这次是做一个SD卡的USB读卡器的功能,我们就在上次NAND Flash模拟出的U盘的工程上修改了,这样的话只要修改一小部分了。
工程的绝大部分不需要修改,只要将fsmc_nand.c文件移除工程,添加上官方的关于SDIO的SD卡的驱动代码文件stm32_eval_sdio_sd.c,我讨厌出现eval,所以将该文件直接改为sdio_sdcard.c。同时,既然我们使用SDIO来驱动SD卡,所以在外设库文件组里要添加stm32_sdio.c文件,否则会出现很多未定错误。
STM32 USB SD读卡器(SDIO)
我们接下去修改的就只有mass_mal.c这个文件了。更NAND Flash工程一样,我们改成简洁点:
uint32_t Mass_Memory_Size[2];
uint32_t Mass_Block_Size[2];
uint32_t Mass_Block_Count[2];
__IO uint32_t Status = 0;
#ifdef USE_STM3210E_EVAL
SD_CardInfo SDCardInfo;
#endif
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
* Function Name : MAL_Init
* Description : 初始化STM32的媒体设备
* Input : lun
* Output : None
* Return : None
uint16_t MAL_Init(uint8_t lun)
uint16_t status = MAL_OK;
switch (lun)
case 0: //SD卡
Status = SD_Init(); //调用SD初始化函数
break;
default:
return MAL_FAIL; //都不是
return status;
uint16_t MAL_Write(uint8_t lun, uint32_t Memory_Offset, uint32_t *Writebuff, uint16_t Transfer_Length)
switch (lun)
case 0:
Status = SD_WriteBlock((uint8_t*)Writebuff, Memory_Offset, Transfer_Length);
SD_WaitWriteOperation(); //等待dma传输结束
while(SD_GetStatus() != SD_TRANSFER_OK); //等待sdio到sd卡传输结束
if ( Status != SD_OK )
return MAL_FAIL;
break;
default:
return MAL_FAIL;
return MAL_OK;
uint16_t MAL_Read(uint8_t lun, uint32_t Memory_Offset, uint32_t *Readbuff, uint16_t Transfer_Length)
switch (lun)
case 0:
Status = SD_ReadBlock((uint8_t*)Readbuff, Memory_Offset, Transfer_Length);
SD_WaitReadOperation(); //循环查询dma传输是否结束
return MAL_FAIL;
break;
default:
return MAL_FAIL;
return MAL_OK;
uint16_t MAL_GetStatus (uint8_t lun)
uint32_t temp_block_mul = 0;
uint32_t DeviceSizeMul = 0;
if (lun == 0)
if (SD_Init() == SD_OK)
SD_GetCardInfo(&SDCardInfo);
SD_SelectDeselect((uint32_t) (SDCardInfo.RCA << 16));
DeviceSizeMul = (SDCardInfo.SD_csd.DeviceSizeMul + 2);
if(SDCardInfo.CardType == SDIO_HIGH_CAPACITY_SD_CARD)
Mass_Block_Count[0] = (SDCardInfo.SD_csd.DeviceSize + 1) * 1024;
else
NumberOfBlocks = ((1 << (SDCardInfo.SD_csd.RdBlockLen)) / 512);
Mass_Block_Count[0] = ((SDCardInfo.SD_csd.DeviceSize + 1) * (1 << DeviceSizeMul) << (NumberOfBlocks/2));
Mass_Block_Size[0] = 512;
Status = SD_SelectDeselect((uint32_t) (SDCardInfo.RCA << 16));
Status = SD_EnableWideBusOperation(SDIO_BusWide_4b);
return MAL_FAIL;
Mass_Memory_Size[0] = Mass_Block_Count[0] * Mass_Block_Size[0];
LED2_ON();
return MAL_OK;
else
LED2_OFF();
return MAL_FAIL;
这样SDIO接口的SD卡读卡器就修改完毕了。我使用8G的SD卡测试的,不知道为什么写这么慢,才60KB/秒左右,读的速度为230KB/秒左右。
STM32 USB SD读卡器(SDIO) - ziye334 - ziye334的博客 STM32 USB SD读卡器(SDIO)
上一篇:STM32 USB SD卡读卡器和NAND FLASH模拟U盘
下一篇:STM32 USB 大容量存储器Mass Storage工程的讲解
推荐阅读最新更新时间:2024-11-07 11:58
设计资源 培训 开发板 精华推荐
- EVALZ-ADN2905、ADN2905 评估板设置和 ADN2905 614 至 10312 MHz 时钟和数据恢复应用
- MPC852TADS-KIT: MPC852T应用开发系统套件
- OP213ESZ 假接地发生器的典型应用
- [夏日必备]手持暴力风扇
- STM32F103C8/C6T6最小系统板
- 具有误差放大器斜率补偿的 LT124XIS8 高速电流模式脉宽调制器的典型应用电路
- DEV-15270,SparkFun gator:log - micro:bit 配件板
- 使用 ON Semiconductor 的 CAT871-20ULGT3 的参考设计
- NUCLEO-L073RZ,STM32 Nucleo 开发板,带有 STM32L073RZT6 MCU,支持 Arduino 和 ST morpho 连接
- 具有 10.5V SEPIC 转换器的 LTC3859AHFE 高效率、1.2V/3.3V 降压转换器的典型应用电路
