51单片机-温度PID算法(C程序)
发布者:芳华逝水最新更新时间:2022-01-27 来源: eefocus关键字:51单片机  温度PID算法  C程序 手机看文章 扫描二维码
随时随地手机看文章
#include "reg51.h"
#include "intrins.h"
#include "math.h"
#include "string.h"
struct PID
unsigned int SetPoint; // 设定目标 Desired Value
unsigned int Proportion; // 比例常数 Proportional Const
unsigned int Integral; // 积分常数 Integral Const
unsigned int Derivative; // 微分常数 Derivative Const
unsigned int LastError; // Error[-1]
unsigned int PrevError; // Error[-2]
unsigned int SumError; // Sums of Errors
struct PID spid; // PID Control Structure
unsigned int rout; // PID Response (Output)
unsigned int rin; // PID Feedback (Input)
sbit data1=P1^0;
sbit clk=P1^1;
sbit plus=P2^0;
sbit subs=P2^1;
sbit stop=P2^2;
sbit output=P3^4;
sbit DQ=P3^3;
unsigned char flag,flag_1=0;
unsigned char high_time,low_time,count=0;//占空比调节参数
unsigned char set_temper=25;
unsigned char temper;
unsigned char i;
unsigned char j=0;
unsigned int s;
void delay(unsigned char time)
unsigned char m,n;
for(n=0;n
for(m=0;m<2;m++){}
void write_bit(unsigned char bitval)
EA=0;
DQ=0;
if(bitval==1)
_nop_();
DQ=1;
delay(5);
DQ=1;
_nop_();
_nop_();
EA=1;
void write_byte(unsigned char val)
unsigned char i;
unsigned char temp;
EA=0;
TR0=0;
for(i=0;i<8;i++)
temp=val>>i;
temp=temp&1;
write_bit(temp);
delay(7);
// TR0=1;
EA=1;
unsigned char read_bit()
unsigned char i,value_bit;
EA=0;
DQ=0;
_nop_();
_nop_();
DQ=1;
for(i=0;i<2;i++){}
value_bit=DQ;
EA=1;
return(value_bit);
unsigned char read_byte()
unsigned char i,value=0;
EA=0;
for(i=0;i<8;i++)
if(read_bit())
value|=0x01<delay(4);
EA=1;
return(value);
unsigned char reset()
unsigned char presence;
EA=0;
DQ=0;
delay(30);
DQ=1;
delay(3);
presence=DQ;
delay(28);
EA=1;
return(presence);
void get_temper()
unsigned char i,j;
do
i=reset();
} while(i!=0);
i=0xcc;
write_byte(i);
i=0x44;
write_byte(i);
delay(180);
do
i=reset();
} while(i!=0);
i=0xcc;
write_byte(i);
i=0xbe;
write_byte(i);
j=read_byte();
i=read_byte();
i=(i<<4)&0x7f;
s=(unsigned int)(j&0x0f); //得到小数部分
s=(s*100)/16;
j=j>>4;
temper=i|j;
void PIDInit (struct PID *pp)
memset ( pp,0,sizeof(struct PID)); //全部初始化为0
unsigned int PIDCalc( struct PID *pp, unsigned int NextPoint )
unsigned int dError,Error;
Error = pp->SetPoint - NextPoint; // 偏差
pp->SumError += Error; // 积分
dError = pp->LastError - pp->PrevError; // 当前微分
