底板上有8个独立按键,可分别使用查询法和中断法控制按键。通过原理图可知:按键按下,GPIO检测到低电平,松开时高电平。
直接查询法程序的实现简单,但是效率很低,CPU一直在查询,啥事也干不了。中断查询法程序的实现较为复杂,但是效率高。
GPIO寄存器(GPH0CON,GPH0DAT),外部中断寄存器(EXT_INT_0_CON,EXT_INT_0_MASK),中断通道选择(VIC0INTSELECT),中断使能(VIC0INTENABLE),中断向量地址(VIC0VECTADDR0,VIC0VECTADDR1),清除中断向量(EXT_INT_0_PEND)
.global _start /*声明一个全局的标号 */
.global key_isr
_start:
/* 设置栈,以调用c函数 */
ldr sp, =0x40000000
/* 开总中断 */
mrs r0,cpsr
bic r0,r0, #0x00000080 /* 清楚第7位,IRQ中断禁止位,写0使能IRQ */
msr cpsr,r0
bl main /* 跳转到C函数去执行 */
halt:
b halt
key_isr:
/* 计算返回地址:PC的值等于当前执行的地址+8,
** 当CPU正要执行某条指令时(还未执行),被中断,
** 这是这条刚要执行的指令的地址刚好=PC-4 */
sub lr,lr, #4
stmfd sp!,{r0-r12, lr} /* 保护现场 */
bl key_handle
/* 恢复现场 */
ldmfd sp!,{r0-r12, pc}^ /* ^表示把spsr恢复到cpsr */
#define GPC0CON *((volatileunsigned int *)0xE0200060)
#define GPC0DAT *((volatileunsigned int *)0xE0200064)
#define GPH0CON *((volatileunsigned int *)0xE0200C00)
#define GPH0DAT *((volatileunsigned int *)0xE0200C04)
#define EXT_INT_0_CON *((volatileunsigned int *)0xE0200E00)
#define EXT_INT_0_MASK *((volatileunsigned int *)0xE0200F00)
#define VIC0INTSELECT *((volatileunsigned int *)0xF200000C)
#define VIC0INTENABLE *((volatileunsigned int *)0xF2000010)
#define VIC0VECTADDR0 *((volatileunsigned int *)0xF2000100)
#define VIC0VECTADDR1 *((volatileunsigned int *)0xF2000104)
#define VIC0ADDRESS *((volatile unsigned int*)0xF2000F00)
#define EXT_INT_0_PEND *((volatileunsigned int *)0xE0200F40)
extern void key_isr(void);
void key_handle()
volatileunsigned char key_code = EXT_INT_0_PEND & 0x03;
VIC0ADDRESS= 0; /* 清中断向量寄存器 */
EXT_INT_0_PEND&= ~0x03; /* 清中断挂起寄存器 */
if(key_code == 1) /* key1 */
GPC0DAT&= ~(0x01 << 3); /* toggleLED1 */
GPC0DAT|= 1 << 3; /* toggle LED1 */
else if(key_code == 2) /* key2 */
GPC0DAT&= ~(0x01 << 4); /* toggleLED1 */
GPC0DAT|= 1 << 4; /* toggle LED1 */
int main()
GPC0CON&= ~(0xFF << 12);
GPC0CON |=0x11 << 12; /*配置GPC0_3和GPC0_4为输出:LED1和LED2 */
GPH0CON |=0xFF << 0; /*配置GPH0_0和GPH0_1为外部中断:key1和key2 */
EXT_INT_0_CON&= ~(0xFF << 0);
EXT_INT_0_CON|= 2 | (2 << 4); /*配置EXT_INT[0]和EXT_INT[1]为下降沿触发 */
EXT_INT_0_MASK&= ~3; /* 取消屏蔽外部中断EXT_INT[0]和EXT_INT[1] */
VIC0INTSELECT&= ~3; /*选择外部中断EXT_INT[0]和外部中断EXT_INT[1]为IRQ类型的中断 */
VIC0INTENABLE|= 3; /*使能外部中断EXT_INT[0]和EXT_INT[1] */
/* 当EXT_INT[0]触发中断,即用户按下key1时,
** CPU就会自动的将VIC0VECTADDR0的值赋给VIC0ADDRESS并跳转到这个地址去执 */
VIC0VECTADDR0= (unsigned int)key_isr;
VIC0VECTADDR1= (unsigned int)key_isr;
while (1);
return 0;
裸机编程编译的时候一定要加16字节的头信息,编译生成的bin文件通过SD卡或者TFTP的方法下载到开发板。
上一篇:TQ210——S5PV210串口通信
下一篇:TQ210——S5PV210中断体系
设计资源 培训 开发板 精华推荐
- 用于射频和模拟电路的 NCP161 450 mA、超低噪声和高 PSRR LDO 稳压器的典型应用
- EVAL-ADXL356BZ,用于评估 ADXL356 低噪声、低漂移、低功耗、3 轴 MEMS 加速度计的评估板
- LT1172CT 的典型应用,1.25A 外部电流限制
- 使用 Microchip Technology 的 TC323A 的参考设计
- 使用 Infineon Technologies AG 的 TDA4935 的参考设计
- 使用 ROHM Semiconductor 的 BD5241 的参考设计
- DC996B-H,演示板,具有 LTC2216 16 位 80 Msps、高速和高动态范围 ADC
- LTC3216 的典型应用 - 具有独立手电筒/闪光电流控制的 1A 低噪声大电流 LED 电荷泵
- NCP301LSN42T1 4.2V 窗口电压检测器的典型应用
- 使用 Analog Devices 的 LTC1479IG 的参考设计
