; // Select lowest DCOx and MODx settings BCSCTL1 = CALBC1_16MHZ; // Set DCO DCOCTL = CALDCO_16MHZ; } void initI2C() { P1SEL |= BIT6 + BIT7; // Assign I2C pins to USCI_B0 P1SEL2|= BIT6 + BIT7; // Assign I2C pins to USCI_B0 UCB0CTL1 |= UCSWRST; // Enable SW reset UCB0CTL0 = UCMST + UCMODE_3 + UCSYNC; // I2C Master, synchronous mode UCB0CTL1 = UCSSEL_2 + UCSWRST; // Use SMCLK, keep SW reset UCB0BR0 = 160; // fSCL = SMCLK/160 = ~100kHz UCB0BR1 = 0; UCB0I2CSA = SLAVE_ADDR; // Slave Address UCB0CTL1 &= ~UCSWRST; // Clear SW reset, resume operation UCB0I2CIE |= UCNACKIE; } #pragma vector = USCIAB0TX_VECTOR __interrupt void USCIAB0TX_ISR(void) { if (IFG2 & UCB0RXIFG) // Receive Data Interrupt { //Must read from UCB0RXBUF uint8_t rx_val = UCB0RXBUF; if (RXByteCtr) { ReceiveBuffer[ReceiveIndex++] = rx_val; RXByteCtr--; } if (RXByteCtr == 1) //特别注意 { UCB0CTL1 |= UCTXSTP; } else if (RXByteCtr == 0) { IE2 &= ~UCB0RXIE; MasterMode = IDLE_MODE; __bic_SR_register_on_exit(CPUOFF); // Exit LPM0 } } else if (IFG2 & UCB0TXIFG) // Transmit Data Interrupt { switch (MasterMode) { case TX_REG_ADDRESS_MODE: UCB0TXBUF = TransmitRegAddr; if (RXByteCtr) MasterMode = SWITCH_TO_RX_MODE; // Need to start receiving now else MasterMode = TX_DATA_MODE; // Continue to transmision with the data in Transmit Buffer break; case SWITCH_TO_RX_MODE: IE2 |= UCB0RXIE; // Enable RX interrupt IE2 &= ~UCB0TXIE; // Disable TX interrupt UCB0CTL1 &= ~UCTR; // Switch to receiver MasterMode = RX_DATA_MODE; // State state is to receive data UCB0CTL1 |= UCTXSTT; // Send repeated start if (RXByteCtr == 1) { //特别注意 //Must send stop since this is the N-1 byte while((UCB0CTL1 & UCTXSTT)); UCB0CTL1 |= UCTXSTP; // Send stop condition } break; case TX_DATA_MODE: if (TXByteCtr) { UCB0TXBUF = TransmitBuffer[TransmitIndex++]; TXByteCtr--; } else { //Done with transmission UCB0CTL1 |= UCTXSTP; // Send stop condition
设计资源 培训 开发板 精华推荐
- TWR-S08RN60: 8位汽车塔式模块
- LTM4636EY 1V、40A DC/DC 降压型稳压器的典型应用电路
- SLWRB4303A,用于 BGM11S Blue Gecko 蓝牙系统级封装模块的无线入门套件
- #第六届立创电赛#DIY小型桌面功放
- 【低创】【20201120更新】TMC2226
- LTC1878 2.5V/500mA 稳压器
- LTC4050 的典型应用 - 具有热敏电阻接口的锂离子线性电池充电器控制器
- ADR395B 5V 输出微功率、低噪声精密电压基准的典型应用
- LT6656BIDC-2.5、2.5V 2 端子电压基准电流源的典型应用
- MIC4801 的典型应用:具有超快速 PWM 控制的高效 600mA 单通道线性 WLED 驱动器