pp->PrevError = pp->LastError;
pp->LastError = Error;
return (pp->Proportion * Error // 比例项
+ pp->Integral * pp->SumError // 积分项
+ pp->Derivative * dError); // 微分项
void compare_temper()
unsigned char i;
if(set_temper>temper) //是否设置的温度大于实际温度
if(set_temper-temper>1) //设置的温度比实际的温度是否是大于1度
high_time=100; //如果是,则全速加热
low_time=0;
else //如果是在1度范围内,则运行PID计算
for(i=0;i<10;i++)
get_temper(); //获取温度
rin = s; // Read Input
rout = PIDCalc ( &spid,rin ); // Perform PID Interation
if (high_time<=100)
high_time=(unsigned char)(rout/800);
else
high_time=100;
low_time= (100-high_time);
else if(set_temper<=temper)
if(temper-set_temper>0)
high_time=0;
low_time=100;
else
for(i=0;i<10;i++)
get_temper();
if (high_time<100)
high_time=(unsigned char)(rout/10000);
else
high_time=0;
// else
void serve_T0() interrupt 1 using 1
if(++count<=(high_time))
output=1;
else if(count<=100)
output=0;
else
count=0;
TH0=0x2f;
TL0=0xe0;
void serve_sio() interrupt 4 using 2
void disp_1(unsigned char disp_num1[6])
unsigned char n,a,m;
for(n=0;n<6;n++)
// k=disp_num1[n];
for(a=0;a<8;a++)
clk=0;
m=(disp_num1[n]&1);
disp_num1[n]=disp_num1[n]>>1;
if(m==1)
data1=1;
else
data1=0;
_nop_();
clk=1;
_nop_();
void display()
unsigned char code number[]={0xfc,0x60,0xda,0xf2,0x66,0xb6,0xbe,0xe0,0xfe,0xf6};
unsigned char disp_num[6];
unsigned int k,k1;
k=high_time;
k=k00;
k1=k/100;
if(k1==0)
disp_num[0]=0;
else
disp_num[0]=0x60;
k=k0;
disp_num[1]=number[k/10];
disp_num[2]=number[k];
k=temper;
k=k0;
disp_num[3]=number[k/10];
disp_num[4]=number[k]+1;
disp_num[5]=number[s/10];
disp_1(disp_num);
void main()
unsigned char z;
unsigned char a,b,flag_2=1,count1=0;
unsigned char phil[]={2,0xce,0x6e,0x60,0x1c,2};
TMOD=0x21;
TH0=0x2f;
TL0=0x40;
SCON=0x50;
PCON=0x00;
TH1=0xfd;
TL1=0xfd;
PS=1;
EA=1;
EX1=0;
ET0=1;
ES=1;
TR0=1;
TR1=1;
high_time=50;
low_time=50;
PIDInit ( &spid ); // Initialize Structure
spid.Proportion = 10; // Set PID Coefficients 比例常数 Proportional Const
spid.Integral = 8; //积分常数 Integral Const
spid.Derivative =6; //微分常数 Derivative Const
spid.SetPoint = 100; // Set PID Setpoint 设定目标 Desired Value
while(1)
if(plus==0)
EA=0;
for(a=0;a<5;a++)
for(b=0;b<102;b++){}
if(plus==0)
set_temper++;
flag=0;
else if(subs==0)
for(a=0;a<5;a++)
for(b=0;a<102;b++){}
if(subs==0)
set_temper--;
flag=0;
else if(stop==0)
for(a=0;a<5;a++)
if(stop==0)
flag=0;
break;
EA=1;
get_temper();
b=temper;
if(flag_2==1)
a=b;
if((abs(a-b))>5)
temper=a;
else
temper=b;
a=temper;
flag_2=0;
if(++count1>30)
display();
count1=0;
compare_temper();
TR0=0;
z=1;
while(1)
EA=0;
if(stop==0)
for(a=0;a<5;a++)
if(stop==0)
disp_1(phil);
// break;
EA=1;
关键字:51单片机  温度PID算法  C程序 引用地址:51单片机-温度PID算法(C程序)
上一篇:51单片机-宏晶STC与硬仿真
下一篇:51单片机-asm与C混合编程
推荐阅读最新更新时间:2024-11-08 10:12
基于51单片机的多点测温系统设计
1.温度传感器DS18B20介绍 DALLAS公司单线数字温度传感器DS18B20是一种新的“一线器件”,它具有体积小、适用电压宽等特点。一线总线独特而且经济的特点,使用户可轻松地组建传感器网络,为测量系统的构建引入全新概念。DS18B20支持“一线总线”接口,测量温度范围为-55℃~+125℃,在-10℃~+85℃范围内,精度为±0.5℃;通过编程可实现9~12位的数字值读数方式;可以分别在93.75ms和750ms内将温度值转化为9位和12位的数字量。每个DS18B20具有唯一的64位长序列号,存放于DS18B20内部ROM只读存储器中。 DS18B20温度传感器的内部存储器包括1个高速暂存RAM和1个非易失性的电可擦
[单片机]
基于<font color='red'>51单片机</font>的多点测温系统设计
8051单片机典型接口电路——串行扩展静态显示电路
8051单片机典型接口电路——串行扩展静态显示电路如下图所示: 例1:按上图编制显示子程序,显示字段码已分别存在32H~30H内RAM中。   程序1:   DIR2: MOV SCON,#00H ;置串口方式0   CLR ES ;串口禁中   SETB P1.0 ;“与”门开,允许TXD发移位脉冲   MOV SBUF,30H ;串行输出个位显示字段码   JNB TI,$ ;等待串行发送完毕   CLR TI ;清串行中断标志   MOV SBUF,31H ;串行输出十位显示字段码   JNB TI,$ ;等待串行发送完毕   CLR TI ;清串行中断标志   MOV SBUF,32H ;串
[模拟电子]
80<font color='red'>51单片机</font>典型接口电路——串行扩展静态显示电路
51单片机教程:单片机数据传递类指令
单片机数据传递类指令 (3)以直接地址为目的操作数的指令 MOV direct,A 例: MOV 20H,A MOV direct,Rn MOV 20H,R1 MOV direct1,direct2 MOV 20H,30H MOV direct,@Ri MOV 20H,@R1 MOV direct,#data MOV 20H,#34H (4)以间接地址为目的操作数的指令 MOV @Ri,A 例:MOV @R0,A MOV @Ri,direct MOV @R1,20H MOV @Ri,#data MOV @R0,#34H (5)十六位数的传递指令 MOV DPTR,#data16 8051是一种8位机,这是
[单片机]
<font color='red'>51单片机</font>教程:单片机数据传递类指令
51单片机控制直流电机正反转程序
本程序能通过按键控制直流电流的的正反转,按键的端口定义直接看程序的定义部分。 /=========自动调压控制程序========================================= #include reg52.h //包含头文件,一般情况不需要改动,头文件包含特殊功能寄存器的定义 sbit KEY1=P3^3;//高端行程开关自定义 sbit KEY2=P3^4;//低端行程开关自定义 sbit LED1=P1^0;//定义电机正转驱动端口 sbit LED2=P1^1;//定义电机反转驱动端口 //*-----------------------------------------
[单片机]
51单片机8*8点阵显示
显示的是0-9数字显示,还有文字显示,请关注微信公众号“伊斯电子编程”免费获取。 仿真图: 代码:
[单片机]
<font color='red'>51单片机</font>8*8点阵显示
基于51单片机的遥控智能小车实作心得
两年前学习51单片机时,买了51hei单片机开发板。现在正在学习基于STM32嵌入式系统的FAT32,UGUI和UCOSII操作系统。几乎很少去看51单片机开发板了。某天,宝贝突然说要我给她买一个遥控小车,说别人都有。俺查了一下网上性能好点的小车价格不菲,我突然想起自己不是还有一块闲置的51hei单片机开发板吗?何不自己动手给宝宝做一个智能小车呢?闲话少说,付诸行动吧。 经过近一个星期的行动,小车终于完成了,虽然说样子是丑了一点,但是性能不弱。主要功能:1,红外遥控器遥控,小车同步前进,小车同步后退,左转弯,右转弯,左倒车,右倒车;2,行进中自动壁障。其实功能可以随便加,只要舍得花银子。 程序是在 51hei单片机
[单片机]
基于LCD12864和51单片机的简单小游戏Proteus仿真程序
以lcd12864作为显示屏,实现一个按钮控制的简单小游戏。主要工作集中于游戏的图形化以及相关逻辑的实现。人物场景设计通过字模提取软件转换成为段码预先储存在单片机中,动画的实现采取局部刷新的方式以提高显示的速度。 仿真原理图如下 单片机源程序如下: #include reg51.h #define LCDLCDDisp_Off 0x3e #define LCDLCDDisp_On 0x3f #define Page_Add 0xb8//ye #define LCDCol_Add 0x40//lie #define Start_Line 0xC0//hang /*****液晶显示器的端口定义*****
[单片机]
基于LCD12864和<font color='red'>51单片机</font>的简单小游戏Proteus仿真程序
AT89C51单片机流水灯c语言程序及详解(扫盲教程)
AT89C51单片机是我们学习单片机必学的一个单片机,也是单片机入门的教材,下面给大家展示一下流水灯的编写方法适合初学者 首先先在proteus画出仿真图,方便仿真程序 下面来编写程序,先来写入头函数 #include “REG51.h” AT89C51单片机流水灯c语言程序及详解 根据自己在proteus画的图,定义一下管脚根据你的原理图进行编写 sbit p0=P1^0; sbit p1=P1^1; sbit p2=P1^2; sbit p3=P1^3; sbit p4=P1^4; sbit p5=P1^5; sbit p6=P1^6; sbit p7=P1^7; 然后写一个延时
[单片机]
AT89C<font color='red'>51单片机</font>流水灯c语言程序及详解(扫盲教程)
推荐帖子
【Iprober 520电流探头】PCB模式下的校准与使用
PCB模式下的校准与使用在使用PCB模式前需要根据PCB走线的尺寸来进行校准: 先确认要进行测量的PCB走线的规格,可以看PCB文件或者使用游标卡尺直接测量。 将探头与示波器正确连接好,然后开始校准。 将探头插入控制板的校准孔中,将MODE(使用模式)拨到PCBTrack模式下,CALIBRATOR(校准模式)拨到AC档,使用交流方波进行校准。 使探头的(+)或者(-)标记对准校准孔下方的黑
gyp1 测试/测量
固定电话里如何区别话音电流和控制信号电流呢?
请问固定电话里如何区别话音电流和控制信号电流呢?要在嵌入式平台实现拨号功能,需要些什么呢?谢谢固定电话里如何区别话音电流和控制信号电流呢?哦,没有人顶吗???没有具体做过,友情帮顶下,MARK.
chenzhongzi 嵌入式系统
关于ccs6.0仿真器
我在官网上下载的ccs6.0软件,仿真器连接好从贵公司购买的TMS570LS3137开发板,在软件上进行仿真器连接测试时,出现下面的提示文,这是为什么呢?仿真器我选择的是TIXDS100V2USBEmulator。Executethecommand:%ccs_base%/common/usciffile:///C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\~(H)S`RV8.gifgjtag-f%boarddatafile%-rv-o-
yuyin 微控制器 MCU
西安市第二届智障人士艺术展
这是2008年度首次智障人士大规模参与的社会宣传、倡导活动,展示智障人士风采的艺术作品展览会,也是继2007年首届智障人士艺术展后,再次推出的系列大型特色活动,本次展会将面向全市市民免费开放,展会将以智障人士才艺表演,艺术展以及艺术品义卖等几个环节进行,义卖收入将返还智障人士,作为智障人士参与社会实现自我价值的表现。活动时间:2008年3月28-30日活动地点:西安市雁引路亮宝楼西安市第二届智障人士艺术展支持一下支持一下 顶upupup
llgg9527 嵌入式系统
因特网冲击加快下一代网络进
蒋林涛  下一代网指的是下一代业务网、承载网和传送网的集合,下一代网包含下一代电信网和下一代因特网。下一代电信网和下一代因特网在技术上是共源的,它们都建立在IP技术的基础上,因此它们发展的最终趋势是成为一个网,即下一代网,并成为国家和社会信息基础设施的重要组成部分。  因特网的发展为社会信息化作出巨大贡献,因特网惊人的发展速度,仅用了十多年的时间就建立了可以和电信网抗衡的全球性大网;因特网技术及其业务进入电信领域,强烈冲击电信的垄断地位,使亿万用户获益;因特网是思维创新、技术创
bob RF/无线
基于HAL库F4系列移植GD的USB协议栈(Device/CDC_ACM)
HAL库开发的现在用的是GD32的程序发现USB配置是个大坑,有没有哪位有移植的经验可以交流一下。基于HAL库F4系列移植GD的USB协议栈(Device/CDC_ACM)GD和HAL根本无法兼容,这是常识ST的HAL能和GD兼容,HAL库不是白开发了吗? gd主打的不是兼容性吗?我没用过gd,听他说的,所以有此一问。
Gavin666 GD32 MCU
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
